This Week Only 26/10/2011 **Spookily Good Offers - Our Biggest TWO to date!!!**
22 Aug 2010
This Week Only we have some great products with prices slashed to celebrate Halloween.
Scythe Gentle Typhoon 120mm 1150 RPM - 3 Pin @ £10.49 inc VAT
The GentleTyphoon achieves high airflow volume and low noise with the newly designed impeller, enabling silent cooling of the latest devices which run very hot.
The GentleTyphoon has a different type of tone. The fan propeller is designed to reduce the disturbing frequency fan noise to human ears. The newly designed motor and motor support mechanism of the GentleTyphoon uses a double vibration reduction structure. The new support mechanism uses coil dampers to greatly reduce vibration.
- Manufacturered in Japan
- Only 21.0 dB(A) at 1150 RPM
- Weight 200 g
- Dimensions 119 x 119 x 25 mm
- Air volume at full speed (12V), CFM ±10% 37.1
- Noise level at full speed (12V), dB(A) 26.0
- Fan speed at full speed (12V), RPM ±10% 1150
- Bearing Type Double Ball Bearing
- MTBF 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories 4-pin Molex Adapter, 4x Screws
Was £12.98 Inc. VAT
Only £10.49 inc VAT.
ORDER NOW
Akasa AK-CC4005SP01 Venom Nano CPU Cooler (Socket LGA775/LGA1155/LGA1156/LGA1366/AM2/AM3) @ £19.98 inc VAT
The highly effective 10cm fan in killer Viper yellow delivers vast amounts of airflow for top notch cooling. The PWM function ensures quiet operation during normal system use and performance cooling under load. Three nickel plated heatpipes with direct CPU contact provide rapid heat transfer from CPU to 50 high grade aluminium fins. Anti-vibration rubber fan mounting pins help to eliminate a lot of fan noise. New design akasa (patented) Easy Select Clip with Intel reference push-pin retention is used for no-hassle mounting on Intel LGA775, LGA1156 and LGA1366 platforms - no backplate is needed. AMD Sockets AM2, AM2+ and AM3 are catered for with a spring-loaded screw mounting for safe and reliable attachment. Performance thermal compound is supplied.
- Low noise 10cm PWM fan in killer Viper yellow
- Three nickel plated heatpipes with direct CPU contact
- Quick installation with akasa Easy Select Clip
- Anti-vibration rubber fan mounts
- Aluminium fins, copper heatpipes
- 154(H) x 107(W) x 80(D) mm
- 600 – 2500 RPM (PWM controlled)
- Max Airflow: 67.38 CFM
- Noise Level: 14 – 28 dB(A)
- 4pin PWM
Was £21.98 Inc. VAT
Only £19.98 inc VAT.
ORDER NOW
Arctic Cooling Freezer 7 Pro Rev 2 CPU Cooler (Socket 939 / AM2 / AM3 / 775 / 1155/ 1156 / 1366) @ £17.99 inc VAT
The Freezer 7 Pro Rev.2 is the upgraded version of the renowned Freezer 7 Pro. With the flexible mounting design, this version is compatible with the Intel Core i7, Core i5, as well as AMD Socket AM3. Featuring an ultra quiet 92mm fan and 6 heatpipes, the Freezer 7 Pro Rev.2 is one of the most efficient and quiet CPU coolers for power users.
The unique heatsink design consists of 42 fins, which significantly increase the heat dissipation area to distribute massive amount of heat faster and more efficient. Featuring a 92mm PWM fan , 6 heatpipes and pre-applied ARCTIC MX-2.,the Freezer 7 Pro Rev.2 offers performance far beyond stock coolers and achieves 130 Watts cooling capacity – becoming one of the most efficient CPU coolers for power users.
- Compatable Sockets: 939 /AM2 /AM2+ / 775 / 1155/ 1156 / 1366
- Compatible with Intel Core i7 and Core i5, as well as AMD sockets
- Excellent cooling performance - 130 Watts
- Ultra quiet 92mm PWM fan
- 6 heatpipes and 42 fins for efficient heat dissipation
- Patented vibration absorption to eliminate buzzing sounds
- Pre-applied ARCTIC MX-2
- Easy installation
Was £19.99 Inc. VAT
Only £17.99 inc VAT.
ORDER NOW
Asus Axe Square Limited Edition Gold CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM3) @ £12.98 inc VAT
Axe Square AMAzing features a 120mm LED fan, five copper C-shaped heatpipes, a copper base and a large-scale heat dissipation surface area of up to 5500cm2 to facilitate highly efficient heat transfers in order to provide enthusiasts worldwide with the ultimate cooling experience.Ultra Silent at 16 dBA and Power Savings
Equipped with the PWM function, Axe Square AMAzing is able to adjust the fan speed according to the CPU’s temperature—providing users with the optimal operating environment at a mere 16 dBA, as well as helping to conserve energy and delivering CPU stability.
Amazing Gold-Aureate Design with Luxury Packing
Axe Square AMAzing is the latest model in the limited AMAzing series, and takes center stage with its stunning gold-aureate color; which juxtaposes with the black nickel-plated surfaces of unique axe-shaped design for the ultimate in aesthetic appeal. Moreover, this stunning Axe Square AMAzing comes in an extremely luxurious packaging with a limited-run identification card that ensures the fine quality of the amazing Series.
- Dimensions: 139 x 133 x 130 (W x H x D)
- Nickel plater for stunning looks
- Supplied with high quality thermal paste
- Noise Level: 16dBA
- Fan Speed: 1400 RPM
Was £19.99 Inc. VAT
Only £12.98 inc VAT.
ORDER NOW
Asus Royal Knight CPU Cooler (Socket LGA775/LGA1155/LGA1156/AM2/AM2+) @ £11.99 inc VAT
Royal Knight provides for an advanced thermal solution, including 6 pure copper heat pipes for efficient heat transference; a 120mm LED fan with a top-flow design for maximum air-flow; last but not the least, twin wing-shaped copper fins that expands the heat exchange area for excellent thermal performance.Equipped with a 120mm LED fan, Royal Knight not only provides maximum air-flow, but also ensures a quiet computing environment with operating levels of only 22 dBA. This is due to the PWM function, which can automatically adjust the fan speed by CPU's temperature - allowing gamers to fully immerse themselves into their games without other distracting noises.This latest Royal Knight presents itself in a retro-chic British Chevalier stylized outlook - integrating a crown, a coat of arms and an eagle that embraces the core spirit of the Knight Series. With the most advanced thermal solution to support impressive overclocking capabilities, coupled with such fine aesthetics, the stunning Royal Knight is truly a crowd pleaser in terms of looks and performance.
- Dimensions: 131 x 140 x 138mm (W x D x H)
- Fan Speed: 800 - 1300 RPM
- Heatsink Material: Copper
- 4-pin PWM plug
Was £17.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Prolimatech Panther CPU Cooler (Socket LGA1155/1156/AM2/AM2+/AM3) @ £34.98 inc VAT
Prolimatech has taken its inspiration for this new cooler from the Armageddon, which results in the same excellent performance at a brand new price point. Both feature the same heatpipe shape, with the only difference being the number of such element as the Panther offers four 6 mm pipes.
In terms of construction, the cooler makes no compromises and offers the same level of quality as one has come to expect from Prolimatech. High quality Nickel plating has been applied to the entire cooler which does not only protect the unit but also results in a great look and feel. On top of that, the crossed fins increase the robustness of the Panther cooler.
The sophistication of this construction also shows in the shape of the heatpipes. These end in a row next to each other, so that each of them has unrestricted access to the fresh airflow of the included fan. This maximizes the efficiency of the Panther CPU cooler, while keeping the dimensions to a minimum.
The 120 mm fan with PWM connector can be controlled automatically by every modern mainboard in the market to keep the noise to a bare minimum. This cooling unit also features transparent red blades along with red LEDs. Prolimatech has also included a second set of clips, allowing the installation of another such fan for a push/pull configuration, further raising the performance bar on this cooler. Also part of the package is the award winning PK-1 thermal past and the very sturdy mounting kit with backplate for Socket 1155, 1156, AM2, AM2+ and AM3.
- Dimensions (with fan): 130 x 158 x 73 mm
- Heatpipes: 4x Ø 6 mm
- Fan: 120 mm (Red LED)
- Fan Noise: (29,1 dB(A)
- Fan RPM: 1.600 U/min +-10%, max.
Was £37.99 Inc. VAT
Only £34.98 inc VAT.
ORDER NOW
Thermalright Venomous X Silent CPU Cooler (Socket 775/1156/1155/1366/AM2) @ £34.98 inc VAT
Patented multiple support pressure vault bracket system, allow users adding pressure to the bracket system (40~70 lbs. pressure system for Intel CPU user only), and have a more efficient and secure mounting. Include AMD Socket AM2/AM3 Bracket system. Mirrored copper base increasingly upgrade the quality and the performance of the heatsink. Special bent winglet design, allows hot air to pass the heatsink more rapidly. Heatsink are all nickel plated to ensure the best quality and performance and could last for years. Soldered heatpipes, copper base and fins, to ensure the best thermal conducting efficiency. Six sintered heatpipe design, all heatpipes are nickel plated.To slow the oxidation deterioration to the heatpipe, to ensure longer usage and performance of the heatsink for the cpu. Including FDB 600RPM ultra low noise Fan Cover set x2 and Chill factor III thermal paste. Convex copper base design, to ensure the Highest thermal conducting thermal efficiency between the cpu and the heatsink.
Heatsink Dimension
- Size: Length 127mm x Width 63mm x Height 160mm
- Weight: 755 g (excluding fan and bracket system)
- Heatpipe: 6mm sintered heatpipe *6 units
- Copper base: C1100 pure nickel plated copper base, with ultra-shine mirrored surface.
Fan Spec
- Dimension : 120 x 120 x 25mm
- Bearing Type : FDB (Fluid Dynamic Bearing)
- Rated Voltage : 12.0 VDC
- Operating Voltage Range: 10.8~13.2 VDC
- Rated Current: 0.130 Amp +10% MAX /0.11AMP
- Rated Power: 1.56 watt
- Rated Speed: 600 RPM ± 10%
- Airflow: 30.5 CFM
- Noise Level: 13.1 dB/A
- Life Expectancy: 60000 HOURS AT 40°c / 65%
- Net weight: 156 GRAMS
- Connector: 3 pin
Was £41.99 Inc. VAT
ORDER NOW
XFX Pro 550W Core Edition '80 Plus Bronze' Power Supply @ £52.98 inc VAT
Unique, continuous EasyRail™ technology enables you to maximize available power and make set-up easy. Stack numerous power-hungry components without fear of crashing. It's also a perfect solution for hardcore gamers.
- 550W of continuous power at 50°C
- Tight voltage regulation (±5%)
- High efficiency operation up to 85% (80 Plus Bronze)
- Single, high power +12V rail (up to 53A/636W)
- High quality Japanese brand capacitors (105°C)
- Quiet 135mm ball bearing fan provides superior cooling
- Supports multiple high-end graphic adapters (NVIDIA SLI & ATI CrossFire Ready)
- Supports the latest ATX12V and EPS12V standards
- Active PFC with Universal AC input
- Energy Star 4.0 and RoHS compliant
- 5-Year Limited Warranty
Was £58.99 Inc. VAT
Only £52.98 inc VAT.
ORDER NOW
XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply @ £79.98 inc VAT
XFX PSUs are designed to deliver tight DC voltage regulation with minimal AC ripple, giving you safer, cleaner power which, along with XFX’s new EasyRail™ Technology allows you to connect numerous devices without worrying about running out of power before reaching the maximum wattage. EasyRail™ optimizes it all for you. Available in 650W, 750W and 850W, XFX ProSeriesPSUs with EasyRail™ Technology gives you one continuous rail of power covering the total maximum wattage. EasyRail™ Technology Provides Maximum Power Unique, continuous EasyRail™ technology enables you to maximize available power and makes set-up easy.
- Fixed FDD: 1
- Fixed Peripheral: 7
- Fixed 6+2-pin PCI-E: 2
- Fixed 6-pin PCI-E: 2
- Fixed ATX12V / EPS12V: One 4+4-pin
- Fixed Motherboard Connector: 20+4 Pin
- Fixed SATA: 8
Was £84.98 Inc. VAT
Only £79.98 inc VAT.
ORDER NOW
Roccat Taito Gaming Mouse Pad @ £9.98 inc VAT
Due to its woven structure, normal mousepads based on textiles generally only glide fast in one direction. To counteract this effect, the Roccat Taito features a heat-treated nano pattern which effectively increases the glideability into all directions on both the x-axis as well as the y-axis. On the microscopic pictures on the right side, the difference is easy noticeable. The heat-treated nano pattern provides the gamer with a most silent and comfortable solution. Its 400x320mm surface with its 3.45mm thickness is convenient and cozy. The thickness also compensates for potentional minor unevenness of your desk. The rubberized backing provides heavy grip and gives you a secure feeling. The Taito will not move, even if you try moving it by pressing your palm on it. The Taito is ruggedized for high strain and it's exeptionally robust and designed for durability.
- Heat-treated Nano pattern for silence and comfort right in the heat of the gaming action
- Rubberized backing provides heavy grip and security
- Long life material ruggedized for high strain
- Dimensions: 400mm x 320mm x 3.45mm
Was £11.98 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Roccat Sense Gaming Mouse Pad - Glacier Blue @ £10.98 inc VAT
Never underestimate the influence of a mouse surface on your gaming performance. This is the reason why Roccat has developed the Sense gaming mouse pad which does not restrict the performance of your mouse and gives you highest comfort for hours and hours of gaming. A large surface area provides sufficient space even for rapid mouse movements in critical situations. The colour variations have been selected to provide the mouse sensor with the ultimate optical response and its low height (1.35mm) guarantees optimum comfort and less strain on your hand and wrist. The special surface coating made from micro-crystals bonded to a rubberized backing noticeably improves the gliding characteristics of the mouse. The coating ensures ultra-low friction between your mouse and the pad.
- Minimized friction thanks to the microcrystalline coating bonded to a particularly soft cloth base
- Optimum gliding area and pointer positioning
- Rubberized backing featuring a nano-sized pattern for the perfect amount of grip on any surface
- Optimized for gaming and professional design applications
- Dimensions: 400mm x 280mm x 1.35mm
Was £12.98 Inc. VAT
Only £10.98 inc VAT.
ORDER NOW
Scythe Kaze Jyuni 1900RPM Slip Stream 120mm Fan @ £7.99 inc VAT
The Slipstream 120mm Case Fans have been developed solely by Scythe engineers. They found out that by reducing the dimension of the centre hub and the wider surface area of the fan blade increased the airflow. There are a range of different fan speeds to choose from which meets the demand from a wide variety of users in the market. Silent users to power users now have more choice when it comes to choosing a suitable case fan.
- Air volume at full speed (12V), CFM ±10% 110.3
- Noise level at full speed (12V), dB(A) 37.0
- Fan speed at full speed (12V), RPM ±10% 1900
- MTBF 3.5 years
Was £8.99 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Scythe Kaze Jyuni 1200RPM Slipstream 120mm Fan @ £6.98 inc VAT
- Air volume at full speed (12V), CFM ±10% 68.5
- Noise level at full speed (12V), dB(A) 24.0
- Fan speed at full speed (12V), RPM ±10% 1200
- MTBF 3.5 years
Was £8.50 Inc. VAT
Only £6.98 inc VAT.
ORDER NOW
Scythe Gentle Typhoon 120mm 1450 RPM - 3 Pin @ £11.99 inc VAT
- Model-No. D1225C12B4AP-14
- Only 21.0 dB(A) at 1450 RPM
- Weight 200 g
- Air volume at full speed (12V), CFM ±10% 50.0
- Noise level at full speed (12V), dB(A) 21.0
- Fan speed at full speed (12V), RPM ±10% 1450
Was £12.98 Inc. VAT
ORDER NOW
Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin @ £11.99 inc VAT
- Only 21.0 dB(A) at 1850 RPM
- Weight 200 g
- Air volume at full speed (12V), CFM ±10% 58.0
- Noise level at full speed (12V), dB(A) 28.0
- Fan speed at full speed (12V), RPM ±10% 1850
Was £12.98 Inc. VAT
ORDER NOW
Scythe Gentle Typhoon 120mm 5400 RPM Cooling Fan, D1225C12BBAP-31 @ £18.98 inc VAT
Gentle Typhoon 120 mm High Speed Series are optimised for high speed as well as high airflow. An implemented ring connects the fan blades creating characteristics similar to 38mm thick fans, while running at a quieter noise level. By employing a large fan motor, little fluctuation in rotation torque has been achieved. Furthermore a vibration absorbing structure has been integrated to further help reduce the noise level.
Optimized for High Airflow
Forceful airflow is created and guided in a linear fashion thanks to the implemented stabilising ring. By using this powerful design the fans are able to generate high pressure to overcome and handle high resistance such as when being used with a duct or coolers with dense fin structure.
Vibration Reduction Structure
By employing a large fan motor, little fluctuation in rotation torque has been achieved. Furthermore a vibration absorbing structure has been integrated to further reduce the noise level. This combination greatly reduces the transfer of vibration from the motor to the fan chassis.
- Weight: 205 g
- Dimensions: 120 x 120 x 25 mm
- Maximum air flow, CFM ±10%: 150.1
- Maximum noise level, dB(A): 50.5
- Maximum fan speed, RPM ±10%: 5400
- Power Consumption: 13.68 W
- Rated Current: 1.14 A
- Starting Current: 2.69 A
- Cable Length: 30 cm
- Bearing Type: Double Ball Bearing
- MTBF: 100,000 hour at 35°C or 60,000 hours at 60°C
- Accessories: 4-pin Molex Adapter, 4x Screws
Was £19.99 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
OcUK Football CD Case - 24 Discs @ £1.19 inc VAT
Perfect for the sports fan or for the kids, the OcUK Football Case is a durable way to carry your media
• 24 Disc capacity
• Tough zip
• Football Design
Was £3.98 Inc. VAT
Only £1.19 inc VAT.
ORDER NOW
OcUK Value Media Carry Case - Holds 40 Discs @ £0.84 inc VAT
This DataSafe branded ringbinder carry case holds an impressive 40 discs and looks good to boot! Comes with a strong and tough black exterior and tough wearing zip.
Was £0.98 Inc. VAT
Only £0.84 inc VAT.
ORDER NOW
Lepa N-Series 600W Power Supply @ £41.99 inc VAT
Designed by Enermax these entry level PSU's are ideal for any low-to-mid range spec'd systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- High efficiency 5Vsb circuit helps system to meet EU ErP Lot 6 2010 standby low power consumption requirements
- 12cm fan with thermal programmed speed controller providing silent cooling performance
- PCI-E connector supplied supporting extreme graphic cards
- Protected by Over Power, Over Voltage, Over Current, Short-Circuit, and Brown Out protections circuits
- CPU 12V connector rail with >18A output to support next generation >6 cores processor structure
- Extended CPU connector cable to 60cm facilitates installation with bottom-mounted-PSU chassis
- SATA power connector with 3.3V rail to support new generation SSD
- Active PFC switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level. (N400-SA-EU, N500-SA-EU, N600-SA only)
- 3 year warranty
Was £43.98 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
Lepa W-Series 450W '80 Plus' Power Supply @ £41.99 inc VAT
Designed by CWT these mid range PSU's are ideal for any gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- 80 PLUS® certified with peak 85% efficiency
- Active PFC universal switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level and automatically adopting AC voltage from 100~240V
- 8P PCI-E connector supplied supporting extreme graphic cards
- 3 year warranty
Was £43.99 Inc. VAT
ORDER NOW
Lepa W-Series 500W '80 Plus' Power Supply @ £45.98 inc VAT
- 3 year warranty
Was £47.99 Inc. VAT
Only £45.98 inc VAT.
ORDER NOW
Lepa B-Series 750W '80 Plus Bronze' Modular Power Supply @ £72.98 inc VAT
Designed by Sirtec these mid to high end PSU's are ideal for any pro-gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- 80 PLUS® Bronze certified with peak 88% efficiency.
- 13.5cm fan with intelligent RPM control guarantees cool performance and silent operation.
- Active PFC universal switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level and automatically adopting AC voltage from 100~240V.
- 8P PCI-E connector supplied supporting extreme graphic cards.
- Protected by Over Power, Over Voltage, Over Current, Short-Circuit, and Brown Out protections circuits.
- CPU 12V connector rail with > 18A output to support next generation >6 cores processor structure.
- Extending CPU connector cable to 60cm facilitates installation with bottom-mounted-PSU chassis.
- SATA power connector with 3.3V rail to support new generation SSD.
- Modular design for easy cable management and flexible system upgrade support.
- 3 year warranty
Was £74.98 Inc. VAT
Only £72.98 inc VAT.
ORDER NOW
Lepa B-Series 850W '80 Plus Bronze' Modular Power Supply @ £92.99 inc VAT
- 3 year warranty
Was £99.98 Inc. VAT
Only £92.99 inc VAT.
ORDER NOW
Lepa Screwless USB2.0 2.5" Hard Drive Enclosure @ £1.98 inc VAT
An interestingly designed USB2.0 2.5" HDD and SSD enclosure, ideal for making your storage medium truely portal.
- USB2.0 Interface
- Max data transfer rate: 480Mb/sec
- USB Powered
- Supports HDD's up to 10,000RPM
- Gorgeous upper cases: match your style
- Zero-screw designfor easy assembly
- Air vents design for maximum heat dissipation
- "Plug & Play" supported
- Supports 2.5” SATA I & II HDD and SSD (9.5 mm high)
- Dimensions: 127mm x 74mm x 16mm
Was £5.99 Inc. VAT
Only £1.98 inc VAT.
ORDER NOW
Intel Pentium Dual-Core E6700 "LGA775 Core 2" 3.20GHz (1066FSB) - Retail @ £62.39 inc VAT
Do extraordinary things with everyday computing when you multitask your favorite music, photo and office applications with a PC running the Intel Pentium dual-core processor. Expand your computing options with two processing cores. And you’ll enjoy that performance with a minimum of power and noise. Enhanced Intel SpeedStep Technology allows your system to dynamically adjust processor voltage and core frequency, enabling decreased power consumption and heat production. And since less heat means less fan noise, you’ll also experience improved acoustics. Plus, you get the protection of built-in Execute Disable Bit designed to help keep your PC safe from viruses, worms and other malicious attacks.1 And with proven Intel technology, you get a level of quality and reliability only the leader in processors for desktop computing can provide.
- Dual Core Technology
- Core2-based CPU
- 3.20GHz clock speed
- 2MB L2 Cache
- Intel Speedstep Technology
- EM64T 64-Bit Technology
- Execute Disable Bit
- Cooler running technology, less heat and less noise!
- Supplied with Intel referance heatsink & fan
Was £69.98 Inc. VAT
Only £62.39 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £161.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Unlocked Multiplier
- Lithography Process: 32 nm
- Cores: 4
- Threads: 4
- Frequency: 3.30 GHz (Turbo Mode 3.70GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1100MHz Turbo)
- Cache: 6 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £173.99 Inc. VAT
Only £161.99 inc VAT.
ORDER NOW
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £173.99 inc VAT
- Cores: 4
- Threads: 4
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £184.99 Inc. VAT
Only £173.99 inc VAT.
ORDER NOW
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail @ £45.59 inc VAT
AMD Athlon II Dual-Core processors put the power of dual-core technology on the desktop. Dual-core processors contain two processing cores, residing on one chip, that perform calculations on two streams of data to increase efficiency and speed while running multiple programs and the new generation of multi-threaded software. AMD Athlon II Dual-Core processors deliver TRUE multi-tasking, allowing users to switch from one program to another without always pausing for the computer to catch up and reducing annoying processing pauses.
- Dual-core Technology
- 3.00Ghz clock speed (AM3 Socket)
- Multiplier unlocked
- 2.0MB L2 Cache
- Cool & Quiet Technology for Energy Efficiency
- Enhanced Virus Protection
- 64-bit Technology
- Hyper Transport Technology
- Virtualization technology
- 3yr Warranty
- Retail Boxed with Heatsink & Fan
Was £46.99 Inc. VAT
Only £45.59 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 850 "95W Edition" 3.30GHz (Socket AM3) - Retail @ £83.99 inc VAT
At home or at play, AMD Phenom II processors let you both do more of the things you want to do in less time and enhance your digital life at the right price, with energy-efficient, multi-core performance.
- Quad Core Technology
- 3.30GHz Clock Speed
- AM3 Socket
- 2MB L2 cache
- 64-Bit Technology
- HyperTransport 3.0 Technology
- AMD Virtualization (AMD-V) Technology
- 3 Year Warranty
- Heatsink & Fan Included
Was £85.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
AMD Phenom II X4 Quad Core 965 Black Edition "125W Edition" 3.40GHz (Socket AM3) - Retail @ £89.99 inc VAT
The AMD Phenom II processors are the most advanced processors for true multitasking offering true quad-core design. AMD Phenom II processors deliver virtually uninterrupted information flow between processor cores, main memory and graphics and video accelerators for amazingly rapid system response and phenomenal system performance. AMD Phenom II processors deliver unbeatable multi-core value with superior high definition computing, advanced multitasking performance, and innovative, energy efficient solutions.
- 3.40GHz clock speed
- 2MB L2 cache
- 6MB L3 cache
- DDR3-1333 support
- 45nm process technology (125W Edition)
- True Multi-core Processing
- Direct Connect Architecture
- Integrated Dual-Channel Memory Controller with up to DDR3-1333 support
- AMD Balanced Smart Cache
- AMD Wide Floating Point Accelerator
- AMD Memory Optimizer Technology
- AMD Digital Media Xpress 2.0
- AMD Virtualization with Rapid Virtualization Indexing
- Cool‘n’Quiet 3.0 technology
Was £91.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1055T "95W Edition" 2.80GHz (Socket AM3) - Retail with FREE Deus Ex PC Game @ £113.99 inc VAT
Six-core processing power for massive performance headroom - at the price of the competition's quad-core products. The AMD Phenom II X6 processor features AMD Turbo CORE technology that enables unlocked performance for cutting-edge applications, and dynamically switches to three cores for raw speed. Direct Connect Architecture that enables leading-edge performance and responsiveness, even on the most demanding applications. HyperTransport 3.0 Technology enables incredible system agility for 3D gaming and ultra-high resolution entertainment. AMD Dedicated Multi-cache that extends the memory bandwidth for intensive applications, delivering fast performance per core.
- Six Core Technology
- 2.80GHz Clock Speed
- 4.0 GT/s System Bus
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- Low Power 95W Edition
- 3 Year Warranty
- Deus Ex: Human Revolution FREE download code. Only on orders placed on 22/09/2011 onwards.
Was £119.99 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
AMD Phenom II X6 Six Core 1090T Black Edition 3.20GHz (Socket AM3) - Retail @ £129.59 inc VAT
- Multiplier Unlocked
- 3.20GHz Clock Speed
- AM3 Socket
- 3MB L2 Cache
- 6MB L3 Cache
- 64-Bit Technology
- 3 Year Warranty
Was £133.99 Inc. VAT
Only £129.59 inc VAT.
ORDER NOW
Corsair Vengeance 6GB (3x2GB) DDR3 PC3-12800C8 1600MHz Triple Channel Kit (CMZ6GX3M3A1600C8) @ £55.19 inc VAT
CORSAIR high performance Vengeance memory module 6GB (3x2GB) 1600MHz 8-8-8-24, CL8, 1.5V for motherboards using Intel triple channel processors. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each three module set is tested at 1600MHz
- Vengeance heat spreader for styling and performance
- Packaged together immediately following system test
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel X58 DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.
- XMP 8-8-8-24 values at 1600MHz, 1.50V
- 6144 Megabytes of DDR3 memory
- Three matched 2GB modules
- 100% tested at 1600MHz in X58-based motherboards
- Supports Intel Extreme Memory Profiles (XMP)
- Lifetime Warranty
Was £59.99 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
Kingston HyperX Genesis 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/6GX) @ £38.39 inc VAT
HyperX DDR3 memory; the latest generation of DDR memory technology. Like all Kingston HyperX products, DDR3 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. DDR3 memory offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR2. HyperX DDR3 modules are available in single, dual and triple-channel memory kits.
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL X58
CAS Latency: 9-9-9-27 2N
Capacity: 6GB (2GBx3)
Speed: DDR3-1600 (PC3-12800)
Test Voltage: 1.60-1.65V
Registered/Unbuffered: Unbuffered
Error Checking: Non-ECC
Type: 240-pin DIMM
Warranty: Lifetime
Was £49.99 Inc. VAT
Only £38.39 inc VAT.
ORDER NOW
Kingston HyperX Genesis 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K3/12GX) @ £65.99 inc VAT
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Capacity: 6GB (4GBx3)
Type: 240-pin DIMM
Warranty: Lifetime
Was £89.99 Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Kingston HyperX Genesis 24GB (6x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel (KHX1600C9D3K6/24GX) @ £119.99 inc VAT
Features:-
Main Board: INTEL
System: DESKTOP
System Type: DDR3
Capacity: 6GB (4GBx6)
Type: 240-pin DIMM
Warranty: Lifetime
Was £149.99 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (CMZ8GX3M2A1866C9) @ £71.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1866MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1866MHz
- Tested together at 1866MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- SPD programmed at: JEDEC standard 9-10-9-27 values at 1333MHz.
- XMP 9-9-9-24 values at 1600MHz, 1.50V
- 8192 Megabytes of DDR3 memory
- Two matched 4GB modules
- 100% tested at 1600MHz in Intel based motherboards
- Lifetime Warranty
- Sandybridge compatible
Was £79.99 Inc. VAT
Only £71.99 inc VAT.
ORDER NOW
Crucial Ballistix Elite 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLE2CP4G3D186HCE1TX0CEU) @ £69.59 inc VAT
'Designed specifically for computer gamers and power users seeking maximum seeking maximum system performance and stability, the Crucial Ballistix high performance memory line features advanced speed grades, low latencies, and integrated aluminium heat spreaders. With Ballistix memory, you can push the performance envelope.
- Black PCB
- Black high performance ALU heatspreaders
- Ultimate performance memory
- Elite heat spreader for performance
- Tested together at 1866MHz, Vdimm = 1.60V, at latency settings of 9-10-9-27 on Intel DDR3-based motherboards.
- XMP 9-10-9-27 values at 1866MHz, 1.60V
- 100% tested at 1866MHz in Intel based motherboards
- Lifetime Warranty
- Bulldozer compatible
Was £74.99 Inc. VAT
Only £69.59 inc VAT.
ORDER NOW
Corsair Vengeance 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz Dual/Quad Channel Kit (CMZ16GX3M4A1600C9) @ £81.59 inc VAT
CORSAIR high performance Vengeance memory module 16GB (4x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each four module set is tested at 1600MHz
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.
- 16384 Megabytes of DDR3 memory
- Four matched 4GB modules
- Lifetime Warranty
Was £99.98 Inc. VAT
Only £81.59 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C9) @ £47.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 9-9-9-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Each two module set is tested at 1600MHz
- Lifetime Warranty
Was £53.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (CMZ8GX3M2A1600C8) @ £59.99 inc VAT
CORSAIR high performance Vengeance memory module 8GB (2x4GB) 1600MHz 8-8-8-24, 1.5V for motherboards using AMD, Intel dual channel processors and upcoming 2nd Generation Intel Core platforms. Vengeance memory modules provide users with outstanding memory performance and stability. Each module is built using carefully selected DRAM to allow excellent overclocking performance, and has a limited lifetime warranty.
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.
- Lifetime Warranty
Was £67.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £43.19 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
Was £49.99 Inc. VAT
Only £43.19 inc VAT.
ORDER NOW
Crucial Ballistix Elite 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLE2CP2G3D1608CE1TX0CEU) @ £33.59 inc VAT
- Black PCB
- 4096 Megabytes of DDR3 memory
- Two matched 2GB modules
- Lifetime Warranty
Was £35.99 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) @ £43.19 inc VAT
Kingston's KHX1600C9D3X2K2/8GX is a kit of two 512M x 64-bit 4GB DDR3-1600MHz CL9 SDRAM (Synchronous DRAM) memory modules, based on sixteen 128M x 8-bit DDR3 FBGA components per module. Each module kit supports Intel® XMP (Extreme Memory Profiles). Total kit capacity is 8GB. Each module kit has been tested to run at DDR3-1600MHz at a low latency timing of 9-9-9-27 at 1.65V. The SPDs are programmed to JEDEC standard latency DDR3-1333MHz timing of 9-9-9 at 1.5V. Each 240-pin DIMM uses gold contact fingers and requires +1.5V.
Model Name: KHX1600C9D3X2K2/8GX
Main Board: INTEL
System: DESKTOP
System Type: DDR3
M/B Chipset: INTEL P67
Capacity: 8GB (4GBx2)
Test Voltage: 1.50-1.65V
Type: 240-pin DIMM
Master Pack Dimension: 8.5 x 5.5 x 0.62 In (L x W x H)
Master Pack Weight: 0.26 lbs
Black PCB
Warranty: Lifetime
Was £47.99 Inc. VAT
ORDER NOW
Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) @ £23.99 inc VAT
Kingston® proudly introduces HyperX® blu, a new line of reliable memory ideal for the entry level gamer or PC enthusiast.
HyperX blu features a new streamlined clipless design. Its heatspreaders provide thermal performance at an improved price point.
- Kingston Hyper-X Blu KHX1600C9AD3B1K2/4G
- 4GB Kit - 2x 2GB Modules
- DDR3-1600
- CL9
- 1.5v
- 240pin
Was £26.99 Inc. VAT
Only £23.99 inc VAT.
ORDER NOW
OCZ Gold 4GB (2x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Dual Channel Kit (OCZ3G1333LV4GK) @ £23.99 inc VAT
OCZ low-voltage DDR3 kits are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new OCZ modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the premium option for the midrange desktops.
OCZ DDR3 PC3-10666 Gold Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 9-9-9-20 (CAS-TRCD-TRP-TRAS)
- Gold Z3 XTC Heatspreader**
- Lifetime Warranty
- 1.55-1.65 Volts
- 240 Pin DIMM
Was £25.99 Inc. VAT
ORDER NOW
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channel Kit (OCZ3P1333LV4GK) @ £26.39 inc VAT
OCZ DDR3 PC3-10666 Platinum Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- CL 7-7-7-20
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader*
- Lifetime Warranty
- 1.50-1.60 Volts**
- 240 Pin DIMM
Was £29.99 Inc. VAT
Only £26.39 inc VAT.
ORDER NOW
Corsair Value 2GB (1x2GB) DDR3 PC3-10666C9 1333MHz Low-Voltage Single Channel Module (VS2GB1333D3) @ £11.99 inc VAT
Corsair low-voltage DDR3 modules are designed specifically for the upcoming Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for single & dual channel mode, these ultra-compatible 2GB modules ensure optimal performance with an ideal combination of low power requirements at 1333MHz.
Developed for cost-conscious enthusiasts and gamers, these new Corsair modules were engineered with the same affordability and performance standards as the new Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, Corsair low-voltage kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and Corsair memory are the premium option for the midrange desktops.
Corsair DDR3 PC3-10666 Low Voltage Dual Channel Kits are 100% hand-tested for quality assurance. Furthermore, each Corsair memory module is backed by the industry-leading Corsair Lifetime Warranty and technical support for unparalleled peace of mind.
- 1333MHz DDR3
- Lifetime Warranty
- 1.50 Volts
- 240 Pin DIMM
Was £14.99 Inc. VAT
ORDER NOW
Kingston HyperX 4GB (2x2GB) DDR2 PC2-8500C5 1066MHz Dual Channel (KHX8500D2K2/4G) @ £50.39 inc VAT
HyperX DDR2 modules are specifically engineered and designed to meet the rigorous requirements of PC enthusiasts. HyperX DDR2 offers faster speeds, lower latencies, higher data bandwidths and lower power consumption than DDR.
- Size: 4GB Kit (2x2GB)
- Speed: 1066MHz
- Timing: 5-5-5-15
- Format: 240-Pin DDR2 DIMM
- 2.1 Volts
- Lifetime Warranty
Was £69.98 Inc. VAT
Only £50.39 inc VAT.
ORDER NOW
Asus ATI Radeon HD 6990 4096MB PCI-Express Graphics Card with FREE Deus Ex PC Game @ £599.99 inc VAT
Designed for the power gamer, AMD Radeon HD 6990 graphics cards include AMD's second-generation, Microsoft DirectX 11 capable architecture, advanced image quality features for the best looking games, and AMD PowerTune intelligent technology to enable higher clock speeds and faster gaming. The AMD Radeon HD 6990 offers the ultimate in immersive HD gaming and computing with native support for up to five displays using AMD Eyefinity multi-display technology, with six display support possible via DisplayPort 1.2 components available for purchase later this year. The AMD Radeon HD 6990 graphics cards also feature a dual-BIOS toggle switch, allowing enthusiast gamers to unlock the card and rev up the clocks and voltages for even more performance. Finally, AMD HD3D technology provides a cutting-edge stereoscopic 3D gaming and movie experience, thanks to HDMI 1.4a support.
Features:-
- Core Clock: 830MHz (880MHz OC Mode)
- Memory: 4096MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: 320GB/sec
- Processing Cores: 3072
- Texture Units: 192
- ROPS: 64
- Bus Type: PCI-Express 2.1
- Display Connectors: 1 Dual-Link DVI & 4x Mini-Display Port (Adapters supplied to HDMI/DVI)
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 450W (Typical 400W)
- 2x 8pin PCI-E power connectors required
- 700W minimum PSU required (1000-1200W recommended for Crossfire with with four 8 Pin connectors)
- Warranty: 2 Years
- Deus Ex: Human Revolution FREE download code. Only on orders placed on 26/08/2011 onwards. Your code shall be emailed to you Wednesday 31st August onwards, please don't call or email us before this time.
Was £649.99 Inc. VAT
Only £599.99 inc VAT.
ORDER NOW
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card @ £199.99 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1 Dual Link DVI-I and 1 single link DVI-D, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 500W minimum PSU recommended
- Warranty: 2 Years
Was £205.99 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
OcUK ATI Radeon 6970 2048MB GDDR5 PCI-Express Graphics Card with FREE Deus Ex PC Game @ £257.99 inc VAT
The ATI Radeon HD 6970 uses a new GPU architecture from AMD which features dual graphics engines in one chip with 24 SIMD engines and a total of 1536 stream processors with 96 texture units, providing massively parallel computing power for graphics and other accelerated applications. Its core clock speed of 880MHz, together with a dedicated high speed interface to 2GB of GDDR5 memory running at 1375MHz (5.5Gb/s effective) delivers the highest performance in this series. New Tesselation engines bring up to three times the performance of the previous generation, and new Enhanced Quality AA and filtering modes bring the highest image quality ever achieved.
Features:-
- Core Clock: 880MHz
- Memory Clock: 5500MHz (Effective)
- Memory Bandwidth: 176GB/sec
- Processing Cores: 1536
- Texture Units: 96
- ROPS: 32
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- ATI Avivo HD
- 1x 8pin and 1x 6pin PCI-E power connectors required
- Warranty: 2 Years
- Supplied with Dirt3 PC Game (Subject to availability)
Was £269.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6950 TOXIC 2048MB GDDR5 PCI-Express Graphics Card @ £239.99 inc VAT
The SAPPHIRE HD 6950 TOXIC Edition ships with clock speeds of 880MHz for the core and 1300 MHz (5.2 Gb/sec effective) for the memory, making it the fastest production HD 6950 on the market. This has been achieved by building the card on a high specification PCB with digital VRMs for excellent power regulation and 8 + 6 pin power connectors. It has a high performance cooler featuring a Vapor Chamber, blower fan and a new perforated backplate to increase airflow out of the system case.
Features:-
- Memory Clock: 5200MHz (Effective)
- Texture Units: 88
- ROPS: 32
- Display Connectors: 1x Dual-Link DVI-I, 1x Single-Link DVI-D, 1x HDMI 1.4a, 2x Mini-DisplayPort & DisplayPort 1.2
- HDCP Capable
- ATI Avivo HD
- 2x 6pin PCI-E power connectors required (Power Adapters Provided)
- 450W minimum PSU recommended
- Warranty: 2 Years
Was £247.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6850 1024MB GDDR5 PCI-Express Graphics Card with DIRT3 & Deus Ex PC Games @ £107.99 inc VAT
Prepare to experience a riveting high-definition gaming experience with the ATI Radeon HD 6800 Series graphics processors. Expand your visual real estate across up to three displays and get lost in the action with revolutionary ATI Eyefinity Technology. Using ATI Stream technology, accelerate even the most demanding applications and do more than ever with your PC. The first to deliver full support for Microsoft DirectX 11, these GPUs enable rich, realistic visuals and explosive HD gaming performance so you can dominate the competition.
- Core Clock: 775MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Processing Cores: 960
- HDCP Capable
- OpenGL 3.2 Support
- ATI Avivo HD
- Warranty: 3 Years
- Supplied with DIRT3 Full PC Game download code (subject to availability)
Only £107.99 inc VAT.
ORDER NOW
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card @ £113.99 inc VAT
- Boost up to 50%* higher with MSI exclusive Voltage Tweak
- Core Clock: 860MHz
- Memory Clock: 4400MHz (Effective)
- HDCP Capable
- ATI Avivo HD
- Warranty: 3 Years
Was £124.99 Inc. VAT
ORDER NOW
Sapphire ATI Radeon HD 6870 1024MB GDDR5 PCI-Express Graphics Card @ £131.99 inc VAT
Immerse yourself with AMD Eyefinity technology and expand your games across multiple displays. Experience ultra-realistic visuals and explosive HD gaming performance in true ?EyeDefinition with AMD’s second generation graphics featuring full Microsoft DirectX® 11 support. Enable incredible video quality and enhanced application performance with AMD EyeSpeed visual acceleration technology.Get unrivalled graphics. Get Radeon™ in your system.
- Core Clock: 900MHz
- Memory Clock: 4200MHz (Effective)
- Memory Bandwidth: 135.6GB/s
- Processing Cores: 1120
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £139.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6870 Vapour-X 1024MB GDDR5 PCI-Express Graphics Card @ £137.99 inc VAT
The SAPPHIRE exclusive Vapor-X cooler ensures that the card runs quietly and efficiently. Together with other special hardware features including on-board 10-phase power control and SAPPHIRE’s highly efficient, cool running patented Black Diamond chokes this ensures there is a good margin for performance tuning (overclocking) by enthusiast users. SAPPHIRE’s overclocking tool for these models - TriXX - is available for users to download from the SAPPHIRE Select Club – free for SAPPHIRE enthusiasts to join online.
- Vapour-X Cooling solution - Capable of very high OC ability
- HDCP Capable
- ATI Avivo HD
- SAPPHIRE TriXX Utility
- Warranty: 2 Years
Only £137.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6770 1024MB GDDR5 PCI-Express Graphics Card @ £77.99 inc VAT
Now, more people than ever can experience real innovation in DirectX® 11 gaming with AMD Radeon™ HD 6770 Graphics. Expand your visual real estate across up to five displays and get lost in the action with AMD Eyefinity multi-display technology. Using AMD App Acceleration, speed up everyday applications and do more than ever with your PC. Loaded with advanced technologies, these GPUs have the power and premium features needed for fully immersive gameplay.
Features:-
- Core Clock: 850MHz
- Memory Clock: 4800MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 800
- Display Connectors: 1 Dual-Link DVI-I, 1 HDMI 1.4a & 1x DisplayPort
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
Was £89.99 Inc. VAT
Only £77.99 inc VAT.
ORDER NOW
Sapphire ATI Radeon HD 6570 Ultimate Edition 1024MB GDDR3 PCI-Express SILENT Graphics Card with FREE DIRT3 Game @ £59.99 inc VAT
The HD 6570 ULTIMATE from SAPPHIRE features a single slot low profile card with silent heatpipe cooler. With its 480 stream processors, engine clocks of 650MHz and 1GB of DDR3 memory clocked at 900MHz (1.8GHz effective) this is an ideal solution for HTPCs or general purpose PCs where silent operation is an advantage. Outputs are HDMI, DVI-D and VGA.
The AMD Radeon™ HD 6570 graphics processors offer advanced video and display features, as well as 2nd generation support for DirectX 11 to offer the ultimate in versatility for the everyday computing desktop.
Features
- Fanless Silent Design
- Core Clock: 650MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1800MHz (Effective)
- Processing Cores: 480
- Display Connectors: 1x Dual-Link DVI-I, 1x HDMI, 1x D-Sub
- HDCP Capable
- ATI Avivo HD
- Dimension 169(L) x 19(W)x94(H) mm Size.
- Warranty: 2 Years
Was £64.99 Inc. VAT
ORDER NOW
Sapphire ATI Radeon HD 6450 HM 512MB GDDR3 PCI-Express Graphics Card (11190-04-20G) @ £31.19 inc VAT
Packed with the latest GPU technologies, the Radeon™ HD 6450 graphics processor is a next-generation visual upgrade that delivers Eyefinity multi-display technology, HDMI 1.4a for stereoscopic (3D) displays, Displayport 1.2 as well as 2nd generation support for DirectX 11 for the most versatile solution for everyday computing.
- Core Clock: 625MHz
- Memory: 512MB GDDR3
- Memory Clock: 1334MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 160
- HDCP Capable
- ATI Avivo HD
- Dimension 146(L)x24(W)x94(H) mm Size.
- Warranty: 2 Years
Was £35.99 Inc. VAT
Only £31.19 inc VAT.
ORDER NOW
ATI Radeon HD 5450 SILENT 512MB GDDR3 PCI-Express Graphics Card **Lowest Price DX11 Graphics Card in UK** @ £19.98 inc VAT
The ATI Radeon™ HD 5450 graphics card offers everything you need for gaming and HD home entertainment in one package. Do more on your PC with ATI stream technology, which accelerates even the most demanding applications. See more with ATI Eyefinity technology, providing the ultimate gaming experience by allowing up to three displays from a single graphics board. The ATI Radeon™ HD 5450 fully supports Microsoft DirectX® 11 which enables real-time rendering with ultra-realistic characters and incredible 3D imagery.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
- Passive cooling design (SILENT)
- Memory Clock: 1066MHz (Effective)
- Display Connectors: 1 VGA, 1 Dual-Link DVI-I & 1 HDMI
- HDCP Capable
- ATI Avivo HD
- Excellent for Media playback
- Support DXVA & surround sound over HDMI
Was £22.99 Inc. VAT
ORDER NOW
OcUK Value GeForce GTX 590 3072MB GDDR5 PCI-Express Graphics Card @ £635.99 inc VAT
Introducing the new NVIDIA® GeForce® GTX 590 - the most powerful DirectX 11 graphics card ever built. With a sleek exterior that houses dual 512-core GTX 500 GPUs and a custom vapour chamber cooler, the GeForce GTX 590 delivers high-end performance with style. Hook up three monitors with GeForce GTX 590's three dual-link DVI ports to play your favourite games at ultra-wide resolutions like 5760x1080 in NVIDIA Surround. Plus get all the premium GTX gaming technologies such as NVIDIA® 3D Vision™, PhysX®, and Quad SLI® for the ultimate PC gaming experience.
