Use autoglym Extra Gloss Protection or HD WAX after Super Resin Polish ?
Caporegime
27 Nov 2005
Guernsey
You can use either really one is a wax the other is a sealant, i prefer HD Wax if you're just going to use one :)
Well they're basically doing the same job aren't they? What would be the point?
Well I thought the Extra Glass would do what it says on the tin; provide extra gloss. The wax will then give it an extra layer of protection against the elements.
I was always under the impression that wax was the last to go on to give the paint that 'extra' bit of physical protection against the big bad world.
EGP is a sealant, essentially designed to be a cheap alternative to wax.
