Hello,
I am a bit of a novice with these things, but had a go at OCing my 2500k by myself. Last time I OCd a chip was my Q6600 and someone on here walked me through the settings and it worked perfectly. Me...well on my own it's not going so well.
Specs of note are:
CPU: Intel SB 2500k
MB: GB z68xp-UD3 (f7 firmware)
RAM: Corsair Vengence (blue if that makes a jot of difference) 16GB (4x4GB) DDR3 PC3-12800C9 1600MHz
Cooler: Antec Kuhler 920
It's all wrapped up in a HAFX, so it's got plenty of air flow and I am running a custom fan profile on the Antec to keep the OC'd temps around 70 degrees on load (a more aggressive profile had these down a bit lower, but I will sort that out once I have a stable OC).
So the problem:
With everything set to auto I can get 4.5GHz. It can run 10 passes on IBT set at maximum, HW Monitor seems to think it's using 1.34 VCore (on auto remember) on load. However as soon as I raise the cpu ratio to 46 and leave everything else the same it bombs out with a BSD after a random number of passes on IBT.
Have I reached the limit for my chip or can I play with the settings and get a bit more? I really don't understand what everything else so I don't want to play too much.
Specs of note are:
CPU: Intel SB 2500k
So the problem:
