- 18 May 2010
- London
Article here.
Very interesting, thanks for the link!
I wonder if the next Xbox will use this version. If so, it would be great if MS enabled 720 games to run on Windows 8 PCs using 11.1 cards, which would make sense with technologies like tessellation that can scale incredibly well.
Fairly sure the consoles use their own propriety APIs.
The Xbox 360 uses a modified version of DX9/10.
Fits the definition of propriety API perfectly![]()
Yay another API that'll get put aside for DX9![]()
An example:
Propriety = OpenCL
Non-propriety = PhysX
To be honest I don't think you understand what propriety means if you meant your comment to be a counter argument to mine.
An example:
Propriety = OpenCL
Assuming you actually meant proprietary since propriety means moral correctness I think you might want to rethink your statementOpenCL is very very much non-proprietary and PhysX is vice versa
http://en.wikipedia.org/wiki/Proprietary_software
Iv always thought of propriety software to mean, closed source.
Owned by only one company or group of individuals.
I thought I was correct, and I am. I meant propriety. You're linking to proprietary, different word mate. Confusing nonetheless, but try not to use the wink of arrogance next time, it's patronising.
Well considering the first time it was mentioned in this thread it was a mispelling of proprietary in the context it was used. 99% of the time propriety is used in reference to software it is a mispelling of proprietary and proprietary software is a common phrase where as propriety software is not recognised anywhere except as a spelling mistake or an odd use of archaic english.
Even taking propriety in the context you wish to use it, the example you gave is still wrong since OpenCL and PhysX apis both conform to their own defined standards. Generally however the word propriety is normally used in reference to manners and etiquette
And as to the wink it was meant as a friendly gesture since the mispelling of proprietary is an all to common mistake but quite a fundamental one. If you want patronising I can do that I'm very good at it because of the idiots I have to spend my working day around but to be patronising would not be a propriety course to take in this situation![]()