- Graphics Engine: GeForce® GTX590
- Bus Standard: PCI Express® 2.0
- Video Memory: 3072MB GDDR5
- Engine Clock: 607 MHz
- CUDA Cores: 1024
- Memory Clock: 3414MHz (855MHz GDDR5)
- Memory Interface: 384 bit x 2
- DVI Max Resolution: 2560 * 1600
- DSub Max Resolution: 2048 * 1536
- D-sub Output: 1 x via DVI-to-D-Sub adapter
- DVI Output: 3 x Dual Link DVI-I Native
- HDMI Output: 1x HDMI via DVI-to-HDMI adapter
- Display Port Output: 1x Mini DisplayPort Native
- HDCP compliant: YES
- Dimensions: 11” x 4.5”
- 2yr Warranty
Was £699.98 Inc. VAT
Only £635.99 inc VAT.
ORDER NOW
Asus GeForce GTX 580 DirectCU II 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £383.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX580 DCII to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 782MHz (reference 772MHz), allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX580 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX580 DCII/2DIS/1536MD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Voltage Tweak Technology
- Super Alloy Power: Provides 15% performance increase, 2.5 times longer product lifespan and 350C cooler operation.
- Gamer OSD: Real-time overclocking, benchmarking and video capturing in any PC game!
- Splendid: Watching movies on PC is as good as on Top-of-the-line consumer television
- Core Clock: 782MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- The card size is 10.24" x 4.84" x 1.58" inch
- Supplied FREE with Batman: Arkham City FULL PC game (subject to availability. Game is launched on 21/10/2011 downloads previous to this date will be declined) (Only supplied with orders purchased after 07/09/2011)
Was £419.99 Inc. VAT
Only £383.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £455.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 772MHz (Fermi GF110)
- Memory: 3072MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 10 Years (Requires registration within 30 days with EVGA)
Was £469.99 Inc. VAT
Only £455.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 580 OC Special Edition 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £383.99 inc VAT
Features:-
- Core Clock: 795MHz (Fermi GF110)
- Shader Clock: 1590MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was £399.98 Inc. VAT
ORDER NOW
Gigabyte GeForce GTX 580 SOC 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £407.99 inc VAT
Features:-
- Core Clock: 855MHz (Fermi GF110)
- Memory Clock: 4100MHz (Effective)
- Shader Clock: 1710MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was £449.99 Inc. VAT
Only £407.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £359.99 inc VAT
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £379.99 Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £407.99 inc VAT
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Uprated quiet cooling solution
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was £439.99 Inc. VAT
ORDER NOW
Asus GeForce GTX 570 DirectCU II 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £251.99 inc VAT
Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan. Based on ASUS DirectCU architecture, which uses copper heat pipes in direct contact with the GPU to speed up heat dissipation for over 20% cooler performance, DirectCU II takes cooling further with twin 80mm fans for 600% airflow. Full throttle overclocking with exclusive ASUS Voltage Tweak via Smart Doctor – boosting 50%* more speed, performance and satisfaction! Advanced output option for all display types from one single output! Factory overclocked to perform at 742MHz, higher than stock performance, resulting in higher frame rates in games.
Features:-
- Core Clock: 742MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Shader Clock: 1464MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £274.99 Inc. VAT
Only £251.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 570 Classified 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £299.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- 6 Phase Digital PWM
- 10 Layer PCB
- Voltage read points
- Core Clock: 822MHz
- Memory Clock: 3902MHz (Effective)
- Shader Clock: 1644MHz
- DisplayPort 1.1a connector included
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 8pin + 6pin power connectors required
- Warranty: 10 years
Was £319.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 570 OC WINDFORCE 3X 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £257.99 inc VAT
Features:-
- Core Clock: 780MHz
- Shader Clock: 1690MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Dual-Link DVI-D & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £279.98 Inc. VAT
ORDER NOW
Gigabyte GeForce GTX 570 SOC WINDFORCE 3X 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £275.99 inc VAT
Features:-
- Core Clock: 845MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £299.99 Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £179.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £187.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
OcUK GeForce GT 430 1024MB GDDR3 PCI-Express Graphics Card @ £41.99 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 700MHz
- Memory Clock: 1600MHz (Effective)
- Shader Clock: 1400MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £53.99 Inc. VAT
ORDER NOW
MSI GeForce 8400GS 512MB SILENT GDDR3 "Low Profile" PCI-Express Graphics Card @ £20.39 inc VAT
co-development by MSI and Rivatuner, MSI releases the ultimate graphics card utility “Afterburner”. This utility enables all MSI graphics cards users to boost performance and to monitor all kinds of critical information in real-time. Afterburner is a completely free utility which is compatible with almost all MSI graphics cards.
MSI StarOSD is a very helpful utility for the avid PC gamers. Users can easily access the StarOSD to adjust the contrast, brightness, overclocking and temperature according to each user’s individual preference.
Note:Star OSD function that be used on different games has some difference cause the game different design.
MSI Live Update 4 is a single utility software that automatically checks BIOS, driver and utility updates and installs for you , which can save your time for searching and lower the risk while updating.
The HDCP provides a robust, cost-effective and transparent method for transmitting and receiving digital entertainment similar to DVI/HDMI-compliant digital displays. HDCP encrypts the date transmitted between the DVI/HDMI connector on the graphics adapter and the display.
MSI DOT Express Technology is the most advanced Dynamic Overclocking Technology Express enabling supreme overclocking, cooling and de-noise performance. It is an advanced overclocking engine, designed to deliver up to 10% extra performance and greatly enhances the synchronized GPU & DDR performance.
Dual-link DVI convertible output supports Video signal through DVI to HDMI interface, which drivers resolution of a digital display up to 1920x1200 or higher.
Both support the latest specifications of Blu-ray and HD DVD(High Definition DVD). It comes with the latest GPU and DDRIII superior processing performance in which users can easily enjoy the high-definition video of 1920x1080(1080p/i).
NVIDIA® CUDA™ technology is the world’s only C language environment that enables programmers and developers to write software to solve complex computational problems in a fraction of the time by tapping into the many-core parallel processing power of GPUs. With millions of CUDA™-capable GPUs already deployed, thousands of software programmers are already using the free CUDA™ software tools to accelerate applications—from video and audio encoding to oil and gas exploration, product design, medical imaging, and scientific research.
Was £25.99 Inc. VAT
Only £20.39 inc VAT.
ORDER NOW
MSI GeForce N210 1024MB GDDR3 "Low Profile" PCI-Express Graphics Card @ £22.79 inc VAT
Get all the video processing power that your digital lifestyle requires. Enhance photos, clean up home videos and post them to Facebook up to 50% faster with the GeForce 210. Convert your video and put it on your iPod in minutes instead of hours or make your DVDs look like HD. Does your PC have a CPU powerful enough to playback high definition Blu-Ray Movies? It doesn’t matter, the GeForce 210 can playback any Blu Ray Movie with any modern CPU.
- Core Clock: 589MHz
- Memory Clock: 1000MHz (Effective)
- Shader Clock: 1178MHz
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 2 Years
Was £29.99 Inc. VAT
Only £22.79 inc VAT.
ORDER NOW
OcUK GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card - OEM @ £131.99 inc VAT
Next-generation gaming has arrived. Nvidia GeForce GTX 470 gives your games an adrenaline shot with screaming fast performance and futuristic, visually stunning graphics. Experience heart pounding,
cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jaw dropping
stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 470: pure adrenaline meets visual bliss.
- Core Clock: 607MHz
- Memory Clock: 3348MHz (Effective)
- Processing Cores: 448
- Shader Clock: 1215MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 1yr Warranty with OcUK
- This is a refurbished fully functional product, it may have minor visual defects and is just a bare card, no cables, drivers etc.
Was £145.99 Inc. VAT
ORDER NOW
OcUK GeForce GTX 285 1024MB GDDR3 PCI-Express Graphics Card - OEM @ £113.99 inc VAT
- Core Clock: 648 MHz
- Processor Cores: 240
- Processor Clock: 1476 MHz
- Texture Fill Rate: 51.8 Billion/sec.
- On-board Frame Buffer: 1024MB GDDR3
- Memory Data Rate, effective: 2484 MHz
- Memory Interface: 512-bit
- Memory Bandwidth: 159 GB/sec.
- On-board Outputs: DVI-I and DVI-I
- Additional Outputs Supported: HDMI, VGA
- Bus Type: PCI Express 2.0
Was £129.98 Inc. VAT
ORDER NOW
OcUK GeForce GTX 260 V2 896MB GDDR3 PCI-Express Graphics Card - OEM @ £59.99 inc VAT
- Core Clock: 576 MHz
- Processor Cores: 216
- Processor Clock: 1242 MHz
- Texture Fill Rate: 41.5 Billion/sec.
- On-board Frame Buffer: 896MB GDDR3
- Memory Data Rate, effective: 1998 MHz
- Memory Interface: 448-bit
- Memory Bandwidth: 111.89 GB/sec.
Was £79.99 Inc. VAT
ORDER NOW
OcUK GeForce GTX 460 768MB GDDR5 PCI-Express Graphics Card - OEM @ £76.79 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 675 MHz
- Processor Cores: 336
- Processor Clock: 1350 MHz
- Texture Fill Rate: 37.8 Billion/sec.
- Memory Amount: 768MB GDDR5
- Memory Data Rate, effective: 3600 MHz
- On-board Outputs: DVI-I, DVI-I, and Mini HDMI
- Additional Outputs Supported: VGA
- Bus Type: PCI Express® 2.0
Was £85.99 Inc. VAT
Only £76.79 inc VAT.
ORDER NOW
OcUK GeForce 9800 GT 512MB GDDR3 PCI-Express Graphics Card - OEM @ £35.99 inc VAT
- Ideal for PhysX!
- Core Clock (MHz): 550 MHz
- Processor Cores: 112
- Processor Clock (MHz): 1375 MHz
- Fill Rate (billion pixels/sec.): 30.8
- Memory Amount: 512MB GDDR3 On-board Frame Buffer
- Memory Frequency (effective): 1800 MHz
- Memory Interface: 256-bit
- Memory Bandwidth (GB/sec): 57.6
- BUS Technology: PCI Express 2.0
Was £47.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Dell IN2020N 20" Widescreen LCD Monitor - Black @ £83.99 inc VAT
Enhance your multimedia experience with the IN2020 high-definition monitor with LED. This 20" widescreen display offers brilliantly vivid features at an even more brilliant price.
Highlights of the Dell 20" Wide IN2020N 5ms LED HD
* Enhance your multimedia view
* Environmental footprint
* Convenient comfort
* Great-value performance
Expand your productivity and multimedia performance with this 20" widescreen display, including LED backlight. With its 16:9 aspect ratio, 8,000,000:1 high dynamic contrast ratio and 1600 x 900 high-definition display, the IN2020 is excellent for viewing movies, photos and videos. Plus, you'll never skip a beat by adding the optional multimedia Dell soundbar for an enhanced audio experience.
The IN2020 monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, Energy Star 5.0, to help you lower energy consumption without sacrificing performance.
Convenient comfort
The IN2020 monitor is uniquely designed for comfort, convenience and visual appeal. With tilt adjustability, the IN2020 offers a versatile and comfortable view. The high-gloss slim black bezel complements both your home environment and your Dell desktop or laptop. Simply connect to any standard computer using the VGA connector.
The IN2020 monitor delivers a high dynamic contrast ratio of 8,000,000:1, vivid 1600 x 900 high-definition resolution, a fast response time and VGA connectivity, all at an affordable price.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 1000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 160°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- Dimensions: 453.7mm x 344.0mm x 204.8mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Was £89.99 Inc. VAT
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £131.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
ORDER NOW
IIyama Prolite E2274HDS 22" Widescreen LED Business Monitor - Black @ £134.39 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
LED-BACKLIT
FULL HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
SPEAKERS
HDMI
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
Specification
Screen Size - 22"
Response Time - 2ms
Height Adustable - No
Rotatable Screen - No
Built in Speakers - Yes
VGA Input - Yes
DVI-D Input - Yes
HDMI Input - Yes
LED Panel - Yes
Was £143.99 Inc. VAT
Only £134.39 inc VAT.
ORDER NOW
IIyama Prolite B2274HDS 22" Widescreen LED Business Monitor - Black @ £143.99 inc VAT
Iiyama's Business LED-backlit LCD, the ProLite B2274HDS follows full HD resolution of 1920 x 1080. It comes with Height Adjustable and Portrait Mode base providing the greatest comfort in use . High specifications include 2msec Response Time and 5M : 1 Advanced Contrast Ratio for vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs! And VESA mount compliance means you can easily mount your monitor to a wall.
LED-Backlit:
Full HD:
ACR:
Speakers:
HDMI:
OverDrive ON / OFF:
VESA:
Height Adjustable Stand:
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
Pivot:
Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
Was £167.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £199.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was £219.98 Inc. VAT
ORDER NOW
Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black @ £269.99 inc VAT
BenQ, proudly announced the release of their 23.6” (16:9 Aspect Ratio) LED Gaming Monitor XL2410T. BenQ understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. In order to achieve this goal, BenQ co-worked with ZOWIE, a professional Gaming gear manufacturer. BenQ have ZOWIE’s gamer teams join in during the product development and testing stages. With their assistance, XL2410T can truly be a professional LED gaming monitor – with a set of Gaming Display Modes which includes the FPS mode (First Person Shooting), co-developed by two legendary Counter-Strike players – Emil “HeatoN” Christensen and Abdisamad “SpawN” Mohamed.
Every serious gamer know that lag will cause you to lose a game; XL2410T is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. XL2410T has a fast refresh rate of 120Hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms GTG (OverDrive) meaning users can see the edge of the enemies clearly and without motion blur, and Dynamic Contrast Ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with BenQ’s gaming tuning technology becomes a huge advantage for gamers.
XL2410T has a smart design, for one purpose – to win. The monitor has two hotkeys available; the first changes the display mode: Full; Aspect; Overscan; 1:1; 17”; 19”; 19” Widescreen and 22” Widescreen. Whereas the second hotkey is Smart Scaling, which lets the users adjust picture size in original input to the screen’s limit. Together with Display Mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. From BenQ’s Gaming Display Modes options, users can choose from FPS Mode, made possible by co-working with the gaming heroes -HeatoN and Spawn as the best setting for personal shooting games, or from the two User Game modes for more dedicated and personalized settings.
For extreme entertainment, XL2410T is the LED monitor to go for. 3D-ready (NVIDIA 3D Vision certified); Picture by Picture (PBP); connectivity values (D-sub; DVI-D-DL, HDMI) and height adjustment feature are offered for users’ enjoyment and comfort. Picture by picture (PBP) is a feature that enables users to show two programs side-by-side on the screen. Feel like camping once in a while for fun? Watch a movie while you do it!
- LED Backlit
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 10000000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 6.0kg
- Height adjustable stand / Swivel 45/45 left/right
- Warranty: 2 Years On-Site
Was £284.99 Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor - Black @ £143.99 inc VAT
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Screen Size: 24" Widescreen
- Contrast Ratio: 60000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £194.39 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Contrast Ratio: 20,000,000:1
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- VESA Compliant
Was £209.99 Inc. VAT
Only £194.39 inc VAT.
ORDER NOW
Asus VE276Q 27" Widescreen LCD Multimedia Monitor - Black @ £215.99 inc VAT
VE276Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Be captivated by stunning images with ASUS Smart Contrast Ratio (ASCR) technology that boosts the display´s contrast ratio to an astonishing 100,000:1. AI Light function enables the VE276Q automatically adjusting to lower brightness and make your eyes feel more comfortable in the dim environment. Furthermore, it helps save more 25% power consumption. Embedded digital HDMI and DisplayPort inputs, VE276Q enables the most advanced graphic cards/ computers connection. The DisplayPort interface also offers better support of multiple display streams, longer cable connection, and interoperability with other inputs, such as VGA, DVI and HDMI. Need to research on the Internet, but a championship game is about to start on TV? The VE276Q offers PIP(Picture in Picture) function(via hotkey) and has the capability to display images of two different signals at the same time. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 27.0"(68.6cm) 16:9 Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 100000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Skin-Tone Selection : 3 Modes
- HDCP support
- Audio Features Stereo Speakers : 3W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DisplayPort,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Power Consumption Power Consumption < 70 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 643x445.6x220mm
- Box Dimension(WxHxD): 732x560x176mm
- Weight Net Weight (Esti.): 7.2 kg
- Gross Weight (Esti.): 10.5 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, EK, J-MOSS, Taiwan Green Mark,RoHS, WEEE, WHQL
Was £229.99 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey @ £1,019.99 inc VAT
Experience amazing wide-angle viewing and color consistency with the DellTM UltraSharpTM U3011 30"W Monitor with PremierColor. Extensive connectivity features and customization via CustomColor mode make the U3011 an ideal choice for professionals in CAD/CAM, graphic design, gaming and other fields where color precision matters.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (CIE 1976) color gamut with excellent AdobeRGB and sRGB coverage for rich, lifelike visuals
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 100,000:1 Contrast Ratio
- 7ms Response Time (7ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- Two DVI-D Input with HDCP support
- Two HDMI Input
- One Display Port Input
- One Analogue Input
- Component Connectors
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Was £1,049.99 Inc. VAT
Only £1,019.99 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £239.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 15000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
Was £249.98 Inc. VAT
ORDER NOW
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Monitor - Black @ £359.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality. Video content bypasses scalers making the HZ27WC ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 1000:1 / 1,000,000:1 (Dynamic)
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x Dual Link DVI-D
- 2.5mm Audio out
- Kensignton Security Port
- 8bits [16.7Million colors]
- Dual Link DVI-D Cable, 2.5mm Audio Cable, 24V External Power Adapter, UK
- PIP/POP, Mapping: Not Supported
- Only available to customers in the United Kingdom
- 3yr RTB Warranty (UK customer only)
ORDER NOW
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Glass Monitor - Black @ £491.99 inc VAT
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
These monitors use a glass coating on the front which results in much sharper images quality, more vibrant colours and an overall better viewing experience. The downfalls of glass fronted panel is the monitor weighs a lot more and the manufacturing process can lead to dust particles been trapped between the panel and the glass which can sometimes be spotted when up very close to the screen and with certain solid coloured backgrounds.
Features:-
- Glass front panel for improved image quality
- 1 x DisplayPort
- 2 x HDMI
- 1 x Dual Link DVI-D [HDCP Supported]
- 1 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- 10bits [1.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
Was £559.99 Inc. VAT
Only £491.99 inc VAT.
ORDER NOW
IIyama Prolite X2775HDS 27" Widescreen LED Monitor - Black @ £239.99 inc VAT
The ProLite X2775HDS is the latest addition to the range of monitors featuring VA Panel technology which offers superb colour performance and viewing angles. This sophisticated technology provides 24 bit 'True Colour and superior black and white display performance. A 3000:1 Native Contrast Ratio means the ProLite X2775HDS is ideal for Photographic Design and Web-design. Featuring a fast response time, full HD 1920 x 1080 resolution with VGA, DVI and HDMI connectivity, this screen is compatible with a wide range of systems and applications and is also a Low Power LED Panel, making it an excellent choice for Universities, Corporate, Financial and Design Markets.
VA matrix offers 24-bit true colour which assures realistic colour reproduction. VA technology offers also higher contrast, darker blacks and much better viewing angles than standard TN technology.
Features:-
- Diagonal: 27"
- Panel: VA, LED-backlit
- Display area h x w: 336.2 x 597.6 mm; 13.2" x 23.5"
- Response time: 8 ms
- Contrast: 3000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 16.7 million
- Pixel pitch h x v: 0.3113 x 0.3113 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate Sync
- Aspect ratio: 16 : 9
- Analog input connector: D-Sub
- Digital input connector: DVI-D, HDMI
- HDCP: yes
- Dimensions w x h x d: 642 x 438.5 (507.5) x 210 mm
- Weight: 6 kg
- Warranty: 3 Year On-Site
ORDER NOW
Dell Inspiron 1011 Intel Atom N270 1.60GHz 10.1" LED, Mini Netbook (Obsidian Black) - Windows 7 @ £167.99 inc VAT
Timing is everything, and now you can have all the time in the world. The newly designed Inspiron Mini 10 offers up to 8.5 hours of battery life to keep you on the go. This Dell Inspiron Mini Netbook features a 160GB hard drive, plenty of room to store all your photos and music. It also features a webcam so you can communicate with friends or family from miles away, or use it to take images of yourself to upload on to the net. If you're looking for a small, lightweight, great quality Netbook for general web browsing, emailing and keeping your photos safe then the popular Dell Mini Inspiron Netbook is for you!
- Intel Atom N270 1.60GHz Pineview Processor
- Display: Built-in 10.1" WSVGA TrueLife widescreen display (1024 x 600)
- 1GB RAM
- 160GB Hard Drive
- 3 in 1 Card Reader
- 3 Cell Battery
- 3x USB2.0
- Windows 7 Starter
- 12 Months Warranty (Brand new sealed product)
Was £179.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I7-740QM, 6GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red **£50 CASHBACK** @ £983.99 inc VAT
nonl2br
<img src="http://www.msimobile.com/img-overview/GX660/Topbanner.jpg" height="480" width="768" alt="GX660" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>• The latest Intel Quad Core i7-740QM 1.73GHz Processor</b><br>
• Genuine Windows 7 Home Premium<br>
• DTS Surround Sensation UltraPC<br>
• Exclusive TDE Technology<br>
• 16:9 Full HD LED Display<br>
• High-end ATi Radeon HD 5870M graphics<br>
• HDMI (High-Definition Multimedia Interface) Output<br>
• Built-in HD Webcam<br>
• 802.11 b/g/ n Wireless LAN with Bluetooth<br>
<br>
<br>
<font size="4"><font color="Blue"><b>New Level of Sound and Performance</b></font></font><br>
<font size="4"><b>MSI + Dynaudio = New Standard of Gaming Notebook</b></font><br>
<br>
<b>Dynaudio Premium Sound Technology</b><br>
<br>
The complex and interconnected elements that comprise excellent sound were painstakingly identified one by one to ascertain how to systematically develop the proper notebook technologies. After undergoing a very long process of cooperative development, Dynaudio and MSI have come up with the GX660. The four directions used to develop Dynaudio Premium Sound Technology are summarized below. For serious gamers who demand extreme audio performance, the GX660 is the best and only choice!<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/speaker-1.jpg" align="centre" alt="GX660" /><br>
<br>
<b>Speaker Placement</b><br>
<br>
In the past, limited space on notebooks meant speaker position was always considered last, which resulted in muddled sound in notebook speakers. Because of this, speaker position was considered during the initial stages of the GX660's development to facilitate optimum audio performance and to avoid sacrificing audio quality for incorrect speaker placement.<br>
<br>
<b>EQ Tuning: Adjusted for Optimization of All Types of Sounds</b><br>
<br>
Different types of music represent distinct requirements for sound ambience. Jazz, pop, rock, or classical all possess special characteristics that affect computer game and movie sound performance and each has specific tone balance requirements. To express different types of music authentically, Dynaudio and MSI spent over 1,200 hours of continuous, repetitive testing and fine tuning of high, mid, and low range frequencies so authentic reproduction of different types of music can be achieved.<br>
<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/inteli7" align="right" alt="" />
<font size="4"><font color="Blue"><b>Choose The Best!</b></font></font><br>
<br>
<b>Powerful Hardware Under the Hood Deliver Enhanced Horsepower and Blazing Speed</b><br>
The GX660 includes the world’s most advanced Intel® Core™ i7 quad core processor, which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br><img src="http://www.msimobile.com/img-overview/GX660/turbo.jpg" align="left" height="300" width="373" alt="GX660" /><br>
<br>
<br>
<b>Accelerated CPU Performance MSI’s Exclusive TDE Technology</b><br>
<br>
By overclocking the CPU and memory frequency, the TDE Technology brings more calculating speed to enhance the system performance. It benefits the video decoding/ encoding, gaming and art work designing. With MSI TDE Technology, you can experience fast-response time and efficient real-time data processing.<br>
<br>
<br>
<b>Exclusive Cooler Boost Technology</b><br>
Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GX660's core temperature variations and fan speed.<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><font color="Blue"><b>Marvel At The Most Amazing Images Around</b></font></font><br>
<b>The ATI Radeon™ HD 5870 Graphics (with GDDR5 1GB VRAM)</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gx660/gx660_05.jpg" align="centre" alt="GX660" /><br>
The 1GB GDDR5 internal memory and the ATi Radeon™ HD 5870 graphics card provide a high-definition gaming experience that puts you right in the middle of the action sequences. Delivering full support for Microsoft DirectX® 11, the GPU enables richer and true-to-life graphics performance so that you can enjoy immersive games or movies.<br>
<br>
<b>16:9 Full HD* LED Backlit Display</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt660/gx660_hd.jpg" align="centre" alt="GX660"/><br>
The 15.6” Full HD screen of the GX660 delivers more details of the high definition content; brings you more pleasure while playing games or watching movies.<br>
<br>
<font size="4"><b>Specifications</b></font><br>
<br>
<b>CPU</b> Intel Core™ i7-740QM 1.73GHz Processor <br>
<b>OS</b> Genuine Windows 7 Home Premium <br>
<b>Chipset</b> Intel PM55 <br>
<b>Memory</b> 6GB DDR3 1066 MHz<br>
<b>LCD Size</b> 15.6" FHD 1920*1080 TFT-LCD Display (LED Backlight) <br>
<b>Graphics</b> ATi Mobility Radeon HD 5870M <br>
<b>Graphics</b> VRAM GDDR5 1GB <br>
<b>HDD</b> 2x500GB in RAID 0 SATA <br>
<b>Optical Drive</b> Super-Multi DVDRW<br>
<b>Audio</b> 2 Theater Class Speakers +1 Subwoofer <br>
<br>
- HD Webcam <br>
- Card Reader XD/SD/MMC/MS <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth V2.0EDR <br>
- D-Sub (VGA)<br>
- HDMI<br>
- 2x USB 2.0 port <br>
- 2x USB 3.0 port <br>
- eSATA <br>
- 120W AC Adapter<br>
- 9 cell Battery<br>
- £50 Cashback MSI Promotion, see:- http://www.overclockers.co.uk/LP/msi_summer_cashback.php
Only £983.99 inc VAT.
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I5-480M, 8GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,103.99 inc VAT
nonl2br
<br>
<Br>
<br>
<b>• The latest Intel Core i5-480M 2.66GHz Processor</b><br>
• Blu-Ray Drive for True HD Movie Playback<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
The GX660 includes the world’s most advanced Intel® Core™ i5 quad core processor (Hyperthreading), which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<b>CPU</b> Intel Core™ i5-480M 2.66GHz Processor <br>
<b>Memory</b> 8GB DDR3 1066 MHz<br>
<b>Optical Drive</b> Blu-Ray Drive<br>
<br>
- HD Webcam <br>
- D-Sub (VGA)<br>
- HDMI<br>
- eSATA <br>
Was £1,149.00 Inc. VAT
Only £1,103.99 inc VAT.
ORDER NOW
MSI GT683 15.6" WLED TFT Intel I7-2630QM, 8GB DDR3, 1.5tb HDD, NVIDIA GTX 570M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Back/Red @ £1,314.00 inc VAT
What do gamers desire most? MSI knows best! In GT683, MSI not only conducted research with the world-class team Fnatic, but also collaborated with SteelSeries, a leading manufacturer of professional gaming peripherals, to develop a “gamer’s keyboard” never before seen in gaming notebooks. GT683 provides you the best gaming experience!
GT683 has a 15.6 inch Full HD screen, which projects a vibrant visual effect. The latest top-end NVIDIA Geforce GTX570M graphic card with 1.5GB GRDDR5 memory gives the notebook an extraordinary gaming performance. GT683 is fully compatible with DX11, which provides an ultra-smooth and vivid three-dimensional visual experience.
In order to present the best sound effects, the GT683 speakers are uniquely configured. Besides the two side speakers projected toward the user, there is also a subwoofer sound hole at the bottom. This configuration immerses gamers into a realistic, three-dimensional battlefield experience.
Features:-
- Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- The Latest 2nd Generation Intel® Core™ i7 Processor
- High-end NVIDIA® GeForce GTX 570M discrete graphics card(with GDDR5 1.5GB VRAM) provides great detail images quality
- Dual SATA hard drives with RAID0 to double the transmission speed
- Exclusive TDE technology to speed up the performance
- Sound by Dynaudio for extreme audio performance
- Exclusive DDR3 SO-DIMM x 4 slot design easily upgrades memory capacity
- THX TruStudio Pro provides excellent surround sound
- Latest & fastest data transfer technology USB 3.0
Specification:-
- CPU Intel® Core™ i7-2630QM Processor (6M Cache, 2.00 GHz)
- OS Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- Chipset Intel HM67
- 8GB Memory DDR3 1333 MHz ,Slot : 4
- LCD Size 15.6" Full HD 1920x1080 resolution
- Graphics nVidia GeForce GTX 570M
- Graphics VRAM 1.5GB GDDR5
- HDD: 1.5TB (2x 750GB in RAID 0) (7200rpm)
- Optical Drive: DVD Super Multi
- Audio 2.1 channels speakers, Sound by Dynaudio, THX TruStudio Pro, 7.1ch output
- Webcam HD type (30fps@720p)
- Card Reader SD(XC/HC)/MMC/MS(PRO)/xD
- LAN 10/100/1000
- Bluetooth Bluetooth v3.0 + HS
- D-Sub (VGA) 1
- HDMI 1 (v1.4)
- USB 2.0 port 3
- USB 3.0 port 2
- eSATA 1
- eSATA/USB Combo N/A
- Mic-in/Headphone-out 1/1
- Line-in 1(line in)/1(line out)
- Express Card N/A
- Modem port N/A
- Keyboard 102-key keyboard by SteelSeries
- Sensor N/A
- AC Adapter 180W
- Battery 9 cells
- Power Management Turbo Battery+
- Weight (KG) 3.2
- 2yr Warranty
Was £1,349.99 Inc. VAT
Only £1,314.00 inc VAT.
ORDER NOW
MSI GT780DXR-290UK 17.3" WLED TFT Intel I7-2670QM, 8GB DDR3, 1.5tb HDD, NVIDIA GTX 570M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Back/Red @ £1,379.99 inc VAT
What do gamers desire most? MSI knows best! In GT780DX, MSI not only conducted research with the world-class team Fnatic, but also collaborated with SteelSeries, a leading manufacturer of professional gaming peripherals, to develop a “gamer’s keyboard” never before seen in gaming notebooks. GT780DX provides you the best gaming experience!
GT780DX has a 17-inch Full HD screen, which projects a vibrant visual effect. The latest top-end NVIDIA Geforce GTX570M graphic card with 1.5GB GRDDR5 memory gives the notebook an extraordinary gaming performance. GT780DX is fully compatible with DX11, which provides an ultra-smooth and vivid three-dimensional visual experience.
In order to present the best sound effects, the GT780DX speakers are uniquely configured. Besides the two side speakers projected toward the user, there is also a subwoofer sound hole at the bottom. This configuration immerses gamers into a realistic, three-dimensional battlefield experience.
The exterior design of the GT780DX combines the classic, succinct appearance of a limousine with the aerodynamic contour of a spacecraft creating a low-key composure but powerful image. The black casing of the GT780DX is specially covered with brushed aluminum, coupled with the silver msi logo, it makes the GT780DX a symbol of the coexistence of textural quality and ultimate performance.
To avoid accidentally touching the touch pad while gaming, the GT780DX is equipped with a control switch for the touch pad on the side of the keyboard
Features:-
- Best gaming keyboard designed by SteelSeries
Specification:-
- CPU Intel® Core™ i7-2670QM Processor (6M Cache, 2.20 GHz)
- LCD Size 17.3" Full HD (1920x1080) LED backlight
- Optical Drive Blu-ray / DVD Super Multi
- LAN 10/100/1000
- D-Sub (VGA) 1
- HDMI 1 (v1.4)
- USB 2.0 port 3
- USB 3.0 port 2
- eSATA 1
- Express Card N/A
- Modem port N/A
- Sensor N/A
- AC Adapter 180W
- Battery 9 cells
- Dimension 428 x 288 x 55mm(WxDxH)
- Weight (KG) 3.9
- UK Model does *NOT* have backlit keyboard
- UK Model comes with FREE Dirt 3 PC Game
- 2yr Warranty
Was £1,499.99 Inc. VAT
Only £1,379.99 inc VAT.
ORDER NOW
OCZ Vertex 2 50GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTX50G) @ £59.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 50GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £64.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Corsair Force Series 3 60GB SATA 6Gb/s Solid State Drive (CSSD-F60GB3A-BK) @ £79.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 60GB Capacity
- Sequential read speeds of up to 525 MB/s
- Sequential write speeds of up to 490 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
- 2.5" - 3.5" Adaptor Included.
Was £82.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
OcUK Professional 2.5" to 3.5" SSD Adaptor Plate - Black @ £3.98 inc VAT
The OcUK Professional 2.5" to 3.5" Hard Drive Adapter offers a simple solution for mounting 2.5" SSDs/Hard Drives within a 3.5" drive bay.
- Aluminium 3.5" Bracket
- Easily add a 2.5" SATA hard drive to your 3.5" slot on your PC
Was £4.79 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
Crucial RealSSD M4 512GB 2.5" SATA 6Gb/s Solid State Hard Drive @ £569.99 inc VAT
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Our products are built on decades of design and manufacturing expertise. It is our expertise in NAND technology that enables us to optimize the performance and endurance necessary to build quality solid-state storage devices.
- Sequential Read (up to): 415MB/sec (SATA 6Gb/s) - 550MB/sec with firmware 0009
- Sequential Write (up to): 260MB/sec (SATA 6Gb/s) - 300MB/sec with firmware 0009
- Random 4k Read: 40,000 IOPS
- Random 4k Write: 50,000 IOPS
- PCMark Vantage: 65K HDD Test Score
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Seek Time: .1ms
- Slim 2.5" Design
- 100.5 x 69.85 x 9.5mm
- Lightweight: 75g
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Low Power Consumption: 150 mW in operation, .85 mW in standby
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.2 million hours
- Limited 3-Year Warranty
** FIRMWARE UPDATE 0009 - Increased speeds up to 550MB/s **
Link to Frimware: - http://www.crucial.com/support/firmware.aspx
Was £599.99 Inc. VAT
Only £569.99 inc VAT.
ORDER NOW
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £127.99 inc VAT
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- RAID Support
** FIRMWARE ISSUE FREE **
Was £139.99 Inc. VAT
Only £127.99 inc VAT.
ORDER NOW
Kingston HyperX 120GB 2.5" SATA-3 Solid State Drive @ £179.99 inc VAT
The all new Kingston HyperX performance SSD featuring the Sandforce SF-2281 controller for blistering fast reads and writes and industry leading IOPS.
- 95k IOPS
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 555MB/sec
- Maximum Write: 510MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File, READ)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- Warranty: 3 Years
Was £188.99 Inc. VAT
ORDER NOW
Kingston HyperX 240GB 2.5" SATA-3 Solid State Drive @ £349.99 inc VAT
- 95k IOPS
- Capacity: 240GB
- Warranty: 3 Years
Was £389.99 Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £163.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br>
<br>
- Capacity: 120GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 550MB/sec<br>
- Maximum Write: 500MB/sec<br>
- Sustained Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- 2.5" to 3.5" SSD adaptor included<br>
- Warranty: 3 Years<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/CKMODN3kIpE" frameborder="0" allowfullscreen></iframe>
Was £172.99 Inc. VAT
Only £163.99 inc VAT.
ORDER NOW
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-240G) @ £349.99 inc VAT
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br><br>
- Capacity: 240GB<br>
- Maximum Write: 520MB/sec<br>
- Sustained Write: 520MB/sec<br>
<br>
ORDER NOW
OCZ Vertex 3 MAX IOPS 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3MI-25SAT3-120G ) @ £204.98 inc VAT
<br>
- Max I/O Per Second (IOPS): 75000 IOPS (4KB File)<br>
<br>
Was £210.98 Inc. VAT
Only £204.98 inc VAT.
ORDER NOW
OcUK Value 32GB USB Drive Black @ £22.99 inc VAT
OcUK Value PinStripe 32GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
- Push and pull sliding feature
- Enhanced for Windows ReadyBoost
- Includes EasyLock Password Protection Software Trial
- Compatible with Windows 2000, XP, Vista & Windows 7
- Compatible with Mac OS 9 or higher & Linux 2.4.0 or higher
With ports in almost every computer and popping up in cars, DVD and Multimedia players, TV's, Photo Frames and many more, USB drives are now being considered an essential accessory.
Was £26.99 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
OcUK Value 16GB USB Drive Black @ £13.99 inc VAT
OcUK Value PinStripe 16GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £15.98 Inc. VAT
Only £13.99 inc VAT.
ORDER NOW
OcUK Value 8GB USB Drive Black @ £7.99 inc VAT
OcUK Value PinStripe 8GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £8.99 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
OcUK Value 4GB USB Drive Black @ £3.98 inc VAT
OcUK Value PinStripe 4GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £4.49 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
Kingston DataTraveler 101 Generation 2 4GB USB 2.0 Flash Drive (DT101G2/4GB) @ £4.79 inc VAT
The Kingston DataTraveler 101 Generation 2 (G2) is here! This convenient storage companion lets you take all of your data to your home, office, school and anywhere you travel. Now with urDrive, it gives you a better way to look at your data while combining cool features to make it your own. It’s like having a customisable, portable desktop – anywhere. Sleek, practical and attractively designed, the DataTraveler 101 G2 serves the needs of the budget-conscious user as well as those looking for significant storage capacity in a lightweight, compact swivel design in fun colours by capacity.
- Capacity: 4GB
- Dimensions - 57.18mm x 10.00mm x 17.28mm
- Simple - just plug into a USB port
- Handy - compact size
- 5-Year warranty
Was £5.99 Inc. VAT
Only £4.79 inc VAT.
ORDER NOW
Kingston 4GB SDHC Class 4 Flash Card (SD4/4GB) @ £4.39 inc VAT
Kingston Technology's Secure Digital High-Capacity (SDHC) memory cards are fully compliant with the new Secure Digital Association 2.00 specification. They are a new performance class of SD memory cards designed to meet the storage demands of high-quality digital still and video cameras and other high-resolution image recording devices.
- Capacity: 4GB
- Data Transfer Speed Class: 4
- Lifetime Warranty
Was £4.99 Inc. VAT
Only £4.39 inc VAT.
ORDER NOW
Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System - 232 Watts RMS @ £179.99 inc VAT
nonl2br
Since you have only one PC speaker system, you don’t want to make sacrifices. That’s why Corsair has created the SP2500.<br>
At its heart are six Class D amplifiers driven by an ultra-efficient power supply. The 8” subwoofer driver is housed in a fourthorder bypass enclosure for clean, tight bass response that can seriously shake the room. The bi-amplified satellites use specially developed 3” drivers and custom-designed, ferrofluid-cooled 1” silk dome tweeters for detailed audio reproduction across the entire spectrum with great stereo imaging and a generous sweet spot. A programmable digital signal processor lets you craft the audio to your liking. It’s all under your command with the 1.8” (4.6cm) color display desktop controller.
<br>
- 232 Watts RMS of continuous power delivery through six Class D amplifiers <br>
- 8” subwoofer with durable rubber surround in a fourth-order bandpass enclosure <br>
- Bi-amplified satellites with 3” drivers and 1” ferrofluid-cooled silk dome tweeters <br>
- Clean, high-fidelity audio reproduction with excellent stereo imaging <br>
- Programmable digital signal processor for advanced dynamic audio processing <br>
- Wired desktop controller with 1.8” (4.6cm) color TFT display and multi-lingual interface<br>
<br>
Specification:<br>
- Frequency response of 35Hz – 20kHz +- 3dB<br>
- 232 Watts of total power (measured via FTC “RMS” method)<br>
- Subwoofer: 18.1” x 10.2” x 11.7” (46 x 25.8 x 29.7cm) enclosure with fourth-order bandpass design for accurate bass reproduction<br>
- Subwoofer: 8” subwoofer driver with durable rubber surround<br>
- Subwoofer: Bridged dual 60 Watt class-D amplifiers with integrated DSP for 120W of power (measured via FTC “RMS” method)<br>
- Subwoofer: Ultra-efficient integral power supply with 100V – 240V AC input<br>
- Satellites: Bi-amplified, two-way design with detachable audio cables<br>
- Satellites: 3” midrange drivers<br>
- Satellites: 1” custom-designed, ferrofluid-cooled silk dome tweeters<br>
- Satellites: 4.25” x 4.7” x 6.25” (10.8 x 12 x 15.9cm) enclosures with asymmetrical tweeter placement for superior stereo imaging<br>
- I/O, Controls, and Programming: PC input on subwoofer<br>
- I/O, Controls, and Programming: Dual 3.5mm auxiliary inputs (one on subwoofer, one on desktop controller)<br>
- I/O, Controls, and Programming: 3.5mm headphone out with digital signal processing<br>
- I/O, Controls, and Programming: Wired desktop controller with 1.8” (4.6cm) color display and multi-lingual interface<br>
- I/O, Controls, and Programming: Digital signal processor with active crossover capability<br>
- I/O, Controls, and Programming: Mod X™ theatrical audio processing for Blu-Ray and DVD audio that recreates the theatre experience<br>
- I/O, Controls, and Programming: Dynamic DSP programs and EQ curves for late night listening, environment simulation, and optimal enjoyment of games, movies, and music<br>
- Package Contents: x1 subwoofer, x2 satellites, x1 desktop controller with 6’ (1.8M) cable, 3.5mm to stereo RCA cable for PC input, 6’ (1.8m) satellite cables with ATX connectors, Power cable, User Guide<br>
- Retail box dimensions: 22.75in L x 19.75in W x 15.75in H (57.8cm x 50cm x 40cm)<br>
- Weight: 30.75 lb (13.9 kg)<br>
<br>
<CENTER><iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/VOo686QhINc" frameborder="0" allowfullscreen></iframe></CENTER>
<br>
Was £188.98 Inc. VAT
ORDER NOW
Corsair Gaming Audio Series SP2200 2.1 PC Speaker System - 46 Watts RMS @ £39.98 inc VAT
The SP2200 is designed for gamers and media enthusiasts who want a powerful, compact 2.1 speaker system that doesn’t take a lot of space. 46 Watts of total power (measured via the FTC “RMS” method), with 30 Watts dedicated to the 6” subwoofer, ensure room-shaking bass and clean, crisp audio reproduction at any volume level. Excellent stereo imaging with a generous “sweet spot” ensure a competitive advantage in games and realistic music and movie audio.
The SP2200 is easy to set up, and easy to use. Controls are up front where you need them, and flexible connection options allow you to connect up to three audio sources at once.
- 46 Watts RMS continuous power delivery for room-filling sound and clean, crisp audio reproduction
- 30 Watt subwoofer with 6” driver for serious bass performance
- Compact satellites with 3” drivers provide detailed audio reproduction without taking lots of desk space
- Excellent stereo imaging with a generous “sweet spot”
Specifications:
- Frequency response of 40Hz – 20kHz +/5 5dB, -10dB @ 35Hz
- 46 Watts total power (measured via FTC “RMS” method)
- Subwoofer: 6” (15.24cm) side-firing, ported subwoofer suitable for desk or floor placement
- Subwoofer: 30 Watts (measured via FTC “RMS” method)
- Subwoofer: Subwoofer enclosure dimensions: 9.1” x 9.9” x 7.1” (23.1cm x 25.2cm x 18cm)
- Satellites: 2” (5cm) drivers
- Satellites: Volume and subwoofer output controls integrated in right satellite
- Satellites: Up-front auxiliary input and headphone output
- Satellites: 8 Watts per satellite (measured via FTC “RMS” method)
- Satellites: Satellite enclosure dimensions: 5” x 3.6” x 5.6” (12.7cm x 9.1cm x 14.2cm)
- Satellites: PC input on subwoofer
- I/O and Controls: Three inputs for maximum flexibility: 3.5mm stereo PC input, RCA stereo auxiliary input for gaming consoles, and a 3.5mm stereo auxiliary input on the right satellite for MP3 players
- I/O and Controls: 3.5mm headphone output
- I/O and Controls: Main volume and subwoofer output control dials on the right satellite
- Package Contents: x1 subwoofer, x2 satellites, Power cable, User Guide
- Retail box dimensions: 12.8” L x 11.5” W x 11” H (32.5cm L x 29.3cm W x 28cm H)
- Weight: 11.17 lb (5 kg)
Was £49.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Logitech S-220 2.1 Speaker System - OEM (980-000022) @ £15.98 inc VAT
Logitech S-220 Speaker System provides the rich acoustics with a high-quality subwoofer and two satellite speakers. A high-performance piano-finish wired remote provides the convenient access of volume and power controls, besides, its headphone jack and microphone jack give you more valuable usages, e.g. private listening, internet video gaming and conferecing.
- High class glossy satellite speakers with the ported subwoofer provides the full and rich audio performance
- Friendly wired control pod designed for minimizing the desk clutter
- The convenient wired control pod provides headphone jack, microphone jack, volume and power controls for adjustment easily
- Easy connection to PCs, CD and MP3 players and between satellite speakers and subwoofer
Was £21.98 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
Edifier R1600T Studio Plus 2.0 Monitors @ £61.99 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
** boxes opened to include UK power connector, 100% new **
Was £69.98 Inc. VAT
Only £61.99 inc VAT.
ORDER NOW
Philips SPA2602 5.1 Surround Sound Speaker System @ £32.99 inc VAT
Perfect for MP3, PC, TV and more.
Connect your speakers to all your gear. A great way to listen to your MP3 player, PC, TV, CD, DVD and all your multimedia stuff.
