As title. I have a heatshield around my cat converter on my 2004 EP3 Type R.
It seems to have split around the bolt mounts where it wraps around the cat (if that makes sense). The metal has split around one of the bolt holes, it's only thin metal... dont think it'll weld back together with ease.
Alas I have an annoying resonating rattle at 3500/4000rpm and if I'm slowing down or sitting at those revs it resonates/rattles loads.
Can I just cut the thing off? I'm sort of reluctant to as really it's gonna have been put on there for a reason... but I don't think it's repairable.
Thanks
Thanks
