Unseen 9/11 footage shows WTC Building 7 consumed by fire
And, while we are on the subject why are there no marks where the jet engines would have hit the pentagon. If you see deep big the hole was in the pentagon from above and you look at one big hole where the plane supposed hit it on the side it just does not make any sense. Where were the marks left by the wings, engine and tail fin? Also, why is there no video of the crash and almost no debris?
This is what happens when something made of light metal hits a solid wall (in the Pentagon's case, limestone reinforced with steel) at high speed. Were people expecting a plane shaped hole in the Pentagon like in cartoons?
Madrid had functional fire suppression and fire fighters hence why the tower was saved.
I think you will find that the Madrid tower only had Passive fire protection. No sprinklers.
It was due for a upgrade to a sprinkler system but the fire got there first :)
"Blah blah blah, anyone who's not a CT is a fool"-type nonsense
Cman, have you ever read John Twelve Hawks "The Traveller" trilogy? I bet you'll love it. It's all about how a powerful cabal of bad people are trapping us all in a virtual prison, even themselves. It'll be your favourite book series EVER! :rolleyes:
The one thing I don't understand about the CT opinions, is that why would the government bother to wire up towers, have so many potential whistleblowers in on the operation, when all they had to do was sit back and let a terror cell go through with their plans?
Makes a lot more sense to me.
Personally I'm off split minds about the whole thing, but overall I'm still saddened it happened. Irrevocably changed the world, and it's certainly not for the better.
saved? The steel half totally collapsed. It was just made in two halls. Concrete reinforced and steel with load bearing outer wall. The steel half Totaly collapsed.
It was only a partial collapse though, its not like all the unprotected steelwork collapsed, the tower could actually have been repaired like the empire state building was after the bomber except Madrid was ruled uneconomical to repair and demolished.
It kinda proves the point about the WTC and the asbestos though doesn't it, the unprotected steel part collapsed whereas the protected steel part did not.
They put everyone who knew about it on the planes and in the towers.
How did the Jet-Fuel which allegedly caused the Super-Hot burning fire which weakened the steel and made the Towers collapse get into WTC7 to do the same thing?
IIRC Steel Framed building do not collapse on themselves due to 'fire' the Twin Towers collapsed due to the Jet-Fuel mixture, there was no Jet-Fuel in WTC7.
WTC7 was damaged by burning debris and caught fire. The combination of flames and structural damage resulted in collapse.
It's always puzzled me how the Twin Towers collapsed the way they did, collapsing above and around where the Planes hit I could understand
Which is what they did.
but why the rest would collapse the way it did just does not make any sense to me
It should, because that's how they were designed to collapse.
the explanations given never ring true either, only 'Controlled Demolition' makes any sense to me regarding the actual collapses.
Why? A controlled demolition starts at the bottom, not near the top. If it was a controlled demolition, we should have seen explosions at ground level and the lower floors pulling down the higher floors as they collapsed. Instead we saw the exact reverse: higher floors collapsing onto lower floors and pushing them down.
Where did you get that from? The crane at the top of the tower was still intact(so says wiki)after the fire
http://en.wikipedia.org/wiki/File:TorreWindsor1.JPG
The crane is a structural member? It is also standing on the reinforced structural core.
The entire structural floors collapse above the 2nd technical floor., all of it.
But then again it is you. Did you have enough several years ago.
It collapsed
http://www.mace.manchester.ac.uk/pr...Study/HistoricFires/BuildingFires/default.htm
It wasn't just fire protection it was also reinforced concrete with reinforced concrete floors - what are described as technical floors.
Read the link I gave you earlier
And not it was beyond repair it had to be demolished, it couldn't be rebuilt.
Nevermind... enjoy your circular arguments...
Thanks I will
dim :rolleyes:
What new facts do you think there are your entire first edited posted is pointless.
And again you keep ignoring fence sitters, or people randomly reading this thread. What do you think they would decide if points went unanswered, maybe that the CT had a point.
Thanks I will
dim :rolleyes:
Nah mate, I just don't see the point of fleshing it out. And thanks for getting insulting, I have thus far avoided making personal attacks. Regarding fence sitters, I'm curious to what end convincing them either way is supposed to have?
Educate them, stop the ever growing CT foothold, which has happened time and time again. When CTs are not challenged. Just have a look at the stats for the moon landings in America of the general populations skeptism.
After the partial collapse the building could have been repaired however it would have been completely financially uneconomical so it was demolished. But the building your talking about though isn't a steel framed skyscraper, its steel reinforced concrete, the damage caused to the steel parts cannot be compared to the WTC (although it frequently is) because the steel sections surrounding the concrete core of the Windsor which collapsed were by design much much much weaker than the steel frame of a steel framed skyscraper.