Sound
- Bass enhancement: Analogue Bass Boost, Bass reflex
- Frequency response: 35 - 20 K Hz
- Loudspeaker Enhancement: Magnetic Shielded LSB
- Music Power: 90 W
- Volume Control: Analogue Volume Control
- Wires: Fixed Wires
- Output power (RMS): 45 W
Loudspeakers
- Satellite speaker drivers: 3"
- Subwoofer driver: 4.25"
Connectivity
- Audio input for data: Stereo Audio (3.5 mm jack) 1 x
- Cable length: 1.5 m
- Connector: 3.5 mm stereo
Was £34.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 140mm Fan @ £11.99 inc VAT
When developing the new generation of our housing-fan series SilentWingsUSC, two things were of particular importance to us: that they should run extremely quietly and at the same time achieve optimum airflow - an extremely tricky challenge.
And with the newly developed Ultra Silent Concept (USC), we have mastered this challenge. The USC comprises, amongst other things, two Innovations from be quiet! protected by german utility patent. In addition, the housing fan has a remarkable lifespan of almost 300,000 hours.
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 120mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Screwless anti-vibration fixtures and rubberised fan frame protected by german utility patent
- Quiet operation thanks to the reduction of vibrations and simple installation without tools
- Minimisation of electrical noises at a constantly high running smoothness
- Fan Speed: 1000 RPM
- Air Flow: 60.4 or 102.7 CFM
- Noise Levels: 16.5 dBA
- 3 Pin Molex
- 3 Year Warranty
Was £16.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Creative Inspire A520 5.1 Speaker System (51MF4110AA008) @ £44.99 inc VAT
Give your games, music and movies a much-needed boost with the Creative A520 5.1 speaker system. Given their contemporary style and ease of use, they are the perfect choice for immersive multi-channel surround sound, bringing to you all the benefits of Creative’s leadership in audio technology. The five satellites make use of the two-inch drivers for crisp dialogue and impressive effects, while the large subwoofer with a flared port tube and separate bass control provides you with the freedom to adjust your bass level and deliver the extra impact and oomph for all of your entertainment needs. The system also includes a wired remote for easy-to-reach and convenient control.
- Speaker Power: 5Watts RMS per channel (5 channels)
- Subwoofer: 12Watts RMS
- Frequency Response: 40Hz ~ 20kHz
- Signal-to-Noise Ratio (SNR): 75dB
- Product Weight: 3.5 kg
- Dimensions (HxWxD): Speaker (144x80x104)mm, Subwoofer (235x192x192) mm
Was £47.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Intel Core i7 990X 3.46GHz (Gulftown) Extreme Edition (Socket LGA1366) - Retail @ £767.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Frequency: 3.46GHz
- Multiplier: 26x
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
- Includes Heatsink & Thermal Paste
- 3yr Warranty.
Was £799.99 Inc. VAT
Only £767.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £233.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £254.99 Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £245.99 inc VAT
- Cores: 4
- Threads: 8
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £259.99 Inc. VAT
Only £245.99 inc VAT.
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £257.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
Was £274.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
LEPA Convertible iPad Flip Case/Stand @ £4.98 inc VAT
The LEPA iPad Flip Leather Cover Case offers maximum protection and functionality. It features a durable, stylish and streamlined leather design.
- Convertible flip book case offers maximum protection and functionality
- Multiple angle settings for enhanced viewing and using your iPad
- Durable, stylish, and streamlined leather design
- Single piece design for ease-of-use
- Supports vertical and horizontal viewing
- Custom made for a perfect fit on all iPad and iPad 3G
- Matieral: PU Leather
- Dimensions: 250 x 195 x 18mm
- Weight 296g
Was £9.98 Inc. VAT
Only £4.98 inc VAT.
ORDER NOW
Boogie Bug AimB.Pad XL Gaming Mouse Surface @ £10.98 inc VAT
The AimB.Pad has been especially designed for gamers looking for precision, fluidity and the perfect harmony between slide and friction. This XL version also represents an essential tool for graphics designers, architects and other users looking for precision and wide movements. Its surface has been made with flexible textile material that not only assures fluidity and precision in the movements, but also allows the AimB.Pad to be folded, rolled up and transported.
- Dimensions: 450mm x 900mm
Was £16.99 Inc. VAT
Only £10.98 inc VAT.
ORDER NOW
Cooler Master HAF X Gaming Tower Case - Black (RC-942) @ £124.98 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Base Mounted PSU Bracket
Was £134.99 Inc. VAT
Only £124.98 inc VAT.
ORDER NOW
Corsair Obsidian 650D Gaming Midi Tower - Black @ £134.99 inc VAT
nonl2br
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.<br><br>
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.<br><br>
- Motherboard Support: ATX / mATX<br>
- Expansion Slots: 8<br>
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6<br>
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans<br>
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller<br>
- Dual 200mm fans provide outstanding cooling for even the hottest components<br>
- Easily accessible dust filters make maintenance simple and hassle-free<br>
- Quick-release side panels make it easier than ever to upgrade your hardware<br>
- Integrated fan controller lets you quickly adjust cooling performance and noise levels<br>
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion<br>
- CPU backplate cutout makes it easy to upgrade your CPU cooler<br>
- Brilliant cable routing system provides a way to keep your system neat and tidy<br>
- Adjustable drive cages can be removed and relocated to accommodate large video cards<br>
- Room for long power supplies gives you peace of mind for future upgrades<br>
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)<br>
<br>
<CENTER>
<IMG SRC="http://www.ocia.net/images/goldseal.gif" width="150" height="150"/>
<IMG SRC="http://techgage.com/reviews/award.jpg" width="150" height="150"/>
</CENTER>
Only £134.99 inc VAT.
ORDER NOW
NZXT Phantom Enthusiast Full Tower Case - Red/White @ £104.99 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Was £114.98 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Silverstone Raven 3 RV03B-W Full Tower Windowed Case - Black/Gold @ £109.98 inc VAT
The RAVEN team’s continued push to redefine and perfect the enthusiast tower chassis has resulted in yet another benchmark in the RAVEN RV03. With world-class cooling performance from the previous RAVEN chassis models retained by the included 180mm Air Penetrator fans, a rethinking of the interior layout enabled dramatic reduction in overall depth of the chassis compared to RAVEN RV02 while still matching RAVEN RV01’s ability to accommodate Extended ATX motherboard and graphics cards longer than 13 inches. Cable management was also improved with a new 5cm thick hard drive compartment to allow nearly all cables to be connected behind the motherboard tray with ease. An unconventional power supply compartment located in the lower front part of the chassis further add to facilitate cable routing so anyone can assemble a pristine looking system with maximum airflow efficiency.
Complementing the finely tuned and engineered interior, the RV03 has Champaign colored trimmings adorning an exterior with aggressive lines yet reserved profile. The stand out styling also fully utilizes the chassis’s powerful cooling ability to full effect by a set of smartly designed, dual-purpose front bezels that helps to keep the RV03 looking sharp and uniform whether the user is setting up for maximum air cooling or for a silencing build.
As a trend-setter and a computer chassis engineering showcase, the RAVEN RV03 has few equals. However, its advanced features are equally accessible that anyone from experienced enthusiasts to novice users will find easy to appreciate and utilize, making RV03 the most appealing RAVEN chassis yet!
- Revolutionary 90 degree motherboard mounting from RAVEN RV01
- Includes two Air Penetrator 180mm fans for superb performance and quietness
- Support up to seven 120mm fans for exceptional cooling flexibility
- Motherboard back plate opening behind CPU area for quick cooler assembly
- Supports Extended ATX motherboard
- Supports eight expansion slots and graphics cards of any length
- Mandatory cable management design for clean looking system on every build
- Hard drive compartment with independent cooling zone
- Upscale and aggressive styling with dual-purpose front panel bezels
- 7 x 5.25" Drive Bays
- 10 x 3.5" Drive Bays
- 2 x 2.5" Drive Bays
- Front I/O Ports: 2 x USB3.0 & 2 x Audio
- Front Cooling: 4 x 120mm Fan (optional)
- Rear Cooling: 1 x 120mm Fan (optional)
- Side Cooling: 1 x 120mm Fan (optional)
- Top Cooling: 1 x 120mm Fan (900RPM @ 18dBA)
- Bottom Cooling: 2 x 180mm Fans (700 or 1200 RPM @ 18 or 34dBA) or 3 x 120mm Fans (optional)
- Max CPU Cooler height: 163mm
- Dimensions: 235 x 522 x 570mm
- Max GPU lenght: 13.58"
Was £119.99 Inc. VAT
Only £109.98 inc VAT.
ORDER NOW
Xigmatek Asgard III Windowed Gaming Case - Black @ £32.99 inc VAT
"Asgard-III" - The Property of Æsir and castle of Odin. As the country of Gods, the inviolable Asgard-III is the world’s first black coating entry-level chassis - milestone. Furthermore this chassis is supplied with 1 x 120mm preinstalled black fan, and 3 more fans can be mounted in different areas for best possible airflow. 4 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5” HDDs are available so you can feel free by "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for pc beginners.
- Screw-less tooling for 5.25” bay installation.
- Screw-less tooling for expansion slot installation.
- Screw-less tooling for 3.5” bay installation.
- Preinstalled 120mm front fan
- Supports 4 cooling fans in total.
- Back window for easy CPU cooler back plate.
- Dust filter behind front panel for intake airflow.
- Dimension: 185(W) x 475(D) x 408(H) mm, 0.6mm thickness SGCC.
- Drive Bay: 5.25” External x 3 (Tool-free)
- 3.5” External x 2 (Tool-free)
- 3.5” Internal x 5 (Tool-free)
- Expansion Slot: 7 slots (tool-free), 290mm free add-on card length.
- Front Fan: 80/90/120mm x 1 fan is available.
- Rear Fan: Preinstalled 120mm black fan x 1 (80/90mm fan is available)
- Side Fan: 80/90/120mm x 2 fans are available.
Was £35.99 Inc. VAT
ORDER NOW
Logitech G700 Wireless Gaming Mouse (910-001759) @ £61.98 inc VAT
The Logitech® Wireless Gaming Mouse G700 keeps you comfortable, in control and deep into your game. Its 13 programmable G-Keys can be used to perform single actions or complex macros with a single click. The natural curves fit your hand for epic levels of comfort, so you can keep at it for as long as you want. And its full-speed wireless connection gives you gaming-grade performance coupled with wireless freedom. It comes with a quick-connect cable that charges your mouse and can transmit data over the cable. When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character. Logitech® SetPoint™ software required for initial setup and is available at logitech.com/downloads.
- 13 individually sculpted, programmable G-Keys let you perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined keys and repeating. No matter what your game, you'll get deep into it. You have the control you need to play better. To conquer more. To win.
- With natural curves that fit your hand, you get epic levels of comfort, while smooth-gliding feet let you manoeuvre effortlessly. You'll play comfortably, without distraction, for as long as you want.
- Full-speed wireless (1,000 reports per second) helps eliminate lag so you enjoy gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
- A quick-connect cable for recharging and data transfer lets you plug in fast and continue your campaign without pause. You'll never run out of power. And you'll always have a backup for reliable connectivity.
- You get a mouse that's crafted just for gaming. The gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you store up to five profiles*. And the dual-mode scroll wheel can switch from click-to-click for weapon selection to free spinning for hyper-fast scrolling.
Was £64.99 Inc. VAT
Only £61.98 inc VAT.
ORDER NOW
Gigabyte M8600 6500DPI Wireless Gaming Mouse @ £69.98 inc VAT
Aivia M8600 Wireless Macro Gaming Mouse has long lasting battery that guarantee 100-hour nonstop gaming experience. QSBS™ (quick swap battery changing system) technology is GIGABYTE's unique design. This patent pending technology allows for Instant battery changing under 2 seconds, as fast as gun clip loading and unloading.
Aivia M8600 Wireless Macro Gaming Mouse comes with an instant charging dock, served as mouse and Li-ion batter charger as well as wireless receiver unit. This device helps you enjoy gaming with wireless transmission speed at 1000Hz polling rate. The powerful wireless reception ensures no signal is lost that every single move made by the mouse is read during game playing.
Aivia M8600 Wireless Macro Gaming Mouse features twin-eye gaming-grade laser engine. Based on advanced laser technology, the twin-eye gaming sensor features high precision, low power, and ultra-fast performance.
When Aivia M8600 Wireless Macro Gaming Mouse is connected to its complimentary wire, it is able to edit GIGABYTE's GHOST™ Macro Engine. GHOST™ Macro Engine is an incredible macro editing software for the memorized macros to be carried around even if the mouse is connected to a different computer. 32KB onboard memory enables up to 5 programmable profile settings. The engine features critically acclaimed easy-to-use drag-and-drop operating system, DPI switching, tilt-wheel speed adjustment, and customizable color hues as profile indicators.
- GamePlay™ Wireless Technology- over 50hrs battery life in game play
- Quick-swap battery system- instant battery changing under 2secs, as fast as gun clip loading
- 32KB onboard memory enables up to 5 programmable profile settings
- Dual mode wired/ wireless functionality-switch between the wireless freedom and the frenzy of wired play
- Advanced GHOST™ Macro Engine
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Logitech G9x Laser Mouse (910-001153) @ £43.98 inc VAT
The Logitech® G9x Laser Mouse offers more customisable features than any other gaming mouse, so you can tune for the way you play. Interchangeable grips let you choose a fit and feel that’s best for your playing style (includes XL and Precision grips). The next-generation gaming laser gives you game-changing precision at any hand speed. And on-the-fly adjustable dpi from 200 to 5000 dpi. Onboard memory lets you program up to five ready-to-play profiles (for keyboard macros, dpi settings and LED colours). The weight-tuning system gives you up to 28 g of extra weight. And the custom-colour LEDs let you match your mouse to your style.
- Interchangeable grips
- Up to 5000 DPI
- Next-generation gaming laser
- Onboard memory
- Weight-tuning system
- Custom-colour LEDs
Was £46.99 Inc. VAT
Only £43.98 inc VAT.
ORDER NOW
Logitech G400 3600DPI Gaming Mouse (910-002279) @ £26.99 inc VAT
Set your sights on victory. With a high-precision optical engine, the G400 gives you consistent tracking and precise aiming no matter how fast you move your hand.
Instant access to four dpi levels lets you shift from pixel-precise targeting to lightning-fast maneuvers. A sculpted comfort grip, low-friction feet and eight programmable buttons keep you comfortable and in command.
You've got the upper hand with precision targeting and pinpoint accuracy. Your mouse communicates over USB at a blazing-fast 1000 reports per second - as fast as USB can go, and eight times faster than standard USB mice.
- Weight: 133 g
- Connectivity Technology: USB
- Movement Detection Technology: Optical
- Buttons Qty: 8
- Movement Resolution: 3600 dpi
- Performance: 1 ms response time, 5.8 megapixels per second, realtime sensitivity switching 400 - 3600 dpi, 25 G maximum acceleration
- Features: Programmable buttons, sensitivity adjustment, polytetrafluoroethylene (PTFE) feet
- Cables Included: 1 x USB cable - integrated
- 3 years warranty
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Logitech G500 Gaming Mouse (910-001262) @ £39.98 inc VAT
The Logitech Gaming Mouse G500. Your weapon of choice for precision and control. Gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you save and take your settings for your favourite title with you. Weight tuning gives you up to 27 grams of extra weight for personalised feel and control. Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection. On-the-fly adjustable dpi gives you the right level of precision, from pixel-precise targeting (200 dpi) to lightning-fast manoeuvres (up to 5700 dpi), for whatever game you're playing. And ten programmable buttons put valuable macros in your hand.
- Gaming-grade laser gives you game-changing precision at any hand speed.
- Onboard memory lets you save and take your settings for your favourite title with you. No software required.
- Weight tuning gives you up to 27 grams of extra weight for personalised feel and control.
- Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection when you're gaming. Or switch to frictionless hyper-fast scrolling to fly through long Web pages when the boss is looking
- On-the-fly adjustable dpi up to 5700
- Ten programmable buttons put valuable macros in your hand
Was £42.98 Inc. VAT
ORDER NOW
Roccat Apuri USB Hub with Mouse Bungee @ £20.99 inc VAT
nonl2br
The first component of the ROCCAT™ Smart Desktop Management System (SDMS) offers you the perfect combination of style and functionality right there on your desktop. The Apuri won’t just power your USB devices; among other things it’ll also bring new order to your desktop by taking control of your mouse cable.<br><br>
USB PORTS ALWAYS WITHIN REACH
The Apuri combines stability and practically in the way it takes over the job of managing your devices and cables on the desktop. The Apuri’s AC adapter delivers sufficient power to supply its USB ports with up to 2A each – allowing you to connect up to four USB devices without the need for additional power supplies. And if you don’t want to use the AC adapter, you can simply power the hub using the supplied USB cable.<br><br>
500mA per port is then available in passive use – perfect for cell phones, cameras and other devices which don’t require their own separate AC adapter. The Apuri allows you to connect everything so it’s within reach, saving you the hassle of crawling around under the desk looking for ports and from the untidiness of cables hanging over the edge of the desk.<br><br>
SMOOTH GAMING
Thanks to the flexible mouse bungee, the mouse cable in particular is optimally catered for. It is simply guided away from the mouse’s gliding area so that it doesn’t get in the way during game play. There won’t be any rubbing on the desktop or snagging of the cable on the edge of the desk to interfere with your gaming experience – you can even adjust the length of the cable to suit, and the flexible arm optimally flexes with your movements.<br><br>
You’ll feel as if you’re using a wireless mouse, without the inherent disadvantages such as increased weight, sudden need to change batteries or long charging times. If you don’t want to use the mouse bungee, it can simply be detached from the hub. .<br><br>
STYLE AND ATMOSPHERE
Contrary to many conventional hubs, which live out their existence as boring boxes, the ROCCAT™ Apuri adds style to your desktop. The unique tripod design gives the Apuri stability even during tense gaming situations. The design fits perfectly with ROCCAT’s new ‘stealth’ style series. Beveled edges and futuristic lines give the hub a unique look. The top features three ice blue LEDs while the base boasts an illuminated ROCCAT logo, which will cast an atmospheric aura onto your desktop. <br><br>
- 4 high-speed USB 2.0 ports<br>
- Output power active (using AC adapter): 2A each<br>
- Output power passive (using USB cable): 500mA each<br>
- Length of USB cable: 1.5m<br>
- Length of power cable: 1.5m<br>
- Detachable Mouse bungee<br>
- 3 LEDs (top) + underlighting<br>
- Stable tripod design<br><br>
<iframe width="640" height="390" src="http://www.youtube.com/embed/e1y49Fi4AXk" frameborder="0" allowfullscreen></iframe>
Was £22.99 Inc. VAT
Only £20.99 inc VAT.
ORDER NOW
Logitech G19 Gaming Keyboard (920-000978) @ £99.98 inc VAT
When you’re gearing up for battle, you never compromise. Not on your team, not on your weapons, and certainly not on your hardware. If you take your gameplay seriously, you want the Logitech® G19 on your side.
- Tiltable, colour GamePanel™ LCD: The (320x240) display shows unprecedented levels of information, both in and out-of-game, including game stats, system information, VOIP communication data, video playback, image slideshows, and many other items.
- User-selectable backlit characters: Personalize the keyboard to better fit with the rest of your computer and gaming equipment, and easily locate keys - even in the dark.
- Twelve fully programmable G-keys with three macros per key: Program up to 36 single keypresses or complex macros; use the MR key to record new macros on-the-fly.
- Multi-key input: Use up to five keys at once to perform multiple complex actions.
- Game/desktop mode: Disable the Windows/Context Menu keys so they won’t interrupt your game if pressed accidentally.
- Two powered Hi-Speed USB 2.0 ports: Transfer data to and from peripherals, such as MP3 players and flash drives - while also charging battery-powered devices.
- Intelligent cable management: Keep mouse, headset, and other cords out of the way by routing them through channels on the underside of the keyboard.
- Instant media access: Use the convenient one-touch controls for volume and media playback.
Was £109.99 Inc. VAT
Only £99.98 inc VAT.
ORDER NOW
Mionix Zibal 60 Mechanical Gaming Keyboard @ £139.98 inc VAT
The Mionix Zibal 60 is a fusion of the best keyboard components together with great gaming features that gives you the edge to your game. Engineered with non-tactile, mechanical, black cherry MX switches that deliver the best feel to every keystroke. Multi-level backlight illumination paired with six key rollover that allows you to perform up to six simultaneous keystrokes with all keys, make the Zibal 60 standout from the crowd. In addition to the performance features, the Zibal 60 offers smart functions that include a two port usb 2.0 hub, audio/mic extensions and media control keys for full integration with your desktop setup.
- Black Cherry MX Mechanical key switches
Mechanical non-tactile Cherry MX black switches with 18K Gold plated switch connectors ensures durability and longer life time.
- Comfortable design
Designed with a detachable wrist rest to be comfortable throughout long gaming sessions.
- Backlit key illumination
Every switch is fitted with a single green LED and you can choose from the three different lighting modes.
- Three lighting modes On, Off and WASD
Select between the three lighting modes On, Off and WASD.
- Multi-level brightness control
Three level adjustable brightness control.
- Mionix Action key
The Mionix Action key provides instant access to all the media and illumination functions.
- Six Key Rollover
Register up to six keystrokes simultaneously.
- Rage proof durability
Fends off rage blasts thanks to the 1.6 mm thick steel frame and heavy duty braided cable.
- Built to last
Lifespan of 50 million keystrokes and wear resistant laser printed keycaps
- Connect-through port for audio
Superior audio quality thanks to the insulated shielded cables
- Full speed USB 2.0 hub
Inbuilt with a two port USB 2.0 hub powered by its own USB cable.
- Plug n Play
Complete Plug n Play, all functions can be performed without any software or drivers.
Was £149.99 Inc. VAT
Only £139.98 inc VAT.
ORDER NOW
Asus VG236HE 23" TRUE 120Hz 3D Widescreen LCD Monitor - Black @ £199.99 inc VAT
Enter an immersive three dimensional Full HD 1080p world of games and movies with the VG236HE. Through the use of market-leading 3D technology and active shutter glasses, it instantly takes you into another dimension - transforming your gaming experience to 3D. There are hundreds of popular PC game titles currently compatible with the NVIDIA 3D Vision kit (not included).
- Tilt and Swivel also Height Adjustable.
- Screen Size: 23" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 100000:1
- Response Time: 2ms
- Viewing Angles: (H/V): 170*/160*
- Colours: 16.7 Million
- Inputs : 1 x DVI-D & 1 x HDMI
- Weight: 7kg
- 3 Years Warranty
Was £249.98 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
NVIDIA 3D Vision Kit with Duke Nukem Forever @ £107.99 inc VAT
Upgrade your PC to a fully immersive stereoscopic 3D experience with Nvidia GeForce 3D Vision. A combination of high-tech wireless glasses and advanced software, GeForce 3D Vision automatically transforms hundreds of PC games into full stereoscopic 3D. Just slip on the stylish glasses and pair them with an Nvidia GeForce GPU and a "GeForce 3D Vision-Ready" display to experience characters and environments come to life on the screen. In addition, you can watch 3D movies and 3D digital photographs in eye popping, crystal-clear quality. Give your eyes something to talk about with GeForce 3D Vision. Requires 120Hz Monitor.
- Convert standard games into stereoscopic 3D
- Highest quality stereoscopic 3D solution
- Designed for comfort and style
- Wear over your prescription glasses
- High power wireless infrared communication
- Game for more than forty hours on a single charge
- Adjust 3D depth adjustment from the IR emitter
- Watch movies in 3D
- Stereoscopic 3D picture support
- Supplied with Duke Nukem Forever Full Game Download
NOTE: Requires 120Hz Monitor
NOTE: Requires Nvidia GeForce 8800 GTX or above Graphics Card
Was £113.99 Inc. VAT
Only £107.99 inc VAT.
ORDER NOW
Antec Tri-Cool 3-Speed 120mm Fan - Black @ £2.59 inc VAT
No matter what type of fan you're looking for, the Antec TriCool line offers reliable, stable performance. Available in 80, 92, and 120mm, TriCool fans offer the perfect balance of silence and efficiency. TriCool fans feature a 3-speed switch so you can find the ideal equilibrium of quiet and cooling.
- 3-speed switch lets you balance quiet performance with maximum cooling
- 4-pin power connectors provide convenient connections to your motherboard or power supply
- Fan-speed monitoring capability included (requires compatible motherboard)
Was £3.98 Inc. VAT
Only £2.59 inc VAT.
ORDER NOW
Akasa AK-191-BL Blue Ultra Quiet 120mm Fan - 3 Pin @ £4.99 inc VAT
Near silent 12 cm fan with distinctive Emperor Blue coloured rotor blades and crystal clear frame. Designed with low air impedance blades providing the ultra quiet acoustic experience.
- Dim: 120 x 120 x 25mm
- Rated speed: 1400 RPM
- Sound: 18.0 dB(A)
- Air flow: 49.74 CFM
- Bearing: Sleeve Bearing
- Life expentancy: 30,000/ hrs
Was £5.99 Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Akasa AK-FN059 120mm Ultra Quiet Venom Viper Cool Fan - 3/4 Pin @ £11.99 inc VAT
High performance 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Viper fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. Killer Viper yellow colour makes this fan distinctive and unique.
- High performance 12cm fan in killer VIPER yellow colour
- S-FLOW fan blade design delivers 30% higher airflow
- Super silent with PWM auto speed control
- Hydro Dynamic Bearing extends fan life up to 50,000 hours
- Dimension: 120 X 120 X 25mm
- Fan speed: 600 -1900 RPM
- Max airflow: 83.63 CFM (141.75 m3/h)
- Max static air pressure: 2.98 mm H2O
- Noise level: 6.9 -28.9 dB(A)
- Fan life expectancy: 50,000 hours
- Connector: 4pin PWM
Was £13.99 Inc. VAT
ORDER NOW
Akasa AK-274CB-4BLS 120mm Blue LED Fan @ £8.99 inc VAT
This is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The Cool Blue look is achieved by four hi-bright blue LED complemented with crystal blue frame and blades.
- Application PC Case fan
- Frame dimension 120 x 120 x 25mm
- Fan speed 1200 RPM
- Fan airflow 38.4 CFM
- Fan air pressure 1.17 mm H20
- Fan life expectancy 20000/hrs 25ºC
- Bearing type Sleeve Bearing
- Connector 3-pin with RPM sensor wire
- Voltage rating 12V
- Current rating 0.15 A
- Noise level 17.5 dB(A)
- Product code AK-274CB-4BLS
Was £11.22 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM @ £11.99 inc VAT
Super silent 12cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum. The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction. IP54 military standard ensures the fan is dust and moisture resistant. It’s powerful, quiet and tough!
- Super silent APACHE fans in Black Stealth colour
- IP-54 military standard moisture and dust protection
- Dimension 120 X 120 X 25mm
- Bearing HDB (Hydro Dynamic Bearing)
- Speed 600 -1300 RPM
- Max airflow 57.53 CFM (97.74 m3/h)
- Sound level 6.9 -16.05 dB(A)
- Max static air pressure 26.40 mm-H2O
- Rated voltage 12V
- Connector PWM-4pin
Was £13.99 Inc. VAT
ORDER NOW
Akasa AK-FN057 Apache Super Silent 120mm Fan - 4 Pin PWM @ £8.99 inc VAT
PWM is a widely available feature on all current Intel and AMD platform based motherboards. It is more accurate than voltage regulation, energy saving and a fully automatic way of controlling the fan speed. PWM provides ultra quiet acoustics during normal PC use and high performance cooling under high system load. The Optional Akasa AK-CB002 cable adapter can provide the system with two additional PWM connectors if needed.
- Super silent APACHE fans in camouflage colours
- Rated voltage 12V
Was £9.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Akasa AK-274CG-4GNS 120mm Green LED Fan @ £5.99 inc VAT
his is an ultra quiet 12cm case fan delivering high air volumes with an incredible acoustic performance of only 17.5dB(A). The bright Green illumination is achieved by four hi-bright green LED complemented with a crystal green frame and blades.
- Product code AK-274CG-4GNS
Was £6.98 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 120mm Fan @ £9.98 inc VAT
- Fan Speed: 1500 RPM
- Air Flow: 50.5CFM
- Noise Levels: 17 dBA
- 3 Pin Molex
- 3 Year Warranty
Was £14.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Coolermaster 120mm Fan - Black @ £1.99 inc VAT
Case cooling is becoming more essential these days. The better airflow inside your system, the cooler and more stable system you will get. This fan provides Silent operation and higher air flow to enhance cooling performance.
- Dimension (W / H / D): 120x120x25mm
- Speed (R.P.M.): 1200 R.P.M. ± 10%
- Air Flow (CFM): 44.03 CFM ± 10%
- Air pressure (mmH2O): 1.83 mm H2O ± 10%
- Fan Noise Level (dB-A): 19.8 dBA
- Weight: 120g
- Bearing Type: Sleeve
- Fan Life Expectancy: 30,000 hours
- Connector: 4 pin
- Cable Length: 300mm
Was £2.99 Inc. VAT
Only £1.99 inc VAT.
ORDER NOW
DeepCool UF-120 Ultra Silent 120mm Fan with Anti-vibration TPE Cover @ £8.99 inc VAT
- Strong plastic frame with soft and elastic TPE cover to absorb vibrations
- Special fan blade design to offer a unique visual effect when operating
- Two ball bearing to offer smooth rotation and long lifetime
- Super silent and big airflow
- Overall Dimension: 120 x 120 x 26mm
- Net Weight: 172g
- Bearing Type: Ball Bearing
- Rated Voltage: 12 VDC
- Operating Voltage: 10.8 to 13.2 VDC
- Started Voltage: 7 VDC
- Rated Current: 0.13 ±10% A (MAX)
- Power Input: 1.56W
- Fan Speed: 500 RPM ±200 to 1500 ±10%
- Max Air Flow: 66.3 CFM
- Noise Level: 17.6 to 27.8 dB(A)
- Warranty: 24 months
- EAN barcode: 6933412704157
Was £12.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 80mm Fan @ £9.98 inc VAT
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 80-mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Fan Speed: 2000 RPM
- Air Flow: 26.0 or 44.20 CFM
- Noise Levels: 15 dBA
- 3 Pin Molex
- 3 Year Warranty
Was £11.99 Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
Akasa AK-FN062 Apache Black Super Silent 140mm Fan - 4 Pin PWM @ £12.98 inc VAT
Super silent 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
The Apache fan creates more focused airflow providing blind-spot cooling, which makes it an ideal solution for a case or heatsink fan. HDB (Hydro Dynamic) bearings extend fan life and further enhance noise reduction.It’s powerful and quiet!
- Super silent APACHE BLACK 14cm fan
- Super silent with PWM speed control
- Application: PC case or heatsink fan
- Dimension: 140 X 140 X 25mm
- Fan speed: 600 -1300 RPM
- Max airflow: 89.55 CFM
- Max static air pressure: 2.76 mm H2O
- Noise level: 12.5 -22.19 dB(A)
- Voltage rating: 12V DC
- Bearing: HDB (Hydro Dynamic Bearing)
- Product code: AK-FN062
Was £14.99 Inc. VAT
Only £12.98 inc VAT.
ORDER NOW
Akasa AK-FN063 140mm Ultra Quiet Viper Cool Fan - 3/4 Pin @ £12.98 inc VAT
High performance 14cm fan with S-FLOW blades supplying 30% more airflow than a standard fan at the same speed. The greater performance combined with PWM automatic speed control allows the fan noise to be kept to a minimum.
- High performance 14cm fan in killer VIPER yellow colour
- Fan speed: 600 -1600 RPM
- Max airflow: 110.61 CFM
- Max static air pressure: 3.12 mm H2O
- Noise level: 12.5 - 26.01 dB(A)
- Product code: AK-FN063
Was £14.99 Inc. VAT
ORDER NOW
BitFenix Spectre 140mm Fan - White @ £7.99 inc VAT
Introducing the Spectre™ Non-LED Fan Series from BitFenix. Engineered for both silent operation and maximum airflow, Spectre will keep your entire system well ventilated without making it sound like an airplane hanger. Spectre Fans are designed with sickle fan blades, which enhance airflow without producing excess noise. Fluid dynamic bearings reduce friction for long life and quiet operation, while an attractive matte finish gives your entire system a look that's second to none.
- Dimensions (mm): 140 x 25
- Current (A): 0.10
- Speed (RPM): 800-1000
- Air Flow (CFM): 60
- Noise (dB-A): 18
- Air Pressure (mmH2O): 1.93
Was £9.98 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Lamptron FC6 5.25" Bay Fan Controller - Black @ £27.98 inc VAT
The FC6 fan controller is a great alternative to those other boring fan controllers with single color displays. Control your fans in style of your choice of 7 different colors. It is designed specifically for today's mainstream fans and features a "up to 20 watts per channel" design.
- Dimentions: 5.25" bay
- Power Output: Up to 20w per Channel
- Face Plate Color Available: Black Anodized/Silver Aluminium
- DC Input: +12v (Standard 4-Pin Connector)
- DC Output: 0-12v
- Changeable Display Color: Red, Yellow, Green, Cyan, Blue, Purple, White
- Control Channels: 4
- CNC milled face plate from blocks of 3/4" thick solid aluminium
- Bring out that full aesthetic appeal you always wanted in the 5.25 inch Bay
- Four knobs to control four 3pin channels
- User's choice of displaying Celsius or Fahrenheit for the bottom line readout
Was £29.99 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
mCubed HFX 113 T-Balancer BigNG Cooling Controller @ £49.99 inc VAT
The T-Balancer bigNG is the first 4-channel controller for air and watercooling with patented Dual Mode Technology (DMT). You can choose whether you want to power each channel analog or with PWM. The T-Balancer bigNG delivers pure analog voltage up to 20W per channel (40W with PWM). This way you can even connect water pumps or Peltiers. An integrated heatsink ensures a cool running. The bigNG will be delivered by standard with four thin analogue sensors and two precise digital sensors. Due to the high absolute accuracy of the digital sensors you can calibrate the rest of your system to it. Using all available extension you can control all together ten analogue sensors, eight digital sensors and two flowmeters. Mounting is very flexible: in a free 3½" bay, in a free chassis slot or anywhere with the transparent acrylic glass.
- Ultimate fan controlling system
- Controls much more than just fans
- Built-in safety features
- 88 x 88 x16mm
- Weight: 150g
- Max Power: 80W
Was £56.99 Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Asus VH242H 24" Widescreen LCD Multimedia Monitor - Black @ £131.99 inc VAT
23.6” 16:9 widescreen with 1920×1080 resolution enables borderless Full HD 1080p full-screen video display. Embedded HDMI simplifies cabling and provides pristine and stunning clarity multimedia experience together with PC, game consoles, Blu-ray Disc players, etc. Built-in hidden stereo speakers and SPDIF audio output enable audio enjoyment together with true-to-life Full HD visual.
ASCR (ASUS Smart Contrast Ratio) Technology automatically adjusts the luminance of the backlight for better displays according to the image contents, and improves the contrast ratio to 20000:1 – resulting in more realistic depictions of night scenes during games or movies.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life Full HD 1080p gaming or movie watching without any data loss or image distortion.
Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the best possible color and image fidelity.
With the five preset modes (Standard, Game, Scenery, Night View and Theater) of Splendid™ Video Intelligence Technology, you will enjoy optimized colors for various multimedia entertainment scenarios.
Features:-
- TFT-LCD Panel Panel Size: 23.6“ Wide Screen
- True Resolution: 1920X1080
- Pixel Pitch: 0.272mm
- Brightness(Max): 300 cd/?
- Contrast Ratio (Max.): 20000 :1 (ASCR)
- Display Color: 16.7M
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 5 ms
- Video Features SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes (5 modes)
- Skin-Tone Selection (3 mode)
- HDCP support
- Color Temperature Selection(5 modes)
- Audio Features Stereo Speakers 2Wx2 stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- Input / Output PC Input: DVI-D/D-Sub
- PC Audio Input: 3.5mm Mini-jack
- Video Input: HDMI
- AV Audio Input: HDMI
- Audio Output: SPDIF
- Earphone jack: 3.5mm Mini-jack
- Signal Frequency Analog Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Digital Signal Frequency: 30 ~ 83 KHz(H)/50 ~ 75 Hz(V)
- Power Consumption Power Consumption < 55 W
- Power Saving Mode < 2 W
- Mechanical Design Chassis Colors: Black
- Tilt: +20°~ -5°
- VESA Wall Mounting: 100x100mm
- Security Kensington lock
- Dimension (WxHxD mm) Phys.Dimension(WxHxD): 562mm x 416mm x 220mm
- Box Dimension(WxHxD): 638mm x 171mm x 491mm
- Weight Net Weight (Esti.): 5.8 kg
- Gross Weight (Esti.): 8.2 kg
- Accessory DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- support CD
- warranty card
- Regulation Approval Energy Star®, UL/cUL, CB, CE, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, J-MOSS, RoHS, WEEE, WHQL
Was £139.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
Asus Xonar HDAV1.3 Deluxe Sound Card @ £166.99 inc VAT
The Xonar HDAV1.3 features Protected Audio Playback Systems (PAPS) and full Advanced Access Content System (AACS) certification. Without both of these certifications, typical PCs will need to downsample Blu-ray audio to DVD quality (48K/16bit). By closely working with ArcSoft´s Total Media Theater, ASUS´ Xonar HDAV1.3 is capable of decoding Blu-ray movies and takes full advantage of lossless digital audio formats such as Dolby TrueHD and DTS-HD Master Audio for professional, high-fidelity sounds at 24bit, 96-192Khz. The PCI Express based Xonar HDAV1.3 is designed from the ground up for next generation home theater PCs (HTPC); and is equipped with the proprietary AV200 audio processor and HDMI1.3a certified Splendid HD video processor - making it capable of delivering the highest quality 7.1 channel 192K linear pulse code modulation (LPCM) audio and high definition video through the HDMI port.
- ASUS AV200 (Max. 192KHz/24bit)
- ASUS Splendid HD Video Processor
- TI Burr-Brown PCM1796 (123dB SNR)
- Cirrus-Logic CS5381 (120dB SNR)
- Swappable DIP-typed NS LM4562 (THD+N~0.00003%)
- PCI Express X1
- HDMI 1.3a
- DTV Resolution: up to 1080p
- PC Resolution: up to UXGA
- up to 48-bit/per pixel color depths (RGB or YCbCr)
- broader xvYCC color space standard
- Photo, Video, Gaming (Gaming mode requires ASUS graphics card)
- 7.1 channel LPCM 192KHz/24bit
- Dolby TrueHD, Dolby Digital Plus, and DTS-HD Master Audio pass-through upgradeable by TotalMedia player
- 192KHz/24bit
- S/PDIF Digital Input & Output
- 192KHz/24bit
- SNR (A-Weighted):
- Output: 120 dB
- Input: 118dB
- THD+N at 1KHz:
- Output: 0.0004% (-108dB)
- Input: 0.0003% (-110dB)
- HDMI-Out Type A *1
- HDMI-In Type A *1
- RCA jack *2 (Front L/R)
- RCA jack *8 (Front L/R and all other 6 surround channels)
- mini jack *1 (Line-In/Mic-In shared)
- HD Audio and AC97
- Aux-In 4-pin header
- Input: Coaxial/TOSLINK combo
output: Coaxial/TOSLINK combo
- Dolby® Digital Live, Dolby® Headphone, Dolby® Virtual Speaker, Dolby® Pro-Logic IIx
- DTS® Connect (DTS Interactive, DTS Neo:PC )
- Latest EAX and DirectSound 3D hardware for Windows Vista & XP.
- VocalFX for online gaming or chatting
- SmartVolume, Acoustic Echo Cancellation, Karaoke Functions, FlexBass
- 44.1K/48K/96K/192KHz @ 16/24bit
- TotalMedia Theatre: 7.1-ch Blu-ray disc/HD-DVD/DVD movie player supports HD video/audio decoding
- DVI-to-HDMI cable
- HDMI cable
- Stereo RCA to 3.5mm cable
- S/PDIF TOSLINK optical adaptor
- H6 Extension Board cable (for connecting HDAV card and extension board)
- DVI-to-HDMI cable
- HDMI cable
- 3 x Stereo RCA to 3.5mm cable
Was £179.99 Inc. VAT
Only £166.99 inc VAT.
ORDER NOW
Asus Xonar HDAV1.3 Sound Card @ £133.99 inc VAT
The Xonar HDAV1.3 features Protected Audio Playback Systems (PAPS) and full Advanced Access Content System (AACS) certification. Without both of these certifications, typical PCs will need to downsample Blu-ray audio to DVD quality (48K/16bit). By closely working with ArcSoft´s Total Media Theater, ASUS´ Xonar HDAV1.3 is capable of decoding Blu-ray movies and takes full advantage of lossless digital audio formats such as Dolby TrueHD and DTS-HD Master Audio for professional, high-fidelity sounds at 24bit, 96-192Khz. The PCI Express based Xonar HDAV1.3 is designed from the ground up for next generation home theater PCs (HTPC); and is equipped with the proprietary AV200 audio processor and HDMI1.3a certified Splendid HD video processor – making it capable of delivering the highest quality 7.1 channel 192K linear pulse code modulation (LPCM) audio and high definition video through the HDMI port.
- PCI Express X1
- HDMI 1.3a
- 192KHz/24bit
- 192KHz/24bit
- SNR (A-Weighted):
- Output: 120 dB
- Input: 118dB
- THD+N at 1KHz:
- HDMI-In Type A *1
- HD Audio and AC97
- DVI-to-HDMI cable
- HDMI cable
- DVI-to-HDMI cable
- HDMI cable
Was £148.99 Inc. VAT
Only £133.99 inc VAT.
ORDER NOW
Creative Sound Blaster X-Fi Titanium HD Sound Card (70SB127000001) @ £139.99 inc VAT
The Sound Blaster X-Fi Titanium HD provides the highest quality audio playback of any sound card Creative has ever introduced and includes THX TruStudio PC audio technology, bringing together two of the most respected names in sound quality to provide an unparalleled audio experience on the PC. The Sound Blaster X-Fi Titanium HD features audiophile-grade components for high-quality playback of music, games and movies, including 122db SNR Digital-to-Analog Converters (DACs), the highest signal-to-noise ratio ever produced by a Creative sound card. Replaceable OP-amp provides the flexibility to further customize the audio experience through different sound coloration. If you are serious about your PC sound, this is the ultimate Sound Blaster experience.
- High-Fidelity audio performance D/A, A/D converter with SN ratio of 122dB with 0.001% (THD) distortion
- High quality audiophile grade performance components designed to eliminate noise, while dramatically improve sound field dynamics in high and mid tones
- Headphone out with 115dB, 24bit/96kHz support High-Definition (HD) quality sound for original playback
- Personalize sound field experiences with swappable OP-amp sockets
- THX TruStudio PC effects transforms your experience into a true High-Definition (HD) multimedia emotional journey
- Hardware-powered 3D positional audio and EAX 5.0 effects provide stunning audio realism over headphones and speakers
- ASIO recording support with latency as low as one millisecond with minimal CPU load. Dolby Digital and DTS encoding enables one-step single-cable connection to home entertainment systems, with included optical cables
Was £157.99 Inc. VAT
Only £139.99 inc VAT.
ORDER NOW
OcUK Value SATA-II 45cm Red Data Cable (NLRB-302LOCK) @ £1.99 inc VAT
The OCuK Value SATA-2 45CM Connection cable with locking ends offers a significantly more secure connection comapred to non-locking connection.
- 1 x 45 CM Red SATA-2 Data Cable with 2 x Locking Ends
- Straight End Connections
Was £2.59 Inc. VAT
Only £1.99 inc VAT.
ORDER NOW
Asus VS247H 24" Widescreen LED Monitor - Black @ £143.99 inc VAT
Delicate touches make a monitor truly great, VS247H Full HD LED monitor, with 50,000,000:1 high contrast ratio and HDMI interface, is optimized for the finest image and color quality. This approach extends to the sturdy stand and slim profile without compromising style in ensuring stability and durability.
Dynamically enhances the display’s contrast by adjusting the luminance
of the backlight to achieve the darkest black and brightest white – delivering lifelike images.
Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port.
When you would like to watch movies upward lying down, Smart View Technology can adjust color parameters to deliver the same image quality and colors with straight viewing.
Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Panel Size: Wide Screen 23.6"(59.9cm) 16:9
- True Resolution : 1920x1080
- Full HD 1080P : Yes (support 1080i/p by 1:1)
- Pixel Pitch : 0.272mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 5ms
- Display Colors : 16.7M
- Signal Input : HDMI , D-Sub, DVI-D
- Earphone jack : 3.5mm Mini-Jack (for HDMI Only)
Was £161.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
OcUK Value SATA-II 90cm Red Data Cable (NLRB-307LOCK) @ £2.39 inc VAT
The OCuK Value SATA-2 90CM Connection cable with locking ends offers a significantly more secure connection comapred to non-locking connection.
- 1 x 90 CM Red SATA-2 Data Cable with 2 x Locking Ends
Was £2.99 Inc. VAT
Only £2.39 inc VAT.
ORDER NOW
OcUK Value AT/ATX "Kettle Plug" Mains Cable @ £1.99 inc VAT
Standard 'kettlle plug' cable for ATX power supplies and monitors - fitted with a moulded and fused plug and with 1.8 meters of cord. While this item is somewhat less exciting than your graphics card and processor you will be going nowhere fast without it.
Was £2.39 Inc. VAT
Only £1.99 inc VAT.
ORDER NOW
Akasa USB Car Charger (AK-CA05-01) @ £3.98 inc VAT
Charge USB-powered devices from car cigarette lighter socket, works with most smart phones and portable music players.
- Application: Charge USB-powered devices from car socket
- Input voltage: DC12-24V
- Output voltage: 5V(1A max)
- Ports: Single USB type-A
- Size 25.2(W) x 42(H) x 20(D) mm
- Weight 11.5g
- Product code AK-CA05-01
Was £4.99 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
MSI CR620-1072UK 15.6" WLED TFT Intel I5-460M, 4GB DDR3, 320GB HDD, Intel Graphics, Win7 HP 64-Bit - Black/Silver @ £399.98 inc VAT
MSI's concise and refined classic cross-hatch design uses high-tech color film print technology for a dazzling look. The sparkling, scratch-resistant enamel provides a high degree of rigidity. Under different light sources, this finish will emit a multitude of color variations that create sparkling visual effects and evoke a minimalist undertone of taste and style.
