**Today Only 25/10/2011*** PNY GTX 580 & OcUK Mug!!!!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Two great deals TODAY ONLY, we've slashed the price of PNY GTX 580 to the lowest price in the UK which is superb considering the looming shortages and possible price increases. Then get yourself into fame buy grabbing your very own OcUK mug.
PNY Geforce GTX 580 1536MB GDDR5 DVI HDMI PCI-E Graphics Card - (GMGTX58N2H15ZPB) @ £353.99 inc VAT
NVIDIA GeForce GTX 580 features with screaming performance and a vapor chamber thermal design. The GTX 580 rips through the games while running quieter than the previous generation. As you've come to expect from a GeForce GTX GPU, GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX, and SLI. GeForce GTX 580 - don't play DX11 without it.
Features:-
- Core Clock: 772MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
*** REFERENCE PCB DESIGN ***
Was [£389.99] Inc. VAT
Only £353.99 inc VAT.
ORDER NOW
Official Overclockers UK Elite Gaming Mug @ £3.98 inc VAT
Introducing the Overclockers UK Official Mug:
'The Ultimate Desktop Peripheral'
Designed and engineered for maximum 'Hot Drink Holding' performance. The Overclockers UK Official Mug leads the way in the fight against thirst.
Desk Mountable for increased stability, the Overclockers UK Official Mug allows you to safely hold hot beverages with its large, ergonomic, easy to hold handle.
Featuring striking graphics on both sides of the Mug, friends and co-workers will know you mean business. It doesn't matter if you are a serious gamer or an overclocking guru, the Overclockers UK Official Mug takes the capabilities of the mug to a whole new level.
A triumph in design, you will never grace your desk with a more capable item.
Developed in conjunction with expert technical staff and overclocking experts, the OcUK mug gives the end user the edge no matter what the scenario
Technical Specification:
• Sleek Black design
• Wide tapered rim for dribble free operation
• Heavy Duty build quality to withstand the hottest beverage
• Unparalleled 'Hot Drink Holding' ability
• Ergonomic Handle Design
• Overclockers UK Logo on both sides
• Advanced Wireless technology
• SLI and Crossfire Compatible
• Available in right and left handed configurations
• Unique 'Mug & Play' features
• Compatible with a wide range of hardware configurations
Was [£4.99] Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
