=((((( @computer heeeeeeeeeeeeelp
10 Aug 2011
Basicully i buit a new computer about 2 weeks ago, been running as swweeeeeet as possible no problems with games or anything.
Now yesterday i got home thought yeah i'll play some SC2 to chill a bit :D but i got no signal to my display...
The computer boots fine, i can here my start up programs make noises through my head set (skype) but i can't get a signal to my monitor.
It's a ASUS GTX 560 ti
Intel I5 2500k
8gb ram
Gigabyte z68 mother board
OCZ 550w '80plus bronze' psu
And 4 fans running so i doubt it's an overheating problem?
Should i get it replaced with warrenty?
I bought it all on OC btw =)
Any help to fix this will be rewarded with my love =);)
I have checked the connections nuthing i can see broken, i will pick up a new one today (need one anyway) so will hope that works, I will also try reseating it later today. =(.
Unless you have one of the crappy Gigabyte boards with no video outputs then you can use the onboard GPU to test if it's the monitor at fault.
Just connected my laptop to my monitor, the monitor works with the same cable, the only thing it could be then is the GPU or the VGA ---> DVI adaptor :(
Tried using the other connections on your gpu? My 480 gtx sli sometimes gives me a blank screen by choosing a different master dvi output to that which is connected to the screen. Sometimes even that doesn't work and I have to restart the pc several times.