- Intel® Core™ i5 Processor
- Genuine Windows® 7 Home Premium
- Classic Cross-Hatch Design
- 15.6” 16:9 wide screen display
- LED power-saving backlight technology
- HDMI (High-Definition Multimedia Interface) Output
- MSI Exclusive ECO Engine Power Management System
- DVD Super Multi
- Intel Core i5 460M
- 1 x 10/100 (LAN)
- 1 x D-Sub
- 1 x HDMI
- 1 x Headphone
- 1 x Mic In
- 3 x USB 2.0
- 2.53 GHz
- 15.6" (1366x768)
- 4GB RAM DDR3 SO-DIMM
- Battery 6-cell
- 500 GB HDD
- Windows 7 Home Premium (64 bit)
- Dimensions: 374 x 35 x 248 mm (WxHxD)
- Graphics Chipset Intel UMA Graphics
- 2.48 kg
Was £449.99 Inc. VAT
Only £399.98 inc VAT.
ORDER NOW
Battlefield War Commander Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 BF3 Limited Edition System @ £619.98 inc VAT
Ready the Scud missiles, arm the Tomahawks and prime the Nukes. Fire up the tanks, scramble the jets and roll in the artillery! Control the Battlefield in the palm of your hand with the "Battlefield War Commander", designed and engineered for hardcore gaming. During the heat of the battle the "Battlefield War Commander" will complete the mission no questions asked. Featuring the Asus P67 Sabertooth motherboard for ultimate reliability and overclocking performance. With a choice of DX11 graphics cards to choose from, you can equip yourself with the right weapon for the mission ahead.
Why You Should Buy This System
- A guaranteed 4.60GHz performance for the price of 3.30GHz
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
System Specification
- Case: BitFenix Shinobi Gaming Case
- Power Supply: OCZ ZS 650w PSU
- CPU: Intel Core i5 2500K 3.30GHz @ 4.60GHz Sandybridge CPU
- Motherboard: Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: OcUK H2 Flo CPU Cooler
- RAM: 8GB DDR3 1600MHz Dual Channel Kit
- Hard Drive: Western Digital Caviar Blue 500GB SATA 6GB/s
- Graphics Card: Choice of DX11 Compatible Graphics Cards
- Sound: Realtek 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Command, control and dominate the battlefield with the "Battlefield War Commander" system.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £759.98 Inc. VAT
Only £619.98 inc VAT.
ORDER NOW
Battlefield War General Intel Core i7 2700K 3.50GHz @ 4.80GHz PLUS DDR3 BF3 Limited Edition System @ £804.98 inc VAT
Ready the Scud missiles, arm the Tomahawks and prime the Nukes. Fire up the tanks, scramble the jets and roll in the artillery! Control the Battlefield in the palm of your hand with the "Battlefield War General", designed and engineered for hardcore gaming. During the heat of the battle the "Battlefield War General" will complete the mission no questions asked. Featuring the Asus P67 Sabertooth motherboard for ultimate reliability and overclocking performance. With a choice of DX11 graphics cards to choose from, you can equip yourself with the right weapon for the mission ahead.
- A guaranteed 4.80GHz performance for the price of 3.50GHz
- CPU: Intel Core i7 2700K 3.50GHz @ 4.80GHz PLUS Sandybridge CPU
- Cooler: OcUK H2 Flo Extreme CPU Cooler
Service Package
Command, control and dominate the battlefield with the "Battlefield War General" system.
Was £919.98 Inc. VAT
Only £804.98 inc VAT.
ORDER NOW
Arkham Destructor Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Limited Edition System @ £639.99 inc VAT
Introducing the OcUK range of limited edition "Arkham" systems. Designed and engineered for maximum gaming performance. Featuring Nvidia 500 series graphics cards for an unparalleled graphical experience. With excellent graphical credentials the deal is even sweeter with a FREE Copy of Batman: Arkhma City included so you can start gaming straight away. With ample memory and storage you can enjoy a flawless computing experience the competition can only dream of.
- A guaranteed 4.40GHz performance for the price of 3.30GHz
- The latest Nvidia 500 series graphics cards for DX11 cinematic graphics
- FREE copy of Batman: Arkham City with every system
- Case: Antec 300 Gaming Case
- Power Supply: OCZ ZS 550w PSU
- CPU: Intel Core i5 2500K 3.30GHz @ 4.40GHz Sandybridge CPU
- Motherboard: Intel Z68 (Socket 1155) DDR3 Motherboard ** B3 REVISION **
- Cooler: Xigmatek Dark Knight CPU Cooler
- RAM: 4GB DDR3 1600MHz Dual Channel Kit
- Graphics Card: Nvidia GTX 560 1024MB GDDR5
Service Package
The Arkham Destructor system provides a great entry in the gaming world. With powerful graphics and a high CPU clock speed, you can be guaranteed performance.
Was £654.98 Inc. VAT
Only £639.99 inc VAT.
ORDER NOW
"Titan Spinosaur" Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge System @ £729.95 inc VAT
Stalking through the jungle, the "Titan Spinosaur" is master of all. Featuring the Intel Core i5 2500K overclocked to a ridiculous 4.60Ghz, you can enjoy ultra smooth framerates and an immersive computing experience. With a choice of the latest DX11 graphics cards, equip yourself ready for the hunt ahead with the best offering from both Nvidia and ATI.
- Case: Antec 300 Case with Purple LED Fans
- Power Supply: OCZ ZS 750w PSU
Service Package
Heighten your gaming experience with the "Titan Spinosaur", stalk your prey down and demolish the competition. Equipped with either ATI or Nvidia, become a champion.
Was £829.96 Inc. VAT
Only £729.95 inc VAT.
ORDER NOW
"Primo 6100a AMD Athlon II X2 Dual Core 250 3.00GHz DDR3 System @ £269.98 inc VAT
The "Primo 6100a" offers the performance needed for home and business use at a low price. The AMD Athlon II X2 Dual Core 250 3.00GHz combined with 4GB of 1600MHz DDR3 RAM, offers a quick and easy multitasking experience.
Why You Should Buy This System?
- AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) offers multitasking performance.
- 500GB Western Digital hard drive gives a solid and reliable storage capacity.
- 4GB of 1333MHz DDR3 RAM allows for snappy and precise processes to be made.
- Case: OcUK IMP microATX case - Black
- Power Supply: OcUK Value 500W PSU
- CPU: AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3)
- Motherboard: AMD nForce 630a (Socket AM2+/AM3) DDR3 Motherboard
- Graphics Card: Onboard integrated NVIDIA GeForce 7025 GPU
- Sound: ALC662 6-channel High Definition Audio CODEC
- Optical Drive: LG GH22NS50 22x DVD±RW SATA ReWriter
Service Package
Compact, reliable and smart. The "Primo 6100a" give you everything you need in a entry level home/business system.
Was £289.97 Inc. VAT
Only £269.98 inc VAT.
ORDER NOW
"Primo 6200i" Intel Core i5 2300 2.80GHz DDR3 Sandybridge System @ £379.98 inc VAT
Introducing the "Primo 6200i" delivering breath taking performance and providing excellent onboard graphics from the integrated Intel HD2000 GPU. The "Primo 6200i" offers everything that is required to make a perfect home computer.
- Intel Ethernet and EUFI graphical BIOS for next gen computing
- Case: Coolermaster Elite 334 - Black
- Power Supply: OCZ ZS 550W PSU
- CPU: Intel Core i5 2300 2.80GHz Sandybridge CPU
- Motherboard: Intel H61 (Socket 1155) MicroATX DDR3 Motherboard ** B3 REVISION **
- Cooler: Intel Stock Cooler
- Graphics Card: Onboard Intel HD2000 graphics with GFX upgrade options
Service Package
With powerful graphics, rapid processing and features by the truck load, the "Primo 6200i" offers more than any other computer at this price.
Was £399.98 Inc. VAT
Only £379.98 inc VAT.
ORDER NOW
"Primo 6100i" Intel Core i3 550 3.20GHz DDR3 System @ £369.97 inc VAT
The "Primo 6100i" features a Intel Core i3 550 3.20GHz processor seamless multi-tasking capabilities which is perfect for home/office use. Awesome power contained within a small chassis the "Primo Ignition" has the option to upgrade to one of many of the latest Low Power, energy efficient Nvidia series graphics cards for extra graphical punch. Utilising Hyper threading technology the "Primo Ignition" makes short work of video encoding and multitasking.
- Intel Core i3 550 3.06GHz (Clarkdale) Processor with Hyperthreading technology for 4 Virtual cores
- 500GB Hard drive gives massive storage capacity including DVD Re-Writer Make this system perfect for data backup
- Case: OcUK IMP microATX Case
- Power Supply: OcUK 500W PSU
- CPU: Intel Core i3 550 3.20GHz (Clarkdale)
- Motherboard: Intel H55 (Socket 1156) DDR3 microATX Motherboard
- Cooler: Intel Approved Cooler
- Graphics Card: Onboard Intel GMA graphics or a choice of energy efficient graphics cards
- Sound: High Definition 7.1 Onboard Sound Card
- Optical Drive: LG GH22NS50 22x DVD+RW SATA ReWriter
Service Package
With multiple video outputs, compact size and advanced hyperthreading technology the "Primo 6100i" is perfect for the user looking for a highperformance system for a low price.
Was £381.98 Inc. VAT
Only £369.97 inc VAT.
ORDER NOW
Creative HS-600 Headset (51MZ0120AA007) @ £17.98 inc VAT
Creative's HS-600 headset is designed to give lifelike results in interactive gaming with internet voice capability. The ideal choice for gamers who like to lead a squad into battle and interact with competitors in an on-line session, it's optimised for Creative and other high-end sound cards, and features an outstanding noise-cancelling microphone that enhances speech accuracy for improved voice communications. The audio experience is immersive, with outstanding detail and impact from the large headphone drivers. A convenient volume control with microphone mute makes life easy for users, while the rotating microphone can easily be positioned for best results.
- Outstanding solution for interactive gaming.
- Microphone with rotary mount adjusts for comfort.
- Improved speech quality from noise-cancelling technology.
- Immersive audio from large 50mm drivers in headphone module.
- Comfortable to wear even in long sessions.
- Convenient volume control with microphone mute switch.
Was £23.98 Inc. VAT
Only £17.98 inc VAT.
ORDER NOW
Corsair Gaming Audio Series HS1A Analogue Headset @ £29.99 inc VAT
The Gaming Audio Series HS1 Gaming Headset is designed for gamers who are serious about audio. Massive 50mm driversdeliver serious punch, without sacrificing the sparkling sound quality you need for music and movies. Extra-large, extra-deep memory foam earpads provide a reliable, custom fit that’s so comfortable, you might forget you’re wearing them.
- Massive 50mm drivers for high-quality audio reproduction
- Detailed audio reproduction with clean, accurate bass and sparkling clarity in mids and highs
- Circumaural, closed-back earcups for superior noise isolation
- Memory foam earpads provide a custom fit that won’t weigh you down
- Includes two sets of earpads to customize your comfort – your choice of microfiber or synthetic leather
- Connectivity: 3.5mm jacks for ear piece and mic
- 2 Years Warranty
Was £33.98 Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Corsair Vengeance 1500 Dolby 7.1 Professional Gaming Headset @ £86.39 inc VAT
If you have onboard sound, the Vengeance 1500 provides easy one-cable USB connection and Dolby Headphone technology that lets you enjoy multi-channel games the way they were meant to be played. Dolby Headphone is compatible with any game with 3D audio, and helps reduce “headphone fatigue” while delivering the accurate 360-degree audio imaging you need if you’re playing to win.
The massive 50mm drivers greatly reduce the overloading and distortion that can occur with gaming headsets that use 40mm drivers. You get more accurate sound reproduction (particularly for the all-important low-frequency effects). You hear more audio, more cleanly, and you get a competitive advantage.
The extra-wide, extra deep earcups don’t just help things sound great — they feel better, too. Customize your comfort with your choice of the included microfiber or synthetic leather covers. Both use memory foam earpads for a comfortable, reliable fit that conforms to the shape of your head without binding or pinching.
The circumaural, closed-back design blocks distracting sounds and keeps your head in the game, and the extra-large inline volume and microphone control is easy to grab and use when the action heats up — you don't need to take your eyes off the screen.
Whether you’re barking instructions to your teammates or chatting with old friends, you deserve to be heard. The unidirectional, noise-cancelling microphone is tuned to capture your voice loudly and clearly, while screening out distracting background noises. And, it flips out of sight when you’re not using it.
Corsair audio: a sound philosophy
You need more than just dramatic audio. You need the comfort that allows you to play or talk for hours without thinking about what’s on your head. You need fidelity that gives you a listening experience that’s not just immersive — it must also be true to the source material. And, of course, you need the detailed positioning and situational awareness that lets you play your best.
- Intense, Immersive Gaming
- Dominate with Dolby 7.1 Sound
- Superior Comfort
- 3m Cable
- Large 50mm Audio drivers
- In Line volume control
- High-sensitivity noise-cancelling microphone with flexible boom
- USB connections
- Two Year Warranty
Was £89.99 Inc. VAT
Only £86.39 inc VAT.
ORDER NOW
Logitech G35 Gaming USB Headset PC 7.1Ch Surround @ £111.59 inc VAT
The Logitech G35 headset. Game-changing immersion with 7.1 surround sound powered by Dolby technology for a detailed soundfield - hear your enemies before they see you. Featuring three swappable headband pads so you can choose the best fit, for long-lasting comfort; three customizable G keys for one-touch command over music, voice morphing, and more; on-ear audio controls for quick access to volume, microphone mute, and surround sound adjustments; and an adjustable, noise-canceling microphone that focuses on your voice and reduces background noise.
- 7.1 surround sound powered by Dolby technology delivers a detailed soundfield - hear your enemies before they see you.
- Three swappable headband pads let you choose the best fit, for long-lasting comfort.
- Three customizable G keys give you one-touch command over music, voice morphing, and more.
- On-ear audio controls provide quick access to volume, microphone mute, and surround sound adjustments.
- Adjustable, noise-canceling microphone focuses on your voice and reduces background noise.
- 2-years limited warranty
Only £111.59 inc VAT.
ORDER NOW
Krypton Z68 600i Intel Core i5 2500K 3.30GHz @ 4.60GHz Overclocked Bundle @ £380.95 inc VAT
Designed by experts the "Krypton Z68 600i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.60GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 600i" will accelerate your computer experience into the next level.
Why You Should Buy This Bundle?
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers unsurpassed bandwidth
- USB3, SATA 6GB/s, Intel Ethernet and EUFI graphical BIOS for next gen computing
Bundle Specification
- Motherboard: Asus P8Z68-V Intel Z68 (default choice)
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
- Cooler: Corsair A50 CPU Cooler
- Artic Silver 5 Thermal Compound
Service Package
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
Was £395.95 Inc. VAT
Only £380.95 inc VAT.
ORDER NOW
Sennheiser HH 10 Headphone Holder @ £19.20 inc VAT
This headphone holder provides easy storage and placement of any type of Sennheiser headphones. It attaches to a table or shelf effortlessly and can be fixed to either the shelf or the vertical upright.
Was £19.99 Inc. VAT
Only £19.20 inc VAT.
ORDER NOW
Sennheiser PC 360 Gaming Headset @ £132.58 inc VAT
Developed with the top eSport team mTw, the PC 360 is a new flagship for pro gaming. It has an open design that makes sure you keep a cool head – and delivers a natural listening experience so you can stay in touch with your surroundings. Thanks to the ultracomfortable ear cups, pro microphone and quick-access controls, it’s also the only headset you’ll ever
need for music, videos and skyping.
Professional gaming with a cool head - the open design lets air in and delivers a natural listening experience;Sennheiser sound – excellent hi-fi sound and acoustics from your games, music, movies and internet calls;Noise canceling clarity – the microphone reduces ambient noise for crystal-clear conversations;All-in-one headset – when you want to enjoy movies or music, just move the microphone out of your way;Practical microphone mute – automatically mute the microphone by raising the boom.
- Cable length: 3m / 9.8ft
- Connector sockets: 2 x 3.5mm for desktop/laptop
- Weight: 300g
Frequency response:15–28,000Hz
- Sound pressure level: 112dB
- Microphone:
Frequency response: 50–16,000Hz
- Pick-up pattern: Noise canceling
Sensitivity: -38dBV/PA
Was £134.98 Inc. VAT
Only £132.58 inc VAT.
ORDER NOW
TT Esports Gamers Headset Shock - Black @ £26.39 inc VAT
nonl2br
The TT Esports Gamers Headset Shock brings gaming to a new level. Immerse deeply into your games with 40mm speaker drivers and stereo surround sound. Take advantage of your soundcard with 3.5mm speaker jacks bringing maximum sound performance. The ultra comfortable padded earcups make sure that comfort is key, especially for intense professional gaming. <br><br>
- Stereo surround sound<br>
- Quality 40mm speaker driver with enhanced bass performance<br>
- Noise cancelling microphone for communciation in gaming activities<br>
- Control Box with In-line control box for instant gaming sound control<br>
- 10 Levels adjustment for a perfect fit<br>
- Foldable design<br>
- Gold plated 3.5mm connctor<br>
<br>
<br>
<iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/2gampqTGEf8" frameborder="0" allowfullscreen></iframe>
Was £29.99 Inc. VAT
Only £26.39 inc VAT.
ORDER NOW
Krypton Z68 590i Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle @ £345.97 inc VAT
Designed by experts the "Krypton Z68 590i Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The Guaranteed 4.40GHz overclock has the processing power and speed unseen at this price point ever before. The "Krypton Z68 590i" will accelerate your computer experience into the next level.
- A solid, optimised 4.40GHz overclock profile provides outstanding processing performance
- USB3, SATA 6GB/s and Intel Ethernet for next gen computing
- Motherboard: Gigabyte Z68AP-D3 Intel Z68 (default choice)
Service Package
Was £355.96 Inc. VAT
Only £345.97 inc VAT.
ORDER NOW
Speedlink Xanthos Stereo Multi Platform Gaming Headset PC/XBOX360/PS3 @ £39.59 inc VAT
Intensify your gaming experience and totally engross yourself in the virtual world - whether on the PS3®, Xbox 360® or PC. The XANTHOS Stereo Console Gaming Headset with atmospheric LED lighting delivers sensational stereo sound for games and multimedia on all three platforms. Your friends and teammates will hear you with optimum clarity thanks to the fold-away microphone, plus you can conveniently adjust the volume level and mute the microphone using the in-line remote. In addition, the three-metre cable offers ultimate freedom, while the padded earcups provide maximum comfort - so you can concentrate on the most important thing: the game.
Features
- In Line Remote
- Rugged fold away microphone
- Crystal Clear Stereo Sound
- Works with Xbox 360, PS3 and PC
Was £44.99 Inc. VAT
Only £39.59 inc VAT.
ORDER NOW
Plantronics GameCOM P90 Bluetooth Headset @ £13.79 inc VAT
Experience Playstation 3 gaming with Plantronics quality. The GameCom P90 Bluetooth Headset gives you a clear and precise impact.
- Maximize your PlayStation 3 gaming experience
- Communicate wirelessly with your friends and opponents
- Take phone calls from most Bluetooth-enabled phones
- Stay comfortable for long gaming sessions, thanks to the slim earloops and contoured eartips
- Silence your chats or calls quickly with the easily accessible mute control
- Charge the headset directly from your PS3 using the USB cable
- Quickly pair to your PS3 and Bluetooth phone using QuickPair technology
Was £14.99 Inc. VAT
Only £13.79 inc VAT.
ORDER NOW
Krypton G1 Killer Intel Core i7 960 3.20GHz @ 4.00GHz DDR3 Overclocked Bundle @ £499.98 inc VAT
Designed by experts the "Krypton G1 Killer i7 960 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 4.00GHz overclock profile provides outstanding processing performance
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 & SATA 6GB/s compatible offering lightning fast transfer speeds
- Bigfoor Killer E2100 LAN Chip & Creative X-Fi Xtreme Fidelity HD sound
- CPU: Intel Core i7 960 3.20GHz @ 4.00GHz
- Motherboard: Gigabyte G1 Killer Guerilla X58 (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
Service Package
Was £509.99 Inc. VAT
Only £499.98 inc VAT.
ORDER NOW
Krypton 700a AMD Phenom II X4 840 3.20GHz @ 3.80GHz Overclocked Bundle @ £243.18 inc VAT
Designed by experts the "Krypton 700a Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Krypton 700a Bundle" will accelerate your computer experience into the next level.
- 4GB of Dual Channel DDR3 memory delivers unlimited bandwidth
- Quad Core processing performance
- CPU: AMD Phenom II X4 840 3.20GHz @ 3.80GHz
- Motherboard: Asus M5A97 PRO AMD 970 (Socket AM3+) DDR3 Motherboard (Upgrade Options available)
- RAM: Kingston HyperX Genesis Grey (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel
Service Package
Was £249.96 Inc. VAT
Only £243.18 inc VAT.
ORDER NOW
Speedlink Spes Clip-On Metal Microphone (SL-8691-SBK) @ £6.24 inc VAT
The microphone is attractively designed and is extremely practical. The noise-suppression system filters out bothersome background noises and makes internet chat easy and uncomplicated. Furthermore, the clothing clip allows you to clip the mic anywhere you like.
- Lots of freedom of movement thanks to the 2.4m cable
- You'll hardly notice you're wearing the mic thanks to it's low weight
- Easy to attach to clothing thanks to the clip
- Highly sensitive microphone featuring noise suppression
- Robust design made from black metal
Was £6.98 Inc. VAT
Only £6.24 inc VAT.
ORDER NOW
Energy Sistem Energy DJ 400 Comic Art DJ Style Headphones @ £27.59 inc VAT
With folding system, padded headband construction and ciurcumaural pads for high isolation, these headphones are designed for the streets. Strong bass thanks to its "Deep Bass Response" technology. Compatible with iPod and iPhone
• Full Folding System
• Gold Plated 3.5mm Stereo Jack
• Excellent Sound Insulation
• Deep Bass Response
• 44 mm Diaphragm
• Fully Enclosed Dynamic Headphones
• Guarantee: 36 Months
Was £28.99 Inc. VAT
Only £27.59 inc VAT.
ORDER NOW
Xenon AMD Phenom II X4 850 3.30GHz Bundle - Quad Core @ £149.99 inc VAT
Designed by experts the "Xenon AMD Phenom II 850 Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X4 850 Bundle" offers you speed and silence in perfect combination.
- Prebuilt and configured. Just "plug and play"
- 4GB of Dual Channel DDR3 memory delivers fast load times
- CPU: AMD Phenom II X4 Quad Core 850 "95W Edition" 3.30GHz
- Motherboard: Asus M5A78L-M LX 760G (Socket AM3) DDR3 Motherboard
- RAM: 4GB (2x2GB) DDR3 1600MHz Dual Channel
- Cooler: AMD Stock Cooler
Service Package
Was £159.98 Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Xenon AMD Phenom II X6 1055T 2.80GHz Bundle - Six Core @ £189.99 inc VAT
Designed by experts the "Xenon AMD Phenom II X6 1055T Bundle" is a pre-configured high performance "plug and play" bundle featuring optimised settings. The "Xenon AMD Phenom II X6 1055T Bundle" offers you speed and silence in perfect combination.
- CPU: AMD Phenom II X6 Hex Core 1055T 2.80GHz
- Motherboard: Asus M5A78L-M LX (Socket AM3) DDR3 Motherboard
Service Package
Was £194.98 Inc. VAT
Only £189.99 inc VAT.
ORDER NOW
Creative Live! Cam Socialize HD 12 Megapixel 1080p Webcam With In built Microphone (73VF068000001) @ £55.19 inc VAT
Record, edit and share your videos in stunning Full HD 1080p quality with Live! Cam Socialize HD 1080. With just one click using Live! Central 3 software, you can easily upload and share your HD video blogs on YouTube and Facebook. Or even combine them with 12-megapixel* photos to produce movies complete with your favorite music! Also, never worry about being out of shooting range or appearing blurry with the auto focus, wide-angle lens. It captures all the action so you enjoy superbly sharp HD 720p online video chats, while built-in Dual Stereo microphones block out unwanted external noise. Got lots of namecards? Included Live! Scan software is able to extract information from them in a snap, and helps you organize these contact details.
- Record in stunning Full HD 1080p video quality
- Smooth HD 720p video chats
- Clear, natural-sounding voice chats with Dual Stereo Microphones
- Capture a wider view with wide-angle lens
- Never look blurry with auto focus
- Do more with new Live! Central 3 software
- Manage your contacts with Live! Scan
- 1-year limited hardware warranty
System Requirements:
Intel® Pentium® Dual-Core 1.6GHz or AMD® equivalent processor
Microsoft® Windows® 7 / Windows Vista® / Windows XP (SP 2 or higher) / Mac OS® X 10.5 / Linux® Kernel 2.6
1 GB RAM
USB 2.0 port
500 MB free hard-disk space
CD/DVD-ROM Drive
For HD 720p Video Calling
Requires dual-core CPU, 2GB RAM, 1Mbps symmetrical bandwidth or higher
Was £69.98 Inc. VAT
Only £55.19 inc VAT.
ORDER NOW
Logitech C910 HD 1080p Pro 10 Megapixel Webcam (960-000598) @ £74.39 inc VAT
Individuals using the webcam to communicate with friends and business associates will benefit from its 720p video calls, 1080p HD recording and its ability to capture ten-megapixel stills. Sharing videos and images could not be easier with the Logitech HD Pro Webcam C910 (960-000598) due to its one-click Facebook upload feature, while its life-like audio quality could appeal to some customers. Users can enhance the security of the webcam by using its face recognition login feature, offering peace of mind and protection against unauthorised use. Meanwhile, Carl Zeiss optics combined with RightLight 2 technology and bundled Logitech video effects could make this device an even more appealing purchase for enthusiasts.
- Full HD 1080p video capture (up to 1920 X 1080 pixels) with recommended system*
- HD video calling (1280 x 720 pixels) with recommended system*
- Logitech More HD technology
- Carl Zeiss® optics with autofocus
- Photos: Up to 10 megapixels (software enhanced)
- Built-in mics with Logitech RightSound™ technology
- Hi-Speed USB 2.0 certified (recommended)
- Universal clip fits laptops, LCD or CRT monitors
- 2-year limited hardware warranty
Basic requirements:
- 1 GHz
- 512 MB RAM or more
- 200 MB hard drive space
- Internet connection
- USB 1.1 port (2.0 recommended)
- Windows® XP (SP2 or higher), Windows Vista® or Windows® 7 (32-bit or 64-bit)
For HD 720p video calling and Full HD 1080p video recording:
- 2.4 GHz Intel® Core™2 Duo
- 2 GB RAM
- USB 2.0 port
- 1 Mbps upload speed or higher
- 1280 x 720 screen resolution
Was £77.99 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
Swann SW223-SPR Sprinkler Night Vision Head Covert Security Camera @ £37.58 inc VAT
420 TV Lines 1/4" Sony CCD high video quality. Day indoor use. Covert surveillance - No one will know! BNC cable 9ft 3m. Easily connects to your TV & DVR.
The Sprinkler Head Camera offers the ulitmate in covert surveillance. Housed in a replica 'sprinkler head' this camera would be used in circumstances where you wouldn't want people to know when they're being filmed. The Sprinkler Head camera has a pinhole lens for covert surveillance, with a wide angle 85 degrees viewing angle and high resolution 420 TV lines. It's perfect for business, offices, warehouse, schools, retail stores, large homes, apartments, hotels and more. Everything you need is included in the pack including 9ft 3m BNC cable for connecting to a recording device and power, BNC to RCA connector for connecting to a TV, power adapter, user guide, security stickers and more.
Was £39.98 Inc. VAT
Only £37.58 inc VAT.
ORDER NOW
Storage Options Pro Outdoor IP Camera @ £150.00 inc VAT
It combines a high quality digital video camera with network connectivity and a powerful web server, to bring clear images to your desktop from anywhere on your local network, or over the Internet.
High quality video images can be transmitted at up to 30fps on a LAN or WAN by using H.264 hardware compression technology.
- True day & night surveillance
- Large aperture lens (F1.4)
- The best cost / performance outdoor solution
- IR effective distance up to 30m
- Low-latency streaming with H.264 compression
Was £166.98 Inc. VAT
Only £150.00 inc VAT.
ORDER NOW
Storage Options CCTV 500GB DVR @ £147.59 inc VAT
nonl2br
A 4 channel digital video recorder with pre-installed hard disk drive, designed to be used with the
Storage Options CCTV Range. Records in H.264, the latest compression technology, which gives
improved image quality and a longer recording time. Remote viewing is available as standard across your network or through the mobile phone/tablet application. Just add cameras for a complete security
solution.<br><br>
Storage Options offers a range of affordable CCTV Solutions for home or small business security. With a range of cameras, digital video recorders and other accessories, our aim is to offer high-quality products and service without the premium price.<br><br>
- 500GB hard disk drive installed<br>
- Real time Viewing/Recording of up to 4 CCTV Cameras <br>
- Easy Setup and Operation, Simple User Interface<br>
- H.264 Compression Technology Provides Higher Quality and Longer Recording Times<br>
-Simultaneous Viewing, Recording, Playback, Backup and Network Operation<br>
- Android TM and Apple® Applications for Mobile Devices Available<br>
- Compatible with Most Modern CCTV Cameras<br>
Was £155.99 Inc. VAT
Only £147.59 inc VAT.
ORDER NOW
Swann Monitoring Kit With PNP-51 day/night Camera and 7 Inch LCD Screen @ £125.39 inc VAT
The Home and Business Monitoring Kit is a new generation of the SecuraView, one of Swannn's best selling products. It allows you to view and hear security video on a crystal clear 7 inch color LCD monitor. The monitor connects to the color camera via a 60 foot / 18 meter cable. You can operate using the remote control in the pack. Both the monitor and camera must be connected to mains power. The pack also includes 4 theft deterrent stickers and everything you need to get started. The Home and Business Monitoring Kit is perfect for anyone wanting an affordable starting point for their security needs. It's ideal for small businesses, retail stores, restaurants or home use. The unit has a discreet, small footprint with a modern and stylish finish. It's a cost effective way to see AND hear what's really happening. You will love the color video. Unlike black and white systems, you will be able to identify what color clothing people are wearing, what color hair they have, and get a truer picture of what is going on. It's easy to do-it-yourself. Mount the camera to a wall or ceiling is simple with screws included in the pack. The LCD monitor can be mounted upside down or side-ways and the video will realign itself to be the right way up using the image flip option. For discretion and to save power you can also use the auto turn-off function when the unit is not needed. The Home and Business Monitoring Kit includes a PNP-51 camera with short range night vision and a built-in microphone to allow you to hear conversations and other sounds. The Kit is also upgradeable in that you can add a second camera and then switch camera views.
- Mount camera & LCD to walls or ceilings
- LCD image flip option. Mount lcd monitor upside down or side ways & flip the image around the right way
- Auto turn on/off LCD monitor - Set time to automatically turn the montior on & off
- Add a second camera - Automatically switch camera views at 4 to 8 second intervals
Was £134.99 Inc. VAT
Only £125.39 inc VAT.
ORDER NOW
APC Back-UPS ES 400VA 230V UPS (BE400-UK) @ £53.33 inc VAT
The Back-UPS ES offers our best value for protecting your home and home office computer systems. It provides battery backup power that allows you to work through short and medium length power outages. It also safeguards your equipment from damaging surges and spikes that travel along your utility and phone lines. Award-winning software automatically shuts down your computer system in the event of an extended power outage. Additional features like audible alarms, an LED status indicator, user replaceable battery, push-button circuit breakers and transformer-block spaced outlets make the Back-UPS ES the perfect unit to protect your productivity from the constant threat of power outages and lost data.
- 400VA Power Storage
- Up to 18minutes of backup power
- LED status display and audible alarm
- 310 Joules Surge Protection
- 3 Year Warranty
- Lifetime protection policy for £50,000
- Cables Included: 1 x power cable - integrated
Was £58.98 Inc. VAT
Only £53.33 inc VAT.
ORDER NOW
Energenie Radio Controlled Socket - 3 sockets + 1 Remote @ £15.10 inc VAT
Switch o! appliances wasting energy in Standby such as older TVs to save money and reduce your carbon footprint. Devices left in standby may also be a fire risk and it is safer to switch them off. The remote control does not require direct line-of-sight to operate. It will work even when the socket is hidden behind furniture or in an adjacent room up to 30 metres range.
• 3 sockets + 1 Remote
• 4 channel remote control plus ALL on/o! buttons
• Socket will learn remote control key code
• On/Off indicator light, manual on/off button on unit
• More than one socket can be programmed to the same remote control key
• 13 Amp rated to BS5733
Was £17.50 Inc. VAT
Only £15.10 inc VAT.
ORDER NOW
Energenie Radio Controlled Extension Lead @ £17.04 inc VAT
A 4-socket radio remote controlled UK Extension lead. Each socket may be individually controlled via the radio frequency remote control or all sockets may be switched on or off simultaneously. Suitable for people with restricted movement and ideal for controlling appliances in inaccessible places. Wide socket spaces for use with appliances that have bulky transformers.
• Remote control will operate through walls and ceilings up to 30 meters.
• Surge Protection protects all of your devices from power spikes
• On/Off indicator lights
• Sockets: 4
• Cable length: 1.5 metres
• Voltage: 240V ac 50Hz
• Maximum total current: 13A
• Maximum total load: 3kW
• Standby power consumption: 2.3W
• Protection: L-N, L-E, N-E
• Total max. spike current: 18000A
• Max. spike voltage: 775V
• Response time: 8-20ìs
Was £21.98 Inc. VAT
Only £17.04 inc VAT.
ORDER NOW
"Primo 500a" AMD DDR3 Ready Barebones (Socket AM3+) @ £59.99 inc VAT
The "Primo 500a" offers the performance needed for home and business use at a low price. The AMD DDR3 barebones will accept all AMD (AM3+) socket compatible processors and any dual channel DDR3 Memory kits. Pre-built and ready to accept your hardware the "Primo 500a" is perfect for the home and business user who wants to add their personal taste to their system. Just add your CPU, RAM, HDD and any Optical Drive and you are ready to go. No external graphics card required thanks to the Onboard Nvidia graphics.
- Motherboard: Asus M5A78L-M LX AMD 760G (Socket AM3+) DDR3
The lead time on all pre-built barebones is between 24-48 hours.
Was £64.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
Battlefield 3: Limited Edition - PC @ £35.98 inc VAT
nonl2br
<a href="http://www.origin.com/download"/>
<img src="http://www.overclockers.co.uk/LP/games/originactivation.PNG"></a>
<a href="http://www.battlefield.com/battlefield3/1/beta"/>
<img src="http://www.overclockers.co.uk/LP/games/BF3BETA.PNG"> <br><br></a>
Battlefield 3 leaps ahead of the competition with the power of Frostbite 2, the next instalment of DICE's cutting-edge game engine. This state-of-the-art technology is the foundation on which Battlefield 3 is built, delivering superior visual quality, a grand sense of scale, massive destruction, dynamic audio and incredibly lifelike character animations. As bullets whiz by, walls crumble, and explosions throw you to the ground, the battlefield feels more alive and interactive than ever before.<br>
In Battlefield 3, players step into the role of the elite U.S. Marines where they will experience heart-pounding single player missions and competitive multiplayer actions ranging across diverse locations from around the globe including Paris, Tehran and New York
<br>
<br>
<b>Please Note:</b> Customers who pre-order Battlefield 3 will receive Battlefield 3: Limited Edition at no extra charge! Battlefield 3: Limited Edition includes the digital expansion pack "Battlefield 3: Back To Karkand" at no extra charge. This themed multiplayer expansion pack includes four legendary maps from Battlefield 2 boldly re-imagined with Frostbite 2 physics, destruction and visuals. Completing the package are classic Battlefield 2 weapons and vehicles, unique rewards, new achievements/trophies, and more. The Battlefield 3: Limited Edition is available as a pre-order incentive and may not be available after launch<br><br>
<b>Frostbite 2 -</b> Battlefield 3 introduces Frostbite 2, the incredible technology that takes animation, destruction, lighting, scale and audio to new heights. Built upon this powerful game engine, Battlefield 3 immerses players physically and emotionally to the world around them like never before
<br>
<b>Feel The Battle -</b> Feel the impact of bullets and explosions, drag your fallen comrades into safety, and mount your weapon on almost any part of the terrain. Battlefield 3's cutting edge animation, spectacular visuals and real as hell battle gameplay attack your senses and make you feel the visceral warriors experience like no other FPS
<br><b>Unparalleled Vehicle Warfare</b> - The best online vehicle warfare experience gets even better with a fitting sonic boom as fighter jets headline impressive lineup of land, air and sea vehicles
<br>
<b>Urban Combat -</b> Take the fight to iconic and unexpected places in the USA, Middle East, and Europe including claustrophobic streets, metropolitan downtowns, and open, vehicle-friendly landscapes as you fight your way through the war of tomorrow
<br>
<br>
<img src="http://www.overclockers.co.uk/LP/games/bf3/bf3_1.jpg"><br>
<img src="http://www.overclockers.co.uk/LP/games/bf3/bf3_2.jpg">
<br>
<br>
<b>(Please note this is an item which is not available until 28/10/11. Please order seperate or this could cause a problem with current orders being held.)</b><br><br>
<center><object width="640" height="390"><param name="movie" value="http://www.youtube.com/v/Ri_szIfDAyU?fs=1&amp;hl=en_US&amp;rel=0"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Ri_szIfDAyU?fs=1&amp;hl=en_US&amp;rel=0" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="390"></embed></object></center>
<br><br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/NDDfPxF3EFE" frameborder="0" allowfullscreen></iframe></center>
Was £36.98 Inc. VAT
Only £35.98 inc VAT.
ORDER NOW
Call Of Duty: Modern Warfare 3 - PC @ £37.79 inc VAT
nonl2br
<a href="http://cdn.steampowered.com/download/SteamInstall.msi"/>
<img src="http://www.overclockers.co.uk/LP/games/steamactivation.PNG"> <br><br></a>
<b>Call of Duty: Modern Warfare 3</b> begins exactly where Modern Warfare 2 left off. Although the remnants of Task Force 141 have neutralized rogue General John Shepard, Makarov is still on the loose and his diabolical plan seems to be working. Can 'Soap' MacTavish save the day?
Modern Warfare 3 is built for online multiplayer carnage. With Call of Duty Elite also scheduled to be launched, you will be able to track your kill/death ratio in Call of Duty: Modern Warfare 3 like never before. Rounding out Modern Warfare 3's explosive multiplayer package is the co-operative Spec-Ops mode, allowing you and a friend to team up for new co-op missions!
Tango Down, pop smoke! Preorder Modern Warfare 3 today!
<br><br>
• Sequel to the greatest FPS shooters of all time.<br>
• WW3 Set in various locations
• Intense adrenaline fueled multiplayer action
<br><br>
<b>(Please note this is an item which is not available until November. Please order seperatly or this could cause a problem with current orders being held.)</b><br>
<br>
Activision and Infinity Ward have confirmed that Call of Duty: Modern Warfare 3 will have dedicated server support at GamesCom 2011<br>
<center><iframe width="640" height="390" src="http://www.youtube.com/embed/coiTJbr9m04" frameborder="0" allowfullscreen></iframe></center><br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/kuOCCeXlszw" frameborder="0" allowfullscreen></iframe></center><br><br>
Was £38.99 Inc. VAT
Only £37.79 inc VAT.
ORDER NOW
Rage - PC @ £25.79 inc VAT
nonl2br
RAGE is the latest game from id Software, the acclaimed designers of such classics as the Wolfenstein, DOOM, and QUAKE series. Eagerly awaited by the gaming community, RAGE is already being touted as one of the industry’s most innovative first-person shooters, winning numerous awards at E3 2010, including ‘Best Overall Game of Show’ from IGN and three ‘Best of E3’ Game Critics Awards including ‘Best Console Game’. Set in the not-too-distant future after an asteroid impacts Earth, you emerge into a vast wasteland to discover humanity working to rebuild itself against such forces as bandit gangs, mutants, and more.<br><br
RAGE is a groundbreaking first-person shooter set in the not-too-distant future after an asteroid impacts Earth, leaving a ravaged world behind. You emerge into this vast wasteland to discover humanity working to rebuild itself against such forces as bandit gangs, mutants, and the Authority – an oppressive government regime that has a special interest in you in particular. Featuring intense first-person shooter action, breakneck vehicle combat, an expansive world to explore and jaw-dropping graphics powered by id’s revolutionary id Tech 5 technology, RAGE promises an experience like no other.<Br><br>
<b>STORY OVERVIEW:</b><br>
Fearing a planet-wide extinction from a massive asteroid headed towards Earth, world leaders are faced with the inexorable task of ensuring human survival. Left with few alternatives, life-sustaining pods filled with select people are buried deep beneath the earth’s surface. You are one of the chosen members of these modern day arks and abruptly enter the RAGE universe after surfacing alone. Leaving you to your own devices to stay alive in a world filled with those who prefer you dead, RAGE combines powerful storytelling with heart-pounding action.<br><br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/Or99qjmxSmY" frameborder="0" allowfullscreen></iframe></center>
Was £26.99 Inc. VAT
Only £25.79 inc VAT.
ORDER NOW
Stronghold 3 - PC @ £23.78 inc VAT
nonl2br
Stronghold 3 is the long-awaited third instalment in the award winning castle-building series. Set 10 years after the original, the Wolf it seems, has cheated death and during his painful recovery he’s become even more bitter and twisted. Now he seeks revenge. Raiding villages and towns during the dead of night, the Wolf has created a tide of panic and you and your allies are the only force that stand against him. In a stunning new update to the world’s favourite Castle Sim, will you triumph by day or die by night?<br>
Stronghold 3 builds upon the phenomenal success of its predecessors with numerous game-play elements including:<br>
<br>
• Build and manage mighty castles with an improved building system allowing unprecedented levels of realism and intricacy<br>
<br>
• Realistic physics and cutting-edge graphics make siege warfare more brutal than ever.<br>
<br>
• Watch your village spring to life in an amazing depiction of medieval village life<br>
<br>
• Story-driven gameplay engages players across two campaigns: combat or economic<br>
<br>
• Dramatic night time sieges add a new dimension to the Stronghold franchise<br>
<br>
• Besiege other players’ castles or defend your own in a range of action-packed online multiplayer modes<br>
<br>
• Attack or defend accurately re-created castles from the pages of history. Will you succeed where others failed?<br>
<br><br>
<center><iframe width="560" height="315" src="http://www.youtube.com/embed/yoivBzNbhzI" frameborder="0" allowfullscreen></iframe></center>
Was £24.98 Inc. VAT
Only £23.78 inc VAT.
ORDER NOW
Gigabyte GA-880GM-USB3 AMD 880G (AM3+) DDR3 Motherboard @ £59.98 inc VAT
nonl2br
<p><font face="Arial" color="#0066CC" size="4"><b>Introduction</b></font></p>
<p><font face="Arial" size="2">GIGABYTE's AMD motherboards are ready to support the new generation of AMD Phenom™II X 6 processors, delivering the very best platform for multitasking, multimedia and high performance gaming. </font></p>
<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / 880GM-USB3</b></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" width="95%" border="0" cellspacing="0" align="center">
<tr valign="middle">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img705.imageshack.us/img705/6789/ultradurable3.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">
<font size="2" face="Arial" color="#0066CC">Ultra Durable 3. <font color="#000000">A
2x copper PCB layer design reduces electrial impedance and lowers temperatures
for a more stable OC.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 1px 0 1px; border-style: solid; border-color: #dcdcdc;" width="5px">&nbsp;</td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img853.imageshack.us/img853/8321/usbpower3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">USB 3x Power Boost. <font color="#000000">Delivering
greater device compatibility and faster charge times.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img30.imageshack.us/img30/6495/crossfirej.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">ATI Hybrid Crossfire Support.
<font color="#000000">Delivering the ultimate in graphics performance for
gaming enthusiasts.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img803.imageshack.us/img803/5448/onoffcharge.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">ON/OFF Charge Technology. <font color="#000000">Allows
you to charge your iPad, iPhone or iPod even of your PC is off.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img16.imageshack.us/img16/957/usb3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Super Speed USB 3.0. <font color="#000000">Super
fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px">&nbsp;</td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">&nbsp;</td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / 880GM-USB3</font></b><font size="2">
<a href="http://www.gigabyte.com/products/product-page.aspx?pid=3412#sp">[Click
for Complete/Advanced]</a></font></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" cellpadding="0" cellspacing="0" width="95%" align="center" border="0" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" " align="left" width="114" height="26">
<font face="Arial" size="2" color="#0066CC">CPU</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="26">
<font face="Arial" size="2">Support for AM3 processors: AMD Phenom™
II processor/ AMD Athlon™ II processor<font size="1">(Go to GIGABYTE's
website for the latest CPU support list.)</font></font> </td>
</tr>
<tr valign="middle" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114">
<font face="Arial" size="2" color="#0066CC">Chipset</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089">
<font face="Arial" size="2">AMD 880G / SB710</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Memory</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="27">
<font face="Arial" size="2">4x DDR3 1800(OC)/1666/1333/1066 MHz memory modules
<br>
<font size="1">* Due to Windows 32-bit operating system limitation, when
more than 4 GB of physical memory is installed, the actual memory size displayed
will be less than 4 GB. </font></font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Onboard
Graphics </font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="24">
<font face="Arial" size="2">1x D-Sub, 1x DVI-D (up to 1920x1200), 1x HDMI
(up to 1920x1200)</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Audio</font></td>
<font face="Arial" size="2">Realtek ALC889 codec High Definition Audio 2/4/5.1/7.1-channel
w/ Support for S/PDIF Out</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">LAN</font></td>
<font face="Arial" size="2">1 x Realtek RTL8111E chips (10/100/1000 Mbit)
</font></td>
</tr>
<font face="Arial" size="2" color="#0066CC">Expansion Slots</font></td>
<p><font face="Arial" size="2">1 x PCI Express x16 slots, running at x16
(PCIEX16)<br>
<font size="1">* For optimum performance, if only one PCI Express graphics
card is to be installed, be sure to install it in the PCIEX16 slot.<br>
</font></font> <font face="Arial" size="2">1 x PCI Express x16 slots,
running at x8 (PCIEX8)<br>
<font size="1">* The PCIEX8 slot shares bandwidth with the PCIEX16 slot.