The reason the twin towers collapsed due to fire (after surviving the impacts of jet airliners) is because the fire was above the asbestos fire protection, the reason WTC 7 collapsed is because its fire suppression had been destroyed by the collapse of the twin towers. No conspiracy was involved it was just a tragic series of events that began during the WTC construction (when the decision was made to continue without a replacement for the asbestos fire protection).
NB:
Excepting the three 9-11 collapses, no fire, however severe, has ever caused a steel-framed high-rise building to collapse. Following are examples of high-rise fires that were far more severe than those in WTC 1 and 2, and Building 7. In these precedents, the fires consumed multiple floors, produced extensive window breakage, exhibited large areas of emergent flames, and went on for several hours. The fires in the WTC towers did none of these things.
The One Meridian Plaza Fire
The First Interstate Bank fire
The Caracas Tower Fire
The Beijing Mandarin Oriental Hotel Fire
The towers were designed to be hit by a fully fuelled 707 doing 600mph and survive, sadly they were not built to the design. No conspiracy, just a tragic series of events beginning in the 70's when the EPA put health and safety before common sense.
Actually it isn't huge amount difference.
Yes it had a reinforced concrete centre. But the metal floors also had metal load bearing outer wall.
How could it be rebuilt?
The whole building was beyond repair and had to be demolished. The estimated property loss was €72m before the renovation.
It want just money, it would have had to been pulled down and rebuilt. You couldn't just rebuild the collapsed section. The damage was far more extensive than just that.
Nice copy and paste from the CT site. Now have you looked into the construction And other differences,i expect not, so here's a starting point from a debunking site.
http://ae911truth.info/wordpress/topten/mandarin-oriental/
The 2009 fire at the Beijing Mandarin Oriental hotel, part of the TVCC complex there, is a recent darling of the controlled demolition advocates. The night shots of this 34-story building on fire are quite impressive. And to see the Mandarin Oriental structure still standing after that nightmarish fire does cause one to question the collapse of the World Trade Center buildings, especially the 47-floor Building 7.
However, there are some notable differences between the two events. First, the design and construction of the Mandarin Oriental building only began after its builder, ARUP East Asia, had conducted a thorough internal study of the WTC collapses(pdf).
Arup’s response to the World Trade Center disaster was swift, establishing an Extreme Events Mitigation Task Force charged with evaluating the risks of disasters similar to those that have taken place in recent years, analysing the technical challenges they represent and developing design solutions to address them. With typical zeal, and chaired by the late Tony Fitzpatrick, then chairmanof Arup’s Americas region, the task force mobilised the might of the firm’s in-house research and development capabilities and specialist teams on tall buildings, fire, materials, structural analysis and other disciplines to see what lessons could be learnt from the World Trade Centre disaster.
For example, instead of the steel-only structural framework of Building 7, ARUP used a combination of concrete and steel framing for the TVCC building.
Another major differences are the response to the fires. Those incredible shots of the Mandarin Oriental on fire were taken during the first hour of the fire. The firefighters were able to gain control of the blaze in about an hour, fully extinguishing the fire six hours after it began. By contrast, the fires in Building 7 were never fought, because what access the FDNY had to water could not reach the building.
This opportunistic treatment of a building fire is simply what AE911Truth does. It has a list of four other buildings to guide understanding, but an deeper look into them all show how the comparisons don’t add up. The Mandarin Oriental fire is only the latest example. That the builder of the hotel building did a comprehensive study of the 9/11 collapses before designing the TVCC building is what truly makes this one of AE911Truth’s top 10 mistakes.
Some pretty important differences, wouldn't you say.
By de-constructing it until the unrepairable parts were gone, then reconstructing/repairing it.
That quote just backs up what I said though, other steel framed skyscrapers have survived worse fires than the towers, because they had better fire protection and the fires were fought better.
The structure was to badly damaged removing the damaged parts would have resulted in a mound of rubble.
You seem to be missing the point. It's not just fire protection, all though plays a massive part. It is the design and more importantly the use of concrete. It isn't as simple as fire protection.
All though I get the feeling we're arguing roughly the same thing.
Only very slightly off topic but is there an explanation of this photo showing what appears to be supporting columns that have been cut in some way?
I've seen it used on many sites claiming that 911 was an inside job and on the surface it does seem to provide strong evidence that at least one of the buildings didn't collapse by plane impacts and fire alone. The photo clearly seems to show a large beam at ground zero that has been cut causing molten metal to form on both the inside and outside of the beam, possible explanations I can think of include...
1. This is a fake photo
2. The photo is real but the beam was cut only as part of the clean up operation after 911
3. The photo is real but natural forces during the collapse somehow cleanly sheered the beam and produced temperatures hot enough to melt the steel
4. The photo is real but was not taken at ground zero i.e. completely unrelated to 911
5. The photo is real and shows clear evidence that something else occurred that aided the buildings collapse
