- 19 Aug 2004
- Stockton-on-tees
Had a few advisorys on the astra this mot 2 are straight forward things,
Nearside Front Tie bar/rod has slight play in a ball joint / Offside Front Tie bar/rod has slight play in a ball joint.
how much would you think for a garage to do them or are they easy enough to do yourself? im quite happy doing normal service stuff like oils and filters and have done the od brake pad change. the other one that came up was Parking brake lever has little reserve travel. now the handbreak holds the car fine and has about 6 clicks or so of travel and then its hard to pull it anymore but im not sure what it means ive looked at the drums and there fine with loads left on them, does it just need adjusting?
