Aha, now that's using your head!Useless people! I'd have one door on the floor and the exit above it, also portal style. Drop a very heavy object in to it and use the perminant velocity caused by mavity to power the country on a turbine or something!
Sorry matey, I've pilfered all the spare doors from the factory. If you want a second, you need to come through me![]()
you do read the bit about both doors needing to be open right?
Fort knox bank vault door will do me, few trips with a trolley & it's gravy from then on.
It can link up to any other door on the planet and will stay connected as long as both ends are open, if you close the door from the other side you're stuck and have to make the journey home on your own.
I'd have the door open to my dads house in New Zealand so I can have a holiday and see family with no plane issues. Mind would explode over the time difference though and door lag would be immense
Overclocking the door would fix the lag problem.
The moon
i'd have the door lead into my imagination![]()
id have it lead to itself
Did someone just watch The Lost Room?![]()
Has to be a real door and on earth.
Im pretty sure it would act like a mirror if you did this so you would just bump into yourself if you tried to enter?
Nope, is that a good film?![]()
. Well worth the watch if you can find it.nah they have scary people that would terrify youOcUK store room.
I could also kill 5UB and make it look like an accident.![]()
The inside of a black-hole. It would be the ultimate planet-destroying weapon.
I'd use it to blackmail the president to the tune of $1 million.
