** TWO DEALS SO GOOD THEY NEED THEIR OWN POST!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
As TWO is so large I wanted to just point out a few of my own very hot deals which you should not miss out on:-
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £169.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 3yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was [£184.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £239.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was [£259.99] Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £251.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
Was [£269.99] Inc. VAT
Only £251.99 inc VAT. - Arriving Friday in volume!
ORDER NOW
Kingston HyperX Genesis 24GB (6x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K6/24GX) @ £119.99 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (4GBx6)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was [£149.99] Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLE2CP4G3D186HCE1TX0CEU) @ £67.99 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Ultimate performance memory
- Each two module set is tested at 1866MHz
- Elite heat spreader for performance
- Packaged together immediately following system test
- Tested together at 1866MHz, Vdimm = 1.60V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 9-10-9-27 values at 1866MHz, 1.60V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1866MHz in Intel based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
- Sandybridge compatible
- Bulldozer compatible
Was [£79.99] Inc. VAT
Only £67.99 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9) @ £79.99 inc VAT
CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each four module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 16384 Megabytes of DDR3 memory
- Four matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Lifetime Warranty
Was [£89.99] Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £43.99 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
Capacity: 8GB (4GBx2)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was [£53.99] Inc. VAT
Only £43.99 inc VAT.
ORDER NOW
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £23.99 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was [£27.99] Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 2 Years
Was [£209.99] Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
OcUK ATI Radeon 6970 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required
- Warranty: 2 Years
- Supplied with Dirt3 PC Game (Subject to availability)
- Deus Ex: Human Revolution FREE download code. Only on orders placed on 26/08/2011 onwards. Your code shall be emailed to you Wednesday 31st August onwards, please don't call or email us before this time.
Was [£274.99] Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card **Lowest Price DX11 Graphics Card in UK** @ £19.99 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Passive cooling design (SILENT)
- Core Clock: 650MHz
- Memory: 512MB GDDR3
- Memory Interface: 64-Bit
- Memory Clock: 1066MHz (Effective)
- Processing Cores: 80
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
Was [£23.99] Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £383.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
- Supplied FREE with Batman: Arkham City FULL PC game (subject to availability. Game is launched on 21/10/2011 downloads previous to this date will be declined) (Only supplied with orders purchased after 07/09/2011)
Was [£399.99] Inc. VAT
Only £383.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £359.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 772MHz (Fermi GF110)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was [£379.99] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £399.98 inc VAT
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Uprated quiet cooling solution
- Memory: 3072MB GDDR5
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£439.99] Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
Asus GeForce GTX 570 DirectCU II 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £251.99 inc VAT
Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan. Based on ASUS DirectCU architecture, which uses copper heat pipes in direct contact with the GPU to speed up heat dissipation for over 20% cooler performance, DirectCU II takes cooling further with twin 80mm fans for 600% airflow. Full throttle overclocking with exclusive ASUS Voltage Tweak via Smart Doctor – boosting 50%* more speed, performance and satisfaction! Advanced output option for all display types from one single output! Factory overclocked to perform at 742MHz, higher than stock performance, resulting in higher frame rates in games.
Features:-
- Core Clock: 742MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £179.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was [£199.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £131.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
- Warranty: 3 Years On-Site
Was [£139.99] Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Asus PA238Q 23" Professional ProArt Widescreen P-IPS LCD Monitor - Black @ £215.99 inc VAT
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. PA238Q adopts 178degrees of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors.
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc.
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution. The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want.
Features:-
- Panel Size: Wide Screen 23.0"(58.4cm) 16:9
- Color Saturation : 100%(sRGB)
- Panel Type : IPS
- True Resolution : 1920x1080
- Full HD 1080P : Yes
- Pixel Pitch : 0.2652mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 178°(H)/178°(V)
- Response Time : 6ms (Gray to Gray)
- Display Colors : 16.7M
- LCD ZBD Warranty : Yes
- Signal Input : HDMI , D-Sub, DisplayPort, DVI-D
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack (for HDMI & DisplayPort Only)
- USB Port(s) : 1 x upstream, 4 x downstream
- Chassis Colors : Black
- Tilt : +20°~-5°
- Swivel : Yes
- Pivot : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Warranty 3yr On-site
Was [£239.99] Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Asus VG236HE 23" TRUE 120Hz 3D Widescreen LCD Monitor - Black @ £199.99 inc VAT
Enter an immersive three dimensional Full HD 1080p world of games and movies with the VG236HE. Through the use of market-leading 3D technology and active shutter glasses, it instantly takes you into another dimension - transforming your gaming experience to 3D. There are hundreds of popular PC game titles currently compatible with the NVIDIA 3D Vision kit (not included).
- Tilt and Swivel also Height Adjustable.
