Snip
Snap! Can't wait to get home and give it a listen!
Snip
try all of the tips provided, when you get the right ones the bass should just hit you in the face and thats how you know most of the time, if non of them work then i would think about getting some comply foam tips. the sound quality on any earphone can sound terrible if you dont have a good seal.
Do I spy with my little eye Peanut Butter MnM's? Those things are awesome!!
^I dont know what that is but i want it.
lightest or brightest?
