Another question while I am at it, What is the best make PSU because this has really put me off OCZ now. Don't really want to spend more than 180 though.
Cant go wrong with the Corsair PSUs
I have put in an RMA, well two actually because I had put one in for the PSU just before seeing the thing about the RAM.
I am hoping they can combine them into one.![]()
Yeah I was looking at this one:Cant go wrong with the Corsair PSUs
Have you told them you want to return the RAM under the Distance Selling Regulations (DSR)?
They won't accept it back as a normal RMA because it isn't faulty so you you need to quote the DSR which entitles you to return it for a full refund no questions asked.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-050-CS&groupid=701&catid=123&subcat=1084
Not much more.
Are you wanting a PSU for SLI or future upgrades because that's major overkill for what you're running now.
You could run what you have now with a PSU half the price.
In fact the 600W PSU you're using now could well be enough depending on the particular model.
850 w is enough for GTX 570 SLI, even 580 SLI if you don't run Furmark.
Not that having some overhead is good, that is a lot.
Planning on Tri SLI?![]()
Hehe, indeed.
Having just checked
http://www.guru3d.com/article/geforce-gtx-580-sli-review/14
850 W is enough for 580 SLI with a good i7-2600K overclock. ^^
So ironically, the fact your PSU went boom turned out to be for the best, saved you money and headaches in the long run![]()
Did you post it after getting the rma?
I posted my 3.4kg psu for less than a tenner with recorded!
How heavy was the package?
unless I'm mistaken(which I more than likely am), ocuk should refund the return cost for the psu if it is faulty(which it should be if it went bang and smoke/smell etc). the ram on the other hand think I've read under dsr ocuk don't have to refund the return cost.
