Didn't get to play the beta, but from that video, is there any additional sound processing going on or is that just the default sound?
It sounds breathtaking.![]()
Default audio, it has options for wartapes like bc2 which enhances it some.
The only time I struggle with M+K is in the jets when turning hard, there is a split second where you have to lift the mouse and move it before carrying on the turn, can be annoying. Otherwise I'm happy, wouldn't use anything else.
How do we feel about unspressed weapons making you visible on radar if you don't use supressor?
http://forums.electronicarts.co.uk/...-weapon-makes-u-show-minimap-dice-lalala.html
It seems like it only works close range-ish tbh, so I'm on the fence.
He has revealed his EA I.D?
I found the keyboard and mouse fine. If by fine you mean taking off, inverting and then exploding in a ball of flame once rapidly reacquainted with the ground... I tended to stay with the infantry a lot after that...
Minimap. FIXED! The minimap has been vastly improved and is almost on par with the map found in BF2.
Im so happy !!!! This really annoyed me so much in the beta !!!! Glad to see all the feedback / moaning by the community is being taken on board by Dice and there pulling there finger out !!!!![]()
Turns out that shooting without a suppressor doesn't show you up on the map after all.
