Yes, a full format in Win7 or Vista will zero-fill the drive, which will put all the data beyond any hope of recovery. There's no real need for the /P switch, a single pass is enough.I've heard of a couple of programs that zero (nuke!) your drive but some users complained those programs rendered their drives unusable.
Would format x: /fs:NTFS /p:2 suffice when selling on your drives?
That was true for Windows XP and before - a full format would just check the drive for bad blocks without actually overwriting anything, so you'd need a third-party utility to make the data unrecoverable. However, Vista and 7 do perform a zero fill during a full format.I was under the impression that the reason it takes so long to do a regular format and not a 'quick' format is because it error checks the entire drive, and doesn't actually wipe anything.
I'm sure it's effective at what it does, but don't forget it will only overwrite the *free space* on a drive, leaving existing files intact.No idea how effective it is but I like to run "cipher /w"
