Remote Shutdown of HTPC
23 Jan 2007
Glasgow
guys
as title, does anyone have any advice or links to some freeware that can help me do this, i have tried some of the guides online, but keep running into admin access problems.
tia
the two PC's are over LAN, the idea is to switch off our HTPC without having to get off my butt from the other room.
the router is a DG834 GT (Sky)
both PC's running win 7
I normally make sure I can connect to the admin share. Then, bring up CMD and type in 'shutdown -m \\PCNAME -s -t 00'
-m means specify remote PC name
-s means to shut it down
-t 00 is the time countdown (I prefer it to instantly shut down)
failing that, just remote in to the PC
then type in 'shutdown -s -t 00' in command prompt.
make sure you have user accounts on each machine with admin rights. give them the same username/password combo and then you won't have any permissions problems.
Code:
shutdown -i
will give you a GUI or you can run a command line like...
Code:
shutdown -m \\htpc -t 0 -s
m is to specify a remote machine
t is the timeout (0)
s is to shutdown
EDIT: ^get the **** out of my head :eek: :D
Code:
shutdown -i
Code:
s is to shutdown
but its soo nice in here! :p
tried running as admin, still getting the access denied (5), and yeah, there is no logon for either pc
by default Windows wont let you do anything remotely without a password on the PC you want to control/log on to. So, you need to get a keyboard plugged (use yours as you only need to set a password)
running as admin on the local pc won't help if you don't have rights on the remote pc. if it's not configured with a password then you'll need to dust off some keyboard and sort it out.
i can plug in a keyboard no prob to set things up, but generally as its an HTPC there will be no keyboard connected, this is why i have no password setup on it.
what settings do i need to change on the HTPC to give my other pc full access?
have an admin account set up on it with a password. You can use these to connect to it and then run commands on it, like the remote shutdown etc.
You may want to enable remote desktop too, just incase you want to connect to it at any point.
Once these are set up, you dont need the keyboard as you will be able to do it remotely :) (although if you do use remote desktop, it will kick the HTPC back to the login screen, so only do it when you need to shut it down).
Once password has been set up, you need to run control userpasswords2 in the run box and set it to log in without prompting for password.
would i not need a keyboard to type a password at logon everytime?
cheers will go give it a try
