Ever checked your MOT History?
Never thought about this when buying so just checked mine. In the last 5 years it hasn't had a single advisory. One fail, due to a bust numberplate bulb and headlights aimed too high, and that's it.
Not bad for a 10 year old Ford!
my last one its getting scrapped when the MOT runs out
Change of details
Make/Model:
NISSAN / MICRA recorded at time of test on 03/12/2009
Date of test:
30/11/2010
Certificate issue refused (Fail)
Odometer reading:
94,713 Miles
Test number:
Test station name:
Test station number:
Test station telephone number:
Test class:
IV
Reason(s) for refusal to issue Certificate
Nearside Front Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Rear Registration plate lamp bulb not working (1.1.C.1c)
Nearside Front Headlamp aim too low (1.8)
Nearside Front Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Nearside Front Tyre has a tear, caused by separation or partial failure of its structure (4.1.D.1b) **DANGEROUS**
Nearside outer sill Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.3)
Offside outer sill Body or chassis has excessive corrosion, seriously affecting its strength within 30cm of the body mountings (6.1.3)
Nearside Front Front constant velocity joint gaiter insecurely mounted to its housing (2.5.C.1a)
Front brakes imbalanced (3.7.A.2d) **DANGEROUS**
Advisory Notice issued
Nearside Rear Vehicle structure has slight corrosion (6.1.1)
Offside Rear Vehicle structure has slight corrosion (6.1.1)
Nearside Rear floor Body has slight corrosion (6.1.3)
Offside Rear floor Body has slight corrosion (6.1.3)
Nearside Rear Brake pipe slightly corroded (3.6.B.2c)
Offside Rear Brake pipe slightly corroded (3.6.B.2c)
Nearside front to rear Brake pipe slightly corroded (3.6.B.2c)
Offside front to rear Brake pipe slightly corroded (3.6.B.2c)
Child seat fitted not allowing full inspection of adult belt
cost £150 to have the work done mates rates
the year before NO ADVISORY dodgy test centers maybe
year before that NO ADVISORY same test center btw
year before that
Drivers door hinge worn (still is)
Front brake pads getting low
O/s/r outer sill & front crossmember starting to corrode (still is)
Exhaust front heat shield insecure (was untill i ripped it off last year)
This was a potentially terrifying moment when I checked up my Audi TT. It was suspiciously missing its last two MOT certificates, which I only noticed after getting it home. :o
Turns out it's been a very boring car, no advisories just the odd light out of position causing a fail. Still, I'm the owner now, things will get more interesting. ;)
Mot'd for the first time in June 2010 after being imported in 1998 and put in storage, failed for having no rear fog as it was imported pre SVA, retested the next week and passed, then retested again this year, nothing I wasn't expecting /phew :P
[TW]Fox;20372651 said:
I think the only thing that seems a bit off is that you thought it acceptable to drive around in a car in that state! I mean what on earth was going on with that tyre?!
the tyre was just a little bit of dry rot. It was the spare had a flat a few days before the mot, no excuses it was pap
urm the breaks certainly didn't feel bad tbh. Anyway they were taken off cleaned up and passed
new wipers and a bit of welding later and yet another year or bargain motoring nearly done! el-heapo crap box has served its purpose
If I saw an advisory list that long first thing I would be thinking is either eBay spares/repairs or scrap yard!
well no.. but surely they would have put some advisory as the same things were picked up on before. then after the two years of no advisory.
just seems a-bit off no?
there's no requirement at all to put any advisories. It's all down to what the tester can be bothered to put down.
For me there's 2 real reasons to put any advisories in,
1. There is something that will soon require replacing/repairing.
2. The tester/garage is trying to make as much money as possible and hope that if they put loads of advisories you'll get at least some of them done.
I've seen a few scary advisories from main dealers, and on things that didn't even come close to needing replacing.
