Retread tyres
Berate the motoring crew, oh come on now. :rolleyes:
Opinions are all good and well, but they are just that! I would like something from someone to substantiate either side of the argument as I haven't been able to find out much myself.
let me break it down for you, no one here is stupid enough to ever ever put re-treads on their car
you would do well to emulate that
[TW]Fox;20441809 said:
There is simply no need to even take the risk. Having just checked tyres in your size are bonkers cheap. For only 20 quid a tyre more you could fit decent premium tyres such as the Continental ContiPremiumContact 2.
http://www.camskill.co.uk/m53b0s418...CONTIPREMIUMCONTACT_2_ECO_-_195_65R15_91H_TL_
If the £20 a tyre saving really is worth it then perhaps a bus pass is a safer option if you've got limited money to spend on keeping your car safe?
Where is the risk? Im yet to see anyone show me something factual rather than opinion or prejudice.
Like Ive said I genuinely want to know if they are dangerous or not, and its not just a price issue, the amount of waste we generate is ridiculous, whilst a pair of retreads wont change anything, it is a start.
The established car tyre brands spend millions developing tyre compounds and tread patterns to ensure tyres deliver optimum performance in a wide range of condition. Not for doing 120mph around tight bends but for day to day driving. Driving on the Motorway at the speed limit in the pouring rain. Driving around town at 30mph and stopping quickly when somebody pulls out. That sort of stuff.
Developing tyres like this costs them a fortune but results in quality tyres that will last a long time and keep you safe whatever the conditions.
A company retreading tyres has neither the budget nor the expertise of the big players.
The results are therefore fairly obvious and it's not at all worth the gamble for the saving of £20 a tyre.
You will probably get 2 years out of a set of tyre. Thats a whole 83p a month more, per tyre, to have the right stuff fitted to your car. The only thing between your car and the road is your tyres.
Decent tyres are what EVERYONE should fit and are nothing to do with how fast you drive.
You didn't compromise on your car when you paid extra and bought a Mk5 Golf over the numerous other much cheaper cars, so why compromise when it comes to choosing safety critical components for it?
I'm trying to decide if you are just trolling, if so, well done plenty of bites
question for you, what happens when you drive fast? your tyres heat up, causing the bonding agent to fail and your re-treaded tyres to fall apart, this casuses the money you saved on a new tyre to disappear as you have to repair your bent and battered wagon.
please by all means go buy some re-treads you will be doing the world a favour :p
This being a forum where automotive enthusiasts congregate you are highly unlikely to find anyone here that uses retreads/remoulds. If you're looking for affirmation of your purchase intent you won't find it here.
I don't know which forums the tyre remanufacturing experts use. Google is your friend.
Keep on having a go at the community and using the lovely rolleyes and I'll assume you enjoy trolling.
Should branded tyres really be the safer option then I will go for them, I just hadn't come across retreaded car tyres before and was curious.
As for the golf... was the wifes choice, figured I should agree before she changed her mind for something daft like a mini!
however, like you, they are to stupid to grasp the simple concept of evidence based conclusions:/
No, we aren't. Some of us here have been at the "on your arse skint" stage and fitted retreads because there was nothing else.
And of those who have used them, how many do you think would recommend them as a "good buy"?
Not me, for one.
Spend an extra couple of quid and get decent tyres.
tl;dr? retreads aren't worth buying, they are not a good "bang per buck" choice.
Not trolling, but struggling to see what was so difficult about my request for information...
Are retreads more likely to disintegrate? Becasue, all research I have done so far indicates retreads have to meet stringent British Standards BS AU 144e to guarantee safety.
Not me, for one.
As I said earlier, I am interested in your experiences of them being dangerous and not good. What was it that made them substandard? Please expand.
as I personally said if you don't ever drive over 30mph they are fine, if you do they are a disaster waiting to happen, sorry if that wasn't clear enough for you :)
or, put another way
THEY FALL APART IF YOU GO FAST
Truck tyres are designed to be retreaded afaik, car tyres are not.
The carcasses aren't designed to reused in such a manner.
However during construction of retreads they must pass various safety checks to ensure they are suitable and safe, hence why their is a British Standard associated with their construction...
or, put another way
And that claim is substantiated by what?
At the end of the day, if you're just after someone to tell you what you want to hear, this isn't the place you're going to get it.
For whatever reason you're obviously wanting the retreads, you're looking for absolutely any excuse you can find to justify them, be it eco friendliness, being a tight git or something else, frankly I doubt any of us really give a **** why but you've had pretty much everyone tell you not to bother.
Take it or leave it, but the advice isn't going to change.
