2500k to 2700k
22 May 2006
I've currently got a rubbish I5 2500k can only reach 4400MHz at 1.340 vcore. As my PC is for general home use, internet and gaming, would I see any real benefit if I upgraded to an i7 2700k? If it helps my gpu is a 1024Mb 560GTX (not the ti version)
Gaming you might see a slight performance increase, but not the extra money's worth IMO, But maybe an SSD would be a better upgrade if you've not got one already ? :D
4.4ghz is fast enough. With the efficient, high performing architecture of Sandy Bridge, it will hardly be a bottleneck in games. Rather, you would see a better performance boost from upgrading your graphics card.
Do you have a performance problem? ...is there something spefic that isn't running as you would like? ...becuase frankly your computer is pretty darn fast, you certainly aren't short on CPU grunt. As for your graphics card ...it really depends what you are doing with it, the 560GTX isn't exactly a slow card.
is it a D1 revision or D2 revision ?
I found the latter overclocks a lot better with less V's.
Nope, it's the same line of chips. Same socket, same ram etc.
I thought the i7 preffered tripple channel ram and the i5 dual? If the OP is complaining about the i5 performance, surely a tripple setup would be on the cards for him? Although, I agree, from what I hear dual is perfectly acceptable for bandwidth, it's just not optimum.
thats bloomfield this thread is sandybridge
OP is on sandybridge which doesnt have triple channel ram, it was the old x58 chip set i7's that had triple channel ram
No the games I have are running fine, it's just that I keep reading of folks getting 4.5 - 4.8 MHz out of their 2500k's.
If everythings running fine why do you want to upgrade? IMO wait until it's not running fast enough, then upgrade.
No point whatsoever, I've got my 2500k clocked at 4.5GHz and it's enough for any games I play. Save your money for the new 28nm graphics cards being released by Nvidia and AMD.
Plus Ivybridge should be out by April 2012, I'll probally get one of those CPU's.
