1055T 95W retail?
can always DSR if they try and pull a fast one and send 125w :)
Takes time though usually a couple of weeks.
Don't see why OCUK would mislead people...
No gain from miss-selling ;)
Well I think the place I ordered from before (not ocuk) were just trying to clear 125w stock and gambling on the fact that most people either wouldn't notice or not care enough to go through the lengthy return process.
Has nobody bought one of these yet? they used to be the dogs balls (even compared to 1090T) if you had a decent motherboard that could do 300bclk.
Received one yesterday to keep me busy, not as good as the OEM one I had a while back which had a 1.275v VID iirc but not bad either compared to 1090T/1100T.
VID: 1.325v / NB: 1.15v
Does 4-4.1ghz watercooled easily on a Sabertooth 990FX with 1.5v but not been able to get IBT stable yet at 4.2ghz, even so can't argue with 4ghz hex for £115. :p really need to make sure you have a good FSB overclocking board though what with the max multiplier at 14.
What would be the best board to use with these chips for £120 or less
I'd recommend a second hand Crosshair IV if you can get hold of one, not had much luck myself with 300BCLK on Gigabyte boards so you might be best off stumping up an extra £20 for an unlocked 1090/1100 if your motherboard isn't a Crosshair/Sabertooth.
My Asus M4A89GTD Pro does 300MHz no probs. Have my 95 1055T at 3.5GHz (250*14) 24/7 @ 1.2v too, though I think I've been blessed with a peach of a chip/board.
Asus AMD boards a much better than Gigabyte from what I've seen, Gigabyte 990FX series seem to have massive voltage variations and back when I had 890FXA-UD5 it couldn't handle BCLK over 275 without giving memory warnings on post, Crosshair IV at the time was again solid though.
I'm after a 95w 1055T to put under phase cooling, My 1075T is 125w and the extra 30w is killing it I think.
Can't even put it up for sale in here as there's no longer a for sale section :(
BTW is there any way to monitor CPU-NB voltage in Windows? I tried installing the Asus software but it won't install for some reason, just want to see if it's worth me enabling LLC for the NB or not.
I used to have access but not posted for a while..
If you've only just activated your trust it can take up to 24 hours to get access to the Members Market.
If you activated your trust a while go, but no longer have access to the Members Market, then you'll need to contact one of the site Moderators.
