- 26 Oct 2011
- Northampton
Hi
Ive just bought the following Amd Phenom II x4 850 MHz and a Crosshair V Formula motherboard.
Using the default over-clocking options on the motherboard the chip is running at 3.48MHz.
Have I got a chance at getting it to run higher and if so what settings should I be using?
I am also using 2x4gb Kingston x memory which is running at 1600MHz and I have an Asus Axe square cooler, not the stock one that came with the CPU.
Thanks in advance for any help or advice.
