Hello everybody,
I’m having some temperature issues with my Gainward GTX580 ‘Good Edition’ graphics card and thought I would try to seek advice from the forums.
When my card is idle it runs at a constant 43˚C which I have read is about normal for this card. When it is under load it can run anywhere from 85˚C to 100˚C, this is the part that concerns me.
I believe the average temperature people have been getting from this card while under load is around 85˚C. If I play Company of Heroes for an hour for example, the temperature quickly gets up to 85˚C and stays there. If I play Crysis or Arma 2 on the other hand, the GPU temp rockets to 96˚C within 10 minutes, and in Arma 2’s case, slowly continues to rise.
The card plays games on the highest settings at 1080p beautifully with no lag or frame rate drops, and has never actually crashed or shut down due to the heat. Although, I do keep my eye on Afterburner and quit to desktop at around 98˚C just in case.
Has anybody experienced anything similar? Or am I just being paranoid?
Here are my system specs:
- Case: Xigmatek Asgard Gaming Case
- Power Supply: Corsair 650w PSU
- CPU: Intel Core i7 950 3.20GHz Overclocked to 4.00GHz
- Motherboard: Asus P6X58D-E DDR3 Motherboard
- Cooler: Corsair H70 CPU Cooler
- RAM: 6GB DDR3 1600MHz Tri-Channel
- Hard Drive: 1TB HDD
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
If you need any more information just ask, although I am at work for the time being and won’t be able to post any photos or screenshots until I get home tonight. Oh, and few more things, there is an Apache case fan blowing straight onto the card and I haven’t overclocked it.
Any response appreciated as I really want this sorted before BF3. Cheers.
