- 20 Jun 2004
- Essex
Is this fine to do?
You probably need to check the fuse in the plug 1st to see if there isnt a 3amp fuse in it before you plug it into a 'kettle'
Otherwise a 3 amp fuse will be OK for up to 750 watt draw, A kettle lead is bog standard anyway (though you may get a 2 pin one like I have for my USA subwoofer)
