I popped into the local camera shop today to have a look at the 24-105 F/4 L, and the guy put it on a 5D Mark 1 body for me to try it out. Part of me wishes he hadn’t, because now I’m considering the body!
I’ve been wanting to upgrade my 500D for a bit now and was planning to pick up a 5DII around Christmas time but I’m thinking the 5D classic might make more sense (and be easier on the wallet). It’s the full frame I’m after mainly. 21 megapixels would be nice, but I’ve not really found the 15 on the 500D lacking so I’m sure I could cope with the 12 on the 5D. The AF isn’t exactly raved about, but I’ve not been exposed to the higher end focusing systems so as long as it is quick and accurate I’m ok with it. It has no weather sealing which is a shame, but you can’t have everything.
My two main worries are – the screen is pretty bad. I’m a bit of a bugger for zooming in and checking sharpness which didn’t seem easy to do on a low resolution screen during the 5 minutes I had playing with it. I suppose I should just get over that. The second concern is ISO performance. I noticed that the expanded setting only goes up to 3200. Do any 5D owners miss the higher sensitivities and does it give usable images at 3200?
I’m going to read a few reviews tonight but I wondered what you guys think. Cosmetically the body is in good/very good condition but I’m not sure what I should be looking for in a second hand camera? Any tips? It comes with a 6 month warranty which gives me a little bit of confidence buying, but what would you look for in a used body? The price is £650 which seems to be the going rate.
I might sleep on it and go back on Thursday.
Cheers
Cheers
