Pz67 and pz68
Permabanned
6 Sep 2011
I've been an idiot and ordered a Asrock z67 instead of the z68 for my intel i5. It wasn't from this site .. Was from amoz .... But it says too late to cancel order... What's the difference between these boards.... :(
do you mean P67? If so you havn't made a mistake atall. Its still 1155 socket, i5 2500 compatible. The Z68 is just a newer chipset.
if u meant p67 instead of z68
mainly the onboard graphics usability lucid virtu thing and the ssd caching
Yes sorry dnt know why I typed the p...cnt change it now lol. I know there both compatible but does it have a huge difference? Extra features??
Z68 has SSD caching and the ability to use integrated graphics. Other than that they are IIRC the same.
Were you intending on doing the SSD caching then?
An SSD is a hugely useful item anyway. I wouldn't worry yourself too much. Will still have an amazing Build.
I would have if I got better performance from my ssd... The main gripe is I bought it for pcie 3 and you need ivy bridge to use that feature... I've read p67 boards may not support ivybridge????
I'm sure if you called up and explained the mistake, they wont cry havoc and refuse.
It's customer service after all ;)
