Hi guys,
Couple of questions regarding my move from a 1090T+AMD CHIV to my new Intel i7 2600k + ASRock Extreme4 Gen3 motherboard.
firstly about the Supreme HF i am currently using - Do I need any other brackets? I'm currently using a Nickel plated AM3 fitting, I'm assuming it comes with something that will let me simply connect it to the Intel Socket?
i noticed there is a 1155 backplate bracket available for the Supreme HF- do I need that?
second - Memory - I currently have Mushkin 1866 9-10-9-24/1T 2x4Gb @ 1.65v. Will this run ok in my mainboard bearing in mind its 1.65v?
thanks in advance. need to order tonight if someone could respond quickly!
Your RAM will run fine OP.
