- 19 Sep 2011
Google says yes, but wanted some real experience/thoughts.
It will only be to test a system, as we are being given one for my sister. I have no idea what is in the box (it is coming from an office, so I doubt it will be super powerful or have any sort of GPU). Will only be used for word processing/surfing the net.
But it wont have the hard drive (the owner would rather destroy that, as it has a lot of personal information on). So, to test the system, I need to put a Hard Drive in. Before I go and buy a new one, I want to see if it is worth it first (and test all the parts see what they are like.
Can I just connect a laptop hard drive to the mobo with ease? And if it works, then I can buy a hard drive? I wouldn't mount the laptop drive in the case, it would be just to test.
However, google also says you can use them. I have a few laptop hard drives knocking around plenty of storeage on them (talking 500GB+). Probably not the quickest, but just for a basic use, will they do a job?
Thanks.
Thanks.
