The best gadget ever, ever...EVA!!!!
Not at all. It really is fantastic - a lot less hassle than the pan and water method. Been experimenting with it all day and it really is perfectomundo!
Put your toast in the toaster, put some boiled water in a pan (you will already have the boiled water for your morning beverage) crack the egg in and wait 3-4 mins, how could this device be any easier than that? :o
They should call this the "Tefal retard poacher" :D
What the...how does that thing work!!
Very simple.....there's a tiny mini non-stick frying pan thing to hold one egg and its suspended above a heating element which heats a small amount of water which sort of steams the egg.
The plastic see-thru top holds the steam to make sure the egg is cooked all over, but lets out a small amount through a hole at the top. If you want your egg more cooked, you put in more water. Less cooked, use less water.
It sounds complicated, but its actually very, very simple to use.
Mornings are no longer a hassle anymore (I also have a George Foreman grill for my bacon! :D )
Thanks for the info on that..sounds like a neat gadget. Hmmm......! Oh yea I got a G-fore they are just awesome and bacon comes out lush on it. And really REALLY sublime toasted cheese n ham sandwiches!!
Jesus Christ, how come you're so negative, cynical and sour?
Oh your from Hull......
The thing works brilliantly. Period.
Try this out its yummy and its what i do with poached eggs:
After you break the egg into the bowl chop up a tomato into *tiny* pieces and chuck em in. If you got a boiled potato to hand slice some bits of that in as well. Sprinkle some coriander on. Dice a *little* green chilli on it (caution: dont get too happy with this ..ur doing it just to add a LITTLE kick) Salt & pepper to taste.
And poach the thing. Yum :)
That sounds tasty. I think I'd have some chopped up bacon in there as well even if it is fast turning into an omlette!
works with eggs too*
*disclaimer: may not have tried this before
That looks utter crap. I could make it manually in half the time, and at least the egg will look like a poached egg in the end. Its hardly effort to use one pan and a slotted spoon is it?
Does it toast normal sized slices fully?
Nothing worse than having to turn a slice of bread halfway through toasting to avoid a soft gooey non-toasted upper section. It really upsets me.
Pretty handy if your in a rush for work in the morning. Whack it on and go get dressed etc, nice little egg sandwich waiting for you on your way out. For £30 I'm buying one!
