Cooler Dont Fit.
Did it have a standard intel cooler or a proprietary HP one on to start with? If the latter the holes may not be the standard size or spacing and you could be stuffed.
Being a OEM board it may be slightly different to normal boards. Is there any way of opening the holes.
Looks like there is a bracket under the board, you would need to remove the motherboard and check.
How to did the old heatsink attach to the board.
this. looks like you forgot to remove the old bracket first, you can see the silver poking out