When the PCIEX8 slot is populated with a PCI Express graphics card, the
PCIEX16 slot will operate at up to x8 mode.</font><font face="Arial" size="2"><br>
1 x PCI Express x16 slots, running at x4 (PCIEX4)</font><font size="1"><br>
</font><font face="Arial" size="2"><font size="1">* The PCIEX4 slot shares
bandwidth with the PCIEX1 slot. When the PCIEX4 slot is populated, the
PCIEX4 slot will operate at up to x1 mode.</font></font><font size="1">
<br>
</font>2 x PCI Express x1 slot<br>
2 x PCI slots </font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Multi
Graphics Technology</font></td>
<font face="Arial" size="2">Support for 2-Way ATI CrossFireX™/NVIDIA SLI
technology.</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="34"><font face="Arial" size="2" color="#0066CC">Storage
Interface</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="34">
<p><font face="Arial" size="2">Chipset: 2x SATA 6Gb/s, 4x SATA 3Gb/s connectors,
w/ SATA RAID 0, RAID 1, RAID 5, and RAID 10</font></p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="43"><font face="Arial" size="2" color="#0066CC">USB</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="43"><font face="Arial" size="2">Chipset:
</font> <font face="Arial" size="2">4x on the back panel, 8x via USB brackets
on headers<br>
</font> <font face="Arial" size="2">Etron EJ168 chip: </font> <font face="Arial" size="2">2
USB 3.0/2.0 ports</font><font face="Arial" size="2"> on back panel</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Internal
I/O Connectors</font></td>
<font face="Arial" size="2">1 x 24-pin ATX main power connector, </font>
<font face="Arial" size="2">1 x 4-pin ATX 12V power connector, </font> <font face="Arial" size="2">2x
SATA 6Gb/s connectors, </font> <font face="Arial" size="2">4x SATA 3Gb/s
connector,</font> <font face="Arial" size="2">1 x CPU fan header, </font>
<font face="Arial" size="2">2</font><font face="Arial" size="2"> x system
fan headers, </font> <font face="Arial" size="2">1 x front panel header,
</font> <font face="Arial" size="2">1 x front panel audio header, </font>
<font face="Arial" size="2">1 x S/PDIF Out header, </font> <font face="Arial" size="2">4
x USB 2.0/1.1 headers</font><font face="Arial" size="2">, 1x Serial port
header</font><font face="Arial" size="2">, </font> <font face="Arial" size="2">1
x clearing CMOS button, </font> <font face="Arial" size="2">1x TPM header</font>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Back
Panel Connectors</font></td>
<font face="Arial" size="2">1 x PS/2 keyboard/mouse port, 1 x D-Sub, 1 x
DVI-D, 1 x HDMI, </font> <font face="Arial" size="2">1 x optical S/PDIF
Out connector</font><font face="Arial" size="2">, </font> <font face="Arial" size="2">4x
USB 2.0/1.1 ports, </font> <font face="Arial" size="2">2 x USB 3.0/2.0 ports,
1 x RJ-45 ports, </font> <font face="Arial" size="2">3 x audio jacks (Line
In/Line Out/Microphone) </font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">BIOS</font></td>
<font face="Arial" size="2">2 x 32 Mbit AWARD BIOS </font> <font face="Arial" size="2">Support
for DualBIOS™</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Form
Factor</font></td>
<font face="Arial" size="2">ATX Form Factor; 30.5cm x 22.5cm</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Warranty</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089"><font face="Arial" size="2">3
Year Gigabyte Warranty</font></td>
</tr>
</table>
Was £64.98 Inc. VAT
Only £59.98 inc VAT.
ORDER NOW
Rift 30 Day Timecard - Digital Email Delivery @ £7.79 inc VAT
The prepaid gamecard is a comfortable payment method to receive 30 additional days of gametime for RIFT. Follow the included descriptions and you are ready to play again in a few minutes.
After the expiration of the 30 days, the subscriptions fee has to be paid again – or you extend your gametime again with a Game Card. The full version of RIFT and an internet connection are needed to play.
Digital email delivery (no shipping cost)
Was £8.99 Inc. VAT
Only £7.79 inc VAT.
ORDER NOW
Rift 60 Day Timecard - Digital Email Delivery @ £15.79 inc VAT
The prepaid gamecard is a comfortable payment method to receive 60 additional days of gametime for RIFT. Follow the included descriptions and you are ready to play again in a few minutes.
After the expiration of the 60 days, the subscriptions fee has to be paid again – or you extend your gametime again with a Game Card. The full version of RIFT and an internet connection are needed to play.
Was £16.99 Inc. VAT
Only £15.79 inc VAT.
ORDER NOW
Bioshock 2 - Xbox360 @ £8.78 inc VAT
Set approximately 10 years after the events of the original BioShock, the halls of Rapture once again echo with sins of the past. Along the Atlantic coastline, a monster has been snatching little girls and bringing them back to the undersea city of Rapture. You are the very first Big Daddy as you travel through the decrepit and beautiful fallen city, chasing an unseen foe in search of answers and your own survival.
Multiplayer in BioShock 2 provides a rich prequel experience that expands the award-winning BioShock gameplay. Set during the fall of Rapture, players assume the role of a Plasmid test subject in the underwater city that was first explored in the original BioShock. Players will need to use all the elements of the game's toolset to survive as the full depth of the BioShock experience is refined and transformed into a unique multiplayer experience that can only be found in Rapture.
Was £9.98 Inc. VAT
Only £8.78 inc VAT.
ORDER NOW
Warhammer 40,000: Space Marine - Xbox360 @ £31.79 inc VAT
nonl2br
<b>Exclusive 24 page full colour Space Marine booklet & Redeem code* to download a golden version of the iconic Chainsword weapon for use in multiplayer games... be the envy of your enemies.</b><br>
(*Access to the PlayStation Network / Xbox Live / Steam is required to redeem your Golden Relic Chainsword code.)<br /><br />
Become an unstoppable one-man army in Relic's 3rd person action/shooter. Space Marine is a fast-paced third person action-shooter from Relic Games allowing players to don the armor of one of the emperor's chosen in a battle for the very survival of humanity.Featuring a seamless mix of melee and ranged combat, Space Marine will deliver a true next generation experience when it launches.<br /><br />
In Warhammer 40,000: Space Marine you are Captain Titus of the Ultramarines, humanity's last hope for survival in a war-ridden future. Step into the armour of this superhuman warrior and use a lethal combination of deadly weapons to crush overwhelming alien forces. Fight against the savage Orks and the unholy forces of Chaos in a brutally violent world based on the richest science fiction fantasy ever created.<br /><br />
- 3rd person action shooter: Space Marine takes the traditional 3rd person shooter genre and adds a new depth of visceral melee combat to deliver an experience like no other<br /><br />
- Experience life as a Space Marine: Players get the unique experience of life as one of the emperor's chosen, the unstoppable Space Marines<br /><br />
- Devastating weaponry: Players will get to unleash an arsenal of devastating weaponry against their foes<br /><br />
- Storm into battle: Step fearlessly into the heart of combat as an unstoppable Space Marine. Never hide, never cower, just purge all that stand in your way<br /><br />
- Unleash visible violent death: Using an innovative new combat system, switch seamlessly from high-calibre ranged weapons to devastating close-combat strikes. Taking out an enemy has never been so satisfying.<br /><br />
- Experience the dark future of Warhammer 40,000: Jump into a rich universe of awe-inspiring landscapes, deadly enemies, immense battles and ruthless annihilation<br /><br />
- Take the battle online: Form your own Space Marine squad or Chaos Space Marine warband and face off in 8 vs 8 online matches. Gain experience and unlock new weapons and armour to customize the Devastator, Assault, and Tactical Marine classes <br /><br />
<img src="http://www.overclockers.co.uk/LP/images/golden.jpg"><br />
<img src="http://www.overclockers.co.uk/LP/images/handbook.jpg">
Was £32.99 Inc. VAT
Only £31.79 inc VAT.
ORDER NOW
Sony PSP 3000 Handheld Console - Black @ £77.98 inc VAT
The PSP3000 PlayStation Portable Console has an improved LCD screen with a greater range of colours, a contrast ratio that's five times greater and half the pixel response time, so you can get involved in the clear details and smooth graphics of your games.
Thanks to Wi-Fi connectivity, the PSP-3000 lets you play against your friends from around the world, browse the internet - and say goodbye to cable clutter! It also means you can contact your friends via Skype and remotely access your PC, TV, DVD player, PS3 and more via DLNA.
You can connect to the PlayStation Store and PlayStation Network and download new content for your PSP-3000, rent and buy movies and TV shows, and watch free game demos, trailers and add-ons. You'll also be able to access to some of the best multimedia entertainment on your PSP-3000 PlayStation, such as movies available on UMD discs, more than 22,000 Internet radio stations and videos and music stored on Memory Stick Duo memory cards.
Was £89.98 Inc. VAT
Only £77.98 inc VAT.
ORDER NOW
Synology Diskstation DS211J 2-Bay Gigabit Ethernet Network Attached Storage Enclosure @ £155.98 inc VAT
nonl2br
Synology DiskStation DS211j is designed to provide a cost-effective file storage and backup solution with RAID protection for your home environments. The operating system, Synology DiskStation Manager, delivers rich features for multimedia enjoyments, worry-free backup, Internet sharing, and energy-saving options.Download Station functions as a 24x7 BitTorrent, FTP, HTTP, eMule, and NZB download center without a PC. The eMule download engine allows search-n-download capability with a web-browser without installing additional desktop applications.
<br><br>
Audio Station supports music, Internet radio stations, and iPod playback with the optional speakers. An optional direction-free Synology Remote allows you to freely enjoy your music. Streaming mode allows your music to be shared with multiple users over the Intranet or Internet.
<br><br>
DLNA/UPnP Compliant Media Sever allows you to stream multimedia files with an UPnP Digital Media Adapter (DMA) to a stereo system or a TV-set. Sony PS3 and Microsoft Xbox360 are also supported.
iTunes® Server is an easy way to share music with other iTunes clients over the network. Password protection prevents unauthorized sharing.
<br><br>
Back Up Your Precious Data - DiskStation Manager offers comprehensive solutions for you to back up data stored on DiskStation or your desktop computer to the DiskStation.<br><br>
Server backup includes two alternatives: Network Backup and Local Backup. Both allow you to back up data in the shared folders and databases. Incremental backup option and flexible schedules are available. All can be easily configured with a step-by-step wizard.<br><br>
Desktop backup provides your Windows PC with Synology Data Replicator for backing up desktop data, Outlook, and Outlook Express emails to your DiskStation by choosing one of the three backup modes: Immediate, Sync, and Scheduled backup, while Mac OS X users can use Apple Time Machine backup application to back up their critical data to DiskStation.<br><br>
USBCopy allows you to quickly back up your data from an USB storage device such as an USB flash or USB card reader to your DiskStation with just one single touch on the front-panel copy button.
Enrich Your Web Presence<br><br>
Photo Station simplifies photo, video, and blog sharing over the Internet. The flexibility of photo theme customization, blog layout arrangement, visitor’s privilege setting, RSS feed, and the dazzling 3-dimentional photo browsing with Cooliris make Photo Station your state-of-the-art lifestyle sharing center on the Internet.<br><br>
Web Station with built-in PHP+MySQL allows you to publish your own websites or install numerous popular open source programs.<br><br>
Access With Your Mobile Device<br>
The iPhone and Android App, DS audio, allows you to stream music stored on your DiskStation with your mobile devices where Internet access is available, while DS photo+ allows browsing and uploading photos and videos stored on DiskStation from your mobile devices.<br><br>
Synology Disk Station is designed and developed perpetually with the concept of energy saving. Compared with average PC counterparts, Synology Disk Station consumes a relatively low amount of power and has the HDDs hibernate when not in use. This not only helps to save energy but also extends the lifespan of the hard disk.<br><br>
Synology Disk Station truly earns the title of "green product" because of the unique Scheduled Power On/Off feature, and the smart fan design effectively cools down the system with minimum power consumption, yet keeps the system quiet on operation.<br><br>
Finally, all Synology products are produced with RoHS compliant parts and packed with recyclable packing materials. Synology recognizes its responsibility as a global citizen and is continually working to reduce the environmental impact of the products we create.<br><br>
<br><br>
• CPU Frequency: 1.2GHz<br>
• Hardware Encryption Engine<br>
• Memory: DDR2 128MB<br>
• Internal HDD1: 3.5" X2 or 2.5" SATA(II) X2<br>
• Max Internal Capacity: 6TB (2x 3TB hard drives)9<br>
• External HDD Interface: USB 2.0 port X3<br>
• Size (H x W x D): 161mm X 88mm X 218mm<br>
• Weight: 0.98kg<br>
• LAN: Gigabit x 1<br>
• Wireless Support<br>
• Fan: 1 x 70mm<br><br>
<a href="http://ripassets.s3.amazonaws.com/w...loads/products/datasheets/2010/oct/ds211j.pdf">
<img src="http://www.overclockers.co.uk/LP/interactivity/buttons/spec_button.png">
Was £161.98 Inc. VAT
Only £155.98 inc VAT.
ORDER NOW
QNAP Turbo NAS TS-110 1-Bay Network Attached Storage Enclosure @ £116.38 inc VAT
nonl2br
More and more people are turning to network attached storage (NAS) as an alternative for PC-based servers to store their digital contents (videos/ photos/ music) due to native NAS advantages such as low power consumption, small size, and easy installation/setup. The QNAP TS-110 Turbo NAS is the most economic single-drive storage solution for Prosumers and SOHO users who want a NAS with compelling features, solid performance, low power consumption, and high reliability.
<br><br>
Incorporating a Marvell 800 MHz CPU and 256MB DDRII RAM, the power consumption of the TS-110 Turbo NAS in operation is only 7W which is much less than that of a PC, and even an energy-saving bulb.
<br><br>
The TS-110 Turbo NAS is not only an ideal storage server but also a multimedia station to enhance your home entertainment experience. The built-in UPnP media server (with TwonkyMedia enabled) of the Turbo NAS supports gaming consoles, e.g. Sony PS3 and Microsoft Xbox 360, for media playing and the NAS works well with NFS-supported High-Definition (HD) digital media players.
<br><br>
The TS-110 is also the perfect download center for high speed BT/ Emule/ FTP/ HTTP download. You can use the Download Station with the QGet utility to manage your download tasks remotely over the local network or the Internet. Also, the TS-110's AJAX-based NAS management software utilizes a web interface that allows intuitive management of all the Turbo NAS features.
<br><br>
The TS-110 offers features more often found in much higher end NAS servers, including built-in iSCSI target service, remote replication, policy-based unauthorized IP blocking, SNMP (Simple Network Management Protocol), and network surveillance with two IP cameras (optional purchase).
<br><br>
<b>Key Features:</b><br>
• File Server - You can create the user ID and password, and define the access right and storage quota of each user on the NAS.<br><br>
• FTP Server - You can establish your own FTP server using the NAS and share the files conveniently with others.<br><br>
• Backup Server - The automatic backup software, NetBak Replicator, is provided for you to perform real-time synchronization or schedule backup from multiple PCs to the NAS.<br><br>
• Remote Replication - The data on the NAS can be backed up to or from another Turbo NAS or Rsync server over the network.<br><br>
• Web Server - The NAS supports Joomla!, MySQL, SQLite and editable php.ini.<br><br>
• MySQL Server - The NAS can be flexibly applied in various deployments such as a database server of another web server in remote site or as an additional backup database server.<br><br>
• Printer Server - The NAS supports network printer sharing function (max 3 USB printers).<br><br>
• UPnP Media Server (with built-in TwonkyMedia Server) - The NAS is a perfect media storage centre and it works well with UPnP Media Server compliant media players. You can play the photos and videos on TV, or listen to your favorite music and Internet radio on your Hi-Fi System.<br><br>
• Multimedia Station - You can share you photos, video, or music over the network by the Multimedia Station of the NAS.<br><br>
• Download Station - The NAS supports PC-less BitTorrent, FTP, and HTTP download. TCP/ UDP, encrypted BT download function, and DHT (Distributed Hash Tables) are also supported.<br><br>
• iTunes Server - You can stream the mp3 music on the NAS to the computers on the home network and listen to the music by iTunes over wired or wireless network connection.<br><br>
• Surveillance Station - The Surveillance Station enables you to configure multiple IP-based security cameras simultaneously for real-time monitoring, recording, and playback.<br><br>
<br><br><br>
The most comprehensive support for numerous brands of IP cameras
The Surveillance Station of QNAP NAS supports all the leading network camera brands such as AXIS, D-Link, IPUX, LevelOne, Linksys, Panasonic and Vivotek etc. By using particular models, users can use two-way video and audio monitoring and recording, and smart PTZ control to control the monitoring direction via the web interface. Each of the supported cameras has been put through stringent tests with the NAS series in QNAP's laboratory to guarantee 100% compatibility and reliability with all these camera brands.
<br><br>
<b>Powerful System Management Tools</b>
<br><br>
Smart Fan<br>
The fan rotation speed is automatically adjusted according to the server's temperature. You can also define the system temperatures to trigger high speed or low speed rotation of the fan. By manually setting the fan rotation speed, the fan will rotate at the defined speed continuously.
<br><br>
Instant SMS/ Email Alert<br>
You can configure the SMTP server and SMSC server settings on the NAS in order to receive instant system warning or error messages by email or SMS.
<br><br>
SNMP (Simple Network Management Protocol)<br>
Simple Network Management Protocol (SNMP) is widely used in network management systems to monitor network attached devices (e.g. NAS). You can set up SNMP trap for alerting via SNMP and there can be up to 3 SNMP trap addresses. Besides, you can also choose the system event log level in SNMP.
<br><br>
SSL Secure Certificate<br>
The administrator can upload a secure certificate and an RSA private key in X.509PEM format issued by a trusted provider in order to allow the users to access the NAS by secure SSL login.
<br><br>
Syslog Settings<br>
All the system event logs and connection logs can be saved to a remote syslog server.
<br><br>
Network Recycle Bin<br>
The files deleted from the network shares of the NAS will be moved to a particular recycle bin folder. You can restore your data anytime in case of unintended file deletion.
<br><br>
Comprehensive Event Log System<br>
The logs of connections to the NAS via samba, FTP, AFP, HTTP, HTTPS, Telnet, and SSH, and networking services accessed by online users are all recorded.
<br><br>
Detailed System Information<br>
You can view the system status, e.g., CPU usage, total memory, free memory, packets received, packets sent, error packets, system up time, CPU temperature, system temperature, HDD temperature, and system fan speed.
<br><br>
DDNS Support<br>
You can register a unique domain name from a DDNS service provider and assign it to your NAS. Your users can access the NAS by the domain name instead of the IP address.
<br><br>
Software Expansion and Website Management<br>
<br><br>
QPKG Software Package Platform<br>
The QPKG software package platform enables the users to maximize the usage of the NAS by installing additional software packages developed from the users and community worldwide. This can be done by simple "download & install" clicking without going through any complicated process.
<br><br>
<a href="http://ripassets.s3.amazonaws.com/w...s/products/datasheets/2009/nov/TS-110_ENG.pdf">
<br><br>
Was £119.98 Inc. VAT
Only £116.38 inc VAT.
ORDER NOW
Synology Diskstation DS1511+ 5-Bay Gigabit Ethernet Network Attached Storage Enclosure @ £629.98 inc VAT
nonl2br
Synology® DiskStation DS1511+ offers a high-performance, scalable, and full-featured network attached storage solution that meets the needs of small and medium-sized businesses that require an efficient way to centralize data protection, simplify data management, and rapidly scale storage capacity with minimal time spent on setup and management. The Synology DS1511+ is backed with Synology’s 3-year limited warranty.<br><br>
With the Link Aggregation enabled, Synology DS1511+ delivers an average 165.91 MB/sec writing speed under RAID 5 configuration in a Windows environment, and 197.8 MB/sec reading. The 2 LAN with failover support and hot-swappable drives will ensure continual service uptime should the drives need replacement or the unexpected LAN failure. Businesses need a strong foundation to face mission-critical tasks so the Synology DS1511+ delivers high-performance with high data availability ensuring access when it’s needed.<br><br>
Windows ADS integration allows the Synology DS1511+ to quickly and easily fit in an existing business network environment with no need to recreate users’ accounts on the Synology DS1511+. The User Home feature minimizes the administrator’s effort in creating a private shared folder for a large amount of users.<br><br>
Windows ACL support on DS1511+ provides much finer-grained access control and efficient privilege settings, allowing IT staffs to set up privileges to files and folders on DS1511+ through their familiar Windows user interface. The privileges set on Windows ACL will be applied to all access entries, including AFP, FTP, File Station, NFS and WebDAV. The secure privilege offers IT staff peace of mind, no worries about any loopholes.<br><br>
With the iSCSI support in DSM 3.0, the Synology DS1511+ provides a seamless storage solution for virtualization servers, such as VMware, Hyper-V, and Citrix. It is the ideal alternative to SAN solution for businesses. Affordable and cost-effective, iSCSI allows SMB users to consolidate storage into data center storage arrays while providing hosts with the illusion of locally-attached disks.<br><br>
When the storage capacity of the Synology DS1511+ is nearing its limits, it can easily be expanded by the Synology DX5103. The Synology DX510 securely connects to the Synology DS1511+ via an eSATA cable of specially-designed connectors on both ends to ensure maximum throughput. The Synology DX510 can directly expand the existing storage on the Synology DS1511+ to a maximum 45 TB capacity.<br><br>
The Synology DS1511+ runs on the renowned operating system, Synology DSM 3.0, offering comprehensive applications and features designed specifically for SMBs. Comprehensive network protocol support assures seamless file sharing across Windows, Mac, and Linux platforms.
Internet file access is simplified by the encrypted FTP server and the web-based file explorer, Synology File Station. HTTPS, firewall, and IP auto-block support ensure file sharing over the Internet is protected at a high security level.<br><br>
A wealth of additional features allows the Synology DS1511+ to replace several pieces of network hardware. Synology Web Station with support for PHP/MySQL content allows for the hosting of up to 30 websites on a single Synology DS1511+. Synology Surveillance Station offers a centralized interface to safeguard the office environments by deploying IP cameras throughout the network. The Mail Station add-on turns a Synology DS1511+ into a mail server with only few steps of installation and the USB printer sharing capability minimizes businesses’ printing cost by sharing printing resources throughout the office.<br>
<br><br>
- 165.91 MB/sec Writing, 197.8 MB/sec Reading<br>
- Windows ADS and ACL support<br>
- iSCSI Support as Virtualization Solution<br>
- Scale up to 15 Drives with Synology DX510<br>
- Expandable RAM Size (up to 3GB)<br>
- 2 LAN with Failover and Link Aggregation Support<br>
- Hot-swappable Hard Drives<br>
- CPU: 1.8GHz<br>
- RAM: 1GB<br>
- Internal HDD: 5 x 3.5" / 5 x 2.5" <br>
- External HDD Internal: 4 x USB2.0 & 2 x eSATA<br>
<br><br>
<a href="http://ripassets.s3.amazonaws.com/w.../2010/dec/Synology DS1511+ Data_Sheet_enu.pdf">
<br><br>
Was £635.98 Inc. VAT
Only £629.98 inc VAT.
ORDER NOW
Asus O!Play HD 1080P Media Streamer HDP-R1 @ £61.58 inc VAT
nonl2br
O!Play HDP-R1 provides the easiest way to enjoy HD content in the living room.<br><br>
HDP-R1 takes the trend to bring new HD experience to viewers in the living room. Simply connecting your O!Play HD Media Player via HDMI, users will witness the vivid and vibrant video coming to full wonder. With exclusive RMVB support on HDP-R1, users do not have to worry about the compatibilities of file format. To most of the video, music and picture formats, HDP-R1 let users plug in their storage and enjoy the show. HDP-R1 is the first HD media player to provide music shuffle function with a dedicated button on the remote control. Just one touch from a distance, O!Play accesses all the music files on the storage and then start playing the music randomly.<br><br>
<b>- Full HD 1080p Support</b><br>
By connecting the O!Play HD Media Player via HDMI, you can enjoy full 1080p high-definition video and digital audio using over a single cable. The HDP-R1 also features an optical digital audio output for lossless audio transfer to your receiver or TV. If you have yet to jump on the HDTV or digital audio bandwagon, no worries, the O!Play also features composite (RCA) audio and video outputs to ensure compatibility with most any setup.<br><br>
<b>- Small but Powerful</b><br>
O!Play may be compact, but it's fully equipped to play most formats in your digital library. O!Play supports these formats: Video Compression (MPEG1/2/4, RM/RMVB, VC-1, H.264) ,Video File Extension (.MP4, .MOV, .XVID, .AVI, .DIVX, .ASF, .WMV, .MKV, .RM, .RMVB, .FLV, .TS, .M2TS, .DAT, .MPG, .VOB), Audio (MP3, WAV, AAC, OGG, FLAC, AIFF), Image (JPEG, BMP, PNG, GIF, TIFF), Subtitle (SRT, SUB, SMI, SSA).
O!Play can also bitstream Dolby Digital and DTS Surround audio to your receiver to bring realism to the next level. If you plan on plugging the O!Play directly to your TV set, HDP-R1 can decode those formats and provide a stereo output without headache or hassle. With such a wide range of compatibility, you can enjoy your media without waiting for conversion.<br><br>
<b>- High Speed Connectivity (eSATA and US 2.0)</b><br>
HD content brings full details to your High Definition TV, but it also requires huge bandwidth to render that detailed content. This is why many consumers have invested in external drives with high-speed USB or eSATA interfaces. HDP-R1 provides an onboard eSATA (external SATA) port that is 6X faster than USB 2.0 for high speed transfer from your portable hard drives. And since the unit features both an eSATA/USB 2.0 combo port and a dedicated USB 2.0 port, you can store your media on drives with either interface, and access multiple drives simultaneously.<br><br>
<b>- Advanced LAN Network Support</b><br>
Those who have their media on network-attached-storage or a networked PC will be delighted to know that the O!Play features an on-board LAN port. With high-speed Ethernet connectivity, you can stream contents directly to the O!Play rather than moving and connecting external drives. No matter your media storage preference, the O!Play's got you covered.
<b>- Easy-to-Use Interface</b><br>
The O!Play features an intuitive user interface that lets you easily access the files on your storage device regardless of your technical know-how. It only takes a few clicks to begin enjoying your media. Plus, with advanced options, you can customize settings such as subtitles, aspect ratio, noise reduction and more, to optimize your viewing experience.<br><br>
<b>- Music Shuffle and More at Your Fingertips</b><br>
The O!Play features a full-function remote for navigating your media, complete with a unique dedicated button for instantly shuffling your music. Just press the Music Shuffle button, and O!Play accesses all the available music files for random playback. O!Play also works great as a photo viewer to easily share your vacation photos with your family and friends. Use the remote to control the slideshow.<br><br>
<b>- Enjoy more Internet media contents in the living room!</b><br>
The On-line Media feature allows you to browse over 5000 Internet TV channels, 20,000 Internet radio stations, Internet photo sharing sites, and weather updates directly streamed over the Internet to your O!Play.<br><br>
Was £63.98 Inc. VAT
Only £61.58 inc VAT.
ORDER NOW
Netgear DGN2200 Wireless-N 300Mbps ADSL2+ Router with ReadySHARE USB Port @ £65.38 inc VAT
The NETGEAR N300 Wireless ADSL2+ Modem Router Router is ideal for both professional and personal Internet use, providing Wireless-N speed for simultaneous downloads, voice and music, and online gaming. Complete with a built-in DSL modem, it is compatible with all major DSL Internet service providers. Storage for downloads is easy with ReadySHARE™ for shared access to a USB storage device.
The NETGEAR N300 Wireless ADSL2+ Modem Router Router is ideal for both professional and personal Internet use.
Providing Wireless-N speed for simultaneous downloads, voice and music, and online gaming. Complete with a built-in DSL modem, it is compatible with all major DSL Internet service providers. Storage for downloads is easy with ReadySHARE™ for shared access to a USB storage device.
• Built-in DSL modem - ADSL2+ modem and router combined create complete gateway for DSL Internet connection
• Faster downloads and online gaming - Provides Wireless-N speed for simultaneous downloads, streaming voice and music and
online gaming, in addition to basic Internet applications.
• Share Internet connection - Allows Internet broadband sharing and the freedom of wireless Internet usage
• Shared storage - ReadySHARE™ provides fast and easy shared access to an external USB storage device
• Easy setup - Smart Wizard® CD with graphical installation guide and multi-language support
• Live Parental Controls - Keeps your Internet experience safe
• Blocks unsafe Internet content and applications and can be managed from anywhere
• Protects connected devices through the router such as PCs, gaming consoles, and iPod touch®
• To learn more visit www.netgear.com/lpc
• Jitter-free voice and gaming - Automatic Quality of Service (QoS) for reliable Internet connections
• Guest network access - Provides separate security and access restrictions for guests using the network
• Broadband usage meter - Monitors Internet traffic and sends customized reports to help keep costs under control
• Secured connection - Push ‘N’ Connect offers a secured wireless Internet connection at the push of a button
• Compatibility - Compatible with all major DSL Internet service providers (ISPs)
Package Contents
N300 Wireless ADSL2+ Modem Router (DGN2200)
Stand
Ethernet cable
Phone cable
ADSL phone filter
Smart Wizard™ installation CD
Power adapter, localized to country of sale
Standards
IEEE™ 802.11 b/g/n 2.4 GHz
Performance
Four (4) Fast Ethernet ports
Security
Wi-Fi Protected Access™ (WPA/WPA2—PSK) and WEP
Intrusion detection and prevention (IDS)
Denial-of-service (DoS) attack prevention
Ease of Use
Push 'N' Connect using Wi-Fi Protected Setup™ (WPS)1
Physical Specifications
Dimensions: 173 x 128 x 33 mm (6.81 x 5.04 x 1.30 in)
Weight: 0.30 kg (0.65 lb)
Advanced Features
Live Parental Controls with flexible and customizable filter settings
ReadySHARE™ USB storage access — supports FAT16/32, NTFS Read/Write
Multiple SSID guest networks (separate security and access restrictions)
Broadband usage meter measures Internet usage
Power and Wi-Fi on/off buttons
Was £68.98 Inc. VAT
Only £65.38 inc VAT.
ORDER NOW
Cisco Linksys E4200 Wireless-N 450Mbps Router - Dual Band 5GHz @ £119.99 inc VAT
The Linksys E4200 is the latest and most advanced member of the Linksys E-series family offering network speeds of up to 450Mbps and a new innovative design. The ideal product to power your home entertainment.
With speeds of up to 450Mbps the Linksys E4200 is ideal for video streaming. Thanks to the integrated advanced technologies, this level of performance is available throughout the entire house:
- 3 x 3 antenna technology delivering 450Mbps on the 5GHz radio band
- SpeedBoost amplifiers that increase the signal strength across greater distances
- MIMO technology that uses the walls of your home to extend the coverage
Built on a single, thin floating plane, it's designed to help hide cables and ports; the flashing LED lights can also be turned off to allow for a calmer environment. In all, these features create a living-room ready router that can sit next to your best home entertainment system.
Cisco Connect software helps you to establish a secured wireless network 3 easy steps, customize your settings and quickly add multiple Internet devices to your network.
It also has key features to help you easily manage your wireless network:
- Wireless-N
- Broad Compatibility
- Simultaneous Dual Band: 2.4 & 5GHz
- Up to 450Mbps
- Maximium Range
- Speed Boost
- Advanced security
- Gigabit Enternet Ports
- USB Storage Port
- UPnP Media Server
- QoS
- Home Theater/Console Ready
Was £121.98 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
OcUK Value 300Mbps Wireless-N USB Adapter @ £9.59 inc VAT
The GN-621U is complied with wireless 802.11b/g/n standards with latest 11n MIMO technology to increase the wireless speed up to 6 times faster and extends the range 4 times further. The GN-621U also reduces "dead spots" within the wireless coverage. The transmission data rate when connecting with wireless 802.11n devices is up to 300Mbps, which makes signal travel farther and maintain wireless connections much reliable than traditional wireless 802.11b/g network.
Wi-Fi Protected Setup (WPS) is a standard for easy and secure establishment of a wireless network. This wireless USB adapter supports software WPS configuration. When both ends of the wireless devices supporting WPS, it will automatically configure the wireless network with robust WPA data encryption and authentication.
- Complies with wireless IEEE802.11b/g and IEEE802.11n standards
- Increases wireless coverage 4 times further
- Includes multi-language setup wizard
- Supports 64/128-bit WEP, WPA , WPA2 encryption and software WPS button
- Interface: USB 1.0/2.0 Type A One LED for Link/Activity 2 x Internal Printed Antennas
- Data Rate
- 11b: 1/2/5.5/11Mbps
- 11g: 6/9/12/24/36/48/54Mbps
- 11n (20MHz): MCS0-7 (up to 72Mbps)
- 11n (40MHz): MCS0-7 (up to 150Mbps)
- Security & Support OS:
- Supports 64/128-bits WEP, WPA, WPA2 for Security
- Support Windows 98SE/ME/2000/XP/Vista
- Standard & Frequency Band: Complies with IEEE802.11b/g and IEEE802.11n Standards
- 2.4 GHz
- Functions: Supports WMM (QoS)
- Supports Software WPS configuration
- Dimensions: 9 x 19.2 x 56 mm
- Certifications: CE & FCC
(please note product may vary from picture)
Was £9.98 Inc. VAT
Only £9.59 inc VAT.
ORDER NOW
TP-Link 150Mbps Wireless PCI Express Adapter (TL-WN781ND) @ £9.59 inc VAT
TP-LINK TL-WN781ND is designed to provide a complete end-to-end wireless performance from the server or server backbone to the switch infrastructure and down through to the desktop with the PCI Express connector. TL-WN781ND Wireless Lite N PCI Express(x1) Adapter provides a wider compatibility, fitting with any standard PCI Express slot, x1, x4, x8, or x16. Compared with standard PCI network cards, it offers increased bandwidth, reliability and more functionality, allowing you to enjoy a fast and advanced connection, such as downloading, making internet call and video streaming.
Complying with IEEE 802.11n, 802.11g and 802.11b standards, the TL-WN781ND Wireless Lite N PCI Express Adapter can perfectly interoperate with all the 802.11n/b/g devices. With WMM based on the IEEE 802.11e, it provides Quality of service (QoS) and prioritizes the network traffic. Also, WMM Power Save guarantees lower power consumption for environmental work.
TL-WN781ND features Quick Security Setup (QSS) function, which is ideal for creating an efficient and safe connection to prevent outside intrusion, and meanwhile maximize the management resources. With the external and detachable antennas, the TL-WN781ND can fit different operation environment and guarantee the easy installation.
The device comes with an auto-run CD that provides information about completing the internet connection step by step, which is quickly and hassle-free for any users, especially for novice users.
- Up to 150Mbps wireless transmission rate
- CCA technology automatically avoids channel conflicts using its channel selection feature
- Provides PCI Express interface
- Advanced secure connection with WPA/WPA2 encryption
- Bundled utility enables easy management
Was £9.98 Inc. VAT
Only £9.59 inc VAT.
ORDER NOW
OcUK Value 150Mbps Wireless-N PCI-Express Adapter @ £9.59 inc VAT
NWP200E is an 11n Wireless PCI Express Adapter that delivers unrivaled wireless performance for your Desktop PC. It complies with IEEE 802.11n draft standard and backward compatible with IEEE 802.11b/g. With this adapter, you can easily upgrade your Desktop PC wireless connectivity. Once connected, access the network with high-speed Internet connection while sharing photos, files, music, video, printers, and storage. Get a better Internet experience with a faster wireless connection so you can enjoy smooth digital phone calls, gaming, downloading, and video streaming. NWP200E also provides peer-to-peer communication among any compatible wireless users and no Access Point required. NWP200E provides maximum transfer rate up to 150Mbps and supports WEP, WPA, WPA2, WPS, 802.1x high-level WLAN security features that guarantee the best security for users.
- Data Transfer Rates 11Mbps (11b mode), 54Mbps (11g mode), 150 Mbps (11n mode )
- Standard IEEE 802.11n, IEEE 802.11g, IEEE 802.11b
- Operating Radius Indoor: 200m, Outdoor: 400m
- Radio Technology
- IEEE 802.11g/11n Orthogonal Frequency Division Multiplexing (OFDM)
- IEEE 802.11b Direct Sequence Spread Spectrum (DSSS)
- Interface x1 PCI Express 2.0
- Modulation Schemes DBPSK/DQPSK/CCK/OFDM
- Bandwidth 20MHz / 40MHz
- Roaming Full mobility and seamless roaming from cell to cell
- Antenna 1 Dipole Antennas
- Media Access Protocol CSMA/CA with ACK
- LED Indicators ACT
- Operating Frequency /Channel
- Range:2.4GHz~2.4835GHz
- FCC:1~11 Channels
- ETSI:1~13 Channels
- Receiver Sensitivity
- 11Mbps : -86dBm @ 8% PER
- 54Mbps : -74dBm @ 10% PER
- 11n(20MHz) : -72dBm ; 11n(40MHz) : -70dBm @ 10% PER
- Transmit Output Power 11b : 18dBm (+-1dBm), 11g : 15dBm (+-1dBm) , 11n(20M/40M) : 14dBm (+-1dBm)
- Power Consumption
- Rx : Max 0.74W at 802.11n Mode
- Tx : Max 0.53W at 802.11n Mode
- Max 0.44W at Link/Standardby Mode
- Working Mode Infrastructure, Ad-Hoc
- Supported OS Windows 2000, XP and Vista (32/64 bit), Win7
Was £9.98 Inc. VAT
Only £9.59 inc VAT.
ORDER NOW
TP-Link Gigabit PCI Network Adapter (TG-3269) @ £5.04 inc VAT
TG-3269 is a 10/100/1000Mbps, 32-bit 33/66MHz PCI-bus Gigabit Ethernet adapter. With single UTP/STP and the Auto-Negotiation (Nway) function support, the Card can auto-negotiate 10Mbps, 100Mbps or 1000Mbps speed, and half or full duplex mode with its link partner (a hub, for example). Supports ACPI, compliant with PCI2.2. Full range of drivers are provided for major Operating Systems.
- Supports 32-bit 33/66MHz PCI Bus
- Supports 10/100/1000Mbps Nway Auto-Negotiation
- Supports 10/100Mbps full and half duplex, 1000Mbps full duplex
- Supports Full Duplex Flow Control (IEEE 802.3x)
- Supports IEEE 802.1P, IEEE 802.1Q VLAN tag
- Supports Jumbo Frame
- Supports Auto-MDI/MDIX
- Provides Bootrom slot, supporting remote boot
- Supports ACPI, PCI power management
- Contain two large independent receive and transmit FIFOs
- One STP/UTP connector
- Provides LEDs to indicate network Link/Activity/Speed/Duplex
- Windows98/98se/2000/ME/NT/XP/2003/VISTA/Novell Netware/LINUX
- Plug and Play
Was £5.99 Inc. VAT
Only £5.04 inc VAT.
ORDER NOW
Gigabyte GA-M68MT-S2P (AM3) Motherboard - Retail @ £33.59 inc VAT
The GA-M68MT-S2P, based on NVIDIA GeForce7025/ nForce630a chipset and supports new generation of 45nm AMD AM3 Phenom II/ AthlonII processors, integrated DirectX 9 graphics engine, DDR3 memory controller, PCI Express interface and so on. With the 50000 hours Japanese solid capacitors for CPU VRM design, the GA-M68MT-S2P is able to provide user friendly computing, reach the maximum system performance easily while still able to save the power and environment in real life at the same time.
- CPU: Support for AM3 processors: AMD Phenom II processor/ AMD Athlon II processor, Hyper Transport Bus, 2000 MT/s;
- Chipset: NVIDIA GeForce 7025/nForce 630a chipset;
- Memory: 2 x 1.5V DDR3 DIMM sockets supporting up to 8GB of system memory, Dual channel memory architecture, Support for DDR3 1333(OC)/1066/800 MHz memory modules;
- Onboard Graphics Integrated in the Chipset: 1 x D-Sub port;
- Audio: Realtek ALC889 codec, High Definition Audio, 2/4/5.1/7.1-channel;
- LAN: Onboard Realtek RTL8211CL (10/100/1000Mbit);
- Expansion Slots: 1 x PCI Express x16 slot, running at x16, 2 x PCI Express x1 slots, 1 x PCI slot;
Storage Interface Chipset 4x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices, Support for RAID 0, RAID 1, RAID 5, RAID 10 and JBOD;
- USB Chipset: Up to 10 USB 2.0/1.1 ports (4 on the back panel, 6 via the USB brackets connected to the internal USB headers);
- Internal I/O Connectors: 1 x 24-pin ATX power connector, 1 x 4-pin ATX 12V power connector, 4 x SATA 3Gb/s connectors, 1 x CPU fan header, 1 x system fan header, 1 x front panel header, 1 x front panel audio header, 3 x USB 2.0/1.1 headers, 1 x parallel port connector, 1 x clearing CMOS jumper;
- Back Panel Connectors: 1 x PS/2 keyboard port, 1 x PS/2 mouse port, 1 x serial port, 1 x D-Sub port, 4 x USB 2.0/1.1 ports, 1 x RJ-45 port, 3 x audio jacks (Line In / Line Out / MIC In);
- I/O Controller: iTE IT8720 chip;
- H/W Monitoring: System voltage detection, CPU / System temperature detection, CPU / System fan speed detection, CPU / System warning temperature, CPU / System fan failure warning, CPU fan speed control;
- BIOS: 2 x 8 Mbit flash, Use of licensed AWARD BIOS, Support for DualBIOS, PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b;
- Warranty: 3 Years
Was £35.99 Inc. VAT
Only £33.59 inc VAT.
ORDER NOW
TP-Link 5 Port Gigabit Desktop Switch (TL-SG1005D) @ £14.64 inc VAT
The TL-SG1005D 5-port Gigabit Ethernet Switch provides you with a high-performance, low-cost, easy-to-use, seamless and standard upgrade to improve old network to 1000Mbps network. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files and other applications that have to move large files across the network almost instantly.
TL-SG1005D adopts Green Ethernet technology. It can automatically power down ports that have no link, and budget power output for different cable length. With Green Ethernet technology, T:-SG1005D can help you save power and network cost.
- Adopts Green Ethernet technology, saving power and cost
- Supports IEEE 802.3x flow control for Full-Duplex mode and backpressure for Half-Duplex mode
- Non-blocking switching architecture that forwards and filters packets at full wire-speed for maximum throughput
- Supports MAC address auto-learning and auto-aging
- Plastic case, desktop or wall-mounting design
- External power adapter supply
Was £15.59 Inc. VAT
Only £14.64 inc VAT.
ORDER NOW
Netgear Powerline Adapter XAVB2001-100UKS 200Mbps @ £74.39 inc VAT
Extends a high speed Internet connection to any power outlet
Perfect for connecting HDTVs, Blu-ray™ players, DVRs, PCs and game consoles to your home network and the Internet
Compact design with push-button security
Turn any electrical outlet into a high-speed home network connection
• Extends a high speed Internet connection to any power outlet to connect HDTVs, Blu-ray™ players, DVRs, PCs and game consoles
• Extra outlet provides noise filtering power socket for additional devices
• Sets up in minutes with Push-and-Secure
• Automatic Pick-a-Plug display for highest performance
NETGEAR Green Product NETGEAR Green
• Automatically powers down when not connected or not in use
• Disable LEDs to help save energy
• Packaging manufactured with at least 95% recycled materials
Was £78.98 Inc. VAT
Only £74.39 inc VAT.
ORDER NOW
Edimax HP-5001K 500Mbps Powerline Adapter Kit @ £77.16 inc VAT
The HP-5001 can transmit network data over existing electrical wires at speeds of up to 500Mbps. It is also backward compatible with the 200Mbps HomePlug AV standard. Additionally, the HP-5001 is built with a highspeed gigabit (10/100/1000Mbps) Ethernet port. You can give network devices like computers, game consoles, HDTVs, and IP cameras ultrafast network connectivity with the HP-5001.
IPTV, VoIP & IGMP Support
The HP-5001 supports Internet Protocol Television (IPTV) and Voice over Internet Protocol (VoIP), giving you the flexibility of using this powerline adapter with your IPTV set-top box or your Internet telephone. The HP-5001 also supports IGMP multicast services. With IGMP, the HP-5001 allows for online video streaming, online gaming, and more efficient use of bandwidth resources. You will be able to transfer high-definition video and digital audio simply by connecting the HP-5001 to an electrical outlet.
Hardware Group & Reset Buttons
The HP-5001 has both a hardware group button and a hardware reset button for simplified group and reset configurations. Press the group button and the HP-5001 will help you set up a password for your network automatically. Press the reset button for 3 seconds to reset the device to factory defaults.
128-bit AES Encryption
Built in compliance with the 128-bit AES encryption standard, the EDIMAX HP-5001 500Mbps PowerLine
Key Features
- Transmit Network Data via Existing Electrical Wires
- PowerLine Data Rates Up to 500Mbps & Gigabit Ethernet Connectivity
- IPTV, VoIP & IGMP Support
- Hardware Group & Reset Buttons
- 128-bit AES Encryption
Was £79.56 Inc. VAT
Only £77.16 inc VAT.
ORDER NOW
TP-Link AV 500 Gigabit PowerLine HomePlug Adapter Kit @ £86.39 inc VAT
The new TP-Link TL-PA511KIT AV 200 Powerline Adapter kit is the new 500Mbps HomePlug that takes advantage of your homes existing electric wires to transfer data fast! That means, with no additional wiring required, users can simply plug one of the TP-Link TL-PA511KIT AV 500 Powerline Adapter into an existing power socket and establish networking infrastructure in a flash*. With high-speed data transfer rates of up to 500Mbps, you can enjoy HD video streaming, online gaming, VoIP or any other high bandwidth intensive tasks all at the same time now.
Key Features
- Complete HomePlug Powerline starter kit, includes 2x TL-PA511 500Mbps HomePlug Adapters
- HomePlug AV standard compliant, high-speed data transfer rate of up to 500Mbps, enough for HD video
- 1x 10/100/1000 Mbps Gigabit RJ45 Network port for connection a wired device such as an Xbox 360
- Super Small Design with a new exterior, blends in completely in front of any power outlet
- Up to 300 meters range over the household power circuit for better performance through walls or across floors
- Patented Power-Saving Mode automatically reduces power consumption by up to 65%**
- Establish a 128-bit AES encryption to secure powerline communications simply by pressing the Pair button on the adapter
- Built-in QoS assures the quality of bandwidth sensitive applications such as voice, video and online games
- Supports IGMP managed multicast IP transmission, optimizes IPTV streaming
- A wide range of plug type including EU, UK, AU and US ensures that it can be used nearly all over the world
Easy Plug and Play operation, No configuration required
Super Small Design
With a new ultra-compact housing design, This TP-Link TL-PA511KIT AV 500 Powerline Adapter Kit is much smaller than most other 500Mbps Powerline Products. At just 30mm thick and with its high quality, elegant white shell, it almost blends in completely in front of any power outlet and additionally can be placed anywhere in the room.
