new build
1 Apr 2009
Splurged, literally, for a new rig.
Intel i5-2500K.
AsRock Z68 Extreme4 Gen3.
Kingston HyperX Genesis 8GB 12800C9.
Thermalright MUX-120.
Sapphire 6950 2GB TOXIC (x2).
Crucial M4 128GB.
Corsair Carbide 500R.
Corsair AX 850.
Microsoft Windows 7 Home Premium Retail.
Samsung F3 1TB (x2).
BlackGold BGT3620 TV tuner.
It's still a work in progress, pictures, benchmarks, power consumption and thoughts to come :)
Sorry about the picture quality, I just can't take good pictures.
the components :
Power supply :
Motherboard :
Cooler, CPU and memory in place :
Cooler : (I know, the fan is the wrong way round. D'oh!).
Cooler and RAM clearance :
Cooler and side fan clearance :
Core components in the case :
PSU in place :
GPUs in place :
CPU - i5 2500K :
+ What is there to say! Best CPU of the moment.
Motherboard - AsRock Z68 Extreme4 Gen 3 : Does what I expects. Looks stable and performant.
+ looks good.
+ good general layout.
+ good feature set.
+ loads of fan headers.
+ good tools.
+ good freebies (4 SATA3 cables, two angled, two straight, good docs).
+ supports 775 / 1155 / 1156 CPU backplates.
- bios fan control could be better.
- location of the molex connector for the PCIE. It's a bit awkward.
- UEFI bios a bit simplistic.
- Comes with Norton. You're better off not installing drivers automatically and selecting the software one by one, if you don't want that ***** smeared all over your new build.
CPU Cooler - Thermalright MUX-120 :
+ SUPERB build quality. All metal.
+ really good mounting system. Easy, secure, and no over-pressure on the CPU.
+ comes with ChillFactor III (I've used some MX-4 I had left).
+ good quiet fan (replaced with an Apache Black I had left over. Not much difference except it's BLACK!).
+ looks great.
+ not heavy (600 grams?).
+ good RAM clearance.
+ Absolute bargain (paid £32).
+ decent performance (50C @ 4.4GHz).
+ good manual.
- Bit tall (160mm). Had reservations about fitting the cooler and the side fan, but it's just right. Maybe a problem with a SilverArrow. I recon I have 5 mm clearance.
- fiddly metal wire things to secure the fan. Don't look too secure either, but seems to hold.
Memory - Kingston HyperX Genesis 8GB 12800C9 : Nothing to report. Just works, and have no intention to overclock over 1600MHz.
GPUs - Sapphire 6950 2GB TOXIC Crossfire : Haven't had the time to stress them out. Crossfire worked out of the box. Did a Unigine run, 11fps min (looks like a hiccup), 150fps max.
SSD - Crucial M4 128GB :
+ Insane boot times. Thought my Vertex2E was fast, the M4 makes the boot dissapear.
+ Quick ATTO run, 250MBps write, over 500MBps read. fast!
- Dunno what bios it's running.
Corsair Carbide 500R : Everything I expected.
+ Good overall cable management. Lots of little holes and gromets at the right place.
+ Great layout. Everything just fits nice and neat. Plenty of room for GPUs.
+ BIG CPU backplate cutout, if I ever need it.
+ removable top, plenty of room for fans.
+ I like the extra width given to the side panels. helps cable management (in fairness, it needs it), and allows a nice 200mm fan blowing straight into the GPUs, leaving room for a nice CPU cooler as well).
+ Great 5.25'' tooless mechanism. It just slots in and wont move in a hurry.
+ motherboard standoffs already in place. A couple extra more thrown in a bag in case you need some.
+ Great build quality. Has a really nice solid feel. Cables for the front case peripherals are nice and chunky (HSB3, Firewire, audio...).
+ Everything is black, even the thumb screws. No red and yellow cables hanging around.
