If I get the game via origin, will it preload the installation files, so that I can play immediately on the launch date?
Yes. pre load begins a week before release. Think you can start now actually ?
1:45 for some Battlefield 3 business. No proper gameplay as such but you can see what they've got inside the PC's graphics card wise.
Well my
Q6600 @ 3.4
4gb Ram
Msi 5850
Ran pretty well. Managed to run few on high settings. infact i took a screenie on Steam so let me upload it quickly.
http://img802.imageshack.us/img802/4618/2011092800010.jpg[IMG][/URL][/QUOTE]
'Managed to run few on high settings' - so you post a screenie with most things set to ultra? :confused: What frame rates did you get with that? I'm debating picking up another Q6600 and a better GPU instead of shelling out for SB.
'Managed to run few on high settings' - so you post a screenie with most things set to ultra?What frame rates did you get with that? I'm debating picking up another Q6600 and a better GPU instead of shelling out for SB.
bf3 is gpu boundFor retail supposedly there's a separate disc on both the PC and PS3 versions with the Ultra textures etc.
lol unlikly.![]()
Well my
Q6600 @ 3.4
4gb Ram
Msi 5850
Uploaded with ImageShack.us
why not ?
They are textures, they just get copied and pasted on screen. Theres no significant graphics processing hit from showing high resolution textures.
Think on, there are none of the DX11 effects that are present in the PC High / Ultra settings, none of lighting effects, and its playing at a very low resolution compared with most 20+ inch PC monitors
Its dead easy to display ultra textures at 1280 x 720 with none of the effects of high / ultra.
Can I still cancel order from origin?
But doesnt the PS3 only have 256mb GPU? I know they can optomise the game hugely on the consoles when compared with a PC but it could be a HELL of a lot of textures to fit in 256mb!
snip.
Is your i7 at stock mate?
