** THE MOST EPIC MONITOR DEAL EVER - HAZRO HZ27WC ONLY £349.99 INC. VAT! **
haha very tempted to replcae my u2410 with this! dunno if it would pair well with my u2711 tho, have dismissed these in the past
Just wondering if you guys can answer some questions.
So im taking this is dvi only, if i use a hdmi to dvi adapter, will it still work?
I'm looking to use my ps3, xbox and macbook pro on it, all have hdmi.
Also what does this mean?
"The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality"
Does that mean i can't down the res to 1080p for ps3 and xbox? Noob question i know.
Thanks
Thanks
there is very little space between the DVI connector at the back of the monitor and the lip at the bottom. I can tell you now that if you are using a HDMI converter on the DVI connecting to the monitor. (so with the intention of using a hdmi cable) you are going to struggle to get it to fit right..