Pair Button for Easy Network Security
Simply push the Pair button on the adapters** and then you can set up a hassle-free Powerline network within minutes, which features 128-bit AES encryption for network security and data protection.
Plug the adapter into the power outlet
Connect the device via the network cable to the adapter
Press the encryption buttons—and youre done
Fast HomePlug Networking Up to 500Mbps
With advanced HomePlug AV technology, Each TP-Link TL-PA511KIT AV 500 Powerline Adapter kit provides you stable, high-speed data transfer rate up to 500Mbps on a line length up to 300 meters. Together with the built-in Qos and powerful AES encryption, a TP-Link TL-PA511KIT AV 500 Powerline Adapter Kit is a good choice for a whole home solution to connect all network compatible devices--from computers and game consoles to set-top boxes for IPTV to printers and to NAS hard drives--and supplies them with broadband Internet.
Power Saving Up to 65%
The TP-Link TL-PA511KIT AV 500 Powerline Adapter kit, a new-generation HomePlug AV Adapter, with its logical practical product design and sophisticated Power-Saving Mode, it now consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular Working Mode to Power-Saving Mode that will reduce the energy consumption by up to 65%**
Was £89.99 Inc. VAT
Only £86.39 inc VAT.
ORDER NOW
Asus P8Z68-V Intel Z68 (Socket 1155) DDR3 Motherboard @ £124.98 inc VAT
nonl2br
<hr />
<table border="0">
<tbody>
<tr>
<td colspan="2">
<h3>
UEFI BIOS (EZ Mode)</h3>
</td>
<td colspan="4">
&nbsp;</td>
</tr>
<tr>
<td colspan="7">
<p>
<img alt="" src="http://www.asus.com/websites/global/images/icons/mb_color/UEFI.gif" style="width: 86px; height: 95px; float: left;" /></p>
<p style="margin-bottom: 0em;">
<strong>Flexible &amp; Easy BIOS Interface</strong><br />
Exclusive to ASUS motherboards, its UEFI (Unified Extensible Firmware Interface) is the first ever mouse-controlled graphical BIOS interface designed with dual selectable modes. It delivers a user-friendly interface that goes beyond traditional keyboard-only BIOS controls to enable more flexible and convenient input with quick scrolling. Users can easily navigate the UEFI BIOS with the smoothness of their operating system. Quick and simple overclocking and setup sharing is facilitated by the F12 hotkey BIOS snapshot feature. The exclusive EZ Mode displays frequently-accessed setup info, while the Advanced Mode is for experienced performance enthusiasts that demand far more intricate system control, including detailed DRAM information.</p>
</td>
</tr>
<tr>
<td colspan="6">
<hr />
</td>
</tr>
<tr>
<td colspan="2">
<h3>
LucidLogix&reg; Virtu</h3>
</td>
<td colspan="4">
<h3>
&nbsp;</h3>
</td>
</tr>
<tr>
<td colspan="6" valign="top">
<strong>Universal Switchable Graphics Technology</strong><br />
LucidLogix&reg; Virtu is designed for the Intel&reg; Sandy Bridge platform's powerful integrated graphics. Its GPU virtualization dynamically assigns tasks to the best available graphics resources based on power, performance and system load on Windows&reg; 7 based PCs. It allows users to fully utilize the unique capabilities of advanced Sandy Bridge multimedia features alongside the high end 3D rendering performance provided by installed graphics cards. When no discrete graphics are needed, the graphics card is put in idle mode to lower utilization, heat, fan speed and power draw down to near zero, making the system more environmentally-friendly. For users with diverse needs, LucidLogix&reg; Virtu GPU virtualization provides great flexibility and efficiency.</td>
</tr>
<tr>
<td valign="top">
<strong>Universal Switchable Graphics </strong><br />
<span>LucidLogix&reg; Virtu's GPU virtualization technology assigns tasks to the best available GPU, allowing dynamic graphics switching between integrated graphics and NVIDIA&reg; or AMD graphics cards.</span></td>
<td valign="top">
<img alt="" src="http://www.asus.com/websites/global/products/JjlGHLJGJPFfGCFA/LucidLogix_new.jpg" style="width: 209px; height: 174px;" /></td>
<td colspan="3" valign="top">
<strong>3X Faster Video Conversion</strong><br />
<span>With switchable graphics, all ASUS P8Z68 Series motherboards leverage the transcoding power of Sandy Bridge, allowing users to enjoy three times faster video conversion with Intel&reg; Quick Sync Video technology.</span></td>
<td valign="top">
<img alt="" src="http://www.asus.com/websites/global/products/JjlGHLJGJPFfGCFA/VideoConversion.jpg" style="width: 203px; height: 202px;" /></td>
</tr>
<tr>
<td colspan="6">
<hr />
</td>
</tr>
<tr>
<td colspan="6">
<h3>
Intel&reg; Smart Response Technology<img alt="" src="http://www.asus.com/websites/global...fGCFA/Intel_Smart_Response_Technology_new.jpg" style="width: 473px; height: 188px; float: right;" /></h3>
<strong>SSD Speed with HDD Capacity</strong><br />
Intel&reg; Smart Response Technology boosts overall system performance. It uses an installed fast SSD (min 18.6GB available capacity) as a cache for frequently accessed data. Harness the combination of SSD-like performance and response with hard drive capacity, that's 4X faster than a HDD-only system.</td>
</tr>
<tr>
<hr />
</td>
</tr>
<tr>
<td colspan="2" rowspan="1" valign="top">
<h3>
DIGI+ VRM</h3>
</td>
<td colspan="4" rowspan="1" valign="top">
<h3>
Dual Intelligent Processors 2</h3>
</td>
</tr>
<tr>
<p>
<strong>Herald the Arrival of a New Digital Power Design Era</strong></p>
<ul>
<li>
<strong>Faster sensing and response:</strong> ASUS DIGI+ VRM acts as a digital controller to perfectly match digital power signal (SVID) requests from the CPU, eliminating digital-to-analog conversion lag.</li>
<li>
<strong>Better cooling:</strong> exclusive dual driver and MOS design doubles the heat dissipation area with expanded cooling surfaces for improved thermal performance. Spacing components out over a wider area speeds up cooling to enhance reliability and stability.</li>
<li>
<strong>2X CPU power supply:</strong> the same exclusive dual driver and MOS design also provides twice the CPU power supply with two complete power stages. This results in far greater phase load tolerances, so the CPU never has to wait for power to arrive, increasing performance and overclocking potential.</li>
</ul>
</td>
<p>
<strong><img alt="" src="http://www.asus.com/websites/global/images/icons/mb_color/TPU.gif" style="width: 95px; height: 95px; float: left;" />TPU - The Ultimate Turbo Processor</strong><br />
Unleash your performance with ASUS' simple onboard switch or AI Suite II utility. The TPU chip offers precise voltage control and advanced monitoring through Auto Tuning and TurboV functions. Auto Tuning offers a user friendly way to automatically optimize the system for fast, yet stable clock speeds, while TurboV enables unlimited freedom to adjust CPU frequencies and ratios for optimized performance in diverse situations.</p>
<p>
<strong><img alt="" src="http://www.asus.com/websites/global/images/icons/mb_color/EPU.gif" style="width: 80px; height: 95px; float: left;" />EPU - Energy Efficiency All Around</strong><br />
Tap into the world's first real-time PC power saving chip through a simple onboard switch or AI Suite II utility. Get total system-wide energy optimization by automatically detecting current PC loadings and intelligently moderating power consumption. This also reduces fan noise and extends component longevity!</p>
</td>
</tr>
<tr>
<hr />
</td>
</tr>
<tr>
<td colspan="2" valign="top">
<h3>
GPU Boost</h3>
</td>
<h3>
BT GO!</h3>
</td>
</tr>
<tr>
<strong><img alt="" src="http://www.asus.com/websites/global/images/icons/mb_color/GPUBoost.gif" style="width: 92px; height: 95px; float: left;" />Go to the Limit with iGPU Level Up! </strong><br />
GPU Boost accelerates the integrated GPU for extreme graphics performance. The user-friendly interface facilitates flexible frequency adjustments. It easily delivers stable system-level upgrades for every use.</td>
<strong><img alt="" src="http://www.asus.com/websites/global/images/icons/mb_color/BT_GO.gif" style="width: 80px; height: 95px; float: left;" />Diverse Bluetooth Enjoyment, New Technology Lifestyle</strong><br />
Onboard Bluetooth wireless design enables smart connectivity to Bluetooth devices with no additional adapter. ASUS BT GO! comes with 7 special functions that offer a significant breakthrough in Bluetooth evolution, including Folder Sync, BT Transfer, BT Turbo Remote, BT-to-Net, Music Player, Shot and Send, and Personal Manager. All are accessible through the exclusive, user-friendly ASUS interface.</td>
</tr>
<tr>
<hr />
</td>
</tr>
<tr>
<img alt="" src="http://www.asus.com/websites/global/products/f0AT3LgZYgFPjNJ8/product_overview.jpg" style="width: 675px; height: 457px;" /></td>
</tr>
</tbody>
</table>
<br />
Was £133.98 Inc. VAT
Only £124.98 inc VAT.
ORDER NOW
EK-VGA Supreme HF - Nickel Acetal @ £37.79 inc VAT
EK-VGA Supreme HF (HF stands for High Flow; revised version) is a universal high performance GPU waterblock designed for the needs of hardcore enthusiast users.
EK-VGA Supreme HF is a direct successor of the world renown EK-VGA Supreme waterblock launched in 2007.
It's main improvements are:
- better flow: due to improved design up to 50% higher flow compared to EK-VGA Supreme
- better cooling performance: up to 3°C lower GPU temperatures
The EK-VGA Supreme HF's cooling engine uses fin design. The water (coolant) accelerates through thin jet plate's channels and turbolently continues it's path through 31 very thin channels which provide large cooling surface area. Very thin copper base bottom wall even further improves cooling performance.
The base plate is made of electroless nickel plated (EN) electrolytic copper lapped and polished to +/- 0,0007 mm flatness. The top is made of quality cast acrylic material.
EK-VGA Supreme HF series waterblocks supports majority of nVidia and AMD high-end graphics cards. Please check compatibility at EK's CoolingConfigurator.
Enclosed in the box:
- EK-VGA Supreme HF series waterblock
- mounting mechanism
Full Compatibility List Available Here:
http://www.coolingconfigurator.com/waterblock/3831109805008
G1/4" threaded fittings are not included!
PLEASE NOTE:
-Due to immense variety of fittings/barbs available on the market and no prescribed standard we guarantee compatibility only for connectors bought from EK Webshop.
-Any heat generating components such as VRM (voltage regulation) or RAM chips needs to be actively or passively cooled by user's preferable method (passive heat sinks, air cooling, ...)
- Due to superior nickel plating method and corrosion resistance, the waterblock may loose brightness over time and become of a bit duller tone.
Was £38.99 Inc. VAT
Only £37.79 inc VAT.
ORDER NOW
EK-DDC X-TOP Rev.2 Acetal Pump Top @ £16.79 inc VAT
#1 DDC TOP currently on the market.
Compatible with all DDC style pumps.
Increases head pressure and improves flow.
gives the user the option to use standard G1/4 watercooling fittings.
EK-DDC X-TOP rev.2 Acetal
Threads: G1/4
Dimensions: 67×62×20mm
Included:
- 4 M4x24mm screws
- Weight of the packet 160g
- fittings not included
Was £16.99 Inc. VAT
Only £16.79 inc VAT.
ORDER NOW
Alphacool 120mm x 100mm Velcro Pad @ £1.44 inc VAT
- 120mm x 100mm Velcro Pads
- Can be used to make pumps stationary within your case
- The use for these pars are unlimited, use your imagination!
- Both parts are self adhesive
Was £1.99 Inc. VAT
Only £1.44 inc VAT.
ORDER NOW
Hardware Labs Black ICE SR-1 240 Radiator @ £65.18 inc VAT
The Black Ice® SR1-240 bridges the gap between ultra-stealth and extreme high performance allowing it to effectively utilize sub-1000 rpm fans and scale performance up to 2000rpm. Ultra-stealth operation with increased thermal capacity, and from the industry's standard bearer for quality and craftsmanship.
Features:
- Two-pass u-flow configuration utilizing high-flow tubes for up to 40% increase in internal flow rates.
- Custom compressed core width to maximize airflow and enhance heat exchange.
- Optimized custom 9 FPI (Fins Per Inch) 45 micron copper maximized conductivity.
- Yields up to 30% more heat exchange capacity than the Black Ice® GTX in ultra-stealth operation mode up to 2000rpm.
- Built-in 15mm deep plenum for equalized core air pressure distribution.
- M4 Threaded Screw Holes for easier mounting and greater adaptability.
- Standard G 1/4" female threaded fittings.
- Full high-temper brass structural construction for weight reduction and superior corrosion resistance.
- High performance compact radiator compatible as an upgrade to the Black Ice® Xtreme III, Black Ice® GTX240 and most 3x120mm fan form factor radiators.
- Uses 100% Non-corrosive water-soluble fluxing process.
- Fully RoHS compliant.
- Full electrostatic polyurethane painting finish for uniform coating with high temperature curing for increased finish durability.
- Carbon Black Finish.
- Renowned Black Ice® quality.
- Patent Pending Design.
Was £69.98 Inc. VAT
Only £65.18 inc VAT.
ORDER NOW
Gigabyte Z68XP-UD3P Intel Z68 (Socket 1155) DDR3 Motherboard @ £119.99 inc VAT
nonl2br
<p><font face="Arial" color="#0066CC" size="4"><b>Introduction</b></font></p>
<p><font face="Arial" size="2">GIGABYTE Z68 series motherboards provide all the advanced overclocking features users have come to know and love about the GIGABYTE P67 series motherboards including increasing processor core ratios, increasing DDR3 memory ratios and increasing power and current limits. In addition, GIGABYTE Z68 motherboards also allow users to increase the graphics core clock speed, for even greater graphics performance. </font></p>
<p><font face="Arial" color="#0066CC" size="4"><b>Special Features / Z68XP-UD3P-B3</b></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" width="95%" border="0" cellspacing="0" align="center">
<tr valign="middle">
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img830.imageshack.us/img830/9393/intelb.jpg" width="82" height="50"></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="*">
<font face="Arial" color="#0066CC" size="2">For INTEL&reg; 1155 Core i3/i5/i7
Sandybridge Processors. <font color="#000000">The latest CPU technology.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 0 1px 0 1px; border-style: solid; border-color: #dcdcdc;" width="5px">&nbsp;</td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img853.imageshack.us/img853/8321/usbpower3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">USB 3x Power Boost. <font color="#000000">Delivering
greater device compatibility and faster charge times.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img715.imageshack.us/img715/2475/touchbios.jpg" width="82" height="50"></td>
<font size="2" color="#0066CC" face="Arial">GIGABYTE Touch BIOS™. <font color="#000000">A
new innovative way to modify BIOS settings.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img62.imageshack.us/img62/4753/crossfiresli.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">2-Way SLI or 2-Way Crossfire
Support. <font color="#000000">Delivering the ultimate in graphics performance
for gaming enthusiasts.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img21.imageshack.us/img21/5617/ssdcache.jpg" width="82" height="50"></td>
<font face="Arial" size="2" color="#0066CC">Supports Intel&reg; Smart Response
Technology. <font color="#000000">Use a 20GB+ SSD as HDD Cache offering
up to 4x speed increase.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img803.imageshack.us/img803/5448/onoffcharge.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">ON/OFF Charge Technology. <font color="#000000">Allows
you to charge your iPad, iPhone or iPod even of your PC is off.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img600.imageshack.us/img600/1639/12phase.jpg" width="82" height="50"></td>
<font face="Arial" size="2" color="#0066CC">Industry's Leading TRUE 12 Phase
Power Design. <font color="#000000">Seamless CPU power delivery, for a cooler
and more stable OC.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img17.imageshack.us/img17/2311/sata3b.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">SATA 6 Gbps. <font color="#000000">High
speed 6 Gbps link speeds with raid support.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="5px"><img src="http://img696.imageshack.us/img696/5028/dualbiosa.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">DualBIOS™ 3TB+ HDD Support.
<font color="#000000">Two physical BIOS ROMs, auto recovery plus 3TB+ HDD
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img16.imageshack.us/img16/957/usb3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Super Speed USB 3.0. <font color="#000000">Super
fast transfer rates of up to 5 Gbps, 10x faster than USB 2.0.</font></font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img705.imageshack.us/img705/6789/ultradurable3.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Ultra Durable 3. <font color="#000000">A
2x copper PCB layer design reduces electrial impedance and lowers temperatures
for a more stable OC.</font></font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="82px"><img src="http://img21.imageshack.us/img21/6616/lucidvirtu.jpg" width="82" height="50"></td>
<font size="2" face="Arial" color="#0066CC">Lucid Virtu Switchable Graphics.
<font color="#000000">Allows power saving and built-in multimedia Intel&reg;
features like Quicksync.</font></font></td>
</tr>
</table>
<p><font face="Arial" color="#0066CC" size="2"><b><font size="4">Tech Spec / </font><font face="Arial" color="#0066CC" size="4"><b>Z68XP-UD3P-B3</b></font></b><font size="2">
<a href="http://www.gigabyte.com/products/product-page.aspx?pid=3912#ov">[Click
for Complete/Advanced]</a></font></font></p>
<table style="border-width: 0 0 1px 1px; border-spacing: 0; border-collapse: collapse; border-style: solid; border-color: #dcdcdc;" cellpadding="0" cellspacing="0" width="95%" align="center" border="0" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" " align="left" width="114" height="26">
<font face="Arial" size="2" color="#0066CC">CPU</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="26">
<font face="Arial" size="2">Support for Intel<sup>®</sup> Core™ i7/ i5 /
i3 and Celeron<sup>®</sup>, Socket 1155<font size="1">(Go to GIGABYTE's
website for the latest CPU support list.)</font></font> </td>
</tr>
<tr valign="middle" >
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114">
<font face="Arial" size="2" color="#0066CC">Chipset</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089">
<font face="Arial" size="2">Intel<sup>®</sup> Z68 Express Chipset</font>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Audio</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="24">
<font face="Arial" size="2">Realtek ALC889 codec High Definition Audio 2/4/5.1/7.1-channel
w/ Support for S/PDIF Out</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="27"><font face="Arial" size="2" color="#0066CC">Memory</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="27">
<font face="Arial" size="2">4x DDR3 2133/1866/1600/1333/1066 MHz memory
modules <br>
<font size="1">* Due to Windows 32-bit operating system limitation, when
more than 4 GB of physical memory is installed, the actual memory size displayed
will be less than 4 GB. </font></font> </td>
</tr>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">Onboard
Graphics </font></td>
<font face="Arial" size="2">1 x HDMI port (max res 1920x1200)</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="24"><font face="Arial" size="2" color="#0066CC">LAN</font></td>
<font face="Arial" size="2">1 x Realtek RTL8111E chips (10/100/1000 Mbit)
</font></td>
</tr>
<font face="Arial" size="2" color="#0066CC">Expansion Slots</font></td>
<p><font face="Arial" size="2">1 x PCI Express x16 slots, running at x16
(PCIEX16)<br>
<font size="1">* For optimum performance, if only one PCI Express graphics
card is to be installed, be sure to install it in the PCIEX16 slot.<br>
</font></font> <font face="Arial" size="2">1 x PCI Express x16 slots,
running at x8 (PCIEX8)<br>
<font size="1">* The PCIEX8 slot shares bandwidth with the PCIEX16 slot.
When the PCIEX8 slot is populated with a PCI Express graphics card, the
PCIEX16 slot will operate at up to x8 mode.<br>
</font>3 x PCI Express x1 slot<br>
</font> <font face="Arial" size="2">2 x PCI slots </font> </p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Multi
Graphics Technology</font></td>
<font face="Arial" size="2">Support for 2-Way ATI CrossFireX™/NVIDIA SLI
technology.</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="34"><font face="Arial" size="2" color="#0066CC">Storage
Interface</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="34">
<p><font face="Arial" size="2">Chipset: 2x SATA 6Gb/s, 4 x SATA 3Gb/s connectors
w/</font><font face="Arial" size="2"> SATA RAID 0, RAID 1, RAID 5, and
RAID 10</font><br>
<font face="Arial" size="2">Marvel: 2x SATA 6GB/s w/ SATA RAID 0 and RAID
1 </font> </p>
</td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114" height="43"><font face="Arial" size="2" color="#0066CC">USB</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089" height="43"><font face="Arial" size="2">Chipset:
</font> <font face="Arial" size="2">8x on the back panel, 6x via USB brackets
on headers<br>
</font> <font face="Arial" size="2">2x Etron EJ168 chips: </font> <font face="Arial" size="2">Up
to 4 USB 3.0/2.0 ports (2 on the back panel, 2 headers)</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">IEEE
1394</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089"><font face="Arial" size="2">VIA
VT6308 chip: </font> <font face="Arial" size="2">1 on the back panel, 1
via header</font></td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Internal
I/O Connectors</font></td>
<font face="Arial" size="2">1 x 24-pin ATX main power connector, </font>
<font face="Arial" size="2">1 x 8-pin ATX 12V power connector, </font> <font face="Arial" size="2">4x
SATA 6Gb/s connectors, </font> <font face="Arial" size="2">4 x SATA 3Gb/s
connector,</font> <font face="Arial" size="2">1 x CPU fan header, </font>
<font face="Arial" size="2">2 x system fan headers, </font> <font face="Arial" size="2">1
x power fan header, </font> <font face="Arial" size="2">1 x front panel
header, </font> <font face="Arial" size="2">1 x front panel audio header,
</font> <font face="Arial" size="2">1 x S/PDIF Out header, </font> <font face="Arial" size="2">3
x USB 2.0/1.1 headers, </font> <font face="Arial" size="2">1 x USB 3.0/2.0
headers, 1x Serial port header,</font> <font face="Arial" size="2">1 x IEEE
1394a header, </font> <font face="Arial" size="2">1 x clearing CMOS button,
</font> <font face="Arial" size="2">1x TPM header</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Back
Panel Connectors</font></td>
<font face="Arial" size="2">1 x PS/2 keyboard/mouse port, </font> <font face="Arial" size="2">1
x optical S/PDIF Out connector</font><font face="Arial" size="2">, </font>
<font face="Arial" size="2">1 x IEEE 1394a ports, </font> <font face="Arial" size="2">8x
USB 2.0/1.1 ports, </font> <font face="Arial" size="2">2x USB 3.0/2.0 ports</font><font face="Arial" size="2">,
</font> <font face="Arial" size="2">1 x RJ-45 ports, 1x HDMI port,</font>
<font face="Arial" size="2">6 x audio jacks (Center/Subwoofer Speaker Out/Rear
Speaker Out/Side Speaker Out/Line In/Line Out/Microphone) </font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">BIOS</font></td>
<font face="Arial" size="2">2 x 32 Mbit AWARD BIOS </font> <font face="Arial" size="2">Support
for DualBIOS™</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Form
Factor</font></td>
<font face="Arial" size="2">ATX Form Factor; 30.5cm x 24.4cm</font> </td>
</tr>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" align="left" width="114"><font face="Arial" size="2" color="#0066CC">Warranty</font></td>
<td style="vertical-align: middle; padding: 4px; border-width: 1px 1px 0 0; border-style: solid; border-color: #dcdcdc;" width="1089"><font face="Arial" size="2">3
Year Gigabyte Warranty</font></td>
</tr>
</table>
Was £127.99 Inc. VAT
ORDER NOW
Bitspower G1/4" Silver Shining Compression Fitting For ID 8MM OD 11MM Tube @ £2.16 inc VAT
Features:
True Hi-Flow Design.
Hi Quality Brass Material.
High Durability Nickel Finished In Silver Shining Color.
Hiding O-Ring Design.
Design For Tube ID 8MM OD 11MM Application.
RoHS Compliant.
Thread : G1/4"
Thread Length : 5MM
Tubing Size : ID 8MM OD 11MM
Was £2.75 Inc. VAT
Only £2.16 inc VAT.
ORDER NOW
Akasa AK-MX002 PSU and Fan Noise reduction Kit @ £2.99 inc VAT
This kit enables the PSU and fans to be isolated mechanically from the chassis reducing acoustic resonance greatly thereby providing quiet operation.
- 8 Fan Mounts
- 1 PSU Mount
Was £3.98 Inc. VAT
Only £2.99 inc VAT.
ORDER NOW
OcUK Value High Flow G1/4 To 3/8" Fitting Silver @ £2.77 inc VAT
High-Flow barb fittings for hoses with up to 10mm inner diameter. Inner diameter of the connector: 7,8mm.
Was £2.78 Inc. VAT
Only £2.77 inc VAT.
ORDER NOW
Xebec 500mm LED Strip - Green @ £8.99 inc VAT
These led strip lights are from the funky new OcUK range - they can be cut into strips to any length you like and re-join them together making a daisy chain. They are waterproof up to IP65, very flexible and super bright compared to standard CCFL lights.
- Dimension: 500mm x 10 mm
- LED Count: 15
- Voltage: 12V DC
- Current: 300mA(max)
- LED Viewing Angle: 120 +- 10 degree
- Power Consumption: 3W
Package Content
- Waterproof IP65 Flexible LED Strip - 500mm
- 12V DC Jack - 200mm
- 4pin to 3 pin Cable - 500mm
- Moled 4pin to 3pin Cable - 100mm
- 4x4-pin Connector
Was £12.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Xebec 500mm LED Strip - White @ £8.99 inc VAT
These led strip lights are from the funky new Xebec range - they can be cut into strips to any length you like and re-join them together making a daisy chain. They are waterproof up to IP65, very flexible and super bright compared to standard CCFL lights.
- LED Count: 15
- Voltage: 12V DC
Package Content
- 4x4-pin Connector
Was £12.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Xebec 500mm LED Strip - Blue @ £8.99 inc VAT
- LED Count: 15
- Voltage: 12V DC
Package Content
- 4x4-pin Connector
Was £12.98 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Shiny Silver Finish @ £1.44 inc VAT
Robust high-quality barbed fitting with cylindrical thread (G1 / 4 "). The fitting is suitable for PVC, PU, PA, PE and silicone hoses with an inner diameter of 11-13mm. With integrated 1 / 4 " Nitrile (r) O-ring seal.
The barbed fitting on this fitting grips well to tubing and provides the end user with a safe and reliable seal for their watercooling setup. Coupled with a high quality O-ring, the risk of leaks is minimised.
Was £1.68 Inc. VAT
Only £1.44 inc VAT.
ORDER NOW
OcUK 30cm Cold Cathode 2-in-1 Kit - UV @ £5.99 inc VAT
CCFLs (cold cathode fluorescent lamps) are best suited for the interior lighting of PC systems. With an inverter they are connected to an unused 4-pin plug of the power-supply and can be used immediately. The CCFLs are 30 cm long.
- 2 CCFLs (same color)
- Self-adhesive pads
- 1 dual-inverter for connecting 2 CCFLs
Was £7.99 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
OcUK 10cm Cold Cathode 2-in-1 Kit - White @ £5.99 inc VAT
CCFLs (cold cathode fluorescent lamps) are best suited for the interior lighting of PC systems. With an inverter they are connected to an unused 4-pin plug of the power-supply and can be used immediately. The CCFLs are 10 cm long.
Was £6.98 Inc. VAT
Only £5.99 inc VAT.
ORDER NOW
OcUK 30cm Cold Cathode 4-in-1 Kit - Blue @ £8.99 inc VAT
- 4 CCFLs (same color)
Was £11.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Akasa AK-178-BL 12" Cold Cathode - Blue @ £7.99 inc VAT
A high quality one-piece blue cold cathode light kit that can be mounted without tools. Consumes just 3 Watts of power (less than a hard drive) and is supplied with additional power splitter for easy installation.
!!<<img src="green.gif">>!!
Was £9.98 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
Asus Maximus IV Extreme Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION ** @ £249.99 inc VAT
nonl2br
The ultimate overclockers dream. The Asus Maximus IV Extreme features all the technological enhancements to climb to the top of the overclocking pile. Welcome to the republic of gamers. <br><br>
This motherboard supports the latest Intel® Core™ i3/Core™ i5/Core™ i7 2nd generation processors in the LGA1155 package, with memory and PCI Express controllers integrated to support 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 2.0 lanes. This provides great graphics performance. Intel® Core™ i3/Core™ i5/Core™ i7 2nd generation processors are among the most powerful and energy efficient CPUs in the world. The Intel® P67 Express is the latest single-chipset design to support new socket 1155 Intel® Core™ i3/Core™ i5/Core™ i7 2nd generation processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, the P67 provides 2 SATA 6Gb/s and 4 SATA 3Gb/s ports for faster data retrieval at double the bandwidth of current bus systems.<br><br>
SLI or CrossFireX? Fret no longer because with the ROG Maximus IV Extreme, you´ll be able to run both multi-GPU setups. The board features SLI/CrossFireX on Demand technology, supporting SLI or CrossFireX configuration. Whichever path you take, you can be assured of jaw-dropping graphics at a level previously unseen. ROG CPU-Z is a customized ROG version authorized by CPUID. It has the same functionality and credibility as the original version, with a unique design. Use the whole new look of ROG CPU-Z to truly report your CPU related information and your uniqueness.<br><br>
The LAN solution from Intel has been long known to have a better throughput, lower CPU utilization as well as better stability. With the dual Intel Gigabit LAN solutions onboard, the ultimate network experience can therefore be delivered to its users like never before. <br><br>
- Intel P67 Chipset: Socket 1155 Support for K edition Unlocked CPUs<br>
- SLI and Crossfire support<br>
- SATA 6GB/s and USB 3.0<br>
- E-ATX Form Factor<br>
- 3 Year Warranty<br>
Was £299.99 Inc. VAT
Only £249.99 inc VAT.
ORDER NOW
EK-PSC Adapter Rotary 90° G1/4 Nickel @ £2.75 inc VAT
Revolvable angled adaptor (90°) with G1/4" threads
Adapter allows connection of fitting with G1/4" threads to extend tubing possibilites in your watercooled case.
Technical specifications:
Material: made of nickel plated brass
Threads: G1/4" outer thread - G1/4" inner thread
Sealed with high quality NBR oring.
ROHS compliant
Was £3.59 Inc. VAT
Only £2.75 inc VAT.
ORDER NOW
Masterkleer Tubing PVC 3/8" ID [16/10mm] Clear @ £3.84 inc VAT
All OcUK Watercooling Tubing is priced per Meter and is cut in one continuous length to suit your needs. For example; to order a five meter length of tubing, enter QTY 5 at the checkout.
Material: PVC
Tubing color: Clear
Outer diameter: 16mm
Inner diameter: 10mm (3 / 8 ")
Maximum operating pressure: 30psi (~ 2.07 bar)
Operating temperature range: -42.8 ° C to 73.9 ° C
Compliant with RoHS
Extent of delivery:
1m Masterkleer hose PVC 16/10mm (3 / 8 "ID) Clear
Was £4.54 Inc. VAT
Only £3.84 inc VAT.
ORDER NOW
Masterkleer 7/16" ID [16/11mm] Tubing Clear/UV Blue @ £3.74 inc VAT
Material: PVC
Tubing colour: Clear
Inner diameter: 11mm (7/16")
Maximum operating pressure: 30psi (~2,07bar)
Operating temperature range: -42.8°C to 73.9°C
Compliant with RoHS
Was £4.00 Inc. VAT
Only £3.74 inc VAT.
ORDER NOW
MSI P67A-C45 Intel P67 (Socket 1155) DDR3 Motherboard ** B3 REVISION ** @ £84.00 inc VAT
nonl2br
<img src="http://marketing-uk.msi.com/images/MSIC45banner.jpg" alt="Military class 2" /><br>
<br>
<Font size="4"><b>Key Features</b></font><br>
<b>Military Class</b><br>
- Super Ferrite Choke - 30% Higher Current Capacity, whistle-free design<br>
- Solid Capacitor - 10 Year Ultra-Long Lifetime, low ESR<br>
<br>
<b>OC Genie 2</b><br>
- Intelligent detect hardware settings<br>
- Automatically overclock CPU and Memory in 1 second<br>
- Increase CPU speed up to 4.2GHz<br>
<br>
<b>Click BIOS</b><br>
- New UEFI BIOS with graphical menu<br>
- User Friendly Mouse or Keyboard Controlled Interface<br>
- Multi-language support<br>
<br>
<img src="http://eu.msi.com/pic/feature/feature_20110217095737.jpg" alt="DrMOS" /><img src="http://eu.msi.com/pic/feature/feature_20101228164501.jpg" width="120" alt="click BIOS" /><img src="http://eu.msi.com/pic/feature/feature_20101228165036.jpg" alt="Super Charger" /><img src="http://eu.msi.com/pic/feature/feature_20101228155412.jpg" alt="Crossfire" /><img src="http://eu.msi.com/pic/feature/feature_20101211121239.jpg" alt="instant OC" /><img src="http://eu.msi.com/pic/feature/feature_20101211120550.jpg" alt="THX" />
<br>
<br>
<br>
<br>
<br>
<Font size="4"><b>Specifications</b></font><br>
- Intel LGA1155 Socket<br>
- Intel 2nd Generation Core i7/i5/i3 & Pentium/Celeron Support<br>
- 4x DIMMs with support for DDR3 1133/1066 up to 16GB MAX<br>
- 1x PCI-Express x16 Slot <br>
- 3x PCI-Express x1 Slots<br>
- 3x PCI Slots<br>
- 4x SATA 3Gb/s ports with RAID<br>
- 2x SATA 6Gb/s ports with RAID<br>
- 2x eSATA ports<br>
- 4x USB 3.0 ports<br>
- 10x USB 2.0 ports<br>
- 2x IEEE 1394 Fire<br>
- 8 Channel HD Audio with THX TruStudio Pro<br>
- Gigabit LAN<br>
- Dual BIOS<br>
<br>
<b>- Now with Three Year Warranty</b><br>
<img src="http://emm.msi.com/admin/temp/newsletters/1226/3yearfinal.jpg" width="250" alt="3 year warranty" /><br>
Was £87.98 Inc. VAT
Only £84.00 inc VAT.
ORDER NOW
XSPC 1/2" ID [19/13mm] High Flex Hose - UV Blue @ £2.39 inc VAT
- 1/2" (13mm) Inner Diameter
- 1/8" (1.5mm) Wall Thickness
- 3/4" (19mm) Outer Diameter
- Stain Resistant
- Max Temperature 60ºC
- Min Temperature -32ºC
- Designed for use with 1/2" barbs
- Blue Tubing with Blue Glow under UV light
Was £2.99 Inc. VAT
Only £2.39 inc VAT.
ORDER NOW
Asus P5G41T-M LX Intel G41 (Socket 775) DDR3 Motherboard @ £34.98 inc VAT
or a great foundation to your everyday computing, take a look at this budget-priced Asus P5G41T-M LX Intel G41 microATX Motherboard.
Supporting multi-core Intel processors through the 775 Intel socket, this motherboard provides an ideal foundation with potential to ramp up performance and functionality with its overclocking tools and available expansion ports.
Including onboard Intel GMA X4500 graphics, this Asus P5G41T-M LX Intel G41 microATX Motherboard provides immediate visual capabilities that are ideal for tasks such as photo editing and DVD movies. A VGA connector lets you hook up almost universally to monitors, with other forms of connectivity including eight USB 2.0 ports, PS/2 keyboard and mouse connectors, an Ethernet interface, parallel port, internal IDE connector and internal S/PDIF connector for digital surround sound.
The P5G41T-M LX Intel G41 microATX Motherboard can support up to 8GB of RAM through its two dual-channel 240-pin DIMM slots.
A smooth all-rounder for the budget-conscious, consider the Asus P5G41T-M LX Intel G41 microATX Motherboard!
hipset Intel® G41 /ICH7
Front Side Bus 1333/1066/800 MHz
Memory 2 x240-pin DIMM, Max. 8 GB, DDR3 1333(O.C.)/1066/800 Non-ECC,Un-buffered Memory
Dual Channel memory architecture
*When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
Expansion Slots 1 x PCIe x16
1 x PCIe x1
2 x PCI
Storage 1 xUltraDMA 100/66/33
4 xSATA 3 Gb/s ports
Audio ALC887 8-Channel AUDIO CODEC
*Choose chassis with HD audio module in front panel to support 8-Channel audio output
Supports Jack-detect and Multi-Streaming teconologies
Supports S/PDIF out interface
LAN PCIe Gb LAN
USB 8 USB 2.0 ports (4 ports at mid-board, 4 ports at back panel)
Special Features ASUS MyLogo 2
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Fan
ASUS Anti-Surge
ASUS EPU-L
ASUS Express Gate
Turbo Key
AI NET2
Overclock Features SFS (Stepless Frequency Selection)
- FSB tuning from 200MHz to 800MHz 1MHz increment
Overclocking Protection
- ASUS C.P.R.(CPU Parameter Recall)
Back Panel I/O Ports
1 x D-Sub
1 x Parallel
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x RJ45 port
4 x USB 2.0/1.1
1 x COM port
3 x Audio jacks
2 x USB connectors support additional 4 USB 2.0 ports
1 x IDE connector
4 x SATA connectors
1 x CPU Fan connector
1 x Chassis Fan connector
1 x High Definition front panel audio connector
1 x S/PDIF Out connector
1 x System Panel
1 x Internal Speaker connector
24-pin EATX power connector
4-pin ATX 12V Power connector
BIOS 8 Mb Flash ROM , AMI BIOS, PnP, DMI2.0, WfM2.0, ACPI2.0, SMBIOS 2.5
Support CD Drivers
ASUS PC Probe II
Anti-virus software (OEM version)
ASUS Update
Accessories User's manual
1 x UltraDMA 133/100/66 cable
2 x SATA cable
I/O Shield
Form uATX Form Factor (microATX)
9.6 inch x 7.9 inch 24.4 cm x 20.1 cm )
Was £37.98 Inc. VAT
Only £34.98 inc VAT.
ORDER NOW
Aqua Computer Aquaero 5 LT USB Fan-Controller @ £54.59 inc VAT
The aquaero is an absolutely autonomous working microprocessor-controlled device with USB 2.0 interface. All speed parameters and sensor values can be set and visualized in an user-friendly PC-software.
The key features of the aquaero 5 include:
· Programmable four channel fan controller
· USB 2.0 and aquabus interface
· Four fan outputs with current measurement
· Versatile control options
· Eight temperature sensor inputs
· Flow sensor input
· Output for IR transmitter
· Three LED outputs
· Potential-free switch
· Two additional power outputs
· Extensive alarm options
· Acoustical alarm
· Speed signal output for status evaluation
· Expandable to a maximum of 10 fan channels
Several aqua computer products can be used to expand the functionality of the aquaero 5 Controller. These expansions are dynamically mapped into the device, creating a consitent control system rather than individual devices.
In maximum configuration, the following devices can be connected to an aquaero 5 simultaneously:
Two aquastream XT pumps
Six poweradjust 2 controllers
One tubemeter
Two multiswitches
For a more thorough feature description, please click this link: aquaero_5_eng.pdf
Extent of delivery:
- aquaero 5 LT controller
- four temperature sensors, length approx. 70 cm
- one internal USB cable, length approx. 100 cm
- one connection cable for speed signal or aquabus
- manual
- mounting material
Was £56.99 Inc. VAT
Only £54.59 inc VAT.
ORDER NOW
Epson Stylus SX125 - All In One Inkjet Printer - Colour @ £29.40 inc VAT
The compact, cost-friendly all-in-one that prints, copies and scans - perfect for scanning college work, printing reports or copying recipes. And with Epson's DURABrite Ultra individual ink cartridges you only replace the colour used, which is good news for you and your budget.
Scan Text with Ease
Whether it's reports, recipes or material for college assignments, scanning text into documents for editing is simple with the inclusion of ABBYY FineReader OCR Software.
Save Money
By using four individual ink cartridges you only replace the colour used, making this an all-round, affordable device.
Incredible, Long-lasting Colours
DURABrite Ultra Inks deliver fast-drying prints that resist water, highlighter pens, smudging and fading so your lab-quality photos will last for generations to come
Photo Processing
Remove red eye from photos, restore colour and correct backlight on faded or old scanned photos, improving and perfecting the quality of your prints with our Easy Photo Fix function and Easy Photo Print software
ENERGY STAR Compliant
This product meets the strict ENERGY STAR® guidelines set by the European Commission. Epson is a global manufacturer committed to protecting the environment for future generations by offering a range of ENERGY STAR® products. This is achieved by significantly reducing electricity usage, which saves energy, money and the environment, without compromising quality.
Was £29.99 Inc. VAT
Only £29.40 inc VAT.
ORDER NOW
Epson Stylus SX525WD - Wireless All In One Inkjet Printer - Colour @ £72.00 inc VAT
This fast, elegant all-in-one with Wi-Fi is the perfect addition to the wireless home. View and print photos easily with the large LCD display and enjoy double-sided printing that’s the fastest in its class. Lose the wires and print, scan and copy from anywhere in your home with the latest high-speed wireless technology. Automatic double-sided printing saves paper, and the front-loading cassette keeps paper neatly stored away. Print outstanding documents and lab-quality photos with Epson DURABrite Ultra ink. And with a choice of individual ink cartridges, you can save money as you only need to only replace the colour used. View and print photos easily using the large 6.3 cm LCD screen or simply print direct from memory cards – no need to use a PC. You can also remove red-eye and restore photos at the touch of a button and even scan text into editable files, thanks to the included software.
Was £79.98 Inc. VAT
Only £72.00 inc VAT.
ORDER NOW
Epson Stylus S22 Inkjet Printer - Colour @ £33.30 inc VAT
The home printer that produces outstanding documents and lab-quality photographs every time, whether printing documents for work, school or college. No-nonsense and no hidden costs - just great results. And by using individual ink cartridges you can save money, as you only replace the colour used.
Incredible, long-lasting colours
DURABrite Ultra Inks deliver fast-drying prints that resist water, smudging, highlighter pens and fading so your lab-quality photos will last for generations to come*4.
Save money
Straightforward photo printing every time
Producing great photos has never been so simple: adjust colour and contrast, plus remove red eye with PhotoEnhance and Easy Photo Print.
This product meets the strict ENERGY STAR® guidelines set by the European Commission. Epson is a global manufacturer committed to protecting the environment for future generations by offering a range of ENERGY STAR® products. This is achieved by significantly reducing electricity usage, which saves energy, money and the environment, without compromising on quality.
Was £33.79 Inc. VAT
Only £33.30 inc VAT.
ORDER NOW
Samsung CLP-320 Laser Printer - Colour @ £70.20 inc VAT
The Samsung CLP-320 boasts being one of the world’s smallest colour laser printers. The print speed of the Samsung CLP-320 is 4ppm in colour and a quick 16ppm in mono. The Samsung CLP-320 colour laser printer is a perfect affordable replacement to an inkjet printer.
Was £71.38 Inc. VAT
Only £70.20 inc VAT.
ORDER NOW
Samsung ML-1860 Mono Laser Printer @ £54.60 inc VAT
The ML-1860's Print Screen button - conveniently located on the printer control panel - lets you print the contents from your screen, quickly and easily, even when you're away from your desk. Just one touch is all that it takes. With one click, there's no more extra editing or cropping of unwanted content-clutter from original web pages or documents. If a single page is what you want, it's what you'll get. One simple press of a button prints your screen, as it appears on your monitor. Hold the button for more than two seconds and the ML-1860 prints the last object that you activated on your monitor. Now you can print anything, anytime.
- Print Technology A4 Mono Laser
- Print speed (Mono A4) 18 Page Per Minute
- Resolution 1200 x 1200 Pixels
- Processor 300MHz
- Standard Memory 8MB
- Internal memory 8MB
- Maximum input capacity 150 Sheet
- Cassette Paper handling Plain Thin Cotton Recycled Archive Colored Pre-Printed Label Bond Thick Envelopes Cardstock Transparency
- Media size (tray 1) A4
- Duplex printing No
- Interface High-Speed USB 2.0
- Network ready No
Was £54.98 Inc. VAT
Only £54.60 inc VAT.
ORDER NOW
Hailea Ultra Titan 500 Water Chiller (HC300=395Watt cooling capacity) @ £301.99 inc VAT
Ordered upon request: Delivery is typically around 1 week, but during busy periods it can take longer.
Award winning Watercooling Water Chillers from Hailea.
New cool design
More robust materials for even longer lifespan
Lowered noise emissions, Quieter than a standard refrigerator!
Suitable for continuous operation
This waterchiller basically replaces the radiator as the coolant is chilled to the desired temperature by this unit. Temperatures down to 4°C are possible, please note that at low temperatures (high temperature difference) condensation may accumulate. Suitable insulation accessories are also available in our shop. Alternatively the coolant temperature can be set to just below room temperature to avoid this problem. Thanks to the low temperatures incredible overclocking potential is available! This system is also great for no-noise applications as the chiller can be located in another room.
We recommend integration of the chiller into the cooling loop in combination with a radiator. This allows use of the chiller when required (overclocking, Benchmarks, summer etc..) and use of the radiator during normal operation.
To estimate the required cooling performance here some non-binding estimates. The exact thermal emissions can be requested from the manufacturer of the hardware.
CPU: 80W (standard) to 150W (overclocked)
GPU: 20W (small cards) to 150W (current models such as 8800)
MB: 10 to 20W per component
The added values of your system must not exceed the given cooling capability of the chiller.
• HC-300A
• 1/4 Horsepower
• Cooling Capacity 390W
• Recommended coolant flow - 500-2500 l/h
• Weight - 18.5kg
• Cooling agent - R134A
• Dimensions (LxWxH) - 448x330x440mm
• Heat exchanger material - Titanium
• Temperature adjustments - Digital read-out (precision 0,1°C)
• Temperature setting in 1°C steps
• Contents - 1 x Chiller
• 4 x 1" fittings (2 straight, 2 right angled)
Note for first-time users:
If you should have problems with your chiller please contact us before returning the chiller to us. In most cases there is no actual problem with the chiller, but the functionality of the unit is not fully understood by the user yet. Please note the following: The compressor unit automatically switches itself on and off, if the temperature sensor is manipulated your warranty is void, the noise level or an allegedly not sufficient cooling performance are no reason for a reclamation. The chiller can only function properly if the cooling loop is equipped with a sufficiently powerful pump. If these facts are considered most reclamations can be avoided and you will greatly enjoy this product!
