My Sensation thinks I am in Japan
I had this with a HTC desire HD, Sorry i cant help but may be a HTC thing.
Try downloading Fastfix from the Market and set your location server as Europe or UK
There's an option under "Location And Security" in options called "Use Wireless Networks" - disabling this should fix it.
[TW]Fox;20364796 said:
Why would it fix it, I wasn't connected to wireless.
I bet you were connected to a mobile network though;) Doesn't explain why it said you were in Japan though :/
It turns the wifi chip on, notes down the SSIDs/MACs and uses Skyhook/Google's big ol' list of MACs that it stole while doing google street view and cross references it to get an approximate position then turns it off again.
I'm confused, how does setting a NTP time server affect the GPS. That's messed up somewhere.
GPS satellites basically send out an encoded time signal, your phone receives these and notices the difference between the arrival times from each satellite and from this it can triangulate it's position. NTP servers are needed to seed this calculation.