+ removable hard disk cages. Started using the bottom one, then decided to switch to the top one. Bit fiddly securing that one once the components were in.
+ thumb screws galore. A sign of quality!
+ has a USB3 to USB2 converter included. Not that it is much use to me.
+ White light on fans. Nice and neutral.
- Bit of a tight fit at the back, if like me you are not great at cable management. The extra 'hump' helps, but even then it's tight.
- Anchor points for cable ties could be better placed. Didn't find much use for them. They provide a couple of stick on cable placements, more useful but they don't stick quite so well.
- No manual.
- The exhaust fan has no light.
- The fan controller seem to be specifically designed for the case fans. Dunno if it would work with 3rd-party case fans.
- Not super quiet. I thought my previous rig could be a bit quieter, the new rig is slightly noisier.
- Haven't worked out how to remove the fan filters on the front fan. Doesn't look like it's a removable panel, like the top panel, and you have to pull the whole front out. Shame :'(
- Couldn't work out how to fit 120mm fans at the top. There is no way to fix them to the case (it's rubber-damped holes, with no metal for the screws to bite in).
- I could only put 3 PSU mounting screws. BTW, I should have use some thumb screws left over instead.
- hard drive cages, while good with hard drives, are too 'wobbly' for SSDs. But once they're in, who cares! HDDs add more rigidity and are well damped.
- Qpad 5K mouse is bugged in UEFI. No biggie. keyboard works just fine, and I have a spare laptop mouse in case. Think the new BIOS fixes some mouse issues but won't bother.
PSU - Corsair AX 850 : Decided to get that one, couldn't wait for the Seasonic X-850 to come back in stock. Saved £15, not so bad after all.
+ Stunning. All black cables, all sleeved.
+ Performance. We all know about them. Seasonic X-850 platform.
- 8pin CPU cable too short (600mm). Just about fitted in the case round the back.
- cables are stiff as hell, could be just me not being used to PSUs.
- Only 4 PCIE 6+2 connectors. Not that it bothers me, and that you should run tri-sli on 850W anyway.
LG DVD-RW 22x :
+ read DVDs and stuff.
- bit noisy in operation. Though it was broken when Norton tried to install itself (don't ask!).
Samsung F3 : An 'old' drive that's been kicking around in my older build. Fast quiet drive, need to put the other one in.
First OC test : 2500K @ 4.4GHz
not quite there : Keeps fluctuating between 4.0-4.4GHZ
The results anyway. More of a check if the performance is sensible rather than e-peen factor.
Peak Power Consumptions (at the plug, AX 850) :
Off : 0.3W
Desktop : 90W
Prime95 Large FFT : 180W
Unigine : 420W
3Dmark 11 Basic Benchmark : 410W
Unigine + Prime95 : 455W
Battlefield 3 : 430W
Cinebench 11.5 CPU test (2500K @ 4.4GHz)
Cinebench 11.5 GPU test (6950 x2)
Unigine Heaven DX11 [1650 x 1050] (6950 x 2 @stock)
3DMark 11 Basic [1280 x 768]
Super Pi 1M (2500K @ 4.4GHz)
Atto Benchmark - Crucial M4 128 GB
Botracer bench (Crucial M4)
Battlefield 3 : Ultra 1920 x 1200
60-80 fps.
Could be just me but the CPU fan looks like it's facing the wrong way :p Although in the last pic it looks like you noticed this and turned it around.
So far everything looks nice!
Really nice, looks great. Interested in the benchmarks since my spec is very similar to yours and thinking of adding another 6950 soon.
What I found interesting is the power consumption. 455W max with Prime and Unigine running at the same time! That's an OC on the CPU and stock GPUs. BTW, I recorded 430W peak on a [email protected] and a 560ti Twin Frozr II (factory overclocked).
And don't ask me to run Furmark, I hate it and I don't want to ruin my 6950's already. I really don't trust that program with my new shiny stuff.
