Take a look at our two great new gaming bundles both featuring Gigabyte quality gaming motherboards and the new Phanteks PH-TC14PE CPU Cooler - Orange on the Krypton X58 OVERDRIVE bundle.
Krypton X58 OVERDRIVE Intel Core i7 960 3.20GHz @ 4.20GHz DDR3 Overclocked Bundle @ £529.98 inc VAT
Designed by experts the "Krypton Intel Core i7 960 Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.00GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
Why You Should Buy This Bundle?
- A solid, optimised 4.20GHz overclock profile provides outstanding processing performance
- Prebuilt, overclocked and configured. Just "plug and play"
- 8 Hours stressed tested and quality controlled
- 6GB of Triple Channel DDR3 memory delivers unlimited bandwidth
- X58 Chipset provides SLI and Crossfire ready support for any GPU configuration
- USB 3.0 & SATA 6GB/s compatible offering lightning fast transfer speeds
Bundle Specification
- CPU: Intel Core i7 960 3.20GHz @ 4.20GHz
- Motherboard: Gigabyte X58A-OC (Socket 1366) DDR3 Motherboard
- RAM: Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Phanteks PH-TC14PE CPU Cooler - Orange
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Note - Please note that adding in additional memory to the spare slots will require new BIOS settings and the maximum clock speed attainable may be significantly reduced. OcUK recommend a quality brand PSU for use with all our bundles such as the Corsair TX & HX range. Updating the BIOS on the overclocked bundle range will void the warranty on the overclock. If you update the BIOS we will no longer be able to provide support for configuring and maintaining the CPU overclock.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £529.98 inc VAT.
ORDER NOW
Krypton Z68 TURBO Intel Core i5/i7 @ 4.60GHz DDR3 Overclocked Bundle @ £411.98 inc VAT
Designed by experts the "Krypton Z68 TURBO Bundle" is a pre-configured high performance "plug and play" bundle featuring hand-picked components and highly optimised settings. The Guaranteed 4.60GHz overclock has the processing muscle to power through the most intensive applications, including the latest games and video editing programs at a price point that will lift your system performance to a new level.
- A solid, optimised 4.60GHz overclock profile provides outstanding processing performance
- 4GB (8GB option available) of Dual Channel DDR3 memory delivers unlimited bandwidth
- Z68 Chipset provides SLI and Crossfire ready support for any GPU configuration
- CPU: Intel Core i5 2500K or i7 2600K overclocked @ 4.60GHz
- Motherboard: Gigabyte Z68X-UD5 (Socket 1155) DDR3 Motherboard
- RAM: Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel
- Cooler: Corsair A50 CPU Cooler
Service Package
Only £411.98 inc VAT.
ORDER NOW
Service Package
ORDER NOW
Service Package
ORDER NOW
. I DEMAND THAT BUNDLE FOR £200!11!!1 False advertising and all that
