First off here are my spec:
Phenom II x4 @3.7ghz
DDR3 8gb @1600mhz
Crossfire 2X 5850
650W Coolmaster PSU
Asus M5A97 PRO
Win7 6bit
So basically my fps with crossfire is terrible in games. At first i accepted crysis at 6048x1080 is at 20fps because its crysis. But other games like Bad company 2 i couldn't get over 30fps. I put the settings to low and it did nothing to increase performance.
I tried TF2 and its pretty much the same thing. 10-15fps? Well this raised suspicion. I disabled CrossfireX in CCC and got these results.
Same settings:
BC2 -
Crossfire below 30fps
Single 5850 60fps
TF2 -
Crossfire below 10-15fps
Single 5850 130fps
Rage -
The same fps
Crysis warhead -
The same fps
Crysis -
Around the same.
So im basically having a dramatic loss in performance in some games. While in other i get no loss but no increase either.
Looking at CCC and GPU-Z it all seems fine. My speed's and temps go up on both card's. And it all says CorssfireX enabled.
Help
DDR3 8gb @1600mhz
Crossfire 2X 5850
650W Coolmaster PSU
Asus M5A97 PRO
Win7 6bit
Same settings:
BC2 -
Single 5850 60fps
TF2 -
Single 5850 130fps
Rage -
The same fps
Crysis warhead -
The same fps
Crysis -
Around the same.
Help
. It uses the 970 chipset, which is not a high end one. This chipset is designed mostly for single GPU setups. If you want true crossfire you need to buy a 990X or 990FX, these chipsets are the ones designed for crossfire.
