best anti spyware/malware
4 Nov 2009
I have anti virus. I can not for the life of me find a legitimate website for spybot search and destroy. Are there any others that you would recommend
never mind found it ^^
I use MSE for anti-virus and I've just installed malware bytes as well. Its fine to have both of these on a system isn't it?
I'm not sure if the line between anti virus and anti malware software has blurred and dont want them conflicting.
You'll be fine as long as you're not running the pro version of mbam (live protection).
I would go naked. I have run without any protection for years and years now and have had no issues, and I'm not exactly an Internet saint.
I've did that before, then let my niece loose on the PC for an hour.. Ended up having to reinstall she got it infected that bad! So, I just run MSE 'just incase' :rolleyes:
i run commando with windows XP. here's my log...
Code:
Malwarebytes' Anti-Malware 1.51.2.1300
www.malwarebytes.org
Database version: 8073
Windows 5.2.3790 Service Pack 2
Internet Explorer 8.0.6001.18702
02/11/2011 22:43:56
mbam-log-2011-11-02 (22-43-56).txt
Scan type: Quick scan
Objects scanned: 168396
Time elapsed: 1 minute(s), 35 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Folders Infected:
Files Infected:
if a quick scan isn't sufficient, i can do a full one....
edit: full scan in progress. what can it be.... :eek:
lol, cookies no doubt :)
My genuine reason was for some of the more advanced hidden browsing habit reporting tools etc that might not be outwardly apparent to anyone.