- Screen Size: 23" Widescreen
- Contrast Ratio: 100000:1
- Viewing Angles: (H/V): 170*/160*
- Inputs : 1 x DVI-D & 1 x HDMI
- Weight: 7kg
- 3 Years Warranty
Was [£249.99] Inc. VAT
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £199.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was [£219.99] Inc. VAT
ORDER NOW
Asus VH242H 24" Widescreen LCD Multimedia Monitor - Black @ £131.99 inc VAT
23.6” 16:9 widescreen with 1920×1080 resolution enables borderless Full HD 1080p full-screen video display. Embedded HDMI simplifies cabling and provides pristine and stunning clarity multimedia experience together with PC, game consoles, Blu-ray Disc players, etc. Built-in hidden stereo speakers and SPDIF audio output enable audio enjoyment together with true-to-life Full HD visual.
ASCR (ASUS Smart Contrast Ratio) Technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 20000:1 – resulting in more realistic depictions of night scenes during games or movies.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life Full HD 1080p gaming or movie watching without any data loss or image distortion.
Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the best possible color and image fidelity.
With the five preset modes (Standard, Game, Scenery, Night View and Theater) of Splendid™ Video Intelligence Technology, you will enjoy optimized colors for various multimedia entertainment scenarios.
Features:-
- TFT-LCD Panel Panel Size: 23.6“ Wide Screen
- True Resolution: 1920X1080
- Pixel Pitch: 0.272mm
- Brightness(Max): 300 cd/?
- Contrast Ratio (Max.): 20000 :1 (ASCR)
- Display Color: 16.7M
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 5 ms
- Video Features SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes (5 modes)
- Skin-Tone Selection (3 mode)
- HDCP support
- Color Temperature Selection(5 modes)
- Audio Features Stereo Speakers 2Wx2 stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- Input / Output PC Input: DVI-D/D-Sub
- PC Audio Input: 3.5mm Mini-jack
- Video Input: HDMI
- AV Audio Input: HDMI
- Audio Output: SPDIF
- Earphone jack: 3.5mm Mini-jack
- Signal Frequency Analog Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Digital Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Power Consumption Power Consumption < 55 W
- Power Saving Mode < 2 W
- Mechanical Design Chassis Colors: Black
- Tilt: +20°~ -5°
- VESA Wall Mounting: 100x100mm
- Security Kensington lock
- Dimension (WxHxD mm) Phys.Dimension(WxHxD): 562mm x 416mm x 220mm
- Box Dimension(WxHxD): 638mm x 171mm x 491mm
- Weight Net Weight (Esti.): 5.8 kg
- Gross Weight (Esti.): 8.2 kg
- Accessory DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- support CD
- warranty card
- Regulation Approval Energy Star®, UL/cUL, CB, CE, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, RoHS, WEEE, WHQL
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £193.99 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Contrast Ratio: 20,000,000:1
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
Only £193.99 inc VAT.
ORDER NOW
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey @ £979.99 inc VAT
Experience amazing wide-angle viewing and color consistency with the DellTM UltraSharpTM U3011 30"W Monitor with PremierColor. Extensive connectivity features and customization via CustomColor mode make the U3011 an ideal choice for professionals in CAD/CAM, graphic design, gaming and other fields where color precision matters.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (CIE 1976) color gamut with excellent AdobeRGB and sRGB coverage for rich, lifelike visuals
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 100,000:1 Contrast Ratio
- 7ms Response Time (7ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- Two DVI-D Input with HDCP support
- Two HDMI Input
- One Display Port Input
- One Analogue Input
- Component Connectors
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Was [£1049.99] Inc. VAT
Only £979.99 inc VAT.
ORDER NOW
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Monitor - Black @ £359.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality. Video content bypasses scalers making the HZ27WC ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 1000:1 / 1,000,000:1 (Dynamic)
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x Dual Link DVI-D
- 2.5mm Audio out
- Kensignton Security Port
- 8bits [16.7Million colors]
- Dual Link DVI-D Cable, 2.5mm Audio Cable, 24V External Power Adapter, UK
- PIP/POP, Mapping: Not Supported
- Only available to customers in the United Kingdom
- 3yr RTB Warranty (UK customer only)
ORDER NOW
MSI CR620-1072UK 15.6" WLED TFT Intel I5-460M, 4GB DDR3, 320GB HDD, Intel Graphics, Win7 HP 64-Bit - Black/Silver @ £399.98 inc VAT
MSI's concise and refined classic cross-hatch design uses high-tech color film print technology for a dazzling look. The sparkling, scratch-resistant enamel provides a high degree of rigidity. Under different light sources, this finish will emit a multitude of color variations that create sparkling visual effects and evoke a minimalist undertone of taste and style.
