Im in a pickle... help me before insania sets in..
3 Jun 2007
Essex
Hi All.
I recently upgraded my PC and at the time had some money burning a whole in my pocket and invested i a second Phantom GTX570...
so now I have a lovley SLI set-up that flies but one thing I could not carry over to the new case is my Asus Xonar sound card due to the SLI taking up most all the slot space.
Yesterday I picked up my first set of gaming headphones and bascially the combination of these and my onboard sound feels a bit well ****
So my predicament is.... do it Stick with SLI and put up with the poo onboard sound or do I look for an altermative to the SLI 570 set-up and buy a single graphics card equivelant and put my dedicated sound card back in..
Answers on a postcard..
Hi All.
What's your motherboard? Can you give us pictures of where this slot is for your soundcard?
My motheboard is the Asrock Extreme4 Gen 3
http://www.overclockers.co.uk/showproduct.php?prodid=MB-054-AK
and the headphones are these
http://www.overclockers.co.uk/showproduct.php?prodid=SP-004-CS
The soundcard is an asus xonar PCI sound card but all the PCI slots are hidden behind the second graphics card when using SLI
http://www.overclockers.co.uk/showproduct.php?prodid=SC-000-AS
infact i just had a thought.... I could sell the sound card and get the PCI-E version as the PCI-e x1 slot is above the top graphics card i beleive....
to be fair anything has to be better than the onboard... even the difference between my old headphones on the asus card and the onboard i currently have is massive.
If you check the thread in the motherboard section I had a similar problem to you. But it turns out there is a slot free right at the top for the ASUS soundcards :D. So I would go with the PCI-E option you suggested.
edit: You can even buy the cheaper pic-e card: The Xonar DX (think it's around £50)
to be honest when i was fiddling around last night trying to see if it would fit i thought I had the PCI-E version so had given up but was only when i checked the website for the link i noticed it was PCI i had..
Probably would have saved me some time looking through the thread...
