My SLI Gigabyte GTX 560 ti GPU's reach high temperatures. I've looked around and read they are ok but I'm curious what other people think
temperatures:
Idle:
GPU 1: 34C
GPU 2: 32C
Usage: 0-5%
FurMark (run for 3 minutes)
GPU 1: 92C
GPU 2: 82C
Usage: 99%
Crysis 2 DX11 Ultra (running for 1hr+)
GPU 1: 95C
GPU 2: 85C
Usage: 50-99%
When idle again, the cards will drop back to 35C in about 3 minutes.
Data taken from MSI afterburner.
I am running the GPU's @ 1100 mV (the voltage MUST be increased for stabilty in DX11 games like Crysis 2 and was required for BF3 Beta also)
I have the core clocks underclocked to 867MHz (default is 900MHz)
The memory clock is underclocked to 1936MHz (default is 2000MHz)
Fan speed is on automatic, driver version is 285.38 - these are the BF3 Beta drivers
I use the coolermaster CM 690 II Advanced case with 3 cooling fans.
My questions
1) Are these healthy temperatures?
2) Is it normal for GPU 1 to operate around 10C higher under load?
3) Should I consider placing a case cooling fan above where the GPU's are located to suck the warm air out of my case?
I believe my temperatures were around 20C lower when I was only running the one 560ti so I have a theory that the SLI configuration is left stewing in it's own heat/obstructing good air flow! I also have a Asus Xonar sound card underneath the second GPU, again cluttering things up a little. Seems like a cooling fan to suck air out of this area would help, but I am no expert on air flow and such.
Thank you for any advice
temperatures:
Idle:
GPU 1: 34C
GPU 2: 32C
Usage: 0-5%
GPU 1: 92C
GPU 2: 82C
Usage: 99%
GPU 1: 95C
GPU 2: 85C
Usage: 50-99%
My questions
