Sky got activated yesterday but I've already ran into some problems.
Here are the stats from a few years a go when we were on Tiscali ADSL Max (8Mbps)
And these are from yesterday when the Sky got activated. It's pretty much the same today as well.
Here is my laptop plugged straight into the router, which is connected straight into the test socket along with phone & HD box.
Stats
This is with just the router plugged in.
Not much difference at all in the stats.
Stats
Now I've tried with the new filters that came with the Sky router and the old one that those Tiscali results where done on and they're pretty much the same.
I know it's still within the testing period and DLM probably hasn't started yet, but surely my line attenuation can not go that high if it was once that low on the Tiscali connection. We're pretty close to the exchange ~200m as the crow flies (I know the actual wire length will be longer).
This just confuses me! Something is surely wrong with the line along the way? We've been having problems with the phone line since it became active and there is a bit of noise when you're ringing some one.
Upstream Noise Margin
noise margin upstream: 19 db
output power downstream: 12 db
attenuation upstream: 13 db
Downstream Noise Margin
noise margin downstream: 6 db
output power upstream: 20 db
attenuation downstream: 23 db
Stats
Stats
