[TW]Fox;20468968 said:A shame you consider the Focus 'truely mundane' because it's a more fun car to chuck around than anything in your OP.
The door bulb being dead is actually more likely to be a faulty door module... can cause issues with locks, interior lights not operating when that door is open, alarm issues...
Decent cars though, I miss my Golf (much the same as a Leon) a bit as it had more toys, it did me well really but they can be niggly cars, pot luck![]()
- Mirror adjuster playing up *edit* it's actually not. Turns out that in one position both mirrors move, and you adjust the NS mirror separately in the other position
Head unit is being a pain (more like I tried inputting the radio code without reading how to do it properly in the manual, thus putting it into 'safe' mode)
Mine moves each mirror independently, that doesn't sound right to me?
Stock ones are utter garbage anyway, and adapter fascias are cheap. Just stick a decent single DIN HU in it![]()
Astra G/Mk4 1.8 16v SRi is 'warm' (8.5s 0-60) handles well enough and book figure gets you 37mpg, which I used to easily achieve on a long run.
You can consider the 2.2 although due to gearing and the additional weight of the engine, there is very little to gain from the extra BHP.
As someone has mentioned, Civic 1.8 VTI, you'll get a good one and around £500 change
If you go for one, you absolutely want the lowest mileage and newest one possible as these do not age well unless they are meticulously looked after
Congratulations on reading the thread. No, seriously, well done.
I obviously did read it
I read about the door latch mech. Not bothered if that's what it is. It might just stay as it is if it is the latch (although I'll obviously check the bulb).
Head unit is being a PITA and is stuck in safe mode. Need to have a read up on what to do to cure it.
I lied, sue me I didnt read the second page
Danza I nearly did, five door pre facelift T-Sport. Would have been my choice over the Leon if I'm honest![]()
