Thomas Cookware 70% off Vouchers
25 Sep 2006
I'm not sure if I can mention the supermarket in question (the same supermarket with the infamous 5p off petrol vouchers) are doing a 70% off offer for Thomas Cookware with 10 vouchers collected in store.
Every £20 spent in store gets you 1 voucher. Redeem 10 for a 70% discount off pots & pans normally retailing for between £50 & £70.
I have come in to quite a few of these and have bought myself plenty of pots and pans making quite a saving, well over £200.
I have 30 vouchers remaining which I am happy to give 10 of each to the first 3 posters. :cool:
I will contact the first three posters claiming them. So make your e-mails available in your trusts. Vouchers will be posted tomorrow.
Thanks,
BennyC
This is not intended to breach or break any forum rules. Mods feel free to amend or delete as appropriate.
You're! It's you're!!!
I'm very busy, too busy to spell correctly!
I've missed it, but I will use these if you'd reconsider your opening offer...
Streeteh
Nathan
Raikiri - you were 3rd as Maccy wasn't claiming them...
I'll contact you shortly.
Unfortunately that's all I have for those of you that missed it :(
You could try redeeming your previous receipts at customer services and see if they will give you some vouchers. On the tills I found most cashiers just tore a load off and gave you them rather than sticking to the 1 per £20.
Thanks again Benny, i've already decided what i want :D
Can the discount be applied to multiple items, or is it 10 vouchers per item?
No problems you're (:p Maccy) welcome.
It's 10 vouchers per item.
You might find they're quite generous and if you ask nicely may give you quite a few with your purchase. Edit: they're not giving them out as of 23.10.11 according to the vouchers.
You have until 6.11.10 to use them while stocks last etc etc
Not too fussed as there's only one thing i NEED. However if they let me do multiple purchases i might just replace a few of my older items :D
Two weeks - plenty of time!
You can buy these on the bay for around £5 for 30.
You save £50 on the stock pot and around £30-45 on the other pieces.
I've sent you all e-mails via trust, please reply this evening.
There actually quite good quality pans.
We've had a frying pan, grill pan and wok and have been very impressed with them and with the money off is a bargain.
