** EPIC HALLOWEEN DEAL - MSI 6970 LIGHTNING ONLY £289.99 INC. VAT! (PRE-ORDER ONLY DEAL) **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Too celebrate Halloween we have a truly epic money saving deal on the MSI 6970 Lightning graphics card. Reduced in price by £70 whilst on Pre-Order grab yourself this truly amazing card which won't even break a sweat whilst playing Battlefield 3:-
MSI ATI Radeon HD 6970 Lightning 2048MB GDDR5 PCI-Express Graphics Card **PRE-ORDER ONLY PRICE** @ £289.99 inc VAT
These cards are specifically designed to handle the extreme overclocking which eager gamers and media outlets around the world have been waiting for. Industry-leading Power4 architecture and Twin Frozr III dual-fan cooling with innovative Propeller Blade technology brings together a solid power supply with advanced cooling technology. This results in huge boosts to overclocking potential and stability, enabling the air-cooled 6970 Lightning to break the 1GHz core clock barrier with ease. The Lightning series of graphic cards is designed to offer the ultimate in overclocking capabilities and is the superior choice for overclocking enthusiasts seeking to set new world records!
Inheriting the impressive Power4 architecture from previous Lightning cards along with improved components and design in four areas. The PWM module is twice as large as before and provides double the amount of current to the GPU. Memory has its own independent power supply using an 8-pin connector for minimum interference to greatly increase overclocking potential. The next-generation Proadlizer capacitor increases signal stability by leaps and bounds while CopperMOS, the industry's best MOSFET, provides the GPU with a large and stable power supply. Combined, these features provide ordinary users as well as extreme overclocking enthusiasts with a more stable operating environment and the best performance out there.
The all new Twin Frozr III cooling design utilizes the innovative Propeller Blade technology to double the amount of airflow compared to conventional fans. The airflow also covers a large surface to remove heat quickly and effectively, and when you add in twin 9cm PWM fans, SuperPipe technology, and the Form-in-one heatsink, the result is GPU operating temperatures 26°C lower than the reference board when the 6970 Lightning are operating under full loads. Fan noise is also 11dB lower in addition to having much higher overclocking potential.
The MSI 6970 Lightning graphic cards come with the latest version of MSI's exclusive Afterburner V2.1.0 overclocking utility. The utility not only adjusts GPU and memory clock but also manage the GPU/Memory/PLL(VDDCI) voltages to maximize overclocking potential. Thanks to Triple Overvoltage, the overclocking potential of 6970 Lightning is much higher than the reference board and offers enthusiasts ultimate performance.
For hardware enthusiasts, the MSI 6970 Lightning graphic cards come with exclusive extreme overclocking features. Apart from V-Check Points and V-Switch for monitoring and adjusting the GPU/Memory/PLL(VDDCI) voltages in real time, Dual Bios switches help to effectively prevent potential problems stemming from liquid nitrogen cooling. PWM Clock Tuner also helps to increase overclocking potential. All of these come together to make the 6970 Lightning the ultimate graphic cards for extreme overclocking<br>
The MSI 6970 Lightning graphic cards use top-quality Military Class II components including All Solid Cap for overclocking and full-speed operation, SFC for 10% higher efficiency, and 30% increase in maximum current, as well as Hi-c Cap with Tantalum core which boasts 8 times the lifetime of conventional solid capacitors. These high-quality components not only increase the graphic cards' overall service life but also enhance GPU stability.
Specification:-
- Stream Processors - 1536 Units
- Core Clock - 880 MHz
- Memory Clock - 5500 MHz
- Memory Size - 2048MB GDDR5
- Memory Bus - 256 bits
- Output - Mini DisplayPort*2 / HDMI / DVI*2
- TDP - 269 W
- Card Dimension - 310x127x40mm
- Form Factor - ATX
- DirectX 11
- OpenGL 4.0
- CrossFireX
- Eyefinity
- AVIVO HD
- PowerPlay
- HDCP
- World’s first 18 phase PWM on HD 6970.
- Independent Memory Power support.
- Copper MOS with 2x high current capacity.
- Proadlizer*4 to optimized power supply.
- Twin Frozr III Thermal Design with 26C cooler & 11dB quieter.
- Propeller Blade technology for 20% more airflow.
- Dual 9cm fans with dual 8mm SuperPipes for best heat dissipation.
- Form-in-one heatsink covers memory and modules to dissipate heat efficiency.
- Support voltage adjustment of GPU/Memory/VDDCI
- Military Class II Components for longer product lifespan.
- LPL (Lightning Power Layer) for the stable power supply.
- Usage of the Micro/DIP switches on rear of card voids warranty - For extreme/expert overclockers ONLY!
- Now with Three Year Warranty
Was [£359.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
Seriously thinking of picking one of these up whilst it's on offer. Not too sure if my power supply will handle it? Got an Enermax Infiniti 650w which runs my 5870 no trouble at all but I'm not sure what connections I'll need etc. Can anyone help please? Cheers
You psu should be fine running one of these, do you know what connections you have?
As you might need to to get a 6 pin to 8 pin PCI-e connector.
Just read that these aren't the 940MHz clock as shown on the MSI website but at 880MHz instead. In two minds now atm whether to get one of these or the 6950 Twin FrozR III :/
