Asrock Z68 Extreme 4 and 7 UEFI
I updated to bios 1.10 and the inverted mouse issue seems to have appeared with it, any fix yet? it's by no means a game breaker but it is annoying when 1.00 worked fine.
If it isn't broken why fix it?:D
Updated bios to 1.10 yesterday works flawlessly.
Using Logitech Deluxe 250 Keyboard & LS1 Laser Mouse, both usb, works perfectly.
Built my third Extreme 4 Gen 3 today & found out it will not work with a PS2 mouse, have four different ones in my spares box & NOT one will work with the board, board won't even boot.
But, but trying several usb mice, Logitech,Deathadder, etc, the board perfoms flawlessly, loads windows in seconds.
Mine works fine with bios 1.0 using the keyboard (PS2) and mouse (USB) below once I'm in. The problem I have is that sometimes I can hammer away on F2 or Delete and it just wont enter the bios at all
how do you flash guys?
I assume you're talking about the BIOS ;)
I also assume you're talking about the ASRock motherboard and not the one in your sig.
Download the latest BIOS file from ASRock.
Copy the file to a USB memory stick.
Restart the PC with the memory stick inserted and go into the BIOS.
Go to the Advanced screen in the BIOS and use the Instant Flash utility.
Extreme 7 Gen 3
i5 2500K
Saitek cyborg V7 keyboard
saiteck R.A.T.5 mouse
No issues whilst running original bios nor in the latest bios, been fault free since i got it.