Note for aquarium-use:
The cooling performance is affected by the aquarium-lamp, the reduced pump power due to filters and the thermal waste of the pump. We therefore recommend to order the chiller at least on the power-lever higher than theoretically calculated.
Was £313.99 Inc. VAT
Only £301.99 inc VAT.
ORDER NOW
Asus PA238Q 23" Professional ProArt Widescreen P-IPS LCD Monitor - Black @ £215.99 inc VAT
Each PA238Q is pre-calibrated with a maximum ?E (Delta E) of less than 5. Ensures precise reading of color input and guarantees excellent color fidelity. PA238Q adopts 178degrees of horizontal and vertical viewing angle that eradicates color shift on your screen no matter where and how you look at it
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Customized hue and saturation control with 6 color adjustment allows user to adjust six colors (red, green, blue, cyan, magenta and yellow) independently without effecting other colors.
PA238Q comes with rich connectivity including DisplayPort, HDMI, DVI, D-sub. It is also equipped with four USB 2.0 ports so that users could easily connect PA238Q to many peripherals, such as USB drives, keyboard, mouse, digital camera, etc.
PA238Q's built-in internal 10-bit Look-up Table can produce greater depth for each RGB colors than 8-bit Look-up Table in conventional monitors. Resulting in smooth gradation and accurate color resolution. The ergonomically-designed PA238Q Professional Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position. Picture-in-Picture and Picture-by-Picture allows users to view images from different signals in almost anyway they want.
Features:-
- Panel Size: Wide Screen 23.0"(58.4cm) 16:9
- Color Saturation : 100%(sRGB)
- Panel Type : IPS
- True Resolution : 1920x1080
- Full HD 1080P : Yes
- Pixel Pitch : 0.2652mm
- Brightness(Max) : 250 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Viewing Angle (CR?10) : 178°(H)/178°(V)
- Response Time : 6ms (Gray to Gray)
- Display Colors : 16.7M
- LCD ZBD Warranty : Yes
- Signal Input : HDMI , D-Sub, DisplayPort, DVI-D
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack (for HDMI & DisplayPort Only)
- USB Port(s) : 1 x upstream, 4 x downstream
- Chassis Colors : Black
- Tilt : +20°~-5°
- Swivel : Yes
- Pivot : Yes
- Height Adjustment : Yes
- VESA Wall Mounting : 100x100mm
- Warranty 3yr On-site
Was £235.99 Inc. VAT
Only £215.99 inc VAT.
ORDER NOW
EK H3O Watercooling Kit - Supreme LT 240 **2011 Compatible** @ £134.40 inc VAT
Until now, watercooling has been off-putting.
The costs involved and the myriad of choices available can be confusing to newcomers who crave the high performance, silence and gorgeous aesthetics that a watercooled system provides.
In the past, Watercooling Kits have nearly always had cheap, low quality parts in the box that are prone to failure or were generally low quality.
EK have stepped in and solved this problem. With each EK Kit you get everything you need to watercool your PC along with full installation instructions. this means you cant go wrong. You don't run the risk of ordering the wrong parts, and you are assured out of the box compatibility.
Pair this with the Ultra High End performance of EK products and you have the quick and easy solution you need to gain those extra MHz
Ideal for first time watercooling enthusiasts and seasoned veterans alike, transform your computer system
All of these kits offer the new EK Standard EN Nickel Plating method which ensures the highest quality nickel plating finish on your water blocks.
Overclockers UK recommends the use of Distilled Water or Watercooling Fluid which is available on this web-store.
To make the kit functional, the user needs 1Litre of Coolant.
The EK-KIT H3O - Supreme LT 240 water cooling kit is a kit dedicated to all users that seek simple, yet quality and effiicient all in one solution.
EK-KIT H3O - Supreme LT 240 can efficiently cool high-end CPU's with optimum thermal performance and low noise level. CPU block is compatible with Intel 775, 1155/1156 and 1366 processors. The CPU block comes with an additional plate to allow use with AMD AM2 and AM3 sockets
Supreme LT block is one of most efficient CPU blocks (value for money) and offers very good thermal conductive performance and low restriction.
EK-CoolStream RAD XT (240) radiator will fit in majority of watercooling cases and will succesfully take heat out of your system (please check template of rad prior to installing in case).
EK-DCP 2.2 pump has been also proven for some time now by water cooling community and allows adequate and optimal flow for your kit.
EK-KIT H3O - Supreme LT 240 water cooling kit includes following items:
- EK-Supreme LT - UNI (universal CPU block based on EK-Supreme LT)
- EK-Backplate CPU Universal
- EK-CoolStream RAD XT (240)
- Yate Loon D12SH (2200rpm) or Yate Loon D12SM (1650rpm)
- EK-DCP 2.2 Pump
- EK-Reservoir Combo DCP 2.2
- EK-DCP PUMP mounting plate KIT
- TUBE Masterkleer 12,7/9,5 CLEAR (2 meters)
- EK-PSC Fitting 10mm - G1/4 Nickel (6 pcs)
- EK-Ekoolant UV Blue (concentrate 100ml)
- TIM Arctic Cooling MX-2 (EKWB 2g)
Supported sockets:
- Intel Socket 775
- Intel Socket 771
- Intel 1366 Socket
- Intel 1156 Socket
- Intel 1155 Socket
- Intel 2011 Socket
- AMD Sockets: 939, 754, 940
- AMD Sockets: AM2, AM2+, AM3
IMPORTANT:
Kit is easy to install, use and maintain (thorough installation manual is included)
This kit can also be upgraded with an additional EK-VGA waterblock!
You will need to buy two additional fittings alongside your graphics card block.
Was £138.98 Inc. VAT
Only £134.40 inc VAT.
ORDER NOW
OcUK Sandwich CD Case - 24 Discs @ £2.39 inc VAT
For years, the OcUK burger was world renowned as the market leader in optical media storage and transportation. The OcUK Sandwich gives all of the benefits of the OcUK burger in a new healthy package.
The OcUK Sandwich is the perfect storage solution for your media. Holding 24 Discs in a tasty exterior. The OcUK Sandwich gives you everything you need to store your CDs, DVDs and BluRay discs in a delicious, soft outer case.
• Durable Zip for security
• Healthy Fillings
• 24 Disc Capacity
• No Nutritional Supplements Required
• Calories - 0
• Total Fat - 0g
• Saturated Fat - 0g
• Cholesterol - 0mg
• Vegetarian Friendly
Was £3.98 Inc. VAT
Only £2.39 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 580 SOC 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £407.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 855MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4100MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1710MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
- Supplied FREE with Batman: Arkham City FULL PC game (subject to availability. Game is launched on 21/10/2011 downloads previous to this date will be declined) (Only supplied with orders purchased after 07/09/2011)
Was £449.99 Inc. VAT
Only £407.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 580 1536MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £359.99 inc VAT
Features:-
- Core Clock: 772MHz (Fermi GF110)
- Memory Clock: 4008MHz (Effective)
- Shader Clock: 1544MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 2 Years
Was £379.99 Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 580 3072MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £407.99 inc VAT
Features:-
- Core Clock: 783MHz (Fermi GF110)
- Uprated quiet cooling solution
- Memory: 3072MB GDDR5
- Memory Clock: 4020MHz (Effective)
- Shader Clock: 1566MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was £439.99 Inc. VAT
ORDER NOW
Asus GeForce GTX 570 DirectCU II 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £251.99 inc VAT
Super Alloy Power technology uses special alloy formula in critical power delivery components for a 15% performance boost, 35°C cooler operation and 2.5 times longer lifespan. Based on ASUS DirectCU architecture, which uses copper heat pipes in direct contact with the GPU to speed up heat dissipation for over 20% cooler performance, DirectCU II takes cooling further with twin 80mm fans for 600% airflow. Full throttle overclocking with exclusive ASUS Voltage Tweak via Smart Doctor – boosting 50%* more speed, performance and satisfaction! Advanced output option for all display types from one single output! Factory overclocked to perform at 742MHz, higher than stock performance, resulting in higher frame rates in games.
Features:-
- Core Clock: 742MHz
- Memory: 1280MB GDDR5
- Memory Clock: 3800MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1464MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £274.99 Inc. VAT
Only £251.99 inc VAT.
ORDER NOW
EVGA GeForce GTX 570 Classified 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £299.99 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Features:-
- 6 Phase Digital PWM
- 10 Layer PCB
- Voltage read points
- Core Clock: 822MHz
- Memory Clock: 3902MHz (Effective)
- Shader Clock: 1644MHz
- DisplayPort 1.1a connector included
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 8pin + 6pin power connectors required
- Warranty: 10 years
Was £319.99 Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 570 OC WINDFORCE 3X 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £257.99 inc VAT
Features:-
- Core Clock: 780MHz
- Shader Clock: 1690MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Dual-Link DVI-D & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £279.98 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
Gigabyte GeForce GTX 570 SOC WINDFORCE 3X 1280MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £275.99 inc VAT
Features:-
- Core Clock: 845MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Only £275.99 inc VAT.
ORDER NOW
Asus GeForce GTX 560Ti DirectCU II TOP 1024MB GDDR5 PCI-Express Graphics Card **Supplied with FREE Batman: Arkham City PC game** @ £179.99 inc VAT
ASUS is proud to introduce the new ASUS ENGTX560 Ti DCII TOP to all our users. Using the unique ASUS DirectCU II Cooler the airflow is doubled and the noise level is greatly reduced by using flattened copper heat pipes which directly contact the GPU core to speed up heat dissipation for a 20%* cooler performance compared to reference. Keeping the card temperatures low also results in quieter operations thanks to reduced fan speeds!
The card also boasts Super Alloy Power which can create a 15% performance increase, 2.5 longer product life span and a 35?C cooler operation. In addition to this, the engine clock runs at a Pre Overclocked 900MHz, allowing users to enjoy high speed and an unprecedented gaming experience. Super Alloy Power is a special blend of elements formed using an ASUS exclusive formula, under extreme pressure and temperatures. The metals are highly-magnetic, heat-resistant and anti-corrosive used to reduce power loss, enhance durability and achieve cooler operation.
Super Hybrid Engine is an intelligent power consumption optimizer that switches between high- and low-intensity power profiles in real-time. This in turn can provide up to 15% improved performance. Furthermore the GTX560 offers a SAP CAP; this is back-to-back with the GPU to provide most efficient power supply for increased stable overclocking of up to 28%.
With exclusive Voltage Tweak technology also being a key feature of this product, the ENGTX560 Ti DCII TOP/2DI/1GD5 covers users for every possible over-clocking and over-volting scenario. With the complete package offered by this card users can easily boost their performance by up to 50%!
Features:-
- Core Clock: 900MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4200MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 384
- Shader Clock: 1800MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 years
Was £187.99 Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
OcUK GeForce GT 430 1024MB GDDR3 PCI-Express Graphics Card @ £41.99 inc VAT
The GT430 provides users with ultra-smooth multimedia entertainment. This makes it the ideal product for a home theatre PC. Accompanied by a low profile design and Blu-ray 3D acceleration the GT430 has the perfect compatibility and fit required for HTPCs and multimedia centres. The GT430 plays Blu-ray 3D playback with true HD and put's minimal stress on the CPU allowing crisp, clear viewing in excellent detail.
Specification:-
- Core Clock: 700MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1600MHz (Effective)
- Memory Interface: 128-Bit
- Processing Cores: 96
- Shader Clock: 1400MHz
- Display Connectors: 1x Dual-Link DVI-I, 1x Analogue & 1x HDMI
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 2 Years
Was £53.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
MSI GeForce 8400GS 512MB SILENT GDDR3 "Low Profile" PCI-Express Graphics Card @ £20.39 inc VAT
co-development by MSI and Rivatuner, MSI releases the ultimate graphics card utility “Afterburner”. This utility enables all MSI graphics cards users to boost performance and to monitor all kinds of critical information in real-time. Afterburner is a completely free utility which is compatible with almost all MSI graphics cards.
MSI StarOSD is a very helpful utility for the avid PC gamers. Users can easily access the StarOSD to adjust the contrast, brightness, overclocking and temperature according to each user’s individual preference.
Note:Star OSD function that be used on different games has some difference cause the game different design.
MSI Live Update 4 is a single utility software that automatically checks BIOS, driver and utility updates and installs for you , which can save your time for searching and lower the risk while updating.
The HDCP provides a robust, cost-effective and transparent method for transmitting and receiving digital entertainment similar to DVI/HDMI-compliant digital displays. HDCP encrypts the date transmitted between the DVI/HDMI connector on the graphics adapter and the display.
MSI DOT Express Technology is the most advanced Dynamic Overclocking Technology Express enabling supreme overclocking, cooling and de-noise performance. It is an advanced overclocking engine, designed to deliver up to 10% extra performance and greatly enhances the synchronized GPU & DDR performance.
Dual-link DVI convertible output supports Video signal through DVI to HDMI interface, which drivers resolution of a digital display up to 1920x1200 or higher.
Both support the latest specifications of Blu-ray and HD DVD(High Definition DVD). It comes with the latest GPU and DDRIII superior processing performance in which users can easily enjoy the high-definition video of 1920x1080(1080p/i).
NVIDIA® CUDA™ technology is the world’s only C language environment that enables programmers and developers to write software to solve complex computational problems in a fraction of the time by tapping into the many-core parallel processing power of GPUs. With millions of CUDA™-capable GPUs already deployed, thousands of software programmers are already using the free CUDA™ software tools to accelerate applications—from video and audio encoding to oil and gas exploration, product design, medical imaging, and scientific research.
Was £25.99 Inc. VAT
Only £20.39 inc VAT.
ORDER NOW
MSI GeForce N210 1024MB GDDR3 "Low Profile" PCI-Express Graphics Card @ £22.79 inc VAT
Get all the video processing power that your digital lifestyle requires. Enhance photos, clean up home videos and post them to Facebook up to 50% faster with the GeForce 210. Convert your video and put it on your iPod in minutes instead of hours or make your DVDs look like HD. Does your PC have a CPU powerful enough to playback high definition Blu-Ray Movies? It doesn’t matter, the GeForce 210 can playback any Blu Ray Movie with any modern CPU.
- Core Clock: 589MHz
- Memory Clock: 1000MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 16
- Shader Clock: 1178MHz
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 2 Years
Was £29.99 Inc. VAT
Only £22.79 inc VAT.
ORDER NOW
OcUK GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card - OEM @ £131.99 inc VAT
Next-generation gaming has arrived. Nvidia GeForce GTX 470 gives your games an adrenaline shot with screaming fast performance and futuristic, visually stunning graphics. Experience heart pounding,
cinematic visuals on your favorite games with the combined power of DirectX 11, CUDA and Nvidia PhysX technologies. And expand your visual real estate across three HD displays in jaw dropping
stereoscopic 3D for the ultimate in immersive gaming. Nvidia GeForce GTX 470: pure adrenaline meets visual bliss.
- Core Clock: 607MHz
- Memory Clock: 3348MHz (Effective)
- Processing Cores: 448
- Shader Clock: 1215MHz
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.3a (Includes HDMI & VGA Adapters)
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 1yr Warranty with OcUK
- This is a refurbished fully functional product, it may have minor visual defects and is just a bare card, no cables, drivers etc.
Was £145.99 Inc. VAT
Only £131.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 285 1024MB GDDR3 PCI-Express Graphics Card - OEM @ £113.99 inc VAT
- Core Clock: 648 MHz
- Processor Cores: 240
- Processor Clock: 1476 MHz
- Texture Fill Rate: 51.8 Billion/sec.
- On-board Frame Buffer: 1024MB GDDR3
- Memory Data Rate, effective: 2484 MHz
- Memory Interface: 512-bit
- Memory Bandwidth: 159 GB/sec.
- On-board Outputs: DVI-I and DVI-I
- Additional Outputs Supported: HDMI, VGA
- Bus Type: PCI Express 2.0
Was £129.98 Inc. VAT
Only £113.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 260 V2 896MB GDDR3 PCI-Express Graphics Card - OEM @ £59.99 inc VAT
- Core Clock: 576 MHz
- Processor Cores: 216
- Processor Clock: 1242 MHz
- Texture Fill Rate: 41.5 Billion/sec.
- On-board Frame Buffer: 896MB GDDR3
- Memory Data Rate, effective: 1998 MHz
- Memory Interface: 448-bit
- Memory Bandwidth: 111.89 GB/sec.
Was £79.99 Inc. VAT
Only £59.99 inc VAT.
ORDER NOW
OcUK GeForce GTX 460 768MB GDDR5 PCI-Express Graphics Card - OEM @ £76.79 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Core Clock: 675 MHz
- Processor Cores: 336
- Processor Clock: 1350 MHz
- Texture Fill Rate: 37.8 Billion/sec.
- Memory Amount: 768MB GDDR5
- Memory Data Rate, effective: 3600 MHz
- On-board Outputs: DVI-I, DVI-I, and Mini HDMI
- Additional Outputs Supported: VGA
- Bus Type: PCI Express® 2.0
Was £85.99 Inc. VAT
Only £76.79 inc VAT.
ORDER NOW
OcUK GeForce 9800 GT 512MB GDDR3 PCI-Express Graphics Card - OEM @ £35.99 inc VAT
- Ideal for PhysX!
- Core Clock (MHz): 550 MHz
- Processor Cores: 112
- Processor Clock (MHz): 1375 MHz
- Fill Rate (billion pixels/sec.): 30.8
- Memory Amount: 512MB GDDR3 On-board Frame Buffer
- Memory Frequency (effective): 1800 MHz
- Memory Interface: 256-bit
- Memory Bandwidth (GB/sec): 57.6
- BUS Technology: PCI Express 2.0
Was £47.99 Inc. VAT
Only £35.99 inc VAT.
ORDER NOW
Dell IN2020N 20" Widescreen LCD Monitor - Black @ £83.99 inc VAT
Enhance your multimedia experience with the IN2020 high-definition monitor with LED. This 20" widescreen display offers brilliantly vivid features at an even more brilliant price.
Highlights of the Dell 20" Wide IN2020N 5ms LED HD
* Enhance your multimedia view
* Environmental footprint
* Convenient comfort
* Great-value performance
Expand your productivity and multimedia performance with this 20" widescreen display, including LED backlight. With its 16:9 aspect ratio, 8,000,000:1 high dynamic contrast ratio and 1600 x 900 high-definition display, the IN2020 is excellent for viewing movies, photos and videos. Plus, you'll never skip a beat by adding the optional multimedia Dell soundbar for an enhanced audio experience.
The IN2020 monitor was designed for the environmentally conscious user. This highly efficient LCD panel is both mercury and arsenic free. The LED backlight complies with the stringent environmental standard, Energy Star 5.0, to help you lower energy consumption without sacrificing performance.
Convenient comfort
The IN2020 monitor is uniquely designed for comfort, convenience and visual appeal. With tilt adjustability, the IN2020 offers a versatile and comfortable view. The high-gloss slim black bezel complements both your home environment and your Dell desktop or laptop. Simply connect to any standard computer using the VGA connector.
The IN2020 monitor delivers a high dynamic contrast ratio of 8,000,000:1, vivid 1600 x 900 high-definition resolution, a fast response time and VGA connectivity, all at an affordable price.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 1000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 160°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue
- Dimensions: 453.7mm x 344.0mm x 204.8mm
- Weight: 4.1kg
- Warranty: 3 Years On-Site
Was £89.99 Inc. VAT
Only £83.99 inc VAT.
ORDER NOW
IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black @ £131.99 inc VAT
The ProLite E2273HDS is a LED-backlit monitor. It is a full 1920x1080 high definition 22” display that features all the benefits this technology affords. Extremely slim and stylish in design, it has a narrow bezel and is finished in the latest glossy-black. The high specifications of the monitor include 5,000,000:1 ACR, fast 2ms response for excellent sharpness in high definition video and triple input connectivity (including HDMI). Power consumption is only 21W typical usage and 0,5W in standby.
A typical CCFL LCD uses four backlight lamps. Using LED diodes considerably lowers the power consumption and reduces the CO2 emission into the environment making this LCD a true ECO-Friendly product.
With true 1920 x 1080p resolution your LCD is ready to display any high definition images. It also offers you much more viewable area than a standard LCD with 1280 x 1024 resolution.
Contrast Ratio is a measurement of this difference between the blackest black and the whitest white your LCD can display. Advanced Contrast Ratio is a feature that automatically adjusts the contrast and brightness based on the darkness of the image. The higher the ratio, the better your screen will look when you have the lights off in a room.
This LED monitor is equipped with two high quality stereo speakers. HDMI stands for High-Definition Multimedia Interface. Much smaller and more convenient than DVI, HDMI also has the significant advantage over DVI that it supports audio as well as video signals. When very fast graphics are displayed your monitor can sometimes get blurry. Turning on the OverDrive feature will eliminate that.
Features:-
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Inputs: 1 x Analogue, 1 x DVD-D, & 1 x HDMI
- Dimensions: 268.1 x 476.6 mm; 10.6" x 18.8"
- Weight: 2.9kg
Was £139.99 Inc. VAT
ORDER NOW
IIyama Prolite E2274HDS 22" Widescreen LED Business Monitor - Black @ £134.39 inc VAT
The LED-backlit ProLite E2773HDS 27” LCD Display features a stunning 1 ms Response Time and a High Definition 1920 x 1080 Resolution. The 5 000,000:1 Advanced Contrast Ratio and 300 cd/m² brightness offer the user clear and vivid images, and the HDMI, DVI and D-Sub connections ensure compatibility across a range of devices including games consoles and work stations. The display is Windows® 7 Compatible and Energy Star® 5.0 qualified.
LED-BACKLIT
FULL HD
With true 1920 x 1080p resolution your monitor is ready to display high definition images. This means you can accommodate more information on your screen; e.g. 60% more in comparison to a 1280 x 1024 monitor.
ACR
Contrast Ratio is a measurement of the difference between the darkest black and the brightest white your monitor can display. Advanced Contrast Ratio is a feature that automatically adjusts contrast and brightness of the screen to assure perfect picture quality while watching films and playing games.
SPEAKERS
HDMI
VESA
VESA mount compliance means you can easily mount your monitor to a wall.
Specification
Screen Size - 22"
Response Time - 2ms
Height Adustable - No
Rotatable Screen - No
Built in Speakers - Yes
VGA Input - Yes
DVI-D Input - Yes
HDMI Input - Yes
LED Panel - Yes
Was £143.99 Inc. VAT
Only £134.39 inc VAT.
ORDER NOW
IIyama Prolite B2274HDS 22" Widescreen LED Business Monitor - Black @ £143.99 inc VAT
Iiyama's Business LED-backlit LCD, the ProLite B2274HDS follows full HD resolution of 1920 x 1080. It comes with Height Adjustable and Portrait Mode base providing the greatest comfort in use . High specifications include 2msec Response Time and 5M : 1 Advanced Contrast Ratio for vibrant images and blur free Video. Triple Input support of Analogue, DVI and HDMI ensures compatibility with the latest installed graphics cards and embedded Notebook outputs! And VESA mount compliance means you can easily mount your monitor to a wall.
LED-Backlit:
Full HD:
ACR:
Speakers:
HDMI:
OverDrive ON / OFF:
VESA:
Height Adjustable Stand:
A Height Adjustable Stand allows you to set the perfect position of the screen ensuring ergonomic posture and optimal viewing comfort which benefits not only your health but also productivity.
Pivot:
Screen rotation means you can change the position of the screen from landscape into portrait. This feature can be very handy while working with long spreadsheets or texts.
Was £167.99 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Dell UltraSharp U2312HM 23" Widescreen LED Monitor - Midnight Grey @ £199.99 inc VAT
See vivid imagery from almost any angle. The 23” Dell UltraSharp U2312HM monitor with LED offers a brilliant view, rich colors and adjustable height options.
- Lose yourself in the details: : Enjoy 1920x1080 (max) HD resolution, a vivid 2,000,000:1 (typical) dynamic contrast ratio and IPS technology for outstanding color consistency across a wide viewing range.
- Stay comfortable and connected: Select your best view with a range of tilt, swivel, pivot and height options. Link to a range of devices with 4 USB ports, a DisplayPort, plus DVI and VGA connections.
- Be environmentally-conscious: Beyond offering efficiency and vivid detail, this monitor also meets EPEAT® Gold standards and is ENERGY STAR® qualified.
DISPLAY
Panel Size: 58.42 cm
Aspect Ratio: Widescreen (16:9)
Panel Type, Surface: IPS (In-Plane Switching), anti glare with hard coat 3H
Optimal Resolution: Full HD resolution, 1920 x 1080 at 60 Hz
Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Dynamic Contrast Ratio:1000: 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Brightness: 300 cd/m2 (typical)
Response Time: 8ms (gray to gray)
Viewing Angle: (178° vertical / 178° horizontal)
Color Support: Color Gamut(typical):82%(CIE 1976)4
Color Depth: 16.7 million colors
Pixel Pitch:0.265mm
Diagonal Viewable Size:58.42 cm
23 inches (23-inch wide viewable image size)
Preset Display Area ( H x V): 509.2 mm x 286.4mm, 20.04" x 11.28"
Backlight Technology: LED
CONNECTIVITY
1 Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort (DP)
1 Video Graphics Array (VGA)
1 USB 2.0 upstream port
4 USB 2.0 downstream ports
DC power connector for Dell Soundbar
COLOR, SIZE AND WEIGHT
Dimensions with stand (H x W x D):365.0 mm(compressed) ~ 493.0 mm(extended) x 546.4 mm x 185.4 mm, 14.37 inches (compressed) ~19.44 inches(extended) x 21.51 inches x 7.30 inches
Dimensions without stand (H x W x D): 323.3mm x 546.4 mm x 59.5 mm, 12.73 inches x 21.51 inches x 2.34 inches
Weight (panel only - for VESA mount): 2.96 kg, 6.53 lbs
Weight (with packaging): 6.47kg,14.26 lbs
Specifications - Service / Support Details: 3-Year Advanced Exchange1 Service and Premium Panel Guarantee
Was £219.98 Inc. VAT
Only £199.99 inc VAT.
ORDER NOW
Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black @ £269.99 inc VAT
BenQ, proudly announced the release of their 23.6” (16:9 Aspect Ratio) LED Gaming Monitor XL2410T. BenQ understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. In order to achieve this goal, BenQ co-worked with ZOWIE, a professional Gaming gear manufacturer. BenQ have ZOWIE’s gamer teams join in during the product development and testing stages. With their assistance, XL2410T can truly be a professional LED gaming monitor – with a set of Gaming Display Modes which includes the FPS mode (First Person Shooting), co-developed by two legendary Counter-Strike players – Emil “HeatoN” Christensen and Abdisamad “SpawN” Mohamed.
Every serious gamer know that lag will cause you to lose a game; XL2410T is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. XL2410T has a fast refresh rate of 120Hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms GTG (OverDrive) meaning users can see the edge of the enemies clearly and without motion blur, and Dynamic Contrast Ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with BenQ’s gaming tuning technology becomes a huge advantage for gamers.
XL2410T has a smart design, for one purpose – to win. The monitor has two hotkeys available; the first changes the display mode: Full; Aspect; Overscan; 1:1; 17”; 19”; 19” Widescreen and 22” Widescreen. Whereas the second hotkey is Smart Scaling, which lets the users adjust picture size in original input to the screen’s limit. Together with Display Mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. From BenQ’s Gaming Display Modes options, users can choose from FPS Mode, made possible by co-working with the gaming heroes -HeatoN and Spawn as the best setting for personal shooting games, or from the two User Game modes for more dedicated and personalized settings.
For extreme entertainment, XL2410T is the LED monitor to go for. 3D-ready (NVIDIA 3D Vision certified); Picture by Picture (PBP); connectivity values (D-sub; DVI-D-DL, HDMI) and height adjustment feature are offered for users’ enjoyment and comfort. Picture by picture (PBP) is a feature that enables users to show two programs side-by-side on the screen. Feel like camping once in a while for fun? Watch a movie while you do it!
- LED Backlit
- Screen Size: 23.6" Widescreen
- Contrast Ratio: 10000000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 6.0kg
- Height adjustable stand / Swivel 45/45 left/right
- Warranty: 2 Years On-Site
Was £284.99 Inc. VAT
Only £269.99 inc VAT.
ORDER NOW
Iiyama ProLite E2407HDS 24" Widescreen LCD Monitor - Black @ £143.99 inc VAT
The ProLite E2407HDSD is HDCP compliant and features true 16:9 High Definition 1920x1080 native resolution. Complimented with a blistering 2ms response rate and 60000:1 Advance Contrast Ratio the E2407HDSD really is, in a class of its own. Opticolour automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity. Finished in a stylish Piano Black design, the E2407HDSD is sure to stand out amongst the crowd!
- Screen Size: 24" Widescreen
- Contrast Ratio: 60000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- Dimensions: 560.0mm x 404.5mm x 220.0mm
- Weight: 5.0kg
Was £149.99 Inc. VAT
ORDER NOW
AOC E2795VH 27" Widescreen LED Monitor - Black @ £194.39 inc VAT
No compromises: The e2795Vh is perfect for office and action. This Full HD large-screen monitor with integrated speakers not only looks fantastic. The generous 16:9 display area offers ample space for complex charts, double-page spreads, image editing, games, videos or movies. High contrast and brightness values in combination with wide viewing angles and a fast response time provide an excellent image quality without blurring from almost every perspective. Thanks to DVI-D and HDMI inputs (with HDCP) high-resolution content from numerous video sources is displayed flawlessly. With electricity-saving LED backlights and a mercury-free manufacturing this flatscreen is also easy on the environment.
Features:-
- Screen Size: 27" Widescreen
- Contrast Ratio: 20,000,000:1
- Contrast Ratio Typical 1.200:1
- Pixel / Dot / Pitch 0.3114 (H) x 0.3114 (V)
- Display Area 597.6 (H) x 336.15 (V)
- Special Features: DCB,e-Saver,i-Menu,Kensington Security Lock,screen+,SRS,USB,Wide View Angle
- VESA Compliant
Was £209.99 Inc. VAT
Only £194.39 inc VAT.
ORDER NOW
Asus VE276Q 27" Widescreen LCD Multimedia Monitor - Black @ £215.99 inc VAT
VE276Q leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Be captivated by stunning images with ASUS Smart Contrast Ratio (ASCR) technology that boosts the display´s contrast ratio to an astonishing 100,000:1. AI Light function enables the VE276Q automatically adjusting to lower brightness and make your eyes feel more comfortable in the dim environment. Furthermore, it helps save more 25% power consumption. Embedded digital HDMI and DisplayPort inputs, VE276Q enables the most advanced graphic cards/ computers connection. The DisplayPort interface also offers better support of multiple display streams, longer cable connection, and interoperability with other inputs, such as VGA, DVI and HDMI. Need to research on the Internet, but a championship game is about to start on TV? The VE276Q offers PIP(Picture in Picture) function(via hotkey) and has the capability to display images of two different signals at the same time. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 27.0"(68.6cm) 16:9 Wide Screen
- Pixel Pitch : 0.311mm
- Brightness(Max) : 300 cd/m
- ASUS Smart Contrast Ratio (ASCR) : 100000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 6 Modes
- Skin-Tone Selection : 3 Modes
- HDCP support
- Audio Features Stereo Speakers : 3W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI ,D-Sub,DisplayPort,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 56~76 Hz(V)
- Power Consumption Power Consumption < 70 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 643x445.6x220mm
- Box Dimension(WxHxD): 732x560x176mm
- Weight Net Weight (Esti.): 7.2 kg
- Gross Weight (Esti.): 10.5 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval UL/cUL, CB, CE, EuP, FCC, CCC, BSMI, Gost-R, C-Tick, VCCI, PSB, EK, J-MOSS, Taiwan Green Mark,RoHS, WEEE, WHQL
Was £229.99 Inc. VAT
ORDER NOW
Dell Ultrasharp U3011 30" Widescreen LCD Monitor - Midnight Grey @ £1,019.99 inc VAT
Experience amazing wide-angle viewing and color consistency with the DellTM UltraSharpTM U3011 30"W Monitor with PremierColor. Extensive connectivity features and customization via CustomColor mode make the U3011 an ideal choice for professionals in CAD/CAM, graphic design, gaming and other fields where color precision matters.
Features:-
- IPS (in-plane switching) technology for minimal color deviation across a wide viewing angle
- 30" (76cm) display with 2560x1600 resolution and 16:10 aspect ratio for clear images and exceptional multitasking
- 117% (CIE 1976) color gamut with excellent AdobeRGB and sRGB coverage for rich, lifelike visuals
- Easy, versatile adjustability and some of the latest connectivity options, including HDMI, DisplayPort, DVI-D, USB ports and a 7-in-1 media card reader
Specification:-
- 30" Widescreen
- About 52.5% more screen area than Dell 2407WFP-HC
- The only 4 mega pixels monitor that shows true resolution of mega pixel pixel photos
- Higher definition than HD Television to meet the most stringent video needs
- 2560 x 1600 (WQXGA) Optimum Resolution (Dual Link capable DVI-D graphics card required)
- 1.07 Billion Colours
- 100,000:1 Contrast Ratio
- 7ms Response Time (7ms Grey-TO-Grey)
- 370 cd/m2 Brightness
- Two DVI-D Input with HDCP support
- Two HDMI Input
- One Display Port Input
- One Analogue Input
- Component Connectors
- Height adjustable stand, tilt and swivel (100mm travel)
- VESA mounting compatible / Security slot : Yes (100mm) / Yes
- Integrated powered USB 2.0 hub : 4 downstream / 1 upstream ports
- Integrated powered 9-in-2 Card Reader: Compact Flash 1&2, Secure Digital, MMC, Smart Media and Microdrive
- Warranty : 3 year next business day exchange supplied by Manufacturer. (Call Dell on 0870 9080800 and have the work number from the original packaging handy, request to speak to the Dell Warranty Monitor Line)
Was £1,049.99 Inc. VAT
Only £1,019.99 inc VAT.
ORDER NOW
Hanns.G HZ281HPB 27.5" Widescreen LCD Monitor - Black @ £239.99 inc VAT
The Hanns.G 27.5" has an industry ultra-fast 3ms response time making it perfect for blur-free video and gaming. With it's 15000:1 contrast ratio and excellent viewing angles there is no other TFT that can match the combination of quality, value and performance. Making the large screen affordable to all this 27.5" is ideal for gamers and home cinema use due to its huge size and 1920x1200 resolution.
- Screen Size: 27.5" Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 15000:1
- Brightness: 400cd/m²
- Response Time: 3ms
- VESA Compliant
- Dimensions: 653.0mm x 523.0mm x 254.0mm
- Weight: 8.5kg
Was £249.98 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
Hazro HZ27WC 8-Bit 27" LED Widescreen Professional Monitor - Black @ £359.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WC features the same high resolution LED IPS panel found in the HZ27WA without scaling functionality. Video content bypasses scalers making the HZ27WC ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 1000:1 / 1,000,000:1 (Dynamic)
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x Dual Link DVI-D
- 2.5mm Audio out
- Kensignton Security Port
- 8bits [16.7Million colors]
- Dual Link DVI-D Cable, 2.5mm Audio Cable, 24V External Power Adapter, UK
- PIP/POP, Mapping: Not Supported
- Only available to customers in the United Kingdom
- 3yr RTB Warranty (UK customer only)
ORDER NOW
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Glass Monitor - Black @ £491.99 inc VAT
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
These monitors use a glass coating on the front which results in much sharper images quality, more vibrant colours and an overall better viewing experience. The downfalls of glass fronted panel is the monitor weighs a lot more and the manufacturing process can lead to dust particles been trapped between the panel and the glass which can sometimes be spotted when up very close to the screen and with certain solid coloured backgrounds.
Features:-
- Glass front panel for improved image quality
- 1 x DisplayPort
- 2 x HDMI
- 1 x Dual Link DVI-D [HDCP Supported]
- 1 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- 10bits [1.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
Was £559.99 Inc. VAT
Only £491.99 inc VAT.
ORDER NOW
IIyama Prolite X2775HDS 27" Widescreen LED Monitor - Black @ £239.99 inc VAT
The ProLite X2775HDS is the latest addition to the range of monitors featuring VA Panel technology which offers superb colour performance and viewing angles. This sophisticated technology provides 24 bit 'True Colour and superior black and white display performance. A 3000:1 Native Contrast Ratio means the ProLite X2775HDS is ideal for Photographic Design and Web-design. Featuring a fast response time, full HD 1920 x 1080 resolution with VGA, DVI and HDMI connectivity, this screen is compatible with a wide range of systems and applications and is also a Low Power LED Panel, making it an excellent choice for Universities, Corporate, Financial and Design Markets.
VA matrix offers 24-bit true colour which assures realistic colour reproduction. VA technology offers also higher contrast, darker blacks and much better viewing angles than standard TN technology.
Features:-
- Diagonal: 27"
- Panel: VA, LED-backlit
- Display area h x w: 336.2 x 597.6 mm; 13.2" x 23.5"
- Response time: 8 ms
- Contrast: 3000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Viewing zone: horizontal/vertical: 178°/ 178°; right/left: 89°/ 89°; up/down: 89°/ 89°
- Display colour: 16.7 million
- Pixel pitch h x v: 0.3113 x 0.3113 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate Sync
- Aspect ratio: 16 : 9
- Analog input connector: D-Sub
- Digital input connector: DVI-D, HDMI
- HDCP: yes
- Dimensions w x h x d: 642 x 438.5 (507.5) x 210 mm
- Weight: 6 kg
- Warranty: 3 Year On-Site
Was £269.99 Inc. VAT
ORDER NOW
Dell Inspiron 1011 Intel Atom N270 1.60GHz 10.1" LED, Mini Netbook (Obsidian Black) - Windows 7 @ £167.99 inc VAT
Timing is everything, and now you can have all the time in the world. The newly designed Inspiron Mini 10 offers up to 8.5 hours of battery life to keep you on the go. This Dell Inspiron Mini Netbook features a 160GB hard drive, plenty of room to store all your photos and music. It also features a webcam so you can communicate with friends or family from miles away, or use it to take images of yourself to upload on to the net. If you're looking for a small, lightweight, great quality Netbook for general web browsing, emailing and keeping your photos safe then the popular Dell Mini Inspiron Netbook is for you!
- Intel Atom N270 1.60GHz Pineview Processor
- Display: Built-in 10.1" WSVGA TrueLife widescreen display (1024 x 600)
- 1GB RAM
- 160GB Hard Drive
- 3 in 1 Card Reader
- 3 Cell Battery
- 3x USB2.0
- Windows 7 Starter
- 12 Months Warranty (Brand new sealed product)
Was £179.99 Inc. VAT
Only £167.99 inc VAT.
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I7-740QM, 6GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red **£50 CASHBACK** @ £983.99 inc VAT
nonl2br
<img src="http://www.msimobile.com/img-overview/GX660/Topbanner.jpg" height="480" width="768" alt="GX660" /><br>
<br>
<Br>
<font size="4"><b>Key Features</b></font><br>
<br>
<b>• The latest Intel Quad Core i7-740QM 1.73GHz Processor</b><br>
• Genuine Windows 7 Home Premium<br>
• DTS Surround Sensation UltraPC<br>
• Exclusive TDE Technology<br>
• 16:9 Full HD LED Display<br>
• High-end ATi Radeon HD 5870M graphics<br>
• HDMI (High-Definition Multimedia Interface) Output<br>
• Built-in HD Webcam<br>
• 802.11 b/g/ n Wireless LAN with Bluetooth<br>
<br>
<br>
<font size="4"><font color="Blue"><b>New Level of Sound and Performance</b></font></font><br>
<font size="4"><b>MSI + Dynaudio = New Standard of Gaming Notebook</b></font><br>
<br>
<b>Dynaudio Premium Sound Technology</b><br>
<br>
The complex and interconnected elements that comprise excellent sound were painstakingly identified one by one to ascertain how to systematically develop the proper notebook technologies. After undergoing a very long process of cooperative development, Dynaudio and MSI have come up with the GX660. The four directions used to develop Dynaudio Premium Sound Technology are summarized below. For serious gamers who demand extreme audio performance, the GX660 is the best and only choice!<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/speaker-1.jpg" align="centre" alt="GX660" /><br>
<br>
<b>Speaker Placement</b><br>
<br>
In the past, limited space on notebooks meant speaker position was always considered last, which resulted in muddled sound in notebook speakers. Because of this, speaker position was considered during the initial stages of the GX660's development to facilitate optimum audio performance and to avoid sacrificing audio quality for incorrect speaker placement.<br>
<br>
<b>EQ Tuning: Adjusted for Optimization of All Types of Sounds</b><br>
<br>
Different types of music represent distinct requirements for sound ambience. Jazz, pop, rock, or classical all possess special characteristics that affect computer game and movie sound performance and each has specific tone balance requirements. To express different types of music authentically, Dynaudio and MSI spent over 1,200 hours of continuous, repetitive testing and fine tuning of high, mid, and low range frequencies so authentic reproduction of different types of music can be achieved.<br>
<br>
<br>
<img src="http://www.msimobile.com/img-overview/GX660/inteli7" align="right" alt="" />
<font size="4"><font color="Blue"><b>Choose The Best!</b></font></font><br>
<br>
<b>Powerful Hardware Under the Hood Deliver Enhanced Horsepower and Blazing Speed</b><br>
The GX660 includes the world’s most advanced Intel® Core™ i7 quad core processor, which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br><img src="http://www.msimobile.com/img-overview/GX660/turbo.jpg" align="left" height="300" width="373" alt="GX660" /><br>
<br>
<br>
<b>Accelerated CPU Performance MSI’s Exclusive TDE Technology</b><br>
<br>
By overclocking the CPU and memory frequency, the TDE Technology brings more calculating speed to enhance the system performance. It benefits the video decoding/ encoding, gaming and art work designing. With MSI TDE Technology, you can experience fast-response time and efficient real-time data processing.<br>
<br>
<br>
<b>Exclusive Cooler Boost Technology</b><br>
Only one finger!! Exclusive Cooler Boost technology provides powerful cooling capabilities and receives real-time notification of the GX660's core temperature variations and fan speed.<br>
<br>
<br>
<br>
<br>
<br>
<font size="4"><font color="Blue"><b>Marvel At The Most Amazing Images Around</b></font></font><br>
<b>The ATI Radeon™ HD 5870 Graphics (with GDDR5 1GB VRAM)</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gx660/gx660_05.jpg" align="centre" alt="GX660" /><br>
The 1GB GDDR5 internal memory and the ATi Radeon™ HD 5870 graphics card provide a high-definition gaming experience that puts you right in the middle of the action sequences. Delivering full support for Microsoft DirectX® 11, the GPU enables richer and true-to-life graphics performance so that you can enjoy immersive games or movies.<br>
<br>
<b>16:9 Full HD* LED Backlit Display</b><br>
<img src="http://eu.msi.com/uploads/Image/product_img/other/nb/gt660/gx660_hd.jpg" align="centre" alt="GX660"/><br>
The 15.6” Full HD screen of the GX660 delivers more details of the high definition content; brings you more pleasure while playing games or watching movies.<br>
<br>
<font size="4"><b>Specifications</b></font><br>
<br>
<b>CPU</b> Intel Core™ i7-740QM 1.73GHz Processor <br>
<b>OS</b> Genuine Windows 7 Home Premium <br>
<b>Chipset</b> Intel PM55 <br>
<b>Memory</b> 6GB DDR3 1066 MHz<br>
<b>LCD Size</b> 15.6" FHD 1920*1080 TFT-LCD Display (LED Backlight) <br>
<b>Graphics</b> ATi Mobility Radeon HD 5870M <br>
<b>Graphics</b> VRAM GDDR5 1GB <br>
<b>HDD</b> 2x500GB in RAID 0 SATA <br>
<b>Optical Drive</b> Super-Multi DVDRW<br>
<b>Audio</b> 2 Theater Class Speakers +1 Subwoofer <br>
<br>
- HD Webcam <br>
- Card Reader XD/SD/MMC/MS <br>
- LAN 10/100/1000 <br>
- Wireless LAN 802.11 b/g/n <br>
- Bluetooth V2.0EDR <br>
- D-Sub (VGA)<br>
- HDMI<br>
- 2x USB 2.0 port <br>
- 2x USB 3.0 port <br>
- eSATA <br>
- 120W AC Adapter<br>
- 9 cell Battery<br>
- £50 Cashback MSI Promotion, see:- http://www.overclockers.co.uk/LP/msi_summer_cashback.php
Only £983.99 inc VAT.
ORDER NOW
MSI GX660R 15.6" WLED TFT Intel I5-480M, 8GB DDR3, 1TB HDD, ATI HD 5870 1GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Black/Red @ £1,103.99 inc VAT
nonl2br
<br>
<Br>
<br>
<b>• The latest Intel Core i5-480M 2.66GHz Processor</b><br>
• Blu-Ray Drive for True HD Movie Playback<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
The GX660 includes the world’s most advanced Intel® Core™ i5 quad core processor (Hyperthreading), which boasts superior multimedia performance and can retrieve data from Blu-ray disks or update online photo albums twice as fast as conventional dual core notebooks. The processor also comes with Intel’s Turbo Boost technology, allowing you to power up or down as necessary, depending on the load requirements of the task at hand.<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<b>CPU</b> Intel Core™ i5-480M 2.66GHz Processor <br>
<b>Memory</b> 8GB DDR3 1066 MHz<br>
<b>Optical Drive</b> Blu-Ray Drive<br>
<br>
- HD Webcam <br>
- D-Sub (VGA)<br>
- HDMI<br>
- eSATA <br>
Was £1,149.00 Inc. VAT
Only £1,103.99 inc VAT.
ORDER NOW
MSI GT683 15.6" WLED TFT Intel I7-2630QM, 8GB DDR3, 1.5tb HDD, NVIDIA GTX 570M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Back/Red @ £1,314.00 inc VAT
What do gamers desire most? MSI knows best! In GT683, MSI not only conducted research with the world-class team Fnatic, but also collaborated with SteelSeries, a leading manufacturer of professional gaming peripherals, to develop a “gamer’s keyboard” never before seen in gaming notebooks. GT683 provides you the best gaming experience!
