Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
In bfbc2 I used fov setting 59 to get 90 fov is this the same for bf3 ?
I did set as 90 in the setting but I think that it's putting me at a disadvantage at mid-long range trying to shoot my targets lol.
So for 1080p should I leave the fov settings at 60?
Thanks.
I am confused, what makes you think your FOV is giving you a dis-advantage at long range? Do you play with a low res?
'Generally'...I have never had that problem really...maybe I don't see them at all ;)
Seriously though, I have never noticed any 'real' difference, I play at a higher res then you also. I guess it comes down to what you are used to and maybe how good your eyesight is ;)
It depends on player/resolutions and aspect ratios.
When I played on my old monitor at 1920x1080 I had a higher FoV - I turned it down when I switched to this to compensate to what I'm used to.
Game still has chronic rubberband issues despite a number of small server-patches (I am led to believe it's up to R7 now?). It seems the engine is pitifully inept at handling or compensating for any ping over 75m/s, which is a pretty poor level of performance. No wonder 64-player servers often become unplayable.
Becomes easier once you unlock the IR Flares - but that's a chore also. :(
The flares also become quickly redundant - there are simply too many ground units (infantry and mobile AA) that can lock you and annoy you. Flares reload pretty fast but still not fast enough for the utter clusterf*ck that the claustrophobic maps create. As soon as you get the extinguisher you'll find that's a much better unlock... by then you'll hopefully have learned the way of the "cut throttle 180 turn" evasive technique, too :p
Meh, I'm not fond of the jets. Helicopters is where I'm at. Then again, the speed the helicopters move is ridiculously slow. :mad:
Status
