Have a Pint of Stella beforehand.
I'm sure you will be fine mate, good luck.
Thanks for the tips chaps! The naked one sounds like it will work!![]()
I'm quite a good driver when I'm comfortable with it.![]()
It's really not that hard, good luck, treat it like a lesson.
Also if you do stall or whatever, do not think you've already failed, just keep going as you would.![]()