GT683 has a 15.6 inch Full HD screen, which projects a vibrant visual effect. The latest top-end NVIDIA Geforce GTX570M graphic card with 1.5GB GRDDR5 memory gives the notebook an extraordinary gaming performance. GT683 is fully compatible with DX11, which provides an ultra-smooth and vivid three-dimensional visual experience.
In order to present the best sound effects, the GT683 speakers are uniquely configured. Besides the two side speakers projected toward the user, there is also a subwoofer sound hole at the bottom. This configuration immerses gamers into a realistic, three-dimensional battlefield experience.
Features:-
- Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- The Latest 2nd Generation Intel® Core™ i7 Processor
- High-end NVIDIA® GeForce GTX 570M discrete graphics card(with GDDR5 1.5GB VRAM) provides great detail images quality
- Dual SATA hard drives with RAID0 to double the transmission speed
- Exclusive TDE technology to speed up the performance
- Sound by Dynaudio for extreme audio performance
- Exclusive DDR3 SO-DIMM x 4 slot design easily upgrades memory capacity
- THX TruStudio Pro provides excellent surround sound
- Latest & fastest data transfer technology USB 3.0
Specification:-
- CPU Intel® Core™ i7-2630QM Processor (6M Cache, 2.00 GHz)
- OS Genuine Windows® 7 Home Premium (MSI recommends upgrade to Genuine Windows® 7 Professional)
- Chipset Intel HM67
- 8GB Memory DDR3 1333 MHz ,Slot : 4
- LCD Size 15.6" Full HD 1920x1080 resolution
- Graphics nVidia GeForce GTX 570M
- Graphics VRAM 1.5GB GDDR5
- HDD: 1.5TB (2x 750GB in RAID 0) (7200rpm)
- Optical Drive: DVD Super Multi
- Audio 2.1 channels speakers, Sound by Dynaudio, THX TruStudio Pro, 7.1ch output
- Webcam HD type (30fps@720p)
- Card Reader SD(XC/HC)/MMC/MS(PRO)/xD
- LAN 10/100/1000
- Bluetooth Bluetooth v3.0 + HS
- D-Sub (VGA) 1
- HDMI 1 (v1.4)
- USB 2.0 port 3
- USB 3.0 port 2
- eSATA 1
- eSATA/USB Combo N/A
- Mic-in/Headphone-out 1/1
- Line-in 1(line in)/1(line out)
- Express Card N/A
- Modem port N/A
- Keyboard 102-key keyboard by SteelSeries
- Sensor N/A
- AC Adapter 180W
- Battery 9 cells
- Power Management Turbo Battery+
- Weight (KG) 3.2
- 2yr Warranty
Was £1,349.99 Inc. VAT
Only £1,314.00 inc VAT.
ORDER NOW
MSI GT780DXR-290UK 17.3" WLED TFT Intel I7-2670QM, 8GB DDR3, 1.5tb HDD, NVIDIA GTX 570M 1.5GB GDDR5 Graphics, Win7 Home Premium 64-Bit - Back/Red @ £1,379.99 inc VAT
What do gamers desire most? MSI knows best! In GT780DX, MSI not only conducted research with the world-class team Fnatic, but also collaborated with SteelSeries, a leading manufacturer of professional gaming peripherals, to develop a “gamer’s keyboard” never before seen in gaming notebooks. GT780DX provides you the best gaming experience!
GT780DX has a 17-inch Full HD screen, which projects a vibrant visual effect. The latest top-end NVIDIA Geforce GTX570M graphic card with 1.5GB GRDDR5 memory gives the notebook an extraordinary gaming performance. GT780DX is fully compatible with DX11, which provides an ultra-smooth and vivid three-dimensional visual experience.
In order to present the best sound effects, the GT780DX speakers are uniquely configured. Besides the two side speakers projected toward the user, there is also a subwoofer sound hole at the bottom. This configuration immerses gamers into a realistic, three-dimensional battlefield experience.
The exterior design of the GT780DX combines the classic, succinct appearance of a limousine with the aerodynamic contour of a spacecraft creating a low-key composure but powerful image. The black casing of the GT780DX is specially covered with brushed aluminum, coupled with the silver msi logo, it makes the GT780DX a symbol of the coexistence of textural quality and ultimate performance.
To avoid accidentally touching the touch pad while gaming, the GT780DX is equipped with a control switch for the touch pad on the side of the keyboard
Features:-
- Best gaming keyboard designed by SteelSeries
Specification:-
- CPU Intel® Core™ i7-2670QM Processor (6M Cache, 2.20 GHz)
- LCD Size 17.3" Full HD (1920x1080) LED backlight
- Optical Drive Blu-ray / DVD Super Multi
- LAN 10/100/1000
- D-Sub (VGA) 1
- HDMI 1 (v1.4)
- USB 2.0 port 3
- USB 3.0 port 2
- eSATA 1
- Express Card N/A
- Modem port N/A
- Sensor N/A
- AC Adapter 180W
- Battery 9 cells
- Dimension 428 x 288 x 55mm(WxDxH)
- Weight (KG) 3.9
- UK Model does *NOT* have backlit keyboard
- UK Model comes with FREE Dirt 3 PC Game
- 2yr Warranty
Was £1,499.99 Inc. VAT
Only £1,379.99 inc VAT.
ORDER NOW
OCZ Vertex 2 50GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTX50G) @ £59.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 50GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £64.99 Inc. VAT
ORDER NOW
Corsair Force Series 3 60GB SATA 6Gb/s Solid State Drive (CSSD-F60GB3A-BK) @ £79.99 inc VAT
Step up to SATA 6Gb/s performance with a Corsair Force Series 3 SSD. Your system responds better, boots quicker, and loads applications faster. Ideal for notebooks, Corsair SSDs run cooler and quieter than traditional hard drives, using less power.
- 60GB Capacity
- Sequential read speeds of up to 525 MB/s
- Sequential write speeds of up to 490 MB/s
- SATA 6Gb/s (SATA 3) connectivity
- High performance SandForce SF-2200 SSD controller
- Native TRIM support (O/S support required)
- RAID Support
- BGC (Background Garbage Collection)
- 2.5" - 3.5" Adaptor Included.
Was £82.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
OcUK Professional 2.5" to 3.5" SSD Adaptor Plate - Black @ £3.98 inc VAT
The OcUK Professional 2.5" to 3.5" Hard Drive Adapter offers a simple solution for mounting 2.5" SSDs/Hard Drives within a 3.5" drive bay.
- Aluminium 3.5" Bracket
- Easily add a 2.5" SATA hard drive to your 3.5" slot on your PC
Was £4.79 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
Crucial RealSSD M4 512GB 2.5" SATA 6Gb/s Solid State Hard Drive @ £569.99 inc VAT
Continuing the tradition of our award-winning solid-state drives, the Crucial m4 offers mobile and desktop users scorching-fast read and write speeds. Low power, lightweight, and durable, it empowers high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management, and the SATA 6Gb/s interface. Together, that technology dramatically improves data transfers for bandwidth-demanding applications.
Our products are built on decades of design and manufacturing expertise. It is our expertise in NAND technology that enables us to optimize the performance and endurance necessary to build quality solid-state storage devices.
- Sequential Read (up to): 415MB/sec (SATA 6Gb/s) - 550MB/sec with firmware 0009
- Sequential Write (up to): 260MB/sec (SATA 6Gb/s) - 300MB/sec with firmware 0009
- Random 4k Read: 40,000 IOPS
- Random 4k Write: 50,000 IOPS
- PCMark Vantage: 65K HDD Test Score
- Interface: SATA 6Gbps / Backwards Compatible 3Gbps
- Seek Time: .1ms
- Slim 2.5" Design
- 100.5 x 69.85 x 9.5mm
- Lightweight: 75g
- Operating Temp: 0°C ~ 70°C
- Storage Temp: -40°C ~ 85°C
- Low Power Consumption: 150 mW in operation, .85 mW in standby
- Shock Resistant up to 1500G
- RAID Support
- MTBF: 1.2 million hours
- Limited 3-Year Warranty
** FIRMWARE UPDATE 0009 - Increased speeds up to 550MB/s **
Link to Frimware: - http://www.crucial.com/support/firmware.aspx
Was £599.99 Inc. VAT
Only £569.99 inc VAT.
ORDER NOW
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive (CSSD-F120GB3-BK) @ £127.99 inc VAT
- 120GB Capacity
- Sequential read speeds of up to 550 MB/s
- Sequential write speeds of up to 510 MB/s
- RAID Support
** FIRMWARE ISSUE FREE **
Only £127.99 inc VAT.
ORDER NOW
Kingston HyperX 120GB 2.5" SATA-3 Solid State Drive @ £179.99 inc VAT
The all new Kingston HyperX performance SSD featuring the Sandforce SF-2281 controller for blistering fast reads and writes and industry leading IOPS.
- 95k IOPS
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 555MB/sec
- Maximum Write: 510MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File, READ)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- Warranty: 3 Years
Was £188.99 Inc. VAT
ORDER NOW
Kingston HyperX 240GB 2.5" SATA-3 Solid State Drive @ £349.99 inc VAT
- 95k IOPS
- Capacity: 240GB
- Warranty: 3 Years
Was £389.99 Inc. VAT
Only £349.99 inc VAT.
ORDER NOW
OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G) @ £163.99 inc VAT
nonl2brAs the third generation of the legendary Vertex Series, OCZ Vertex3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Vertex3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Vertex3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.<br>
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br>
<br>
- Capacity: 120GB<br>
- Controller: SandForce SF-2281<br>
- Maximum Read: 550MB/sec<br>
- Maximum Write: 500MB/sec<br>
- Sustained Write: 500MB/sec<br>
- Max I/O Per Second (IOPS): 60000 IOPS (4KB File)<br>
- NAND Flash: Multi-Level Cell (MLC)<br>
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)<br>
- TRIM Support (Requires Windows 7)<br>
- 2.5" to 3.5" SSD adaptor included<br>
- Warranty: 3 Years<br>
<br>
<iframe width="560" height="315" src="http://www.youtube.com/embed/CKMODN3kIpE" frameborder="0" allowfullscreen></iframe>
Was £172.99 Inc. VAT
Only £163.99 inc VAT.
ORDER NOW
OCZ Vertex 3 240GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-240G) @ £349.99 inc VAT
Using the latest break through controller and flash technology, Vertex3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.<br><br>
- Capacity: 240GB<br>
- Maximum Write: 520MB/sec<br>
- Sustained Write: 520MB/sec<br>
<br>
ORDER NOW
OCZ Vertex 3 MAX IOPS 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3MI-25SAT3-120G ) @ £204.98 inc VAT
<br>
- Max I/O Per Second (IOPS): 75000 IOPS (4KB File)<br>
<br>
Was £210.98 Inc. VAT
Only £204.98 inc VAT.
ORDER NOW
OcUK Value 32GB USB Drive Black @ £22.99 inc VAT
OcUK Value PinStripe 32GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
- Push and pull sliding feature
- Enhanced for Windows ReadyBoost
- Includes EasyLock Password Protection Software Trial
- Compatible with Windows 2000, XP, Vista & Windows 7
- Compatible with Mac OS 9 or higher & Linux 2.4.0 or higher
With ports in almost every computer and popping up in cars, DVD and Multimedia players, TV's, Photo Frames and many more, USB drives are now being considered an essential accessory.
Was £26.99 Inc. VAT
Only £22.99 inc VAT.
ORDER NOW
OcUK Value 16GB USB Drive Black @ £13.99 inc VAT
OcUK Value PinStripe 16GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £15.98 Inc. VAT
Only £13.99 inc VAT.
ORDER NOW
OcUK Value 8GB USB Drive Black @ £7.99 inc VAT
OcUK Value PinStripe 8GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £8.99 Inc. VAT
Only £7.99 inc VAT.
ORDER NOW
OcUK Value 4GB USB Drive Black @ £3.98 inc VAT
OcUK Value PinStripe 4GB USB Flash Drive (Black) The new "Pin Stripe" utilises a pull-mechanism which protects the USB connector without requiring a separate cap.
Key Features
Was £4.49 Inc. VAT
Only £3.98 inc VAT.
ORDER NOW
Kingston DataTraveler 101 Generation 2 4GB USB 2.0 Flash Drive (DT101G2/4GB) @ £4.79 inc VAT
The Kingston DataTraveler 101 Generation 2 (G2) is here! This convenient storage companion lets you take all of your data to your home, office, school and anywhere you travel. Now with urDrive, it gives you a better way to look at your data while combining cool features to make it your own. It’s like having a customisable, portable desktop – anywhere. Sleek, practical and attractively designed, the DataTraveler 101 G2 serves the needs of the budget-conscious user as well as those looking for significant storage capacity in a lightweight, compact swivel design in fun colours by capacity.
- Capacity: 4GB
- Dimensions - 57.18mm x 10.00mm x 17.28mm
- Simple - just plug into a USB port
- Handy - compact size
- 5-Year warranty
Was £5.99 Inc. VAT
Only £4.79 inc VAT.
ORDER NOW
Kingston 4GB SDHC Class 4 Flash Card (SD4/4GB) @ £4.39 inc VAT
Kingston Technology's Secure Digital High-Capacity (SDHC) memory cards are fully compliant with the new Secure Digital Association 2.00 specification. They are a new performance class of SD memory cards designed to meet the storage demands of high-quality digital still and video cameras and other high-resolution image recording devices.
- Capacity: 4GB
- Data Transfer Speed Class: 4
- Lifetime Warranty
Was £4.99 Inc. VAT
Only £4.39 inc VAT.
ORDER NOW
Corsair Gaming Audio Series SP2500 High-Power 2.1 PC Speaker System - 232 Watts RMS @ £179.99 inc VAT
nonl2br
Since you have only one PC speaker system, you don’t want to make sacrifices. That’s why Corsair has created the SP2500.<br>
At its heart are six Class D amplifiers driven by an ultra-efficient power supply. The 8” subwoofer driver is housed in a fourthorder bypass enclosure for clean, tight bass response that can seriously shake the room. The bi-amplified satellites use specially developed 3” drivers and custom-designed, ferrofluid-cooled 1” silk dome tweeters for detailed audio reproduction across the entire spectrum with great stereo imaging and a generous sweet spot. A programmable digital signal processor lets you craft the audio to your liking. It’s all under your command with the 1.8” (4.6cm) color display desktop controller.
<br>
- 232 Watts RMS of continuous power delivery through six Class D amplifiers <br>
- 8” subwoofer with durable rubber surround in a fourth-order bandpass enclosure <br>
- Bi-amplified satellites with 3” drivers and 1” ferrofluid-cooled silk dome tweeters <br>
- Clean, high-fidelity audio reproduction with excellent stereo imaging <br>
- Programmable digital signal processor for advanced dynamic audio processing <br>
- Wired desktop controller with 1.8” (4.6cm) color TFT display and multi-lingual interface<br>
<br>
Specification:<br>
- Frequency response of 35Hz – 20kHz +- 3dB<br>
- 232 Watts of total power (measured via FTC “RMS” method)<br>
- Subwoofer: 18.1” x 10.2” x 11.7” (46 x 25.8 x 29.7cm) enclosure with fourth-order bandpass design for accurate bass reproduction<br>
- Subwoofer: 8” subwoofer driver with durable rubber surround<br>
- Subwoofer: Bridged dual 60 Watt class-D amplifiers with integrated DSP for 120W of power (measured via FTC “RMS” method)<br>
- Subwoofer: Ultra-efficient integral power supply with 100V – 240V AC input<br>
- Satellites: Bi-amplified, two-way design with detachable audio cables<br>
- Satellites: 3” midrange drivers<br>
- Satellites: 1” custom-designed, ferrofluid-cooled silk dome tweeters<br>
- Satellites: 4.25” x 4.7” x 6.25” (10.8 x 12 x 15.9cm) enclosures with asymmetrical tweeter placement for superior stereo imaging<br>
- I/O, Controls, and Programming: PC input on subwoofer<br>
- I/O, Controls, and Programming: Dual 3.5mm auxiliary inputs (one on subwoofer, one on desktop controller)<br>
- I/O, Controls, and Programming: 3.5mm headphone out with digital signal processing<br>
- I/O, Controls, and Programming: Wired desktop controller with 1.8” (4.6cm) color display and multi-lingual interface<br>
- I/O, Controls, and Programming: Digital signal processor with active crossover capability<br>
- I/O, Controls, and Programming: Mod X™ theatrical audio processing for Blu-Ray and DVD audio that recreates the theatre experience<br>
- I/O, Controls, and Programming: Dynamic DSP programs and EQ curves for late night listening, environment simulation, and optimal enjoyment of games, movies, and music<br>
- Package Contents: x1 subwoofer, x2 satellites, x1 desktop controller with 6’ (1.8M) cable, 3.5mm to stereo RCA cable for PC input, 6’ (1.8m) satellite cables with ATX connectors, Power cable, User Guide<br>
- Retail box dimensions: 22.75in L x 19.75in W x 15.75in H (57.8cm x 50cm x 40cm)<br>
- Weight: 30.75 lb (13.9 kg)<br>
<br>
<CENTER><iframe title="YouTube video player" width="640" height="390" src="http://www.youtube.com/embed/VOo686QhINc" frameborder="0" allowfullscreen></iframe></CENTER>
<br>
Was £188.98 Inc. VAT
ORDER NOW
Corsair Gaming Audio Series SP2200 2.1 PC Speaker System - 46 Watts RMS @ £39.98 inc VAT
The SP2200 is designed for gamers and media enthusiasts who want a powerful, compact 2.1 speaker system that doesn’t take a lot of space. 46 Watts of total power (measured via the FTC “RMS” method), with 30 Watts dedicated to the 6” subwoofer, ensure room-shaking bass and clean, crisp audio reproduction at any volume level. Excellent stereo imaging with a generous “sweet spot” ensure a competitive advantage in games and realistic music and movie audio.
The SP2200 is easy to set up, and easy to use. Controls are up front where you need them, and flexible connection options allow you to connect up to three audio sources at once.
- 46 Watts RMS continuous power delivery for room-filling sound and clean, crisp audio reproduction
- 30 Watt subwoofer with 6” driver for serious bass performance
- Compact satellites with 3” drivers provide detailed audio reproduction without taking lots of desk space
- Excellent stereo imaging with a generous “sweet spot”
Specifications:
- Frequency response of 40Hz – 20kHz +/5 5dB, -10dB @ 35Hz
- 46 Watts total power (measured via FTC “RMS” method)
- Subwoofer: 6” (15.24cm) side-firing, ported subwoofer suitable for desk or floor placement
- Subwoofer: 30 Watts (measured via FTC “RMS” method)
- Subwoofer: Subwoofer enclosure dimensions: 9.1” x 9.9” x 7.1” (23.1cm x 25.2cm x 18cm)
- Satellites: 2” (5cm) drivers
- Satellites: Volume and subwoofer output controls integrated in right satellite
- Satellites: Up-front auxiliary input and headphone output
- Satellites: 8 Watts per satellite (measured via FTC “RMS” method)
- Satellites: Satellite enclosure dimensions: 5” x 3.6” x 5.6” (12.7cm x 9.1cm x 14.2cm)
- Satellites: PC input on subwoofer
- I/O and Controls: Three inputs for maximum flexibility: 3.5mm stereo PC input, RCA stereo auxiliary input for gaming consoles, and a 3.5mm stereo auxiliary input on the right satellite for MP3 players
- I/O and Controls: 3.5mm headphone output
- I/O and Controls: Main volume and subwoofer output control dials on the right satellite
- Package Contents: x1 subwoofer, x2 satellites, Power cable, User Guide
- Retail box dimensions: 12.8” L x 11.5” W x 11” H (32.5cm L x 29.3cm W x 28cm H)
- Weight: 11.17 lb (5 kg)
Was £49.99 Inc. VAT
Only £39.98 inc VAT.
ORDER NOW
Logitech S-220 2.1 Speaker System - OEM (980-000022) @ £15.98 inc VAT
Logitech S-220 Speaker System provides the rich acoustics with a high-quality subwoofer and two satellite speakers. A high-performance piano-finish wired remote provides the convenient access of volume and power controls, besides, its headphone jack and microphone jack give you more valuable usages, e.g. private listening, internet video gaming and conferecing.
- High class glossy satellite speakers with the ported subwoofer provides the full and rich audio performance
- Friendly wired control pod designed for minimizing the desk clutter
- The convenient wired control pod provides headphone jack, microphone jack, volume and power controls for adjustment easily
- Easy connection to PCs, CD and MP3 players and between satellite speakers and subwoofer
Was £21.98 Inc. VAT
Only £15.98 inc VAT.
ORDER NOW
Edifier R1600T Studio Plus 2.0 Monitors @ £61.99 inc VAT
The Edifier R1600T Plus is a professional low-noise amplifier with all wood enclosure. The high performance crossover provides superior coverage while magnetic shielding prevents interference. The 5-inch bass driver is designed using a composite cone structure for a truly balanced acoustic. Built-in, side-mounted controls mean volume, treble and bass are at your fingertips. Dual RCA inputs allow connection of two additional devices for maximum flexibility in your set-up.
- Professional low-noise amplifier coupled with high performance crossover.
- 4.5inch bass driver - designed using a composite cone structure for a balanced acoustic.
- Silk diaphragm 18 mm tweeter with aluminum phase plug.
- Side mounted rotary volume, bass and treble controls.
- All wood enclosure.
- Power Output: RMS 2 × 16W
- Signal to noise ratio: 85 dBA
- Distortion: 0.1%
- Bass unit: 5 inch (120mm), magnetically shielded, 6ohm
- Tweeter unit: 18mm silk dome tweeter, magnetically shielded, 4 ohm
- Input impedance: 10K ohm
- Input sensitivity: 550 mV ± 50 mV.
- What's in the box:
- 1 x Active speaker
- 1 x Passive speaker
- 1 x 3.5mm to RCA connector cable
- Audio connecting cable
- User manual
- Dimensions: 152(W) x 252(H) x 228(D) (mm)
** boxes opened to include UK power connector, 100% new **
Was £69.98 Inc. VAT
Only £61.99 inc VAT.
ORDER NOW
Philips SPA2602 5.1 Surround Sound Speaker System @ £32.99 inc VAT
Perfect for MP3, PC, TV and more.
Connect your speakers to all your gear. A great way to listen to your MP3 player, PC, TV, CD, DVD and all your multimedia stuff.
Sound
- Bass enhancement: Analogue Bass Boost, Bass reflex
- Frequency response: 35 - 20 K Hz
- Loudspeaker Enhancement: Magnetic Shielded LSB
- Music Power: 90 W
- Volume Control: Analogue Volume Control
- Wires: Fixed Wires
- Output power (RMS): 45 W
Loudspeakers
- Satellite speaker drivers: 3"
- Subwoofer driver: 4.25"
Connectivity
- Audio input for data: Stereo Audio (3.5 mm jack) 1 x
- Cable length: 1.5 m
- Connector: 3.5 mm stereo
Was £34.99 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 140mm Fan @ £11.99 inc VAT
When developing the new generation of our housing-fan series SilentWingsUSC, two things were of particular importance to us: that they should run extremely quietly and at the same time achieve optimum airflow - an extremely tricky challenge.
And with the newly developed Ultra Silent Concept (USC), we have mastered this challenge. The USC comprises, amongst other things, two Innovations from be quiet! protected by german utility patent. In addition, the housing fan has a remarkable lifespan of almost 300,000 hours.
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 120mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Screwless anti-vibration fixtures and rubberised fan frame protected by german utility patent
- Quiet operation thanks to the reduction of vibrations and simple installation without tools
- Minimisation of electrical noises at a constantly high running smoothness
- Fan Speed: 1000 RPM
- Air Flow: 60.4 or 102.7 CFM
- Noise Levels: 16.5 dBA
- 3 Pin Molex
- 3 Year Warranty
Was £16.99 Inc. VAT
Only £11.99 inc VAT.
ORDER NOW
Creative Inspire A520 5.1 Speaker System (51MF4110AA008) @ £44.99 inc VAT
Give your games, music and movies a much-needed boost with the Creative A520 5.1 speaker system. Given their contemporary style and ease of use, they are the perfect choice for immersive multi-channel surround sound, bringing to you all the benefits of Creative’s leadership in audio technology. The five satellites make use of the two-inch drivers for crisp dialogue and impressive effects, while the large subwoofer with a flared port tube and separate bass control provides you with the freedom to adjust your bass level and deliver the extra impact and oomph for all of your entertainment needs. The system also includes a wired remote for easy-to-reach and convenient control.
- Speaker Power: 5Watts RMS per channel (5 channels)
- Subwoofer: 12Watts RMS
- Frequency Response: 40Hz ~ 20kHz
- Signal-to-Noise Ratio (SNR): 75dB
- Product Weight: 3.5 kg
- Dimensions (HxWxD): Speaker (144x80x104)mm, Subwoofer (235x192x192) mm
Was £47.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Intel Core i7 990X 3.46GHz (Gulftown) Extreme Edition (Socket LGA1366) - Retail @ £767.99 inc VAT
Dominate your gaming competition with the unlocked, unleashed and uncompromised Intel Core i7 Extreme Edition. Thanks to the latest ultra-threaded, killer combination of smart features, including Intel Turbo Boost Technology and Intel Hyper-Threading Technology, the Intel Core i7 Extreme Edition is Intel’s most capable and downright devastating PC processor ever.
- Core Size: 32nm
- Socket: LGA1366
- Six Core
- Frequency: 3.46GHz
- Multiplier: 26x
- L2 Cache: 6x 256KB
- L3 Cache: 12MB
- QPI: 6.4 GT/s
- TDP: 130W
- Includes Heatsink & Thermal Paste
- 3yr Warranty.
Was £799.99 Inc. VAT
Only £767.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £233.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Was £254.99 Inc. VAT
Only £233.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail @ £245.99 inc VAT
- Cores: 4
- Threads: 8
- TDP: 95W
- Socket: LGA1155
- 3yr Warranty
Was £259.99 Inc. VAT
Only £245.99 inc VAT.
ORDER NOW
Intel Core i7-2700K 3.50GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £257.99 inc VAT
- Cores: 4
- Threads: 8
- Frequency: 3.50 GHz (Turbo Mode 3.90GHz)
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
Was £274.99 Inc. VAT
Only £257.99 inc VAT.
ORDER NOW
LEPA Convertible iPad Flip Case/Stand @ £4.98 inc VAT
The LEPA iPad Flip Leather Cover Case offers maximum protection and functionality. It features a durable, stylish and streamlined leather design.
- Convertible flip book case offers maximum protection and functionality
- Multiple angle settings for enhanced viewing and using your iPad
- Durable, stylish, and streamlined leather design
- Single piece design for ease-of-use
- Supports vertical and horizontal viewing
- Custom made for a perfect fit on all iPad and iPad 3G
- Matieral: PU Leather
- Dimensions: 250 x 195 x 18mm
- Weight 296g
Was £9.98 Inc. VAT
Only £4.98 inc VAT.
ORDER NOW
Boogie Bug AimB.Pad XL Gaming Mouse Surface @ £10.98 inc VAT
The AimB.Pad has been especially designed for gamers looking for precision, fluidity and the perfect harmony between slide and friction. This XL version also represents an essential tool for graphics designers, architects and other users looking for precision and wide movements. Its surface has been made with flexible textile material that not only assures fluidity and precision in the movements, but also allows the AimB.Pad to be folded, rolled up and transported.
- Dimensions: 450mm x 900mm
Was £16.99 Inc. VAT
Only £10.98 inc VAT.
ORDER NOW
Cooler Master HAF X Gaming Tower Case - Black (RC-942) @ £124.98 inc VAT
The much anticipated HAF X arrives as the flagship of the popular HAF (High Air Flow) series. Designed for performance systems, this chassis is able to house today's latest and hottest CPUs, motherboards, GFX cards and is even USB3.0 compatible. With specialised support and cooling for graphic cards, massive airflow with the help of up to four gigantic fans and easy access to installed components, this is as close as it gets to a system builder's 'dream case'.
- Dimensions: 230 x 550 x 590mm ( W x H x D)
- Motherboard Compability: Micro- ATX, ATX and E-ATX
- 6 x 5.25" Drive Bays
- 5 x 3.5" Drive Bays
- I/O Panel: USB3.0 x 2, USB2.0, Audio x 2, e-SATA x 1, FireWire x1
- Cooling (Front): 230 x 30 mm red LED fan x1
- Cooling (Top): 200 x 30mm fans x 2 (1 included)
- Cooling (Side): 200 x 30mm fan x 1
- Cooling (Rear): 140 x 25mm fan x 1
- VGA Fan Duct: 120 x 25mm fan x 1 (not included)
- VGA Holder: 80 x 15mm fan x 1 (not included)
- PCI Slots: 9
- Base Mounted PSU Bracket
Was £134.99 Inc. VAT
Only £124.98 inc VAT.
ORDER NOW
Corsair Obsidian 650D Gaming Midi Tower - Black @ £134.99 inc VAT
nonl2br
The Obsidian Series 650D mid-tower case is manufactured with strong, stamped steel parts for increased rigidity, and coated in a black textured paint. The front panel features a beautiful black brushed aluminum faceplate to bring a subtle elegance to your next build.<br><br>
A large, black 200mm intake fan hides behind the front dust filter, quietly pushing vast amounts of air over your hard drives and video cards. The air is then exhausted by a second 200mm fan on top of the case, and a rear 120mm fan. The top fan can be replaced by dual 120mm or 140mm fans, and is pre-spaced for a dual radiator if you’re interested in watercooling. And all fans are controlled by a three-mode, four-channel fan controller should you want to make your own choice between noise and performance.<br><br>
- Motherboard Support: ATX / mATX<br>
- Expansion Slots: 8<br>
- Drive Bays: 5.25" x 4 & 3.5"/2.5" x 6<br>
- Cooling: 2 x 200mm Fans and 1 x 120mm Fans<br>
- Front I/O Ports: USB2.0 x 4 / FireWire x 1 / Audio x 2 / 4-Channel Fan Controller<br>
- Dual 200mm fans provide outstanding cooling for even the hottest components<br>
- Easily accessible dust filters make maintenance simple and hassle-free<br>
- Quick-release side panels make it easier than ever to upgrade your hardware<br>
- Integrated fan controller lets you quickly adjust cooling performance and noise levels<br>
- Four tool-free optical drive bays and up to six SSD-ready hard drive trays provide plenty of expansion<br>
- CPU backplate cutout makes it easy to upgrade your CPU cooler<br>
- Brilliant cable routing system provides a way to keep your system neat and tidy<br>
- Adjustable drive cages can be removed and relocated to accommodate large video cards<br>
- Room for long power supplies gives you peace of mind for future upgrades<br>
- Dimensions: 546mm (L) x 229mm (W) x 521mm (H)<br>
<br>
<CENTER>
<IMG SRC="http://www.ocia.net/images/goldseal.gif" width="150" height="150"/>
<IMG SRC="http://techgage.com/reviews/award.jpg" width="150" height="150"/>
</CENTER>
Was £139.99 Inc. VAT
Only £134.99 inc VAT.
ORDER NOW
NZXT Phantom Enthusiast Full Tower Case - Red/White @ £104.99 inc VAT
NZXT presents the cutting edge Phantom Full Tower Chassis. Designed with sleek, pristine contours, the Phantom radiates personality and quality. As with all NZXT products, we strive to set apart our customers from the rest with unique, original designs – we run the extra mile so you won’t have to settle with the typical rectangular box. The Phantom delivers high performance cooling advantages with 7 fan cooling options, dual radiator support, quad watercooling cutouts, and five 20W per channel fan controls. An innovative 5.25” screwless system, vast space to encompass 7 hard drives, and five 5.25” bays enable smooth customization. Establish your power, your presence.
- High Performance Cooling Advantages
– Phantom’s extensive cooling capabilities include 7 fan cooling options with dual 200mm, single 230/200mm, triple 120mm, and front 140mm fan options
- NZXT includes dual radiator support, quad watercooling cutouts, and an integrated fan controller with up to five 20W channels.
- Simple Installation
– Phantom celebrates an array of innovative features designed to enhance every stage of the build
- Meticulous cable management is easily attainable with large spacing behind the motherboard.
- Innovative all-new 5.25” screwless rails make installing and swapping HDDs an effortless process
- Rubber grommets dampens vibration during operation.
- LED on/off button to control fan lighting
- Rubber PSU and case feet to reduce vibration
- Easily removable front and top panels
- Top mounted USB, Audio/Mic, and E-SATA ports.
– Features support for larger heat sinks, graphics cards, and E-ATX motherboards enabling enthusiasts to include any of today’s hottest components
- Vast space within the enclosure allows for 7 hard drives with SDD support and up to five 5.25” bays
Was £114.98 Inc. VAT
Only £104.99 inc VAT.
ORDER NOW
Silverstone Raven 3 RV03B-W Full Tower Windowed Case - Black/Gold @ £109.98 inc VAT
The RAVEN team’s continued push to redefine and perfect the enthusiast tower chassis has resulted in yet another benchmark in the RAVEN RV03. With world-class cooling performance from the previous RAVEN chassis models retained by the included 180mm Air Penetrator fans, a rethinking of the interior layout enabled dramatic reduction in overall depth of the chassis compared to RAVEN RV02 while still matching RAVEN RV01’s ability to accommodate Extended ATX motherboard and graphics cards longer than 13 inches. Cable management was also improved with a new 5cm thick hard drive compartment to allow nearly all cables to be connected behind the motherboard tray with ease. An unconventional power supply compartment located in the lower front part of the chassis further add to facilitate cable routing so anyone can assemble a pristine looking system with maximum airflow efficiency.
Complementing the finely tuned and engineered interior, the RV03 has Champaign colored trimmings adorning an exterior with aggressive lines yet reserved profile. The stand out styling also fully utilizes the chassis’s powerful cooling ability to full effect by a set of smartly designed, dual-purpose front bezels that helps to keep the RV03 looking sharp and uniform whether the user is setting up for maximum air cooling or for a silencing build.
As a trend-setter and a computer chassis engineering showcase, the RAVEN RV03 has few equals. However, its advanced features are equally accessible that anyone from experienced enthusiasts to novice users will find easy to appreciate and utilize, making RV03 the most appealing RAVEN chassis yet!
- Revolutionary 90 degree motherboard mounting from RAVEN RV01
- Includes two Air Penetrator 180mm fans for superb performance and quietness
- Support up to seven 120mm fans for exceptional cooling flexibility
- Motherboard back plate opening behind CPU area for quick cooler assembly
- Supports Extended ATX motherboard
- Supports eight expansion slots and graphics cards of any length
- Mandatory cable management design for clean looking system on every build
- Hard drive compartment with independent cooling zone
- Upscale and aggressive styling with dual-purpose front panel bezels
- 7 x 5.25" Drive Bays
- 10 x 3.5" Drive Bays
- 2 x 2.5" Drive Bays
- Front I/O Ports: 2 x USB3.0 & 2 x Audio
- Front Cooling: 4 x 120mm Fan (optional)
- Rear Cooling: 1 x 120mm Fan (optional)
- Side Cooling: 1 x 120mm Fan (optional)
- Top Cooling: 1 x 120mm Fan (900RPM @ 18dBA)
- Bottom Cooling: 2 x 180mm Fans (700 or 1200 RPM @ 18 or 34dBA) or 3 x 120mm Fans (optional)
- Max CPU Cooler height: 163mm
- Dimensions: 235 x 522 x 570mm
- Max GPU lenght: 13.58"
Was £119.99 Inc. VAT
Only £109.98 inc VAT.
ORDER NOW
Xigmatek Asgard III Windowed Gaming Case - Black @ £32.99 inc VAT
"Asgard-III" - The Property of Æsir and castle of Odin. As the country of Gods, the inviolable Asgard-III is the world’s first black coating entry-level chassis - milestone. Furthermore this chassis is supplied with 1 x 120mm preinstalled black fan, and 3 more fans can be mounted in different areas for best possible airflow. 4 x 5.25" bays will be able to house all your optical drives, but also 5 trays for your 3.5” HDDs are available so you can feel free by "DIY". Tool free design and a "gorgeous" outlook are only a few points why this chassis is a "must" not only for enthusiast but also for pc beginners.
- Screw-less tooling for 5.25” bay installation.
- Screw-less tooling for expansion slot installation.
- Screw-less tooling for 3.5” bay installation.
- Preinstalled 120mm front fan
- Supports 4 cooling fans in total.
- Back window for easy CPU cooler back plate.
- Dust filter behind front panel for intake airflow.
- Dimension: 185(W) x 475(D) x 408(H) mm, 0.6mm thickness SGCC.
- Drive Bay: 5.25” External x 3 (Tool-free)
- 3.5” External x 2 (Tool-free)
- 3.5” Internal x 5 (Tool-free)
- Expansion Slot: 7 slots (tool-free), 290mm free add-on card length.
- Front Fan: 80/90/120mm x 1 fan is available.
- Rear Fan: Preinstalled 120mm black fan x 1 (80/90mm fan is available)
- Side Fan: 80/90/120mm x 2 fans are available.
Was £35.99 Inc. VAT
ORDER NOW
Logitech G700 Wireless Gaming Mouse (910-001759) @ £61.98 inc VAT
The Logitech® Wireless Gaming Mouse G700 keeps you comfortable, in control and deep into your game. Its 13 programmable G-Keys can be used to perform single actions or complex macros with a single click. The natural curves fit your hand for epic levels of comfort, so you can keep at it for as long as you want. And its full-speed wireless connection gives you gaming-grade performance coupled with wireless freedom. It comes with a quick-connect cable that charges your mouse and can transmit data over the cable. When your guild gets together, you'll have all the control you need to do battle, complete quests and level up your character. Logitech® SetPoint™ software required for initial setup and is available at logitech.com/downloads.
- 13 individually sculpted, programmable G-Keys let you perform either single actions or intricate macros with multiple keystrokes, mouse events, user-defined keys and repeating. No matter what your game, you'll get deep into it. You have the control you need to play better. To conquer more. To win.
- With natural curves that fit your hand, you get epic levels of comfort, while smooth-gliding feet let you manoeuvre effortlessly. You'll play comfortably, without distraction, for as long as you want.
- Full-speed wireless (1,000 reports per second) helps eliminate lag so you enjoy gaming-grade responsiveness and wireless freedom. You get a steady, powerful connection with no dropouts.
- A quick-connect cable for recharging and data transfer lets you plug in fast and continue your campaign without pause. You'll never run out of power. And you'll always have a backup for reliable connectivity.
- You get a mouse that's crafted just for gaming. The gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you store up to five profiles*. And the dual-mode scroll wheel can switch from click-to-click for weapon selection to free spinning for hyper-fast scrolling.
Was £64.99 Inc. VAT
Only £61.98 inc VAT.
ORDER NOW
Gigabyte M8600 6500DPI Wireless Gaming Mouse @ £69.98 inc VAT
Aivia M8600 Wireless Macro Gaming Mouse has long lasting battery that guarantee 100-hour nonstop gaming experience. QSBS™ (quick swap battery changing system) technology is GIGABYTE's unique design. This patent pending technology allows for Instant battery changing under 2 seconds, as fast as gun clip loading and unloading.
Aivia M8600 Wireless Macro Gaming Mouse comes with an instant charging dock, served as mouse and Li-ion batter charger as well as wireless receiver unit. This device helps you enjoy gaming with wireless transmission speed at 1000Hz polling rate. The powerful wireless reception ensures no signal is lost that every single move made by the mouse is read during game playing.
Aivia M8600 Wireless Macro Gaming Mouse features twin-eye gaming-grade laser engine. Based on advanced laser technology, the twin-eye gaming sensor features high precision, low power, and ultra-fast performance.
When Aivia M8600 Wireless Macro Gaming Mouse is connected to its complimentary wire, it is able to edit GIGABYTE's GHOST™ Macro Engine. GHOST™ Macro Engine is an incredible macro editing software for the memorized macros to be carried around even if the mouse is connected to a different computer. 32KB onboard memory enables up to 5 programmable profile settings. The engine features critically acclaimed easy-to-use drag-and-drop operating system, DPI switching, tilt-wheel speed adjustment, and customizable color hues as profile indicators.
- GamePlay™ Wireless Technology- over 50hrs battery life in game play
- Quick-swap battery system- instant battery changing under 2secs, as fast as gun clip loading
- 32KB onboard memory enables up to 5 programmable profile settings
- Dual mode wired/ wireless functionality-switch between the wireless freedom and the frenzy of wired play
- Advanced GHOST™ Macro Engine
Was £79.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Logitech G9x Laser Mouse (910-001153) @ £43.98 inc VAT
The Logitech® G9x Laser Mouse offers more customisable features than any other gaming mouse, so you can tune for the way you play. Interchangeable grips let you choose a fit and feel that’s best for your playing style (includes XL and Precision grips). The next-generation gaming laser gives you game-changing precision at any hand speed. And on-the-fly adjustable dpi from 200 to 5000 dpi. Onboard memory lets you program up to five ready-to-play profiles (for keyboard macros, dpi settings and LED colours). The weight-tuning system gives you up to 28 g of extra weight. And the custom-colour LEDs let you match your mouse to your style.
- Interchangeable grips
- Up to 5000 DPI
- Next-generation gaming laser
- Onboard memory
- Weight-tuning system
- Custom-colour LEDs
Was £46.99 Inc. VAT
Only £43.98 inc VAT.
ORDER NOW
Logitech G400 3600DPI Gaming Mouse (910-002279) @ £26.99 inc VAT
Set your sights on victory. With a high-precision optical engine, the G400 gives you consistent tracking and precise aiming no matter how fast you move your hand.
Instant access to four dpi levels lets you shift from pixel-precise targeting to lightning-fast maneuvers. A sculpted comfort grip, low-friction feet and eight programmable buttons keep you comfortable and in command.
You've got the upper hand with precision targeting and pinpoint accuracy. Your mouse communicates over USB at a blazing-fast 1000 reports per second - as fast as USB can go, and eight times faster than standard USB mice.
- Weight: 133 g
- Connectivity Technology: USB
- Movement Detection Technology: Optical
- Buttons Qty: 8
- Movement Resolution: 3600 dpi
- Performance: 1 ms response time, 5.8 megapixels per second, realtime sensitivity switching 400 - 3600 dpi, 25 G maximum acceleration
- Features: Programmable buttons, sensitivity adjustment, polytetrafluoroethylene (PTFE) feet
- Cables Included: 1 x USB cable - integrated
- 3 years warranty
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Logitech G500 Gaming Mouse (910-001262) @ £39.98 inc VAT
The Logitech Gaming Mouse G500. Your weapon of choice for precision and control. Gaming-grade laser gives you game-changing precision at any hand speed. Onboard memory lets you save and take your settings for your favourite title with you. Weight tuning gives you up to 27 grams of extra weight for personalised feel and control. Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection. On-the-fly adjustable dpi gives you the right level of precision, from pixel-precise targeting (200 dpi) to lightning-fast manoeuvres (up to 5700 dpi), for whatever game you're playing. And ten programmable buttons put valuable macros in your hand.
- Gaming-grade laser gives you game-changing precision at any hand speed.
- Onboard memory lets you save and take your settings for your favourite title with you. No software required.
- Weight tuning gives you up to 27 grams of extra weight for personalised feel and control.
- Dual-mode scroll wheel with hyper-fast scrolling provides click-to-click scrolling that's perfect for weapon selection when you're gaming. Or switch to frictionless hyper-fast scrolling to fly through long Web pages when the boss is looking
- On-the-fly adjustable dpi up to 5700
- Ten programmable buttons put valuable macros in your hand
Was £42.98 Inc. VAT
ORDER NOW
Roccat Apuri USB Hub with Mouse Bungee @ £20.99 inc VAT
nonl2br
The first component of the ROCCAT™ Smart Desktop Management System (SDMS) offers you the perfect combination of style and functionality right there on your desktop. The Apuri won’t just power your USB devices; among other things it’ll also bring new order to your desktop by taking control of your mouse cable.<br><br>
USB PORTS ALWAYS WITHIN REACH
The Apuri combines stability and practically in the way it takes over the job of managing your devices and cables on the desktop. The Apuri’s AC adapter delivers sufficient power to supply its USB ports with up to 2A each – allowing you to connect up to four USB devices without the need for additional power supplies. And if you don’t want to use the AC adapter, you can simply power the hub using the supplied USB cable.<br><br>
500mA per port is then available in passive use – perfect for cell phones, cameras and other devices which don’t require their own separate AC adapter. The Apuri allows you to connect everything so it’s within reach, saving you the hassle of crawling around under the desk looking for ports and from the untidiness of cables hanging over the edge of the desk.<br><br>
SMOOTH GAMING
Thanks to the flexible mouse bungee, the mouse cable in particular is optimally catered for. It is simply guided away from the mouse’s gliding area so that it doesn’t get in the way during game play. There won’t be any rubbing on the desktop or snagging of the cable on the edge of the desk to interfere with your gaming experience – you can even adjust the length of the cable to suit, and the flexible arm optimally flexes with your movements.<br><br>
You’ll feel as if you’re using a wireless mouse, without the inherent disadvantages such as increased weight, sudden need to change batteries or long charging times. If you don’t want to use the mouse bungee, it can simply be detached from the hub. .<br><br>
STYLE AND ATMOSPHERE
Contrary to many conventional hubs, which live out their existence as boring boxes, the ROCCAT™ Apuri adds style to your desktop. The unique tripod design gives the Apuri stability even during tense gaming situations. The design fits perfectly with ROCCAT’s new ‘stealth’ style series. Beveled edges and futuristic lines give the hub a unique look. The top features three ice blue LEDs while the base boasts an illuminated ROCCAT logo, which will cast an atmospheric aura onto your desktop. <br><br>
- 4 high-speed USB 2.0 ports<br>
- Output power active (using AC adapter): 2A each<br>
- Output power passive (using USB cable): 500mA each<br>
- Length of USB cable: 1.5m<br>
- Length of power cable: 1.5m<br>
- Detachable Mouse bungee<br>
- 3 LEDs (top) + underlighting<br>
- Stable tripod design<br><br>
<iframe width="640" height="390" src="http://www.youtube.com/embed/e1y49Fi4AXk" frameborder="0" allowfullscreen></iframe>
Was £22.99 Inc. VAT
Only £20.99 inc VAT.
ORDER NOW
What are those Lepa PSU's like?
Wondering the same.
"Designed by CWT these mid range PSU's are ideal for any gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's."
If I remember right CWT psu's were made by antec? :p
Very good price on the G400 mouse for those with free shipping.
Can anyone tell me if either of those first two cpu coolers are significantly better than the stock cooler?
