Never heard of collermaster? They sound like a shirt compnay. Are you sure that your PSU is reliable?
i have 1 6970 atm and am going to add a second what i need to know is if my psu can deal with it atm i have a coolermaster gx750 will this do
You'll have enough wattage but you're going to need to use molex to PCI-E power adapters.
2 HD 6970's will need 2x8 pin and 2x6 pin power cables and I believe your PSU only has 2x8pin.
You'll have to make up 2x6 pin using adapters.
no it has 4 x 6pin with that 2 pin adaptor on all of them so 4 x 6 or 8 pin
Yes Matthew31 is correct. The psu has enough connectors. Source can be found here