- Intel® Core™ i5 Processor
- Genuine Windows® 7 Home Premium
- Classic Cross-Hatch Design
- 15.6” 16:9 wide screen display
- LED power-saving backlight technology
- HDMI (High-Definition Multimedia Interface) Output
- MSI Exclusive ECO Engine Power Management System
- DVD Super Multi
- Intel Core i5 460M
- 1 x 10/100 (LAN)
- 1 x D-Sub
- 1 x HDMI
- 1 x Headphone
- 1 x Mic In
- 3 x USB 2.0
- 2.53 GHz
- 15.6" (1366x768)
- 4GB RAM DDR3 SO-DIMM
- Battery 6-cell
- 500 GB HDD
- Windows 7 Home Premium (64 bit)
- Dimensions: 374 x 35 x 248 mm (WxHxD)
- Graphics Chipset Intel UMA Graphics
- 2.48 kg
Was [£449.99] Inc. VAT
ORDER NOW
MSI GT780DXR-290UK 17.3" WLED TFT Intel I7-2670QM, 8GB DDR3, 1.5tb HDD, NVIDIA GTX 570M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Back/Red @ £1,379.99 inc VAT
What do gamers desire most? MSI knows best! In GT780DX, MSI not only conducted research with the world-class team Fnatic, but also collaborated with SteelSeries, a leading manufacturer of professional gaming peripherals, to develop a “gamer’s keyboard” never before seen in gaming notebooks. GT780DX provides you the best gaming experience!
GT780DX has a 17-inch Full HD screen, which projects a vibrant visual effect. The latest top-end NVIDIA Geforce GTX570M graphic card with 1.5GB GRDDR5 memory gives the notebook an extraordinary gaming performance. GT780DX is fully compatible with DX11, which provides an ultra-smooth and vivid three-dimensional visual experience.
In order to present the best sound effects, the GT780DX speakers are uniquely configured. Besides the two side speakers projected toward the user, there is also a subwoofer sound hole at the bottom. This configuration immerses gamers into a realistic, three-dimensional battlefield experience.
The exterior design of the GT780DX combines the classic, succinct appearance of a limousine with the aerodynamic contour of a spacecraft creating a low-key composure but powerful image. The black casing of the GT780DX is specially covered with brushed aluminum, coupled with the silver msi logo, it makes the GT780DX a symbol of the coexistence of textural quality and ultimate performance.
To avoid accidentally touching the touch pad while gaming, the GT780DX is equipped with a control switch for the touch pad on the side of the keyboard
Features:-
- Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- The Latest 2nd Generation Intel® Core™ i7 Processor
- High-end NVIDIA® GeForce GTX 570M discrete graphics card(with GDDR5 1.5GB VRAM) provides great detail images quality
- Best gaming keyboard designed by SteelSeries
- Dual SATA hard drives with RAID0 to double the transmission speed
- Exclusive TDE technology to speed up the performance
- Sound by Dynaudio for extreme audio performance
- Exclusive DDR3 SO-DIMM x 4 slot design easily upgrades memory capacity
- THX TruStudio Pro provides excellent surround sound
- Latest & fastest data transfer technology USB 3.0
Specification:-
- CPU Intel® Core™ i7-2670QM Processor (6M Cache, 2.20 GHz)
- OS Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- Chipset Intel HM67
- 8GB Memory DDR3 1333 MHz ,Slot : 4
- LCD Size 17.3" Full HD (1920x1080) LED backlight
- Graphics nVidia GeForce GTX 570M
- Graphics VRAM 1.5GB GDDR5
- HDD: 1.5TB (2x 750GB in RAID 0) (7200rpm)
- Optical Drive Blu-ray / DVD Super Multi
- Audio 2.1 channels speakers, Sound by Dynaudio, THX TruStudio Pro, 7.1ch output
- Webcam HD type (30fps@720p)
- Card Reader SD(XC/HC)/MMC/MS(PRO)/xD
- LAN 10/100/1000
- Wireless LAN 802.11 b/g/n
- Bluetooth Bluetooth v3.0 + HS
- D-Sub (VGA) 1
- HDMI 1 (v1.4)
- USB 2.0 port 3
- USB 3.0 port 2
- eSATA 1
- eSATA/USB Combo N/A
- Mic-in/Headphone-out 1/1
- Line-in 1(line in)/1(line out)
- Express Card N/A
- Modem port N/A
- Keyboard 102-key keyboard by SteelSeries
- Sensor N/A
- AC Adapter 180W
- Battery 9 cells
- Power Management Turbo Battery+
- Dimension 428 x 288 x 55mm(WxDxH)
- Weight (KG) 3.9
- UK Model does *NOT* have backlit keyboard
- UK Model comes with FREE Dirt 3 PC Game
- 2yr Warranty
Was [£1499.99] Inc. VAT
Only £1,379.99 inc VAT.
ORDER NOW
My first reaction was, WOW 24GB RAM for £120 :cool:
My next reaction was, Who the **** needs 24GB of RAM :eek::confused:
Lol must smack abit as one of the OcUK dons is selling his second hand 30" dell monitor in the MM for 950 and you guys come in with a new one at 980.
KaHn
When did these prices change? I'm Sure I looked at the weekend and several were the "reduced" price...:confused:
