- 18 May 2010
What brand and model would be a considered as a good budget performance tyre if they exist at all?
Thanks
Thanks
I've tried Falken and had problems with slow punctures causing a blow out but that could have been caused by other factors but I'm still wary
Slow punctures do not cause blow outs. Continuing to drive on partially inflated tyres does, and that will happen with any brand.
I had a pretty nasty accident because of this blow out, I know how it was caused thanks, the tyre was inflated that day I remember it perfectly![]()
[TW]Fox;20349160 said:I didnt realise having an accident automatically made you an expert on tyre dynamics. Why were you driving on a punctured tyre anyway, seems a bit daft?
I never claimed I was expert in anything so why you are saying that I mentioned I was an expert is ridiculous?
[TW]Fox;20349255 said:You are claiming you know exactly what caused a blowout. How can you know exactly what caused a tyre to blow out?
I dont, I'm stating what happened, what else caused it? A tactical nuclear missile?
[TW]Fox;20349320 said:A manufacturing fault in the tyre? A foreign object on the road? Other un-noticed damaged to the tyre?
Who knows what caused it? You don't. Neither do I. You can make a guess but you'll never know the exact cause.
Fulda Sport Control
