Battlefield 3 thread - Server details in opening post -
Status
Not open for further replies.
Ok, bought BF3 today, but seem to have developed an odd bug... Randomly (multiplayer and singleplayer), the game decides having loaded to automatically point the gun as skyward as possible, and whatever I do I don't seem to be able to sort it out.. The only way around it seems to be completely rebooting battlelog...
Anyone had similar issues?
kd
You don't have a 360 pad turned on do you? Once the stick on my 360 pad was slightly to the right, not sure how it was slightly to the right but it kept making me move.
kd
Yes but at my feet, turned out i had the tv remote resting against my xbox controller and it was pushing the stick down, you got one plugged in?
kd
I get that if I leave my G27 wheel plugged in.
Hmm, no Controller, but thinking about it I do have my DFGT plugged in, maybe me resting my feet on the pedals are resulting in stupid things, shall go test it out, and may come find an OcUK server xD
kd
Bugger, i've had 2 crash to desktops now. 1 in the campaign and the other in multiplayer.
Basically the screen goes black and then the desktop appears, with out the mouse. I have to bring up the task manager to kill BF3 :(
and now this little gem is appearing every few minutes.....this really needs to get sorted
Just had a couple of top games on the OcUK server playing Caspian....think I finally have the hang of jets and dogfighting now, though some buggers are hard to shake!
Still, 1800 points in jets in 2 matches...not bad! :p
Played a few games on the ocuk server earlier, going back on now infact. The game is so much more enjoyable when you have a decent squad/team. :)
With my logitech dual action controller, sometimes I end up pressing downward onto the right analogue stick while maneuvering and option menu comes up. It is so annoying as I have to press Esc key to get rid of it.
I tried looking for such command in the key bindings but there doesn't seem to be. :(
Any idea??
Edit: Do you get similar thing with xbox 360 pad if you push down on right analogue stick?
Evening Guys.
I've recently set up a server for myself & friends which is as follows;
- 32 Slot
- Conquest (Mainly Large)
- UK Hosted (Killercreation)
- Normal
I'd really appreciate if some OcUK guys could join up and favorite the server so we could get a few games going and get the server a little busier. I'd enjoy playing with some of you guys.
I also have reserved slots and admin positions to give away for those that help us out.
FA-Fatal-Ascension-24-7-CQL-UK-Hosted
Cheers.
Is anyone else suffering from their PC simply rebooting during the SP Campaign?. I can play about 5 mins or so and then suddenly my PC just reboots. No BSOD, nothing. Event viewer shows a Kernel 41 error but both my CPU and GPU temps are fine, Memtest runs with no issues and my PSU is more than up to scratch. It's getting really, really annoying. :(
Status
