ok, I'll take your word of the graph is inaccurate, but the issue with AA application is something I noticed from reading various reviewers prior to even the BF3 results. You might want to believe it is driver issue, but I don't think that is the case. Just bare with me.Not trying to prove anything, just saying like many others that the chart is total rubbish. Search the bf 3 threads and you will see it again and again. The AA is not really a 6950 weakness, I think it is a driver weakness. Until AMD release new drivers we won't know if it really is a weakness on the card itself.
Also I think you think I was taking a dig at you for posting it, not the case. I am saying that chart even with AA on is rubbish. None of the figures are correct according to people on this site with those exact same cards. But anyway my post was not a dig at you at all. Just the chart.
As I said if you actually read my post at #16 for the BFBC2 performance comparison, you will see that 6970 2GB take a much deeper dive in frame rate than the GTX570. If you don't want to believe bit-tech's result, here's one from techpowerup:
http://www.techpowerup.com/reviews/AMD/HD_6950_1_GB/6.html
6970 2GB's performance is actually on par with, if not faster than GTX570 in BFBC2 when it is on 0xAA...but when 4xAA is applied, its frame rate become lower than that of the GTX570, so the conclusion I drew is that 6970 2GB don't handle 4xAA as well as GTX570.
Don't get me wrong...I think it is actually something to do with Nvidia's Fermi's GF100/GF110 architecture (GTX470/GTX480/GTX570/GTX580) being able to hold up frame rate better with the application of 4xAA; cards like GTX560Ti, GTX460 that are base only on the GF104/GF114 also seem to not hold up frame rate as good as the GF100/GF110, just like the AMD 6950/6970 cards. For example, there's going to be a new GTX560Ti going to be out soon, which will have 64 more cores than the current GTX560Ti (384 vs 448 cores). I predict performance wise, it would probably be close to, or on par with the GTX570 at 0xAA...but with 4xAA applied, it would most likely be lower than the GTX570, due to it still being on the GF114 architecture.
