Hey guys, just wanted to put some info here.
The Corsair XMS3 is NOT, I say again, NOT a good choice for your build.
I built my new build a week ago friday and Im currently in the process of returning the Corsair XMS3 in favour of the G.skills.
I have had nothing but blue screens since I first turned on the machine, after a week of trying everything (ram tests, gpu tests, updating drivers etc etc) I had narrowed it down to the RAM. I ran somemore RAM tests and everything came back clear.
So I did some looking into it and it turns out its the RAM volrage, not the RAM itself. I phoned overclockers support line today and even they recommended RAM running at 1.5v instead of 1.65v.
If you take a look at the G.skills its even got Sandybridge compatible in the info underneath.
I have the same Cpu and Mobo that you are going to be using, and the RAM has caused me a week of headaches. DO NOT buy this ram for your 2600k build, go with the G.kills X RipjawX seies instead as its 1.5v.
Your experience is at odds with many, many other users who are using Corsair XMS3 with Sandy Bridge and without any problems.
I'm quite happily using 16GB of XMS3 @ 1.5V with an i7-2600K.
Just because you've had problems, for whatever reason, that doesn't make XMS3 unsuitable for Sandy Bridge and your sweeping statements are not approriate.
In fact running XMS3 @ 1.5V can get rid of any problems caused by trying to run it at 1.65V.
See this thread where the OP's RAM problems were sorted out in 10 minutes.
Just setting the voltage to 1.5V might have solved your problems.
But then if you don't ask....
If you would have googled, you would know its actually quite a common problem.
I even asked (see, I did ask) overclockers support if they would advise me turning the voltage down to 1.5v and they said they wouldnt.
They are refunding my original RAM so its not like they are trying to get another sale.
Surveyor, mate, cant thank you enough.
I have been trying to fix my BSOD and random crashes for a week now.
Just set my volts to 1.5 in the bios about 15 min, gonna test it.
If your right and my machine doesnt crash anymore, and i dont have to order new ram, I could kiss you!
Seriously, Ive been trying everything for a week solid, thanks man.
Maybe Im just unlucky and got a set of faulty XMS3's....
CPU isnt overclocked no.
GPU are though.
I used cpu-z. it was set to t1 so ove changed it to t2
in the bios. Any other suggestions? im in work all day but will
be testing it when i get home. if i cant get it working tonight ill
be ordering the g.skills in the morning.
